  3. Was läuft falsch?What's wrong?
5 Posts 3 Posters 1.6k Views 3 Watching
  • aDm1NA
    aDm1NA
    aDm1N
    wrote on last edited by aDm1N
    Hallo
    Hello
    Ich habe diesen Sketch :
    i have this sketch :
    //ds18b20 & DHT
    #include <OneWire.h>
    #define CHILD_ID_MOISTURE1 0
    #define CHILD_ID_MOISTURE2 1
    #define CHILD_ID_MOISTURE3 2
    #define CHILD_ID_MOISTURE4 3
    //#define CHILD_ID_BATTERY 1
    #define SENSOR_ANALOG_PIN 0
    #define SENSOR_ANALOG_PIN1 1
    #define SENSOR_ANALOG_PIN2 2
    #define SENSOR_ANALOG_PIN3 3
    #define SENSOR_POWER_PIN 8
    //#define SLEEP_TIME 600000 // Sleep time between reads (in milliseconds) (=10 MINUTES)
    #define STABILIZATION_TIME 500 // Let the sensor stabilize before reading
    //#define BATTERY_FULL 3700 // 3,700 millivolts
    //#define BATTERY_ZERO 1700 // 1,700 millivolts
    //ds18b20 & DHT
    #define MAX_ATTACHED_DS18B20 10
    #define ONE_WIRE_BUS 6
    #define DHT1_DATA_PIN 7
    #define CHILD_ID_DHT1HUM 6
    #define CHILD_ID_DHT1TEMP 7
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 3000;
    unsigned long SLEEP_TIME = 30000;
    boolean receivedConfig = false;
    boolean metric = true;
    int numSensors=0;
    MyMessage msgDallas(0,V_TEMP);
    MyMessage msg6DHT1Temp(CHILD_ID_DHT1TEMP,V_TEMP);
    MyMessage msg7DHT1Hum(CHILD_ID_DHT1HUM,V_HUM);
    DHT dht;
    MyMessage msg1(CHILD_ID_MOISTURE1, V_HUM);
    MyMessage msg2(CHILD_ID_MOISTURE2, V_HUM);
    MyMessage msg3(CHILD_ID_MOISTURE3, V_HUM);
    MyMessage msg4(CHILD_ID_MOISTURE4, V_HUM);
    //MyMessage voltage_msg(CHILD_ID_BATTERY, V_VOLTAGE);
    int lastsoilValue1 = 0;
    int lastsoilValue2 = 0;
    int lastsoilValue3 = 0;
    int lastsoilValue4 = 0;
    //ds18b20 & DHT
    void before()
      sensors.begin();
      gw.begin();
      //ds18b20 & DHT
      for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++)
         gw.present(i, S_TEMP);
      gw.present(CHILD_ID_DHT1TEMP,S_TEMP);
      gw.present(CHILD_ID_DHT1HUM,S_HUM);
      pinMode(SENSOR_POWER_PIN, OUTPUT);
      gw.sendSketchInfo("Bodenfeuchte, Temperatur und Temp-Hum w bat", "1.0");
      gw.present(CHILD_ID_MOISTURE1, S_HUM);
      gw.present(CHILD_ID_MOISTURE2, S_HUM);
      gw.present(CHILD_ID_MOISTURE3, S_HUM);
      gw.present(CHILD_ID_MOISTURE4, S_HUM);
      //delay(250);
      //gw.present(CHILD_ID_BATTERY, S_CUSTOM);
      //ds18b20 & DHT
      gw.sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
      gw.send(msgDallas.setSensor(i).set(temperature,1));
          #ifdef MY_DEBUG
          Serial.print("Dallas");
          Serial.print(i);
          Serial.print(" :");
    //  sleep(SLEEP_TIME);
      dht.setup(DHT1_DATA_PIN); // set data pin of DHT1 sensor
      gw.sleep(dht.getMinimumSamplingPeriod());
      //dht.readSensor(true);
      float dht1temperature = dht.getTemperature();
      if (isnan(dht1temperature)) {
      } else
        if (!metric) {
          dht1temperature = dht.toFahrenheit(dht1temperature);
        dht1temperature += SENSOR_TEMP_OFFSET;
        gw.send(msg6DHT1Temp.set(dht1temperature, 1));
        #ifdef MY_DEBUG
        Serial.print("DHT1TEMP: ");
        Serial.println(dht1temperature);
      gw.sleep(UPDATE_INTERVAL);
      float dht1humidity = dht.getHumidity();
      if (isnan(dht1humidity)) {
      else {
       gw.send(msg7DHT1Hum.set(dht1humidity, 1));
        #ifdef MY_DEBUG
        Serial.print("DHT1HUM: ");
        Serial.println(dht1humidity);
      //DHT Ende
      digitalWrite(SENSOR_POWER_PIN, HIGH); // Power on the sensors
      gw.sleep(STABILIZATION_TIME);     //stabilization before mesuring
