  3. not working Ethernet Gateway (sensebender and/or nano gateway)
32 Posts 9 Posters 6.2k Views 8 Watching
  • R rafael156
    Hello!
    I have the problem that I cannot use an ethernet gateway at the moment. I have a sensebender board, which can't be programmed any more. I exchanged the Atmel SAMD21 and have to program it now.
    Can you tell me with which programmer and at which pins on the sensebender board I have to program the processor?
    and my second question is:
    i tried to build an ethernet gateway with an arduino(clone) nano + nrf+w5100 (https://www.mysensors.org/view/178#enc28j60-ethernet-module). i did everything as described in the manual, but neither openhab nor MYSController can connect to the gateway. LEDs from the nano and w5100 light up/flash. does anyone know why this could be? is the normal usb-connection of the nano sufficient for the power supply?
    @rafael156 for the second question, looking at the debug output will likely be the fastest way to figure out what is wrong.
    • tbowmoT
      tbowmoT
      tbowmo
      @rafael156
      In order to program a fresh atsamd21 without bootloader, a CMSIS-DAP / SWD debugger. P4 on the front of the PCB (unpopulated) is used to connect with a standard cortex swd pinout.
      Alternative connection is on the back, where there are testpads for the SWD / CLK pins.
      • R
        R
        rafael156
        @tbowmo said in not working Ethernet Gateway (sensebender and/or nano gateway):
        ok, unfortunately i have never used a swd debugger before. i read on the internet that the JTAGICE mkII can program the cortex mo+. i have that here. is it really possible?
        with the ch341 i currently have the problem that windows does not recognize the driver after an update. before it was always possible. i have the driver from http://www.wch.cn/download/CH341SER_EXE.html.
        all my arduino nanos are no longer recognized.
        tbowmoT 1 Reply Last reply
        • R
          R
          rafael156
          ok, the log of the nano ethernet gateway is as follows:
          0 MCO:BGN:INIT GW,CP=RNNGA---,REL=255,VER=2.3.1<\n>
          4 TSM:INIT<\n>
          5 TSF:WUR:MS=0<\n>
          11 TSM:INIT:TSP OK<\n>
          13 TSM:INIT:GW MODE<\n>
          15 TSM:READY:ID=0,PAR=0,DIS=0<\n>
          17 MCO:REG:NOT NEEDED<\n>
          642 GWT:TIN:IP=255.255.255.255<\n>
          1644 MCO:BGN:STP<\n>
          1645 MCO:BGN:INIT OK,TSP=1<\n>
          1648 TSM:READY:NWD REQ<\n>
          1685 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:<\n>
          900006 TSF:SAN:OK<\n>
          is it possible, that the w5100 draws too much current for the nano?i connected only USB
          • R rafael156
            tbowmoT
            tbowmoT
            tbowmo
            @rafael156
            I'm using the atmel jtagice3 myself, however I had to make a converter, because the pinout of the jtagice 3 is not compatible with the cortex m0 debug port pinout. So check the pinout of both devices first to be sure that they match.
            • R
              R
              rafael156
              wrote on last edited by rafael156
              ok, i tried again to get the nano ethernet GW running with the following sketch, with partial success: the fritzbox recognizes the ip address. But with the MYSController or Openhab I still can't establish a connection (connection refused).:
               * Copyright (C) 2013-2018 Sensnology AB
               * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
               * Version 1.0 - Henrik EKblad
               * LED purposes:
               * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
               * - ERR (red) - fast blink on error during transmission error or receive crc error
              #define MY_RADIO_RF24
              //#define MY_RADIO_NRF5_ESB
              //#define MY_RADIO_RFM95
              #define MY_GATEWAY_W5100
              //#define MY_GATEWAY_MAX_CLIENTS  3
              //#define MY_W5100_SPI_EN 4
              // radio on the same spi bus.
              #define MY_SOFTSPI
              #ifndef MY_RF24_CE_PIN
              #define MY_RF24_CE_PIN 5
              #ifndef MY_RF24_CS_PIN
              #define MY_RF24_CS_PIN 6
              // Enable UDP communication
              //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
              #define MY_IP_ADDRESS 192,168,1,110
              #define MY_PORT 5003
              // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
              //#define MY_MAC_ADDRESS 0x7F, 0x24, 0xCE, 0x40, 0x46, 0x44
              // Enable inclusion mode
              // Set blinking period
              // Flash leds on rx/tx/err
              #if defined(MY_USE_UDP)
              #include <EthernetUdp.h>
              #include <Ethernet.h>
              the log of it is two posts before.
