  3. ๐Ÿ’ฌ EFEKTA nRF5 Motion sensor
motionnrf52nrf52832nrf5lux
8 Posts 5 Posters 2.3k Views 3 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/642/EFEKTA-nRF5-Motion-sensor
    scalzS 1 Reply Last reply
      @berkseo
      nice board :+1:
      Just a note, in case it could improve your board performance :)
      In datasheet, if you take a look in section 53-4&5, you'll find some infos about the rf path, also on nordic's forums.
      • it's not really recommended to change layout on rf output, especially close to the mcu the keepout area and inductor+capa, and how it's connected to gnd, else you may get some harmonics.
      • coplanar waveguide for impedance matching feedline
      then you can add footprints close to antenna, for tuning, in case. cut antenna length etc.
      of course better to do this tuning in final setup (enclosed).
      might improve rf ;)
      hope this helps. keep the good work.
      berkseoB 1 Reply Last reply
      • scalzS scalz
        @berkseo
        nice board :+1:
        might improve rf ;)
        berkseoB
        berkseoB
        berkseo
        @scalz Thanks for your support and tips(this is really important)!!! I tried to calculate everything by RF part(as far as possible). In the prototype version (homemade Board, see the video), there were made special places for additional capacitors, later after the tests I refused them. I paid attention to everything that is recommended to pay attention in the Datasheet. This also applies to paragraphs 53 4 & 5( in my case 53 1). Working tests continue, this is the first revision of the Board, perhaps this will be added in the future - - https://www.johansontechnology.com/datasheets/2450FM07A0035/2450FM07A0035.pdf
        https://youtu.be/hXmxzo0OiMs
          @berkseo
          cool. if it helps, I'm glad :)
          On your homemade proto pcb, you didn't have gnd plane I guess, so you can't really compare with your board from fabhouse. board layout change antenna tuning for example.
          I meant, on your board, rf routing is not great. not sure if your feedline is 50ohms (route seems thin vs 2layer board and coplanar waveguide).
          for rf, devil is in details, just saying, if you plan to sell your boards, even nrf5 hasn't the best range so a pity to not get best perf ;)
          Below a pic from datasheet, about the layout and , rf pin/inductor/capacitor placement.
          there is a keepout area. how capa gnd is connected. so the values for the inductor and capa. with different layout and no tuning->harmonics etc.
          • R
            R
            renatocan
            Great project!
            Have you released software for the board?
            Are there pins on the board to flash the uC?
            Renato.
            • R renatocan
              Great project!
              Renato.
              berkseoB
              berkseoB
              berkseo
              @renatocan said in ๐Ÿ’ฌ EFEKTA nRF5 Motion sensor:
              Great project!
              Renato.
              Added test sketch with adjustable delay of response time - https://www.openhardware.io/view/642#tabs-source
              Programmable through an adapter, it always comes with the device(a little different SWD + RX TX) - https://www.openhardware.io/view/588/ICSPandFTDI-Adapter
              • R
                R
                renatocan
                Thank you very much @berkseo. Can you release the schematics and PCB layout files? I am working on a workspace analytics application in which I have to monitor several office desks to log utilization. I've already deployed a poc using mysensors hardware assembled using jump wires. Now we're looking for a more robust implementation and I think your project may be a great solution. Do you have resources related to this project published somewhere else? Or are you just using Openhardware.io?
                Renato.
                • O
                  O
                  Omemanti
                  Can you tell something about the range of this node?
                  And do you see a chance to post the schematic?
                  With your input, this post could be even better ๐Ÿ’—