      int moistureLevel = (1023 - analogRead(SENSOR_ANALOG_PIN)) / 10.23; // read moisture of the first sensor
      if (moistureLevel != lastsoilValue1) {                //test if moisture is different than before
        gw.send(msg1.set(moistureLevel));                  //send to controller moisture level of sensor 1
        lastsoilValue1 = moistureLevel;
      int moistureLevel1 = (1023 - analogRead(SENSOR_ANALOG_PIN1)) / 10.23; // read moisture of the second sensor
      if (moistureLevel1 != lastsoilValue2) {                 //test if moisture is different than before
        gw.send(msg2.set(moistureLevel1));                  //send to controller moisture level of sensor 2
        lastsoilValue2 = moistureLevel1;
      int moistureLevel2 = (1023 - analogRead(SENSOR_ANALOG_PIN2)) / 10.23; // read moisture of the third sensor
      if (moistureLevel2 != lastsoilValue3) {                 //test if moisture is different than before
        gw.send(msg3.set(moistureLevel2));                  //send to controller moisture level of sensor 3
        lastsoilValue3 = moistureLevel2;
      int moistureLevel3 = (1023 - analogRead(SENSOR_ANALOG_PIN3)) / 10.23; // read moisture of fourth sensor
      if (moistureLevel3 != lastsoilValue4) {               //test if moisture is different than before
        gw.send(msg4.set(moistureLevel3));                  //send to controller moisture level of sensor 4
        lastsoilValue3 = moistureLevel3;
      //debugging comment it when dont use
      Serial.print("first plant :");
      Serial.println(moistureLevel);
      Serial.print("second plant :");
      Serial.println(moistureLevel1);
      Serial.print("third plant :");
      Serial.println(moistureLevel2);
      Serial.print("fourth plant :");
      Serial.println(moistureLevel3);
      digitalWrite(SENSOR_POWER_PIN, LOW); //spower off sensors
      //long voltage = readVcc();
      //gw.send(voltage_msg.set(voltage / 1000.0, 3)); // redVcc returns millivolts and set wants volts and how many decimals (3 in our case)
      //gw.sendBatteryLevel(round((voltage - BATTERY_ZERO) * 100.0 / (BATTERY_FULL - BATTERY_ZERO)));
      gw.sleep(SLEEP_TIME);
    /*long readVcc()
      // From http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
    Das ist die ausgabe des Seriellen Monitor :
    This is the serial monitor:
    send: 6-6-1-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
    send: 6-6-1-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=fail:1.5.4
    send: 6-6-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:1
    sensor started, id=6, parent=1, distance=2
    send: 6-6-1-0 s=7,c=0,t=6,pt=0,l=0,sg=0,st=ok:
    send: 6-6-1-0 s=6,c=0,t=7,pt=0,l=0,sg=0,st=ok:
    send: 6-6-1-0 s=255,c=3,t=11,pt=0,l=25,sg=0,st=ok:Bodenfeuchte, Temperatur
    send: 6-6-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
    send: 6-6-1-0 s=0,c=0,t=7,pt=0,l=0,sg=0,st=ok:
    send: 6-6-1-0 s=1,c=0,t=7,pt=0,l=0,sg=0,st=ok:
    send: 6-6-1-0 s=2,c=0,t=7,pt=0,l=0,sg=0,st=fail:
    send: 6-6-1-0 s=3,c=0,t=7,pt=0,l=0,sg=0,st=ok:
    send: 6-6-1-0 s=7,c=1,t=0,pt=7,l=5,sg=0,st=ok:18.8
    send: 6-6-1-0 s=6,c=1,t=1,pt=7,l=5,sg=0,st=ok:25.2
    send: 6-6-1-0 s=0,c=1,t=1,pt=2,l=2,sg=0,st=fail:86
    send: 6-6-1-0 s=1,c=1,t=1,pt=2,l=2,sg=0,st=fail:86
    send: 6-6-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0,st=fail:86
    send: 6-6-1-0 s=3,c=1,t=1,pt=2,l=2,sg=0,st=fail:86
    first plant :86
    second plant :86
    third plant :86
    fourth plant :86
    Das ist der Verdrarungsplan dazu :
    This is the wiring :
    • tbowmoT
      tbowmoT
      tbowmo
      Could you please keep it in English in here, as more people would be able to help, and benefit from the conversations.
