  3. Plotting graphs with plot.ly service with luup scene using REST API
plot.lygraphluupplot
56 Posts 10 Posters 34.6k Views 2 Watching
  • korttomaK
    korttomaK
    korttoma
    @samppa this is sweet :+1: . Thank you so much for sharing this!
    • Tomas
    • NuubiN
      NuubiN
      Nuubi
      Uh...oh...still.. do you need to initialize the graph or what? Still not getting this to work, sorry for being such a dummie :-E
      S 1 Reply Last reply
      • korttomaK
        korttomaK
        korttoma
        You should use username and not <username>. The same goes for the API key.
        In UI5 you can test your Lua in Vera from APPS -> Develop Apps -> Test Luup code
        Here is a few more examples of variable_get:
        local InAirHum = luup.variable_get("urn:micasaverde-com:serviceId:HumiditySensor1", "CurrentLevel", 347)
        local OutTemp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 229)
        local InAirTemp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 346)
        local InAirQ = luup.variable_get("urn:upnp-org:serviceId:VContainer1", "Variable1", 348)
        • Tomas
        • korttomaK
          korttomaK
          korttoma
          I'm having trouble with one variable to. I would like to have the status of a qubino switch in the same graph.
          I tried this:
          local VentOn = 100 luup.variable_get("urn:upnp-org:serviceId:BinaryLight1", "Status", 356)
          It gives me the value 100 in the graph. Please let me know what this 100 in front of the luup.variable_get does. If I remove it the Luup code fails.
          • Tomas
          • korttomaK korttoma
            I tried this:
            samppa
            wrote on last edited by samppa
            I tried this:
            Actually there should be asterisk character between 100 and the luup.variable_get and the (forum editor does not show that) since the returned value 1 or 0 is scaled to 100 so try:
            local VentOn = 100 * luup.variable_get("urn:upnp-org:serviceId:BinaryLight1", "Status", 356)
            Then you get 100 if binary light is on. Remove the 100 if you like it to be 1 or 0.
            korttomaK 1 Reply Last reply
            • NuubiN Nuubi
              samppa
              You just send the data and the graph named with "filename":"xxxx" gets created if not yet existing.
              NuubiN 1 Reply Last reply
              • S samppa
                I tried this:
                korttomaK
                korttomaK
                korttoma
                I thought it was a multiplier of some kind. Anyhow the code fails allso if I add the asterisk so I thik it has a problem with:
                Any suggestions what I should try instead? Tried also this but no luck:
                luup.variable_get("urn:micasaverde-com:serviceId:BinaryLight1", "Status", 356)
                • Tomas
                • korttomaK
                  korttomaK
                  korttoma
                  Had a chat with @BulldogLowell and he taught me that you can hover the mouse on a variable to check the complete variable name so it turned out I had to use the following:
                  luup.variable_get("urn:micasaverde-com:serviceId:SwitchPower1", "Status", 356)
                  • Tomas
                  • S samppa
                    NuubiN
                    NuubiN
                    Nuubi
                    @samppa Yep, works now, thanks!
                    The problem turned out to be the actual value I wanted to send. Need to figure out how to read MySensors based values in LUA...
                    • NuubiN Nuubi
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      @Nuubi
                      have you tried luup.inet.wget( )
                      local brightness = luup.variable_get("urn:upnp-org:serviceId:Dimming1", "LoadLevelStatus", 118)
                      luup.inet.wget("192.168.1.50//?brightLevel="..brightness.."&", 1)
                      • korttomaK
                        korttomaK
                        korttoma
                        Anyone figured out a way to add another variable to an old graph without deleting the file from plot.ly? Seems like it does not include the new variable unless you delete and create a new file.
                        • Tomas
                          samppa
                          I have noticed the same thing; If you want to add a trace you need to delete the file..
                          So perhaps it is wise to be prepared and add a few extra traces for some future use.
                          • S samppa
                            korttomaK
                            korttomaK
                            korttoma
                            Good suggestion for a workaround but it does not seem to pick up name changes for the trace either. Tried also to edit one of the plots on the website but when I wanted to save I could not save the changes to the file used by "Vera". I had to save the file with a different name so no editing seems to be possible.
                            • Tomas
                            • korttomaK
                              korttomaK
                              korttoma
                              Since the nightly heal at 2 in the morning no data is transferred to plot.ly any more :( anyone else see this and know how to solv it?
                              • Tomas
                              DwaltD 1 Reply Last reply
                                DwaltD
                                DwaltD
                                Dwalt
                                @korttoma
                                My plots stopped last night as well, last data point transmitted was at 12:03am GMT, but not after a nightly heal.
                                -Dwalt
                                • korttomaK
                                  korttomaK
                                  korttoma
                                  12 GMT is 2 in my timezone so I guess it was just a coincidence that it happened at the time of the heel. Maybe plot.ly blocked us for some reason.
                                  • Tomas
                                    samppa
                                    My graphs stopped as well. I have asked what is going on.. Let's see when it gets back up again..
                                    • korttomaK
                                      korttomaK
                                      korttoma
                                      I sent them some feedback to but have not heard anything yet. Maybe we should try the "Streaming API" instead?
                                      • Tomas
                                      DwaltD S 2 Replies Last reply
                                        DwaltD
                                        DwaltD
                                        Dwalt
                                        wrote on last edited by Dwalt
                                        #23
                                        @korttoma
                                        I tried to set up a new graph using the REST API and could not get it to register with Plot.ly. Without any explanation from Plot.ly, I tried sending the same data streams to ThingSpeak.com and it set up with out any trouble. The API is slightly different but just as easy to use. I set up a scene to run every 15 minutes with the following code:
                                        -- Get Light Levels
                                        local LR_LIGHT_LEVEL = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", 47)
                                        local BR_LIGHT_LEVEL = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", 55)
                                        - - Get Temps
                                        local LR_TEMP = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 46)
                                        local BR_TEMP = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 54)
                                        local OUT_TEMP = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 23)
                                        -- Send data to ThingSpeak.com
                                        local http = require("socket.http")
                                        http.TIMEOUT = 5
                                        result, status = http.request("http://api.thingspeak.com/update?key=Insert Your API Key here&field1="..LR_TEMP.."&field2="..BR_TEMP.."&field3="..OUT_TEMP.."&field4="..LR_LIGHT_LEVEL.."&field5="..BR_LIGHT_LEVEL.."", "run=run") ````
                                        The service has a limited functionality to manipulate your data but the base configuration is easy to tweak and can be made public or private.  See [here for my sample data](https://thingspeak.com/channels/25629).
                                        ...plus it is free to use.
                                          samppa
                                          #24
                                          @korttoma
                                          Now plot.ly is back up again.
                                          Apparently they upgraded the infrastructure and broke something. Hopefully that does not happen too often..
