  3. πŸ’¬ Solar Energy Harvester
ltc3105solarmppcmpptchargerenergy harvestingboost converterboosterstep-upconverterboostboostingcharging
20 Posts 7 Posters 8.6k Views 6 Watching
    I just now posted Version 4.
    Changes from Version 3:
    1. removed unnecessary header pins,
    2. added more GND header pins to facilitate easier hookups, and
    3. made the board more compact in size.
      I just now posted Version 5.
      Changes from version 4:
      1. Uses same inductor as my other Linear Technology based boost converter projects.
      2. Enlarged PCB board to accomodate the larger design footprint.
        I just now posted Version 6.
        Changes from Version 5: removed or re-arranged silk screen to mitigate potential for solder bridging.
          Update: the land pattern contained an error that I didn't notice until I tried to solder the chip onto the PCB. I've now fixed the problem and have now sent revised files to the fab. As with the other projects, I'll wait for the board to arrive and test that it works before I deem it no longer a work in progress.
            I've received the board and assembled it (see photo). It appears to work in accordance with the datasheet. Therefore, this project is finished.
              A Former User
              Is a schematic available?
              • ? A Former User
                @celem said in πŸ’¬ Solar Energy Harvester:
                Yes. If you look in the photos section, it's there. It's the same as what's in the datasheet as a "typical application."
                • akumarA
                  akumarA
                  akumar
                  Hi. Do you think this will be enough for indoor usage to power a simple temperature sensor ?
                  What type of battery did you use this module with ?
                  • akumarA akumar
                    @akumar
                    Of course.
                      Mar
                      First time SM assembly. Photos do not show connections to 3 tiny holes that must go to ground. Is this done with small wires to side holes on either side or ...?
                      skywatchS 1 Reply Last reply
                      • M Mar
                        skywatchS
                        skywatchS
                        skywatch
                        @mar The three tiny holes may not go to ground. They are probably 'vias' that take a trace from one side of the board to the other.
                        Vias are through plated at manufacture and shouldn't need anything from you.
                        But I don't know this particular board and so things might be different here. Use a multimeter to check the circuit diagram against the board.
                          Mar
                          Right you are. Live and learn (even at 81), and I even learned a new word -'vias.' Thanks.
                          With your input, this post could be even better πŸ’—