              For the W5100 does "MO"=MOSI and "MI"=MISO?
              Bild Text
              What am I doing wrong? has one of you already built a nano with W5100?
              • R
                R
                rafael156
                for a short moment I was able to connect to the myscontroller and got the following log:
                21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=?^a?
                21.01.2019 22:24:41	RX	B?$?]?}?L?*+2a??MQt҆Ÿ?Go?I??
                21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=B?$?]?}?L?*+2a??MQt҆Ÿ?Go?I??
                21.01.2019 22:24:41	RX	??z??xQG&F⎙(݄???¢
                21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=??z??xQG&F⎙(݄???¢
                21.01.2019 22:24:41	RX	??`???i?Ŀ?^a?Hf????wHH?h?Gb؛??W?U��Y??
                21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=??`???i?Ŀ?^a?Hf????wHH?h?Gb؛??W?U��Y??
                21.01.2019 22:24:41	RX	Ⱥ?x)ل?c??
                21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=Ⱥ?x)ل?c??
                21.01.2019 22:24:41	RX	?R]hgGR?r7"?JOS?-&?{??%?~?s??ɋ5??.Ejj?7?er?8?P?1@T?s{?\G$
                21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=?R]hgGR?r7"?JOS?-&?{??%?~?s??ɋ5??.Ejj?7?er?8?P?1@T?s{?\G$
                21.01.2019 22:24:41	RX	"'??
                ?12???9?7˩/9[u?u?[?6Z
                ???{#|X|M??4!?GB?8??b̨??۽?x?v??Ar?/?m'!n"
                21.01.2019 22:24:41	ERROR	"ErrorFlag=255, Msg='??
                21.01.2019 22:24:41	RX	?c?b?-
                21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=?c?b?-
                21.01.2019 22:24:41	RX	eH{??J6
                21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=eH{??J6
                21.01.2019 22:24:41	RX	5[?4??*?j????ql??5
                21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=5[?4??*?j????ql??5
                21.01.2019 22:24:41	RX	">?/??]J?v@;jL!F?????>???TX?B#	?n??	?O?}?8?ǀ???
                T?0y1?U??/?H?Lj?*ߋ8t??#7pY??""&O??r? ?p?7??ļ_^??>?+*??ҖPR???Cz?!f?:&~z?Hӑ"
                21.01.2019 22:24:41	ERROR	"ErrorFlag=255, Msg=>?/??]J?v@;jL!F?????>???TX?B#	?n??	?O?}?8?ǀ???
                21.01.2019 22:24:41	RX	?:?E??I????
                21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=?:?E??I????
                21.01.2019 22:24:41	RX	"?,T?$?f8\?׺^?o
                ?݈s??P)?F??W	?Z':?`q??y?<??\F駐???<??0?DȅΠ?BZ_?!gB??"
                21.01.2019 22:24:41	ERROR	"ErrorFlag=255, Msg=?,T?$?f8\?׺^?o
                21.01.2019 22:24:41	RX	"??""
                ??i32٫+?m??{p?<H?^>'bl?\?\?h???ځ{?C"
                21.01.2019 22:24:41	ERROR	"ErrorFlag=255, Msg=??""
                21.01.2019 22:24:41	RX	??4??(3AX?Hb?[k?؊??iT?6
                21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=??4??(3AX?Hb?[k?؊??iT?6
                21.01.2019 22:24:41	RX	"??A??,??*??ab!?^3l=???[M3??lay?f9B??J?8G?C?}JOU?%
                Tǽ?I/h???\
                4b%<??!AH??kw??^؁?"
                21.01.2019 22:24:41	ERROR	"ErrorFlag=255, Msg=??A??,??*??ab!?^3l=???[M3??lay?f9B??J?8G?C?}JOU?%
                Tǽ?I/h???\
                4b%<??!AH??kw??^؁?"
