  3. Plotting graphs with plot.ly service with luup scene using REST API
plot.lygraphluupplot
56 Posts 10 Posters 34.6k Views 2 Watching
  • korttomaK
    korttomaK
    korttoma
    I'm having trouble with one variable to. I would like to have the status of a qubino switch in the same graph.
    I tried this:
    local VentOn = 100 luup.variable_get("urn:upnp-org:serviceId:BinaryLight1", "Status", 356)
    It gives me the value 100 in the graph. Please let me know what this 100 in front of the luup.variable_get does. If I remove it the Luup code fails.
    • Tomas
    S 1 Reply Last reply
    • korttomaK korttoma
      I tried this:
      samppa
      wrote on last edited by samppa
      I tried this:
      Actually there should be asterisk character between 100 and the luup.variable_get and the (forum editor does not show that) since the returned value 1 or 0 is scaled to 100 so try:
      local VentOn = 100 * luup.variable_get("urn:upnp-org:serviceId:BinaryLight1", "Status", 356)
      Then you get 100 if binary light is on. Remove the 100 if you like it to be 1 or 0.
      korttomaK 1 Reply Last reply
      • NuubiN Nuubi
        Uh...oh...still.. do you need to initialize the graph or what? Still not getting this to work, sorry for being such a dummie :-E
        samppa
        You just send the data and the graph named with "filename":"xxxx" gets created if not yet existing.
        NuubiN 1 Reply Last reply
        • S samppa
          I tried this:
          korttomaK
          korttomaK
          korttoma
          I thought it was a multiplier of some kind. Anyhow the code fails allso if I add the asterisk so I thik it has a problem with:
          Any suggestions what I should try instead? Tried also this but no luck:
          luup.variable_get("urn:micasaverde-com:serviceId:BinaryLight1", "Status", 356)
          • Tomas
          • korttomaK
            korttomaK
            korttoma
            Had a chat with @BulldogLowell and he taught me that you can hover the mouse on a variable to check the complete variable name so it turned out I had to use the following:
            luup.variable_get("urn:micasaverde-com:serviceId:SwitchPower1", "Status", 356)
            • Tomas
            • S samppa
              NuubiN
              NuubiN
              Nuubi
              @samppa Yep, works now, thanks!
              The problem turned out to be the actual value I wanted to send. Need to figure out how to read MySensors based values in LUA...
              • NuubiN Nuubi
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @Nuubi
                have you tried luup.inet.wget( )
                local brightness = luup.variable_get("urn:upnp-org:serviceId:Dimming1", "LoadLevelStatus", 118)
                luup.inet.wget("192.168.1.50//?brightLevel="..brightness.."&", 1)
                • korttomaK
                  korttomaK
                  korttoma
                  Anyone figured out a way to add another variable to an old graph without deleting the file from plot.ly? Seems like it does not include the new variable unless you delete and create a new file.
                  • Tomas
                    samppa
                    I have noticed the same thing; If you want to add a trace you need to delete the file..
                    So perhaps it is wise to be prepared and add a few extra traces for some future use.
                    • S samppa
                      korttomaK
                      korttomaK
                      korttoma
                      Good suggestion for a workaround but it does not seem to pick up name changes for the trace either. Tried also to edit one of the plots on the website but when I wanted to save I could not save the changes to the file used by "Vera". I had to save the file with a different name so no editing seems to be possible.
                      • Tomas
                      • korttomaK
                        korttomaK
                        korttoma
                        Since the nightly heal at 2 in the morning no data is transferred to plot.ly any more :( anyone else see this and know how to solv it?
                        • Tomas
                        DwaltD 1 Reply Last reply
                          DwaltD
                          DwaltD
                          Dwalt
                          @korttoma
                          My plots stopped last night as well, last data point transmitted was at 12:03am GMT, but not after a nightly heal.
                          -Dwalt
                          • korttomaK
                            korttomaK
                            korttoma
                            12 GMT is 2 in my timezone so I guess it was just a coincidence that it happened at the time of the heel. Maybe plot.ly blocked us for some reason.
                            • Tomas
                              samppa
                              My graphs stopped as well. I have asked what is going on.. Let's see when it gets back up again..
                              • korttomaK
                                korttomaK
                                korttoma
                                I sent them some feedback to but have not heard anything yet. Maybe we should try the "Streaming API" instead?
                                • Tomas
                                DwaltD S 2 Replies Last reply
                                  DwaltD
                                  DwaltD
                                  Dwalt
                                  wrote on last edited by Dwalt
                                  #23
                                  @korttoma
                                  I tried to set up a new graph using the REST API and could not get it to register with Plot.ly. Without any explanation from Plot.ly, I tried sending the same data streams to ThingSpeak.com and it set up with out any trouble. The API is slightly different but just as easy to use. I set up a scene to run every 15 minutes with the following code:
                                  -- Get Light Levels
                                  local LR_LIGHT_LEVEL = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", 47)
                                  local BR_LIGHT_LEVEL = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", 55)
                                  - - Get Temps
                                  local LR_TEMP = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 46)
                                  local BR_TEMP = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 54)
                                  local OUT_TEMP = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 23)
                                  -- Send data to ThingSpeak.com
                                  local http = require("socket.http")
                                  http.TIMEOUT = 5
                                  result, status = http.request("http://api.thingspeak.com/update?key=Insert Your API Key here&field1="..LR_TEMP.."&field2="..BR_TEMP.."&field3="..OUT_TEMP.."&field4="..LR_LIGHT_LEVEL.."&field5="..BR_LIGHT_LEVEL.."", "run=run") ````
                                  The service has a limited functionality to manipulate your data but the base configuration is easy to tweak and can be made public or private.  See [here for my sample data](https://thingspeak.com/channels/25629).
                                  ...plus it is free to use.
                                    samppa
                                    #24
                                    @korttoma
                                    Now plot.ly is back up again.
                                    Apparently they upgraded the infrastructure and broke something. Hopefully that does not happen too often..
                                    • korttomaK
                                      korttomaK
                                      korttoma
                                      Yes, now it is working again. Maybe you should try again @Dwalt ?
                                      • Tomas
                                        DwaltD
                                        DwaltD
                                        Dwalt
                                        @korttoma
                                        I noticed it back online right after I posted my Thingspeak scene. I had not deleted my Plot.ly scenes and they continued to send http requests during the outage and when Plot.ly came back online, my data resumed plotting.
                                        I have both services running right now plotting similar data and I will leave them both running to test reliability and quirks. It seems the time reporting drifts a little in Plot.ly. I am also going to test Beebotte.
                                        • korttomaK
                                          korttomaK
                                          korttoma
                                          There was an outage again last night. No data uploaded for 3h. Was it just me or plot.ly?
                                          • Tomas
