  2. Bug Reports
  3. Strange value being sent from controller using mixed temp/relay node
multiple sensormqtterror
42 Posts 6 Posters 22.9k Views 3 Watching
  • G Gambituk
    I tried to modify the temp child presentation like this..... but it seemed to have no effect
    int offsetforrelays=5;   //(at start of sketch)
    // and this further down in the presentation for temp sensors
     for (int i=0; i<(numSensors+offsetforrelays) && i<(MAX_ATTACHED_DS18B20+offsetforrelays) && i>offsetforrelays; i++) {
         gw.present(i, V_TEMP);
    but so far it hasn't assigned any different id's to the temp sensors. Anyone got any pointers?
    BulldogLowellB
    BulldogLowellB
    BulldogLowell
    @Gambituk said:
    #include <OneWire.h>presen
    do you still have this typo in your code?
    • G
      G
      Gambituk
      no, i took it out (without effect) about an hour ago
      • G Gambituk
        BulldogLowellB
        BulldogLowellB
        BulldogLowell
        @Gambituk
        try something like this:
        #define NUMBER_OF_TEMP_SENSORS 3
          sensors.begin();
          gw.sendSketchInfo("Temp and Relays", "1.0");
          for (int i=0; i < NUMBER_OF_TEMP_SENSORS ; i++)
            gw.present(i, V_TEMP); // creates 0, 1 and 2
          for (int sensor=1, pin=RELAY_1 ; sensor <= NUMBER_OF_RELAYS ; sensor++ , pin++)
            gw.present(NUMBER_OF_TEMP_SENSORS + sensor, S_LIGHT); // should create 3 and 4
            pinMode(pin, OUTPUT);
            digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
        you will also have to sort out the sensor numbers in the callback
        • G
          G
          Gambituk
          0;0;3;0;9;read: 25-25-0 s=0,c=0,t=0,pt=0,l=5:1.4.1
          0;0;3;0;9;read: 25-25-0 s=1,c=0,t=0,pt=0,l=5:1.4.1
          0;0;3;0;9;read: 25-25-0 s=2,c=0,t=0,pt=0,l=5:1.4.1
          0;0;3;0;9;read: 25-25-0 s=4,c=0,t=3,pt=0,l=5:1.4.1
          0;0;3;0;9;read: 25-25-0 s=5,c=0,t=3,pt=0,l=5:1.4.1
          So far it seems to create 0,1,2,4,5 but i think that's not going to be a problem, just working my way through to figure what else i need to change for the callback? (and what a callback is :D )
          Thanks for the help so far!
          • BulldogLowellB
            BulldogLowellB
            BulldogLowell
            the call back function:
            incomingMessage()
            look to get this right:
            so that the command matches the sensor numbers...
            G 1 Reply Last reply
              incomingMessage()
              G
              G
              Gambituk
              @BulldogLowell
              For the earlier part, should this be "for (int sensor=0" to get 3 and 4?
              I get 4 and 5 ... But either way, i dont suppose it matters that there is a gap of 1 in the sensor child id's.
              1. I change the callback to this:
                digitalWrite(message.sensor - 4 + RELAY_1, message.getBool() ? RELAY_ON : RELAY_OFF);
              and that works.... i can send a message and it activates the relay.. :D
              1. BUT.... :(
                 repeater started, id 25
                 send: 25-25-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
                 send: 25-25-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                 read: 0-0-25 s=255,c=3,t=6,pt=0,l=1:M
                 send: 25-25-0-0 s=255,c=3,t=11,pt=0,l=15,st=ok:Temp and Relays
                 send: 25-25-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                 send: 25-25-0-0 s=0,c=0,t=0,pt=0,l=5,st=ok:1.4.1
                 send: 25-25-0-0 s=1,c=0,t=0,pt=0,l=5,st=ok:1.4.1
                 send: 25-25-0-0 s=2,c=0,t=0,pt=0,l=5,st=ok:1.4.1
                 send: 25-25-0-0 s=4,c=0,t=3,pt=0,l=5,st=ok:1.4.1
                 send: 25-25-0-0 s=5,c=0,t=3,pt=0,l=5,st=ok:1.4.1
                 send: 25-25-0-0 s=0,c=1,t=0,pt=7,l=5,st=ok:19.1
              Here i am sending a message with 1 and then 0 to relay id4 and then the same to relay id5 -It works, but i still have the 1.3 and 0.3 values
                  read: 0-0-25 s=5,c=1,t=2,pt=0,l=4:1.3r
                  Incoming change for sensor:5
                  Incoming change for sensor:5, New status: 1
                  read: 0-0-25 s=5,c=1,t=2,pt=0,l=4:0.3r
                  Incoming change for sensor:5, New status: 0
              And then it starts going even crazier, only seeing the status as 1 and received command is nothing like boolean so it see's 0's and 1's as only 1's
                  read: 0-0-25 s=4,c=1,t=2,pt=0,l=4:1.3r
                  Incoming change for sensor:4
                  Incoming change for sensor:4, New status: 1
                  read: 0-0-25 s=4,c=1,t=2,pt=0,l=4:0.3r
                  read: 0-0-25 s=5,c=1,t=2,pt=0,l=4:003r
                  read: 0-0-25 s=5,c=1,t=2,pt=0,l=4:013r
                  read: 0-0-25 s=4,c=1,t=2,pt=0,l=4:113r
                  read: 0-0-25 s=4,c=1,t=2,pt=0,l=4:013r
              1. So i am thinking it is still a problem with what is sent from gateway somehow... :(
              Any ideas
              • G Gambituk
                @BulldogLowell
                1. BUT.... :(
                Any ideas
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @Gambituk
                would you mind posting your latest (sorta working) code?
