  2. Bug Reports
  3. Strange value being sent from controller using mixed temp/relay node
multiple sensormqtterror
42 Posts 6 Posters 22.8k Views 3 Watching
  • G
    G
    Gambituk
    I guess this probably should have been in troubleshooting :S
    • gaduG
      gaduG
      gadu
      Just guessing here, have you different child id's on the temp and relay?
      • G
        G
        Gambituk
        No it seems like they are given the same child id's. Ok, so maybe i'l look at how to force a different child id for each sensor/actuator
        • BulldogLowellB
          BulldogLowellB
          BulldogLowell
          the combining of the extensible sketches make it harder than needs to be.
          How many sensors are you connecting of each type?
          • G
            G
            Gambituk
            Hi, i have 3 temp sensors and 2 relays, I am just looking at how to make this work but am not making much progress. Cant figure out how to assign the child id's. Any help would be appreciated.
            • G
              G
              Gambituk
              was thinking of presenting the temps sensors first, and adding something like && i>NUMBER_OF_RELAYS to start assigining child id's above the range of relays? Will test and report back
              • G
                G
                Gambituk
                wrote on last edited by Gambituk
                I tried to modify the temp child presentation like this..... but it seemed to have no effect
                int offsetforrelays=5;   //(at start of sketch)
                // and this further down in the presentation for temp sensors
                 for (int i=0; i<(numSensors+offsetforrelays) && i<(MAX_ATTACHED_DS18B20+offsetforrelays) && i>offsetforrelays; i++) {
                     gw.present(i, V_TEMP);
                but so far it hasn't assigned any different id's to the temp sensors. Anyone got any pointers?
                • G Gambituk
                  BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  @Gambituk said:
                  #include <OneWire.h>presen
                  do you still have this typo in your code?
                  • G
                    G
                    Gambituk
                    no, i took it out (without effect) about an hour ago
                    • G Gambituk
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      @Gambituk
                      try something like this:
                      #define NUMBER_OF_TEMP_SENSORS 3
                        sensors.begin();
                        gw.sendSketchInfo("Temp and Relays", "1.0");
                        for (int i=0; i < NUMBER_OF_TEMP_SENSORS ; i++)
                          gw.present(i, V_TEMP); // creates 0, 1 and 2
                        for (int sensor=1, pin=RELAY_1 ; sensor <= NUMBER_OF_RELAYS ; sensor++ , pin++)
                          gw.present(NUMBER_OF_TEMP_SENSORS + sensor, S_LIGHT); // should create 3 and 4
                          pinMode(pin, OUTPUT);
                          digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
                      you will also have to sort out the sensor numbers in the callback
                      • G
                        G
                        Gambituk
                        0;0;3;0;9;read: 25-25-0 s=0,c=0,t=0,pt=0,l=5:1.4.1
                        0;0;3;0;9;read: 25-25-0 s=1,c=0,t=0,pt=0,l=5:1.4.1
                        0;0;3;0;9;read: 25-25-0 s=2,c=0,t=0,pt=0,l=5:1.4.1
                        0;0;3;0;9;read: 25-25-0 s=4,c=0,t=3,pt=0,l=5:1.4.1
                        0;0;3;0;9;read: 25-25-0 s=5,c=0,t=3,pt=0,l=5:1.4.1
                        So far it seems to create 0,1,2,4,5 but i think that's not going to be a problem, just working my way through to figure what else i need to change for the callback? (and what a callback is :D )
                        Thanks for the help so far!
                        • BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          the call back function:
                          incomingMessage()
                          look to get this right:
                          so that the command matches the sensor numbers...
                          G 1 Reply Last reply
                            incomingMessage()
                            G
                            G
                            Gambituk
                            @BulldogLowell
                            For the earlier part, should this be "for (int sensor=0" to get 3 and 4?
                            I get 4 and 5 ... But either way, i dont suppose it matters that there is a gap of 1 in the sensor child id's.
                            1. I change the callback to this:
                              digitalWrite(message.sensor - 4 + RELAY_1, message.getBool() ? RELAY_ON : RELAY_OFF);
                            and that works.... i can send a message and it activates the relay.. :D
                            1. BUT.... :(
                               repeater started, id 25
                               send: 25-25-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
                               send: 25-25-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                               read: 0-0-25 s=255,c=3,t=6,pt=0,l=1:M
                               send: 25-25-0-0 s=255,c=3,t=11,pt=0,l=15,st=ok:Temp and Relays
                               send: 25-25-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                               send: 25-25-0-0 s=0,c=0,t=0,pt=0,l=5,st=ok:1.4.1
                               send: 25-25-0-0 s=1,c=0,t=0,pt=0,l=5,st=ok:1.4.1
                               send: 25-25-0-0 s=2,c=0,t=0,pt=0,l=5,st=ok:1.4.1
                               send: 25-25-0-0 s=4,c=0,t=3,pt=0,l=5,st=ok:1.4.1
                               send: 25-25-0-0 s=5,c=0,t=3,pt=0,l=5,st=ok:1.4.1
                               send: 25-25-0-0 s=0,c=1,t=0,pt=7,l=5,st=ok:19.1
                            Here i am sending a message with 1 and then 0 to relay id4 and then the same to relay id5 -It works, but i still have the 1.3 and 0.3 values
                                read: 0-0-25 s=5,c=1,t=2,pt=0,l=4:1.3r
                                Incoming change for sensor:5
                                Incoming change for sensor:5, New status: 1
                                read: 0-0-25 s=5,c=1,t=2,pt=0,l=4:0.3r
                                Incoming change for sensor:5, New status: 0
                            And then it starts going even crazier, only seeing the status as 1 and received command is nothing like boolean so it see's 0's and 1's as only 1's
                                read: 0-0-25 s=4,c=1,t=2,pt=0,l=4:1.3r
                                Incoming change for sensor:4
                                Incoming change for sensor:4, New status: 1
                                read: 0-0-25 s=4,c=1,t=2,pt=0,l=4:0.3r
                                read: 0-0-25 s=5,c=1,t=2,pt=0,l=4:003r
                                read: 0-0-25 s=5,c=1,t=2,pt=0,l=4:013r
                                read: 0-0-25 s=4,c=1,t=2,pt=0,l=4:113r
                                read: 0-0-25 s=4,c=1,t=2,pt=0,l=4:013r
                            1. So i am thinking it is still a problem with what is sent from gateway somehow... :(
                            Any ideas
                            • G Gambituk
                              @BulldogLowell
                              1. BUT.... :(
                              Any ideas
                              BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              @Gambituk
                              would you mind posting your latest (sorta working) code?