                21.01.2019 22:24:41	RX	?9??H ?Y0?*?aͧ?Z.!?p2P??
                21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=?9??H ?Y0?*?aͧ?Z.!?p2P??
                21.01.2019 22:24:41	RX	"f?>;???0f??iB*}?/?J*1?~?S6WjH.?w?	?K#?29?(?kq8-O?V??U?n\"
                21.01.2019 22:24:41	ERROR	"ErrorFlag=255, Msg=f?>;???0f??iB*}?/?J*1?~?S6WjH.?w?	?K#?29?(?kq8-O?V??U?n\"
                21.01.2019 22:24:41	RX	?^a?
                Tǽ?I/h???\
                4b%<??!AH??kw??^؁?"
                Tǽ?I/h???\
                4b%<??!AH??kw??^؁?"
                can it be that the nano has too little power (+5V) for the NRF and W5100 when I feed it via USB?
                • R
                  R
                  rafael156
                  ok, I have now flashed the sensebender gateway with previously compiled SensebenderGatewayW5100.ino.hex, but no LEDs flash.
                  can someone send me the factory hex?
                  or do I have to change the fuses?
                  my factory fuses are:
                  NVMCTRL_NVM_LOCK = 0x00
                  NVMCTRL_PSZ = 0x03
                  NVMCTRL_NVMP = 0x1000
                  ADC_LINEARITY_0 = 0x08
                  ADC_LINEARITY_1 = 0x04
                  ADC_BIASCAL = 0x03
                  OSC32K_CAL = 0x42
                  USB_TRANSN = 0x05
                  USB_TRANSP = 0x1D
                  USB_TRIM = 0x03
                  DFLL48M_COARSE_CAL = 0x23
                  DFLL48M_FINE_CAL = 0x200
                  ROOM_TEMP_VAL_INT = 0x1D
                  ROOM_TEMP_VAL_DEC = 0x08
                  HOT_TEMP_VAL_INT = 0x7D
                  HOT_TEMP_VAL_DEC = 0x00
                  ROOM_INT1V_VAL = 0x00
                  HOT_INT1V_VAL = 0xF9
                  ROOM_ADC_VAL = 0xB38
                  HOT_ADC_VAL = 0xEC1
                  NVMCTRL_BOOTPROT = 0x07
                  NVMCTRL_EEPROM_SIZE = 0x07
                  BOD33USERLEVEL = 0x07
                  BOD33_EN = [ ]
                  BOD33_ACTION = 0x01
                  WDT_ENABLE = [X]
                  WDT_ALWAYSON = [X]
                  WDT_PER = 0x0B
                  WDT_WINDOW_0 = [ ]
                  WDT_WINDOW_1 = 0x05
                  WDT_EWOFFSET = 0x0B
                  WDT_WEN = [X]
                  BOD33_HYST = [X]
                  NVMCTRL_REGION_LOCKS = 0xFFFF
                  OTP1_WORD_0 = 0x10000300 (valid)
                  OTP4_WORD_0 = 0x40004007 (valid)
                  OTP4_WORD_1 = 0x8DF4B09C (valid)
                  OTP4_WORD_2 = 0xFFFFFE00 (valid)
                  TEMP_LOG_WORD_0 = 0x7D81D (valid)
                  TEMP_LOG_WORD_1 = 0xEC1B38F9 (valid)
                  USER_WORD_0 = 0xD8E0C7FF (valid)
                  USER_WORD_1 = 0xFFFFFC5D (valid)
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @rafael156
                    You probably need to have the bootloader as well.. I might be able to find the binary/hex file that is used for production at itead in one of my old emails.. If interested, I can send it in an email (PM me if interested)
                    • R rafael156
                      Tǽ?I/h???\
                      4b%<??!AH??kw??^؁?"
                      Tǽ?I/h???\
                      4b%<??!AH??kw??^؁?"
                      Tǽ?I/h???\
                      4b%<??!AH??kw??^؁?"
                      Tǽ?I/h???\
                      4b%<??!AH??kw??^؁?"
                      @rafael156 said in not working Ethernet Gateway (sensebender and/or nano gateway):
                      There is a large variety of cloned Nano's around, and most of them use crappy voltage regulators, so yes this could be the case.
                      What regulator is on the Nano? Or picture if you don't know...
