  3. Plotting graphs with plot.ly service with luup scene using REST API
plot.lygraphluupplot
56 Posts 10 Posters 34.5k Views 2 Watching
  • korttomaK
    korttomaK
    korttoma
    Had a chat with @BulldogLowell and he taught me that you can hover the mouse on a variable to check the complete variable name so it turned out I had to use the following:
    luup.variable_get("urn:micasaverde-com:serviceId:SwitchPower1", "Status", 356)
    • Tomas
    • S samppa
      @Nuubi said:
      Uh...oh...still.. do you need to initialize the graph or what? Still not getting this to work, sorry for being such a dummie :-E
      You just send the data and the graph named with "filename":"xxxx" gets created if not yet existing.
      NuubiN
      NuubiN
      Nuubi
      @samppa Yep, works now, thanks!
      The problem turned out to be the actual value I wanted to send. Need to figure out how to read MySensors based values in LUA...
      • NuubiN Nuubi
        BulldogLowellB
        BulldogLowellB
        BulldogLowell
        @Nuubi
        have you tried luup.inet.wget( )
        local brightness = luup.variable_get("urn:upnp-org:serviceId:Dimming1", "LoadLevelStatus", 118)
        luup.inet.wget("192.168.1.50//?brightLevel="..brightness.."&", 1)
        • korttomaK
          korttomaK
          korttoma
          Anyone figured out a way to add another variable to an old graph without deleting the file from plot.ly? Seems like it does not include the new variable unless you delete and create a new file.
          • Tomas
          S 1 Reply Last reply
          • korttomaK korttoma
            samppa
            I have noticed the same thing; If you want to add a trace you need to delete the file..
            So perhaps it is wise to be prepared and add a few extra traces for some future use.
            korttomaK 1 Reply Last reply
            • S samppa
              korttomaK
              korttomaK
              korttoma
              Good suggestion for a workaround but it does not seem to pick up name changes for the trace either. Tried also to edit one of the plots on the website but when I wanted to save I could not save the changes to the file used by "Vera". I had to save the file with a different name so no editing seems to be possible.
              • Tomas
              • korttomaK
                korttomaK
                korttoma
                Since the nightly heal at 2 in the morning no data is transferred to plot.ly any more :( anyone else see this and know how to solv it?
                • Tomas
                DwaltD 1 Reply Last reply
                  DwaltD
                  DwaltD
                  Dwalt
                  @korttoma
                  My plots stopped last night as well, last data point transmitted was at 12:03am GMT, but not after a nightly heal.
                  -Dwalt
                  • korttomaK
                    korttomaK
                    korttoma
                    12 GMT is 2 in my timezone so I guess it was just a coincidence that it happened at the time of the heel. Maybe plot.ly blocked us for some reason.
                    • Tomas
                      samppa
                      My graphs stopped as well. I have asked what is going on.. Let's see when it gets back up again..
                      • korttomaK
                        korttomaK
                        korttoma
                        I sent them some feedback to but have not heard anything yet. Maybe we should try the "Streaming API" instead?
                        • Tomas
                        DwaltD S 2 Replies Last reply
                          DwaltD
                          DwaltD
                          Dwalt
                          wrote on last edited by Dwalt
                          #23
                          @korttoma
                          I tried to set up a new graph using the REST API and could not get it to register with Plot.ly. Without any explanation from Plot.ly, I tried sending the same data streams to ThingSpeak.com and it set up with out any trouble. The API is slightly different but just as easy to use. I set up a scene to run every 15 minutes with the following code:
                          -- Get Light Levels
                          local LR_LIGHT_LEVEL = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", 47)
                          local BR_LIGHT_LEVEL = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", 55)
                          - - Get Temps
                          local LR_TEMP = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 46)
                          local BR_TEMP = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 54)
                          local OUT_TEMP = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 23)
                          -- Send data to ThingSpeak.com
                          local http = require("socket.http")
                          http.TIMEOUT = 5
                          result, status = http.request("http://api.thingspeak.com/update?key=Insert Your API Key here&field1="..LR_TEMP.."&field2="..BR_TEMP.."&field3="..OUT_TEMP.."&field4="..LR_LIGHT_LEVEL.."&field5="..BR_LIGHT_LEVEL.."", "run=run") ````
                          The service has a limited functionality to manipulate your data but the base configuration is easy to tweak and can be made public or private.  See [here for my sample data](https://thingspeak.com/channels/25629).
                          ...plus it is free to use.
                            samppa
                            wrote on last edited by samppa
                            #24
                            @korttoma
                            Now plot.ly is back up again.
                            Apparently they upgraded the infrastructure and broke something. Hopefully that does not happen too often..
                            • korttomaK
                              korttomaK
                              korttoma
                              Yes, now it is working again. Maybe you should try again @Dwalt ?
                              • Tomas
                                DwaltD
                                DwaltD
                                Dwalt
                                @korttoma
                                I noticed it back online right after I posted my Thingspeak scene. I had not deleted my Plot.ly scenes and they continued to send http requests during the outage and when Plot.ly came back online, my data resumed plotting.
                                I have both services running right now plotting similar data and I will leave them both running to test reliability and quirks. It seems the time reporting drifts a little in Plot.ly. I am also going to test Beebotte.
                                • korttomaK
                                  korttomaK
                                  korttoma
                                  There was an outage again last night. No data uploaded for 3h. Was it just me or plot.ly?
                                  • Tomas
                                    DwaltD
                                    DwaltD
                                    Dwalt
                                    @korttoma I got it too.
                                    • D
                                      derrij
                                      • korttomaK
                                        korttomaK
                                        korttoma
                                        Did plot.ly change something or did I brake my own ploting somehow? Anyone else having problems?
                                        • Tomas
                                          DwaltD
                                          DwaltD
                                          Dwalt
                                          @korttoma
                                          My plots are still working.
