  3. Recompiling for different channels
mysbootloader
13 Posts 4 Posters 2.6k Views 4 Watching
  • D DanieleF
    Could someone help me understading how to recmpile MYSBootloader for a different channel?
    I searched around but I haven't found a guide or anything similar.
    I'm not very familiar with gcc and it's configurations...
    I could work both on a Windows or Linux box, I guess the second could be easier to set up.
    Daniele
    skywatchS
    skywatchS
    skywatch
    @danielef First load the clear eeprom sketch for the gateway and nodes. This will let you start with a clean arduino.
    Then simply add
    #define MY_RF24_CHANNEL (97)
    (Or whatever channel you want)
    This MUST be Before
    in your sketch.
    No recompiling needed.
    Note that I am assuming that you are using mysensors 2.3.0, an nrf24l01+ and an arduino gateway/node.
    • skywatchS skywatch
      Then simply add
      This MUST be Before
      in your sketch.
      @skywatch DanieleF was asking about the bootloader, not the sketch.
      skywatchS 1 Reply Last reply
      • rejoe2R
        rejoe2R
        rejoe2
        wrote on last edited by rejoe2
        Might not work, but perhaps you start by modyfing line 53 in MYSBootloader.c (https://github.com/mysensors/MySensorsBootloaderRF24/blob/development/MYSBootloader.c#L53) and then recompile?
        (That's not arduiono code, so I'd use commandline and start with "make")
        D 1 Reply Last reply
          skywatchS
          skywatchS
          skywatch
          @mfalkvidd
          Aha, then I take it all back!
          I thought DanieleF was simply wanting to use a different channel and had assumed that the bootloader needed to be modified to do this (as was the case in earlier versions of my sensors).
          • rejoe2R rejoe2
            DanieleF
            @rejoe2 I tried this, and I also changed the frequency in the makefile (CLK = ... at line 8), but when I flash this bootloader, the arduino hangs and I'm not able to upload any sketch.
            I'm using a micro 3.3V 8MHz and MYSBootloader DEV branch.
            rejoe2R 2 Replies Last reply
            • D DanieleF
              rejoe2R
              rejoe2R
              rejoe2
              @danielef Didn't find any option to change CLK and imo this should not be necessary (hope all the three versions are build and you have just to choose the right one for your board).
              As the file states, it was build using the 2.2 MySensors version. Perhaps you have to downgrade first (and then go back after BL is build successfully).
              • D
                DanieleF
                The option I found is here.
                When I run make, only one hex file is generated, so I assumed I have to change it in order to configure che frequency of my arduino.
                BTW, I don't understand your reference to MySensors version: I'm compiling a C program, not ann Arduino sketch (and I haven't seen a place to give the path to MySensors library).
                rejoe2R 1 Reply Last reply
                • D DanieleF
                  rejoe2R
                  rejoe2R
                  rejoe2
                  @danielef OK, seems your changes have been ok.
                  I didn't check any dependencies, just saw tekka's remark in Line 4 of MYSBootloader.c.
                  Did you add anything in your boards definitions in Arduino IDE for the new BL? Or tried to use the BL definitions from boards.txt included already in the repo?
                  • D
                    DanieleF
                    I'm using the definitions from board.txt available in the repo, simply changing the hex file in the folder where the IDE searches the bootloaders.
                    • D DanieleF
                      rejoe2R
                      rejoe2R
                      rejoe2
                      @danielef said in Recompiling for different channels:
                      Sorry, didn't realize this when first reading through it.
                      So are you using a ATmega328p as mcu (pro mini) or in fact a pro micro (ATMega32U..)?
                      The BL project seems to be limited to the first mcu type (L8 of MYSBootloader.c). Porting to the other mcu most likely is much more work, as this should support upload through USB also.
                      • D
                        DanieleF
                        Sorry, my mystake!!!
                        Pro mini!
                        • rejoe2R
                          rejoe2R
                          rejoe2
                          Seems I'm running out of ideas. If you are sure to have flashed succcessfully the new BL and won't get any sync afterwards to upload any sketch built using that board def, most likely you shoud open an issue in github wrt that.
                          (I myself went the other way round and modified the MYSENSORS modules in FHEM to make use of a second Gateway for flash purposes only - this GW with the standard channel (etc.) settings... Testing is ongoing, but seems to work)
