  3. Home Assistant
  4. sendBatteryLevel not showing up in HA dasboard
15 Posts 4 Posters 4.3k Views 3 Watching
    @peerv could it be related to https://forum.mysensors.org/topic/8838/sendbatterylevel-and-child-sensor-problems/7 ?
    P
    P
    peerv
    @mfalkvidd I had seen that discussion on the mysensors forum.
    I my case the battery level % shows up correctly in the HA entities list attributes.
    It just does not show up on the HA Console.
    Have never seen it on the HA Console. What should I expect to see?
    • P
      P
      peerv
      Can anybody help my with how to display the MySensors sendBatteryLevel percentage on the HA user interface.
      The percentage appears correctly in Home Assistant Developertools - States- Attrributes.
      how to get this attribute displayed on the UI?
      AlaskaDIYA 1 Reply Last reply
      • P peerv
        AlaskaDIYA
        AlaskaDIYA
        AlaskaDIY
        @peerv Any luck with getting it working?
        P 1 Reply Last reply
        • AlaskaDIYA AlaskaDIY
          P
          P
          peerv
          @alaskadiy No solution still.... I doubt if it has been implemented in the interface
          • P peerv
            @peerv for Domoticz, a workaround is to present a separate child id. Maybe that could work for you as well? See https://github.com/mfalkvidd/arduino-plantmoisture/blob/65165ada9b265d4218ef10952ea06b13d6cfdb38/arduino-plantmoisture.ino#L29
              P
              P
              peerv
              @mfalkvidd
              Thanks, yes your solution could work. Also a voltage divider with a seperate child-id could work.
              But my point is that the Arduino battery_level value is already available in the mysensors.json in Home Assistant.
              "type": 17,
                      "sketch_name": "N60Breed",
                      "sketch_version": "1.0",
                      "battery_level": 91,
                      "protocol_version": "2.3.1",
                      "heartbeat": 0
              I just don't know how to get the battery_level value presented in the HA UI.
              • P peerv
                @mfalkvidd
                "type": 17,
                        "heartbeat": 0
                mvader
                @peerv said in sendBatteryLevel not showing up in HA dasboard:
                @mfalkvidd
                "type": 17,
                        "heartbeat": 0
                you have to use a template.
                under the sensors section
                • platform: template
                  sensors:
                  computer_room_15_0:
                  unit_of_measurement: "%"
                  entity_id: sensor.computer_room_15_1
                  icon_template: mdi:battery
                  value_template: >-
                  {%- if states.sensor.computer_room_15_1 != None -%}
                  {{states.sensor.computer_room_15_1.attributes.battery_level}}
                  {%- else -%}
                  {%- endif -%}
                  mvader
                    mvader
                    then under groups
                    computer_room_group:
                    entities:
                    - sensor.computer_room_15_0
                    - sensor.computer_room_15_1
                    - sensor.computer_room_15_2
                    - binary_sensor.computer_room_15_3
                    - sensor.computer_room_15_4
                    • M mvader
                      @mfalkvidd
                      "type": 17,
                              "heartbeat": 0
                        sensors:
                        computer_room_15_0:
                        value_template: >-
                        {%- else -%}
                        {%- endif -%}
                      P
                      P
                      peerv
                      @mvader Thanks, have a problem translating you example to my situation
                      This is the card were I want to add the battery_level:
                       - type: entities
                              title: Levelmeter breed
                              show_header_toggle: false
                              entities:
                                - entity: sensor.n60breed_20_54
                                  icon: mdi:battery
                                - entity: sensor.n60breed_20_50
                                  icon: mdi:temperature-celsius
                                - entity: sensor.n60breed_20_51
                                  icon: mdi:water-percent
                                - entity: sensor.n60breed_20_52
                                - entity: sensor.n60breed_20_53
                      I played around with the following entry in configuration.yaml
                      sensor:
                        - platform: template
                          sensors:
                          n60breed_20_55:
                          entity_id: sensor.n60breed_20_53
                          value_template: "{{ states.sensor.n60breed_20_53.attributes.battery_level }}"
                          unit_of_measurement: '%'
                      but could not get it to work! Did not find any docs on platform Template.
                      Please advice
                      • P peerv
                         - type: entities
                                entities:
                                    icon: mdi:battery
                        sensor:
                            sensors:
                            n60breed_20_55:
                        Please advice
                        mvader
                        @peerv in my situation, if i click on any of my child devices, like temp, lux, humidity, etc. i can see the battery level. so i have to create a new sensor, in this case i'm creating computer_room_15_0, and i pull the value from child 1, i could pull it from 2,3 or 4, but i chose 1. and the value that i'm pulling is an attribute of child 1 called battery_level
                        now that i have created that sensor. i can place it where ever i want.
                        so the newly created sensor computer_room_15_0 is my entity_id that can go in a card or whatever.
                        before you do that, i would trouble shoot in the following way.
                        1. pick a child device and open it, ensure you can see the battery level.
                        2. create a new sensor based on the template above (restart after)
                        3. go into the the states dev tool page and ensure it's there and has the correct value.
                        4. if yes, then open the standard states based screen see if it shows up at the top in the circle.
                        5. if yes, put that entity in your lovelace ui as you see fit, if no, go back and figure out where it's not working.
                          you can also tail the log file and you restart and look for any error messages that may offer a clue to why.
                          here is my states screen for the battery sensor.
                        • M mvader
                          P
                          P
                          peerv
                          @mvader Thanks, got it working. Your explanation and the right indentions (:angry: ) did it!