                      You could try powering from USB using a separate regulator, or using a separate supply.
                      Do the standard ethernet examples that come with the Arduino IDE work correctly?
                        Stephen205
                        Yes.
                        I have just built a gateway with funduino w5100, I have it connected over usb (for power) to a RPI for now, it works well.
                          Stephen205
                          did you add a decoupling capacitor to the radio?
                          • R
                            R
                            rafael156
                            Yes, on every radio.
                            tomorrow I'll try different tests and then report back
                              Stephen205
                              / Enable MY_IP_ADDRESS here if you want a static ip address (no DHCP)
                              change #define MY_IP_GATEWAY_ADDRESS 192,168,1,1
                              to MY_IP_GATEWAY 192,168,1,110
                              and see if that works.
                              • R
                                R
                                rafael156
                                can anyone tell me how to flash the sensebender board (Atmel ATSAMD21J18A) with openocd and an Atmel JtagIce3 running on windows? i have a batch file, but it returns an error.
                                Batch file:
                                openocd\bin\openocd --debug 4 --log_output log.txt -d0 -s openocd/share/openocd/scripts/ -f arduino_zero.cfg -c "telnet_port disabled; init; halt; at91samd bootloader 0; program {{%1}} verify reset;shutdown"
                                log_file:
                                Debug: 17 12 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_debug_level 0
                                Debug: 18 12 command.c:145 script_debug(): command - debug_level ocd_debug_level 0
                                debug_level: 0
                                adapter speed: 500 kHz
                                adapter_nsrst_delay: 100
                                target state: halted
                                xPSR: 0x81000000 pc: 0x00005460 msp: 0x20007fb8
                                xPSR: 0x81000000 pc: 0x000005e8 msp: 0x20007ffc
                                ** Programming Started **
                                auto erase enabled
                                Runtime Error: embedded:startup.tcl:454: ** Programming Failed **
                                in procedure 'program'
                                in procedure 'program_error' called at file "embedded:startup.tcl", line 510
                                • R
                                  R
                                  rafael156
                                  ok, I flashed the bootloader and now LED5 (D5) is lit permanently. A new USB port is also not recognized.
                                  the fuse settings were probably not set either. do I still have to set them or don't I need them at sensebender gw?
                                  but i need the USB port, otherwise i can't transfer sketches.
                                  if I transfer sketches via SWD nothing happens after the upload.
                                  • R
                                    R
                                    rafael156
                                    i just found out that the platform.txt is not correct/outdated. The file "...\Arduino15\packages\MySensors\hardware\samd\1.0.5\platform.txt"
                                    Line 148 should be changed from
                                    openocd-0.9.0-arduino5-static.path
                                    to
                                    openocd-0.9.0-arduino6-static.path
                                    can one of the mysensors samd board 1.0.5 please change that?
                                    • R
                                      R
                                      rafael156
                                      has anyone managed to get an arduino nano running with NRF and W5100 as ethernet gateway? mine won't even accept the IP address (should be 192.168.1.110) after a successful sketch:
                                      4 TSM:INIT<\n>
                                      5 TSF:WUR:MS=0<\n>
                                      580 GWT:TIN:IP=0.0.0.0<\n>
                                      1582 MCO:BGN:STP<\n>
                                      1584 MCO:BGN:INIT OK,TSP=1<\n>
                                      1586 TSM:READY:NWD REQ<\n>
                                      1624 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:<\n>
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        The SAMD21 doesn't use fuses in the same way that the atmega328 does. For example, the clock source is set by the running program, and not the fuses. The only fuses awailable is BOD, WDT and bootprotection. (See page 43 in the datasheet)
                                        So it should not be needed to set any fuses in the SAMD21 in order to get it working.
                                        btw. why did you replace the atsamd21 in the first place?
                                        • R
                                          R
                                          rafael156
                                          Okay, thanks for the clarification.
                                          i changed the processor because the USB interface was not recognized under windows and i couldn't program the board anymore. leds were lit but, so i thought that the samd must be broken.
                                          the new one shows the same behavior after flashing with mysensors 2.3.1 ... so it must be somewhere due to the software.
                                          can you please initiate the change to the "platform.txt" (see https://forum.mysensors.org/post/96909)?
