  3. 💬 Smart Alarm Clock
💬 Smart Alarm Clock
alarmled ring lightspeakerdomoticzmysensorsclock
37 Posts 10 Posters 15.0k Views 12 Watching
  • micahM
    micahM
    micah
    I found a library online.... #include <AnalogMatrixKeypad.h>
    I made some modifications (although I can't quite remember what they were), I think about the number of buttons, or combinations, or target values.
    But generally the library provided the 1 wire, resistor ladder and debouncing functionality I needed
    dbemowskD 1 Reply Last reply
    • micahM
      micahM
      micah
      I often wish our fancy mysensor nRF chips only used 1 arduino wire :(
      • micahM micah
        dbemowskD
        dbemowskD
        @micah Picking resistor values based on the number of switches you have shouldn't be too terribly difficult. You ar just creating a voltage divider circuit. When pushing multiple buttons, you just have to look at the resistor values for the buttons you have and calculate out the parallel resistance. Then you just have to figure out the analog value for any key combinations you want to use and create IF or Switch/Case statements to perform your logic.
        • dbemowskD
          dbemowskD
          So, I didn't look the sketch over for this, but I am planning on building one of these and I have some questions. Does this show in 12 hour or 24 hour format? If it is 12 hour, how do you indicate AM or PM? Also, do you have a way of indicating that alarms are set? I may add some LEDs for these features.
          micahM 1 Reply Last reply
          • dbemowskD
            dbemowskD
            Here is my start on this. No speaker yet and I haven't added the LEDs for AM/PM and alarms, but that will come.
            0_1509333312144_upload-29d46ab7-e40a-49b9-aa1e-330beede8488
            I will need to make a bunch of modifications to the sketch. Mainly because I am using a different RTC module (DS1307). It is one that I have had laying around in my parts bin for years. I get a bunch of compile errors when I try to include the RTC library for this module.
            0_1509333483010_upload-75b8f66d-d692-412f-9171-d0175ea0402d
            Here is the board layout so far.
            0_1509333525901_upload-7777b1c8-2200-4300-aae8-c0a94786b7c8
            • dbemowskD dbemowsk
              micahM
              micahM
              micah
              @dbemowsk
              To use a 24 hour clock switch the following bool
              bool Screen_HourFormat24 = false;
              I think I used the colon to signify that an alarm was set, I think I flashed it on and off. in the Update_Screen method
                 if ((Alarm1_Enabled) && (!Keys_ShowAlarmOnScreen)){
                    if(Screen_ClockPoint)ledScreen.point(POINT_ON);
                    else ledScreen.point(POINT_OFF);
                  } else
              • micahM micah
                @dbemowsk
                    } else
                dbemowskD
                dbemowskD
                @micah said in 💬 Smart Alarm Clock:
                I wasn't necessarily saying that I wanted to switch to 24hr format. I was wondering if you had a way of indicating AM and PM when in 12 hour format.
                I see, so when it is blinking there is an alarm and when it is on solid there is not. I may add a different alarm indicator..
                One other question on this. I see you have 5 buttons on your switch panel. What were your planned uses of those 5 buttons? I didn't see anything documented on that.
                • micahM
                  micahM
                  micah
                  wrote on last edited by micah
                  #35
                  The method Check_KeyPad (Line 300) handles the buttons.
                  Currently my buttons do the following
                  • show/program alarm
                  • hour
                  • minute
                  • turn alarm on and off
                  • turn on or off nightlight
                  • micahM
                    micahM
                    micah
                    Another thing that I've thought of is removing the RTC module completely since we can query the time from the server periodically.
                    This would save components and pins, but it would limit the clock to only working with the controller, whereas the current design allows it to run independently
                    • alowhumA
                      alowhumA
                      alowhum
                      :-D Wow, what an amazing design.
                      12.5k