      Also try reformatting your code, using the inline code format, it makes it much easier to read your code
      • aDm1NA
        aDm1NA
        aDm1N
        is it better like this?
        • aDm1NA aDm1N
          @adm1n try adding gw.wait(200) after each send. Sending many messages quickly often strains the power supply too much. Waiting a bit gives the power supply time to recover.
          What size of capacitors are you using? Adding a larger capacitor in paralell to the existing capacitor can also help stabilize the power supply.
          If you haven’t already, see https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for the most common problems and how to troubleshoot them.
          Note that the sketch is using MySensors 1.x. That’s why the syntax and debug output is different from todays code.
          • aDm1NA
            aDm1NA
            aDm1N
            Danke schon mal für die Hilfe.
            Thank you in advance for the help.
            Ich bin jetzt so weit das alle Daten gesendet werden, bis auf die ds18b20. Ich habe die Verkabelung überprüft, kann jedoch keinen Fehler finden. Bin ich Blind? Sieht jemand eventuell einen Fehler in dem Sketch?
            I am now so far that all data is sent, except for the ds18b20. I have checked the cabling but can not find a fault. Am I blind? Does anyone see an error in the sketch?
            //ds18b20 & DHT
            #define STABILIZATION_TIME 300 // Let the sensor stabilize before reading
            //ds18b20 & DHT
            #define MAX_ATTACHED_DS18B20 6
            int numSensors=0;
            DHT dht;
            //ds18b20 & DHT
            void before()
              sensors.begin();
              gw.begin();
              gw.sendSketchInfo("Bodenfeuchte_Temperatur_Hum", "1.0");
              //ds18b20 & DHT
              sensors.setWaitForConversion(true);
              delay(250);
              //ds18b20 & DHT
                  //#ifdef MY_DEBUG
                  Serial.print(i);
                  Serial.print(" :");
                  //#endif
                  gw.wait(200);
            //  dht.readSensor(false);
              } else
                if (!metric) {
                //#ifdef MY_DEBUG
                //#endif
              else {
                //#ifdef MY_DEBUG
                //#endif
              //gw.wait(300);
              //DHT Ende
              //gw.wait(500);
                gw.wait(200);
                gw.wait(200);
                gw.wait(200);
                gw.wait(200);
            /*long readVcc()
            send: 6-6-1-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.4
            read: 0-1-6 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            read: 0-1-6 s=255,c=3,t=6,pt=0,l=1,sg=0:M
            send: 6-6-1-0 s=255,c=3,t=11,pt=0,l=25,sg=0,st=ok:Bodenfeuchte_Temperatur_H
            send: 6-6-1-0 s=7,c=1,t=0,pt=7,l=5,sg=0,st=ok:18.3
            DHT1TEMP: 18.30
            send: 6-6-1-0 s=6,c=1,t=1,pt=7,l=5,sg=0,st=ok:25.0
            DHT1HUM: 25.00
            first plant :0
            second plant :0
            third plant :0
            fourth plant :0