                • G
                  G
                  Gambituk
                  // Running DS temperature sensor(s) and relay(s) on one mysensor arduino node
                  // Combines Onewire and Relay code
                  // 2014-10-14 Pego: Tested and Running on Uno/Clone and MQTT gateway
                      // Example sketch showing how to send in OneWire temperature readings
                      // Example sketch showing how to control physical relays.
                      // This example will remember relay state even after power failure.
                      #define ONE_WIRE_BUS 3 // Pin where dallas sensor is connected
                      #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                      #define NUMBER_OF_RELAYS 2 // Total number of attached relays
                      unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds) 30000 orig
                      //int numSensors = 0;
                      boolean receivedConfig = false;
                      boolean metric = true;
                      MyMessage msg(0, V_TEMP);
                      //int offsetforrelays = 5;
                        // Startup OneWire
                        sensors.begin();
                        gw.begin(incomingMessage, AUTO, true);        // Startup and initialize MySensors library. Set callback for incoming messages.
                        gw.sendSketchInfo("Temp and Relays", "1.0");   // Send the sketch version information to the gateway and Controller
                        for (int i = 0; i < NUMBER_OF_TEMP_SENSORS ; i++)
                        for (int sensor = 1, pin = RELAY_1 ; sensor <= NUMBER_OF_RELAYS ; sensor++ , pin++)
                          //   loop from sensor1/pin4 to sensor2/pin5 (numofrelays=2)
                          digitalWrite(pin, gw.loadState(sensor) ? RELAY_ON : RELAY_OFF);
                        // Process incoming messages (like config from server)
                        for (int i = 0; i < NUMBER_OF_TEMP_SENSORS && i < MAX_ATTACHED_DS18B20; i++) {
                          float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
                          // Only send data if temperature has changed more then 1 degC and no error
                          if (int(lastTemperature[i]) != int(temperature) && temperature != -127.00) { //added integer
                            gw.send(msg.setSensor(i).set(temperature, 1));
                            lastTemperature[i] = temperature;
                        //gw.sleep(SLEEP_TIME); //no sleep for relays!!!!
                          // Change relay state
                          // Store state in eeprom
                  • G
                    G
                    Gambituk
                    wrote on last edited by Gambituk
                    @BulldogLowell I just tried uploading a standard vanilla relay node, and i get the same garbled data instead of 1 and 0 (should have tried this at the start, but i am happy with what i have learned in the last 12 hours.) So it seems almost certain that it is an issue with the @gadu version of the mqtt gateway.. which is unaltered from the above post. #2 above
                    • gaduG
                      gaduG
                      gadu
                      Interesting findings, if you find any solution for this in the MQTT gateway I would really appreciate if you post it. I'm about to start implementing relays as well.
                      (it's actually not my version, I think @ntruchsess is the one who created it) ;)
                      • G
                        G
                        Gambituk
                        @gadu if you have a setup running, could you publish a message on your mosquitto server just like this?
                        MyMQTT/25/1/V_LIGHT 1
                        MyMQTT/25/1/V_LIGHT 0
                        I don't think it matters if you have any relays connected or defined, it's just to see what value it tries to send to the node... (assuming you have your gateway connected to a pc to be able to see the serial output)?
                        No problems if this is not possible.
                        gaduG 1 Reply Last reply
                        • G
                          G
                          Gambituk
                          I cannot see where the issue is coming from, the mqttgateway seems very straightforward, i think the answer might be in the libraries or some kind of conflict with the datatypes? it's a little over my head, but i would really love to get this working. :/
                          • G
                            G
                            Gambituk
                            #23
                            // NOTE above : Beware to check if there is any length on payload in your incommingMessage code:
                            // Example: if (msg.type==V_LIGHT && strlen(msg.getString())>0) otherwise the code might do strange things.
