  3. πŸ’¬ HLK-PM01 breakout board
hlk-pm01
38 Posts 17 Posters 12.6k Views 15 Watching
  • sundberg84S
    sundberg84S
    Hi! Really? Im sure I have uploaded them.
    Well, I will upload them again!
    Edit: All files removed and updated. New revision created.
    A 1 Reply Last reply
    • sundberg84S sundberg84
      apeeters
      @sundberg84 said in πŸ’¬ HLK-PM01 breakout board:
      Thanks for the excellent work!
      • alexsh1A
        alexsh1A
        alexsh1
        This is a 5V version. Did you consider doing a 3.3V version? I have pretty much all my sensors /GW using 3.3V power source
        • alexsh1A alexsh1
          sundberg84S
          sundberg84S
          @alexsh1 the 3.3v uses the same pinout so you should be able to just change the hlk module ?
          http://www.hlktech.net/product_detail.php?ProId=59
          alexsh1A 1 Reply Last reply
            alexsh1A
            alexsh1A
            alexsh1
            @sundberg84 thank you for pointing at this. I did not realise there is a 3.3v version :((
            I have a few 5V ones which are useless without a voltage dropout
            • pihomeP
              pihomeP
              pihome
              Thank you for sharing, what Varistor part number you are using?
              PiHome - Smart Heating Control
              • pihomeP pihome
                sundberg84S
                sundberg84S
                @pihome im using the recommendations from this thread: https://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers
                Make sure you buy the right depending on what AC voltage you have 120/240 or other.
                I think these are the ones i bought last time.
                • beicB
                  beicB
                  beic
                  Dear @sundberg84 can you please read and write here the Varistors exact model/part number from your assembled board, please?
                  • beicB beic
                    sundberg84S
                    sundberg84S
                    @beic hi. Please see the thread above yours
                    beicB 1 Reply Last reply
                      beicB
                      beicB
                      beic
                      wrote on last edited by beic
                      There is no value mentioned there, and how did you calculated the tp peak of the sine for varistor against mains?
                      You just trow some varistor value in there without calculating anything for RMS and Vpp?!
                      • sundberg84S
                        sundberg84S
                        @beic - sorry, I missed your reply :(
                        I didnt calculate - it depends on your AC, depending on your locations so everyone using this PCB has to get their own MOV.
                        I have followed the collected recommendations from this thread: https://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers
                        Im happy to learn more about varistors (haven't got that far in AOE yet :) ) so please inform us if you know more that would be usefull here. You can use the thread above.
                        The varistor was recommended here: http://lygte-info.dk/review/Power Mains to 5V 0.6A Hi-Link HLK-PM01 UK.html
                        • R
                          R
                          ru64
                          Hi @sundberg84, did you create custom components for this design? Can you add your library files to the download, please?
                          • R ru64
                            sundberg84S
                            sundberg84S
                            @ru64 - i tried uploading them but openhardware didnt allow it.
                            @hek - is it possible to allow these?
                            .dcm
                            .lib
                            .kicad_mod
                              Yes, should be possible to allow those file extensions. I'll take a look at it tonight.
                                @sundberg84
                                Could you give it another try try uploading the files. They should work now.
                                • sundberg84S
                                  sundberg84S
                                  @hek - worked! Tnx
                                  @ru64 - uploaded!
                                  • R
                                    R
                                    ru64
                                    @sundberg84 - thanks! but still schematic does not open correctly, remapping says:
                                    Warning: No symbol β€œHLK-PM01” found in symbol library table.
                                    Warning: No symbol β€œCONN_01X02” found in symbol library table.
                                    Warning: No symbol β€œFUSE” found in symbol library table.
                                    Warning: No symbol β€œVR” found in symbol library table.
                                    Warning: No symbol β€œC” found in symbol library table.
                                    Any ideas? Sorry if asking stupid thing, but I am really new with KiCad
                                    • R
                                      R
                                      ru64
                                      Oh, ok, never mind. Apparently, it does not work correctly in the latest KiCad version. When I open it in 4.0.4, it looks fine :)
                                      • A
                                        ab192
                                        @sundberg84 can you please tell me what is the type or specifications (other than 600mA) for the output fuse? Could you name a specific fuse as an example?
                                        Thank you.
                                        • A ab192
                                          Thank you.
                                          sundberg84S
                                          sundberg84S
                                          @ab192 - I put that there because that is the limit of the HLK-PM01 output. I never use it though, (i just bridge it) and use the input-fuse... When you choose a fuse its much about what kind if load you are going to have on that circuit.
                                          With your input, this post could be even better πŸ’—