                              • G
                                G
                                Gambituk
                                // Running DS temperature sensor(s) and relay(s) on one mysensor arduino node
                                // Combines Onewire and Relay code
                                // 2014-10-14 Pego: Tested and Running on Uno/Clone and MQTT gateway
                                    // Example sketch showing how to send in OneWire temperature readings
                                    // Example sketch showing how to control physical relays.
                                    // This example will remember relay state even after power failure.
                                    #define ONE_WIRE_BUS 3 // Pin where dallas sensor is connected
                                    #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                                    #define NUMBER_OF_RELAYS 2 // Total number of attached relays
                                    unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds) 30000 orig
                                    //int numSensors = 0;
                                    boolean receivedConfig = false;
                                    boolean metric = true;
                                    MyMessage msg(0, V_TEMP);
                                    //int offsetforrelays = 5;
                                      // Startup OneWire
                                      sensors.begin();
                                      gw.begin(incomingMessage, AUTO, true);        // Startup and initialize MySensors library. Set callback for incoming messages.
                                      gw.sendSketchInfo("Temp and Relays", "1.0");   // Send the sketch version information to the gateway and Controller
                                      for (int i = 0; i < NUMBER_OF_TEMP_SENSORS ; i++)
                                      for (int sensor = 1, pin = RELAY_1 ; sensor <= NUMBER_OF_RELAYS ; sensor++ , pin++)
                                        //   loop from sensor1/pin4 to sensor2/pin5 (numofrelays=2)
                                        digitalWrite(pin, gw.loadState(sensor) ? RELAY_ON : RELAY_OFF);
                                      // Process incoming messages (like config from server)
                                      for (int i = 0; i < NUMBER_OF_TEMP_SENSORS && i < MAX_ATTACHED_DS18B20; i++) {
                                        float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
                                        // Only send data if temperature has changed more then 1 degC and no error
                                        if (int(lastTemperature[i]) != int(temperature) && temperature != -127.00) { //added integer
                                          gw.send(msg.setSensor(i).set(temperature, 1));
                                          lastTemperature[i] = temperature;
                                      //gw.sleep(SLEEP_TIME); //no sleep for relays!!!!
                                        // Change relay state
                                        // Store state in eeprom
                                • G
                                  G
                                  Gambituk
                                  @BulldogLowell I just tried uploading a standard vanilla relay node, and i get the same garbled data instead of 1 and 0 (should have tried this at the start, but i am happy with what i have learned in the last 12 hours.) So it seems almost certain that it is an issue with the @gadu version of the mqtt gateway.. which is unaltered from the above post. #2 above
                                  • gaduG
                                    gaduG
                                    gadu
                                    Interesting findings, if you find any solution for this in the MQTT gateway I would really appreciate if you post it. I'm about to start implementing relays as well.
                                    (it's actually not my version, I think @ntruchsess is the one who created it) ;)
                                    • G
                                      G
                                      Gambituk
                                      @gadu if you have a setup running, could you publish a message on your mosquitto server just like this?
                                      MyMQTT/25/1/V_LIGHT 1
                                      MyMQTT/25/1/V_LIGHT 0
                                      I don't think it matters if you have any relays connected or defined, it's just to see what value it tries to send to the node... (assuming you have your gateway connected to a pc to be able to see the serial output)?
                                      No problems if this is not possible.
                                      gaduG 1 Reply Last reply
                                      • G
                                        G
                                        Gambituk
                                        I cannot see where the issue is coming from, the mqttgateway seems very straightforward, i think the answer might be in the libraries or some kind of conflict with the datatypes? it's a little over my head, but i would really love to get this working. :/
                                        • G
                                          G
                                          Gambituk
                                          #23
                                          // NOTE above : Beware to check if there is any length on payload in your incommingMessage code:
                                          // Example: if (msg.type==V_LIGHT && strlen(msg.getString())>0) otherwise the code might do strange things.
                                          I have a question regarding this line in MyMQTTClient.h that perhaps @hek or @ntruchsess might be able to comment on, Is the above issue that i am seeing linked to this warning? it is beyond my weak coding to grasp the implications... Or anyone who may have a comment, i would really love to get this to work!!!
