  3. Sparkfun8266 Wifi Shield + Arduino Due = WiFi Gateway
8 Posts 3 Posters 1.8k Views 3 Watching
  • Z Offline
    Z Offline
    ZachFlem
    Hi Folks,
    I'm trying to convert an existing Ethernet Gateway (shield based w5100) into a WiFi gateway.
    I have the wifi shield working, can ping the Due etc.
    I've copied my relay code below the 8266 setup stuff, but I get an error when compiling:
    C:\Users\zach\Documents\Arduino\libraries\MySensors/MySensors.h:389:2: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    I guess it's because I have no:
    #define MY_GATEWAY_W5100
    defined in my new sketch, but I'm not sure what to define. Will the w5100 work once the WiFi is up and running?
    I appreciate any help you folks can shed on this!
    Full sketch here:
    // Set the gateway type
    #define MY_GATEWAY_w5100
    #define MY_PORT 5003
    #include <SoftwareSerial.h>
    #include <SparkFunESP8266WiFi.h>
    // Define relays
    #define RELAY_1  2            // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define NUMBER_OF_RELAYS 4    // Total number of attached relays
    #define RELAY_ON 0            // GPIO value to write to turn on attached relay
    #define RELAY_OFF 1           // GPIO value to write to turn off attached relay
    // Replace these two character strings with the name and
    // password of your WiFi network.
    const char mySSID[] = "yourSSIDhere";
    const char myPSK[] = "yourPWDhere";
    void before()
      for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
        pinMode(pin, OUTPUT);
        digitalWrite(pin, loadState(sensor) ? RELAY_ON : RELAY_OFF);
      sendSketchInfo("Audry - GW w/Relays", "1.0");
        present(sensor, S_BINARY);
        // Change relay state
        digitalWrite(message.sensor - 1 + RELAY_1, message.getBool() ? RELAY_ON : RELAY_OFF);
        // Store state in eeprom
    M Y 2 Replies Last reply
    • Z ZachFlem
      Hi Folks,
      Full sketch here:
      // Define relays
      void before()
      M Offline
      M Offline
      manutremo
      @zachflem Be sure that the #define is in capitals:
      Otherwise it won't be correctly used by the compiler.
      • Z ZachFlem
        Hi Folks,
        Full sketch here:
        // Define relays
        void before()
        Y Offline
        Y Offline
        @zachflem your setup is not compatible with the standard setups supported by mySensors.
        The sparkfun shield requires the esp8266 AT command set to communicate over wifi.
        I would advise you to use a different esp8266 board (E. G. NodeMCU) and program this directly as an Arduino.
        This should get you started: https://www.mysensors.org/build/esp8266_gateway
        M Z 2 Replies Last reply
        • Y Yveaux
          M Offline
          M Offline
          manutremo
          Ups yes I didn't realize that board won't work.
          I'm using a Wemos D1 R2 with support for OTA firmwar updates. I can share the code if you 're interested.
          • Y Yveaux
            Z Offline
            Z Offline
            ZachFlem
            @yveaux Well that's just handy isnt it! So that shield was a waste of $12 bux!
            I've just ordered a prototyping shield and I'm going to have a go at building my own hack job esp-01 based shield.
            I've got an existing MEGA that I want to retrofit with wifi, rather than rebuilding the whole thing from scratch, and I'm using a LOT of I/O, which I havn't seen much of on the ESP stuff.
            Unless you can suggest an ESP based MEGA replacement with plenty (20+) I/O pins available??
            • Z ZachFlem
              M Offline
              M Offline
              manutremo
              @zachflem There are no ESP based boards wich such a high number of GPIOs that I know of. But there are some MEGA + ESP boards out there. I'm not sure they would work with Mysensors but may want to have a look.
              https://robotdyn.com/mega-wifi-r3-atmega2560-esp8266-flash-32mb-usb-ttl-ch340g-micro-usb.html
              https://www.instructables.com/id/Arduino-MEGA-2560-With-WiFi-Built-in-ESP8266/
              • Z ZachFlem
                Y Offline
                Y Offline
                @zachflem I advise to keep your setup and your nodes simple. A gateway has a clear function and although gateway support for sensors has been added recently I would not try to fit everything into a single node.
                Reconsider your setup, using a simple esp8266+radio as your wifi gateway and one or more nodes providing the functionality you're looking for.
                Z 1 Reply Last reply
                • Y Yveaux
                  Z Offline
                  Z Offline
                  ZachFlem
                  @yveaux well that's just not going to work for me, I'm trying to cut down on the amount of power supplies and random junk I have spread all over the place.