                            I have a question regarding this line in MyMQTTClient.h that perhaps @hek or @ntruchsess might be able to comment on, Is the above issue that i am seeing linked to this warning? it is beyond my weak coding to grasp the implications... Or anyone who may have a comment, i would really love to get this to work!!!
                              Not my code :)
                              I have no idea what does. Especially the special check for V_LIGHT seems a bit peculiar.
                              • G
                                G
                                Gambituk
                                Ok, well i guess you were listed on the sketch from before it was branched, but thanks for replying.
                                As an update to my struggles ;) i have found a workaround which might hint at a solution..
                                If i publish :
                                MyMQTT/25/5/V_LIGHT 0.0r
                                MyMQTT/25/5/V_LIGHT 1.0r
                                instead of
                                Then it seems that it overwrites the scraps of the previous temp readings that are causing trouble, and activates the relay everytime.
                                also.. interestingly if i publish 0.00r to my mqtt, then the gateway reads all the following temps with a trailing 0 eg 21.90 instead of 21.9 / or '1.9rr' instead of '1.9r' so it seems like it is storing a value somewhere and only overwriting the parts that are conflicting with the next received value.
                                • G Gambituk
                                  gaduG
                                  gaduG
                                  gadu
                                  Actually yes, I have a relay sketch that BulldogLowell helped me with in this thread:
                                  http://forum.mysensors.org/topic/901/relaywithbuttonactuator-another-n00b-question/7
                                  The idea behind the sketch is written in the thread, but the short story is that I needed two relays and when the button is pressed one goes on for a sec (then off) and the other goes on until i push the button again. So it's actually only controlling one relay, nothing else.
                                  By publishing...
                                  pi@raspberrypi ~ $ mosquitto_pub -r -t MyMQTT/23/1/V_LIGHT -m "1"
                                  pi@raspberrypi ~ $ mosquitto_pub -r -t MyMQTT/23/1/V_LIGHT -m "0"
                                  I can see the following...
                                  pi@raspberrypi ~ $ mosquitto_sub -v -t MyMQTT/#
                                  MyMQTT/23/1/V_LIGHT 1
                                  MyMQTT/23/1/V_LIGHT 0
                                  • G
                                    G
                                    Gambituk
                                    #27
                                    ah, sorry, @gadu i dont think i explained clearly... what i wanted to see was what happens in the serial monitor on the gateway when those values are published (what gets sent over nrf to the node). thanks for trying that, i understand if you cant get serial monitor output. but if it was possible, i would really appreciate it
                                    • gaduG
                                      gaduG
                                      gadu
                                      I'll get tomorrow. No worries :)
                                      • G
                                        G
                                        Gambituk
                                        Thanks! That would be really useful
                                        • gaduG
                                          gaduG
                                          gadu
                                          Here goes...
                                          This is the ProMini output from the monitor when I turn on and off the relay...
                                          send: 23-23-0-0 s=1,c=1,t=2,pt=2,l=2,st=ok:1
                                          read: 0-0-23 s=1,c=1,t=2,pt=2,l=2:1
                                          This is an ack from gateway
                                          Incoming change for sensor:1, New status: 1
                                          read: 0-0-23 s=1,c=1,t=2,pt=0,l=4:1.6r
                                          send: 23-23-0-0 s=1,c=1,t=2,pt=2,l=2,st=ok:0
                                          read: 0-0-23 s=1,c=1,t=2,pt=2,l=2:0
                                          Incoming change for sensor:1, New status: 0
                                          read: 0-0-23 s=1,c=1,t=2,pt=0,l=4:0.6r
                                          This what I see on the gateway when I turn on and off the relay....
                                          publish: MyMQTT/23/1/V_LIGHT 1
                                          0;0;3;0;9;send: 0-0-23-23 s=1,c=1,t=2,pt=0,l=4,st=ok:1sor
                                          0;0;3;0;9;read: 23-23-0 s=1,c=1,t=2,pt=2,l=2:0
                                          0;0;3;0;9;send: 0-0-23-23 s=1,c=1,t=2,pt=2,l=2,st=ok:0
                                          publish: MyMQTT/23/1/V_LIGHT 0
                                          0;0;3;0;9;send: 0-0-23-23 s=1,c=1,t=2,pt=0,l=4,st=ok:0sor
                                          0;0;3;0;9;read: 23-23-0 s=1,c=1,t=2,pt=2,l=2:1
                                          0;0;3;0;9;send: 0-0-23-23 s=1,c=1,t=2,pt=2,l=2,st=ok:1
                                          I hope it helps.
