  3. Everything nRF52840
Everything nRF52840
323 Posts 28 Posters 172.1k Views 33 Watching
    You can now run mecrisp-stellaris FORTH on the nRF52840-DK: https://github.com/rabbithat/FORTH_NRF52840-DK
    • rozpruwaczR
      rozpruwaczR
      rozpruwacz
      @NeverDie did You compared somehow the range of the nrf52840 dongle with other nrf52840/nrf52832/nrf51822 modules ? I'm asking because after first test it appears that the nrf52840 dongle has worse range than core51822 module using the same radio settings.
      • rozpruwaczR rozpruwacz
        @rozpruwacz No, I hadn't noticed that. Do note though that you can increase the tx power on the nRF52840 dongle to 8db, whereas 4db is the max for the nRF51822.
          rozpruwaczR
          rozpruwaczR
          rozpruwacz
          @neverdie said in Everything nRF52840:
          Yes, but with the same settings I would expect at least the same range. I will keep testing.
            @rozpruwacz The nRF52840 chip itself should be better because of its greater receive sensitivity.You didn't say exactly what you're comparing it against (aside from it being an nRF51822), but the dongle has a smallish antenna and a small ground plane. Usually those don't have as good a range. It's one of the trade-offs that comes with smaller size. It may also be more directional that what you're expecting, so try rotating it and see if that makes a difference.
              rozpruwaczR
              rozpruwaczR
              rozpruwacz
              @neverdie i'm comparing it with core51822 module which also has pcb antenna
                I just now posted a much easier mecrisp-starellis FORTH for the nRF52840-DK: https://github.com/rabbithat/nRF52840-DK_easy/blob/master/README.md
                On this one, all you need do is upload the hex file located in that repository and you're done. :-)
                H 1 Reply Last reply
                  H
                  H
                  heinzv
                  @neverdie interesting research and ideas. Have you tried to get BLE 5.0 running (the S140 SD) or using the nrf52840 radio features (best with long range) so that we can consider a sensor node/actor and does the sleep properly work? There are some basic features which have to work before switching the development/runtime env.
                  • H heinzv
                    @heinzv
                    I haven't been working on that per se, but I do have a REPL over radio working: https://github.com/rabbithat/nRF52_wireless_Forth_REPL
                    which can also be used for doing OTA code updates.
                      @heinzv
                      H
                      H
                      heinzv
                      @NeverDie You doing a great research! I have quickly checked your REPL code and the radio lib.
                      So you have implemented a OSI Layer 3+4 (Transport Layer with IP/TCP Stack).
                      I'm wondering if/how this can be used to complay to BLE 5.0 (long range), ZigBee and Threads which the new Nordic SDK (Zigbee and Threads 2.0) offers? Are they also using the Softdevice S140 (6.1) libs or ...?
                      There is a ZigBee OTA update example provided by Nordic (but I have not yet enogh time to test it).
                      Currently, I'm still using MySensors and the NRF5_ESP (Nordic private) protocol which works. IT would be also interesting to use a more industry standard protocol like ZigBee or THREADS which seem to be also supported by OpenHAB.
                      I'll certainly do further investigations in this direction. I have tried to test it with Segger Embedded studio and also with IAR Studio for ARM (the second requires some newer 32Bit version libs from Nordic and an internat request for that was raised already). Segger works fine with the J-Link adapters.
                      • H heinzv
                        @heinzv said in Everything nRF52840:
                        If you specifically want those protocols, then at present the Nordic SDK is the only existing library I know of that will get you them.
                          It appears that Fanstel is now selling the amplified nRF52840 modules:
                          https://www.fanstel.com/bt840f-nrf52840-ble-5-module-secure-iot-802154-thread-zigbee-1
                          • alowhumA
                            alowhumA
                            alowhum
                            Wait, what? The nRF52840 can now act as a Zigbee device too??
                            So I could make Arduino projects that talk Zigbee?
                            • alowhumA alowhum
                              #192
                              @alowhum Well, 802.15.4 for sure. I already did it, as I reported earlier. Beyond that, there's no native on-chip support for Zigbee per se. Maybe they confused it with zigbee? https://www.electronicdesign.com/what-s-difference-between/what-s-difference-between-ieee-802154-and-zigbee-wireless
                              That said, someone could certainly write a zigbee on top of it. It's meant for stuff like that. I imagine Thread is already written on top of it.
                              Anyway, I suspect that the amplified nRF52840 modules will be as good as it gets for quite some time and will remain relevant for years to come. The long wait is finally over!
                                #193
                                By the way, I now have the wireless FORTH REPL working on the same nRF52840-dongle as in the OP of this thread: https://github.com/rabbithat/nRF52840-Dongle_hex/blob/master/README.md
                                I can plug the dongle into any USB port to power it, and with the wireless REPL the experience is exactly the same as if I had a wired serial connection to the dongle. I can interact with the REPL, start programs, load code or updates, and/or debug--all wirelessly. If you want to try it, I have getting started instructions in the github repository.
                                • B
                                  B
                                  blademckain
                                  Someone know if exist a usb nRF52840-dongle (with external antenna ) to plug into a raspberry to scan nearby tag?
                                  • alowhumA
                                    alowhumA
                                    alowhum
                                    @blademckain The Micro:bit comes close.
                                    • nagelcN
                                      nagelcN
                                      nagelc
                                      The new Arduino Nano 33 BLE is going to use the nrf52840. It will be interesting to see how support for the nrf52840 evolves in the Arduino environment.
                                      https://hackaday.com/2019/05/19/new-arduino-nano-line-rolls-out-in-four-flavors-at-maker-faire-bay-area/
                                      monteM 1 Reply Last reply
                                      • nagelcN nagelc
                                        monteM
                                        monteM
                                        monte
                                        • alowhumA
                                          alowhumA
                                          alowhum
                                          @nagelc that's great news!!
