  3. 💬 HLK-PM01 breakout board
hlk-pm01
38 Posts 17 Posters 12.6k Views 15 Watching
  • sundberg84S sundberg84
    @beic hi. Please see the thread above yours
    beicB
    beicB
    beic
    wrote on last edited by beic
    @sundberg84 said in 💬 HLK-PM01 breakout board:
    There is no value mentioned there, and how did you calculated the tp peak of the sine for varistor against mains?
    You just trow some varistor value in there without calculating anything for RMS and Vpp?!
    • sundberg84S
      sundberg84S
      @beic - sorry, I missed your reply :(
      I didnt calculate - it depends on your AC, depending on your locations so everyone using this PCB has to get their own MOV.
      I have followed the collected recommendations from this thread: https://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers
      Im happy to learn more about varistors (haven't got that far in AOE yet :) ) so please inform us if you know more that would be usefull here. You can use the thread above.
      The varistor was recommended here: http://lygte-info.dk/review/Power Mains to 5V 0.6A Hi-Link HLK-PM01 UK.html
      • R
        R
        ru64
        Hi @sundberg84, did you create custom components for this design? Can you add your library files to the download, please?
        • R ru64
          sundberg84S
          sundberg84S
          @ru64 - i tried uploading them but openhardware didnt allow it.
          @hek - is it possible to allow these?
          .dcm
          .lib
          .kicad_mod
            Yes, should be possible to allow those file extensions. I'll take a look at it tonight.
              @sundberg84
              Could you give it another try try uploading the files. They should work now.
              • sundberg84S
                sundberg84S
                @hek - worked! Tnx
                @ru64 - uploaded!
                • R
                  R
                  ru64
                  @sundberg84 - thanks! but still schematic does not open correctly, remapping says:
                  Warning: No symbol “HLK-PM01” found in symbol library table.
                  Warning: No symbol “CONN_01X02” found in symbol library table.
                  Warning: No symbol “FUSE” found in symbol library table.
                  Warning: No symbol “VR” found in symbol library table.
                  Warning: No symbol “C” found in symbol library table.
                  Any ideas? Sorry if asking stupid thing, but I am really new with KiCad
                  • R
                    R
                    ru64
                    Oh, ok, never mind. Apparently, it does not work correctly in the latest KiCad version. When I open it in 4.0.4, it looks fine :)
                    • A
                      ab192
                      @sundberg84 can you please tell me what is the type or specifications (other than 600mA) for the output fuse? Could you name a specific fuse as an example?
                      Thank you.
                      • A ab192
                        Thank you.
                        sundberg84S
                        sundberg84S
                        @ab192 - I put that there because that is the limit of the HLK-PM01 output. I never use it though, (i just bridge it) and use the input-fuse... When you choose a fuse its much about what kind if load you are going to have on that circuit.
                        • A
                          Almamater
                          Hello, thank you for the good job! Just one question, do you remember what is the size of the 200mA fuse that you put? (5x20mm Fuse? or other?) Thanks
                          • A Almamater
                            sundberg84S
                            sundberg84S
                            #29
                            @Almamater its a glas fuse with legs, so not a holder and fuse, that took to much space. Search axial lead fuse.
                            Example:
                            https://www.ebay.co.uk/itm/112791896665
                            https://www.ebay.com/itm/174073055432
                            • SleipnirrS
                              SleipnirrS
                              Sleipnirr
                              Thanks for the great design. I wonder if you could edit the design for new Hi-link 5V products (5V 5W HLK-5M05, 5V 10W HLK-10M05L, and 5V 20W HLK-20M05). They are very similar but different in size. Thank you.
                              • J
                                J
                                JohanH
                                I've modified the PCB and added support for the 5W module (you can select to use either the 3W or 5W on same PCB). I've also added screw holes. Here is the list of changes:
                                • Imported to KiCad 5.1.8
                                • Added M2.5 screw holes
                                • Added EMI/EMC filter
                                • Added HLK-5MXX 5W models
                                • Board size: 72 mm * 42 mm
                                I've also changed track width to a more proper one for the respective voltages (secondary has larger current). You can leave out the EMI/EMC filter (add jump wires instead of the inductor) as it is not tested. I have not updated the BOM, but e.g. the inductor part id is mentioned in the circuit and the X2 cap is of common size.
                                You can download the updated design here: https://johanh.net/hlk/HLK-5M12_Breakout_board.zip
                                Comments are appreciated. I'm new to KiCad, so I might have done some mistakes. The KiCad project should maybe have been named as it was originally, but I renamed it to keep it separate.
                                • J
                                  J
                                  JohanH
                                  So I actually built one of the boards now. Only tested so far that it outputs 5V (more tests later). Still waiting on the common mode inductor (so jumpered so far). It was hard to find, but the one I designed it for is available at Digikey, part number 817-2151-ND‎ (manufacturer Schaffner RN202-0.3-02-12M‎).
                                  One tricky thing I noticed about the original design by sundberg84 is that he incorporates a thermal fuse. These are really tricky to solder and are normally crimped in production devices, e.g. for fans and such. If you hold the solder iron more than half of a second to the leg you will pop it (you will hear a tiny click when the spring releases) and you have to discard it. Now it isn't absolutely needed on this board, you could just put a jumper in place. But here is a trick if you want to solder a thermal fuse.
                                  Don't solder any other components before the thermal fuse (makes it more easy). Take a small bowl of water and submerge the fuse in water while soldering it. Keep it submerged a while after soldering is ready, to let it cool down completely. This is a 100% reliable way to not destroy the fuse.
                                  Here is a picture of the thermal fuse being soldered:
                                  ![Thermal fuse being soldered](image https://johanh.net/hlk/thermofuse_s.png)
                                  • R
                                    R
                                    RobIII
                                    Hi! I was wondering why you used the 73°C thermal fuse specifically? I’m assuming it’s what you had lying around and any value of, say 70-85°C will do? Or is there a specific reason for that specific value?
                                    I’m asking since that specific value (+/- 1°C) keeps popping up everywhere:
                                    https://everythingesp.com/if-youre-like-me-you-constantly-find-that/
                                    https://forum.arduino.cc/t/hlk-pm01-power-supply/427005
https://easyeda.com/matimoto/HLK_PM01-33b4760fcdff46b6b71784304f89c379
                                    Thanks in advance!
                                    • R RobIII
                                      Thanks in advance!
                                      sundberg84S
                                      sundberg84S
                                      @RobIII - there is no specific reason why I choose 73dgr, probably it was easy avalible.
                                      70-85 woudl sure work good.
                                      • T
                                        titou4307
                                        Hello
                                        I would like to pass order for this PCB....
                                        Is it possible to have a version more larger for fixations (screw x4) for to fix this PCB on a box ?
                                        Best regard
                                        • T titou4307
                                          Hello
                                          Best regard
                                          sundberg84S
                                          sundberg84S
                                          @titou4307 Hello! I dont really work on that project anymore, but its open hardware and all files are there so feel free to modify
