  3. MY_GATEWAY_TINYGSM
MY_GATEWAY_TINYGSM
14 Posts 8 Posters 5.8k Views 9 Watching
  • ThucarT
    ThucarT
    Thucar
     * Version 1.0 - Rait Lotamõis
    //Running on Mega
    #define MY_RF24_CE_PIN 49
    #define MY_RF24_CS_PIN 53
    #define MY_GATEWAY_TINYGSM
    // Define the GSM modem
    #define TINY_GSM_MODEM_A6
    #define MY_GSM_APN "internet"
    //#define MY_GSM_USR ""
    //#define MY_GSM_PSW ""
    //#define MY_GSM_PIN "0000"
    // Use Hardware Serial on Mega, Leonardo, Micro
    #define SerialAT Serial3
    // or Software Serial on Uno, Nano
    //#define MY_GSM_RX 4
    //#define MY_GSM_TX 5
    // Set your modem baud rate or comment it out for auto detection
    //#define MY_GSM_BAUDRATE 115200
    #define MY_PORT 5003
    #define MY_CONTROLLER_URL_ADDRESS "xxx.yyyyyyy.com"
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    Controller: Node-Red
    Gateway: SerialGateway & GSMMQTTGateway
    MySensors: 2.2.0
    • ThucarT
      ThucarT
      Thucar
      It is alive!!!
      MQTT Client gateway with GSM modems and ESP8266 as a modem seems to be working as intended.
      To replicate, do this:
      • Install the TinyGSM library
      • Use this MyGatewayTransportMQTTClient.cpp
      * Copyright (C) 2013-2017 Sensnology AB
      // Topic structure: MY_MQTT_PUBLISH_TOPIC_PREFIX/NODE-ID/SENSOR-ID/CMD-TYPE/ACK-FLAG/SUB-TYPE
      #include "MyGatewayTransport.h"
      #if defined MY_CONTROLLER_IP_ADDRESS
      IPAddress _brokerIp(MY_CONTROLLER_IP_ADDRESS);
      #if defined(MY_IP_ADDRESS)
      IPAddress _MQTT_clientIp(MY_IP_ADDRESS);
      #if defined(MY_IP_GATEWAY_ADDRESS)
      IPAddress _gatewayIp(MY_IP_GATEWAY_ADDRESS);
      #elif defined(MY_GATEWAY_ESP8266) /* Elif part of MY_IP_GATEWAY_ADDRESS */
      // Assume the gateway will be the machine on the same network as the local IP
      // but with last octet being '1'
      IPAddress _gatewayIp(_MQTT_clientIp[0], _MQTT_clientIp[1], _MQTT_clientIp[2], 1);
      #endif /* End of MY_IP_GATEWAY_ADDRESS */
      #if defined(MY_IP_SUBNET_ADDRESS)
      IPAddress _subnetIp(MY_IP_SUBNET_ADDRESS);
      #elif defined(MY_GATEWAY_ESP8266) /* Elif part of MY_IP_SUBNET_ADDRESS */
      IPAddress _subnetIp(255, 255, 255, 0);
      #endif /* End of MY_IP_SUBNET_ADDRESS */
      #endif /* End of MY_IP_ADDRESS */
      #if defined(MY_GATEWAY_ESP8266)
      #define EthernetClient WiFiClient
      #elif defined(MY_GATEWAY_LINUX)
      // Nothing to do here
      uint8_t _MQTT_clientMAC[] = { MY_MAC_ADDRESS };
      #endif /* End of MY_GATEWAY_ESP8266 */
      #ifdef MY_GATEWAY_TINYGSM
      #include <TinyGsmClient.h>
      static TinyGsm modem(SerialAT);
      static TinyGsmClient _MQTT_gsmClient(modem);
      static PubSubClient _MQTT_client(_MQTT_gsmClient);
      #if defined(MY_GSM_BAUDRATE)
      uint32_t rate = MY_GSM_BAUDRATE;
      uint32_t rate = 0;
      static EthernetClient _MQTT_ethClient;
      static PubSubClient _MQTT_client(_MQTT_ethClient);
      #endif /* End of MY_GATEWAY_TINYGSM */
      static bool _MQTT_connecting = true;
      static bool _MQTT_available = false;
      static MyMessage _MQTT_msg;
      bool gatewayTransportSend(MyMessage &message)
      	if (!_MQTT_client.connected()) {
      		return false;
      	setIndication(INDICATION_GW_TX);
      	char *topic = protocolFormatMQTTTopic(MY_MQTT_PUBLISH_TOPIC_PREFIX, message);
      	GATEWAY_DEBUG(PSTR("GWT:TPS:TOPIC=%s,MSG SENT\n"), topic);
      #if defined(MY_MQTT_CLIENT_PUBLISH_RETAIN)
      	bool retain = mGetCommand(message) == C_SET ||
      	              (mGetCommand(message) == C_INTERNAL && message.type == I_BATTERY_LEVEL);
      	bool retain = false;
      #endif /* End of MY_MQTT_CLIENT_PUBLISH_RETAIN */
      	return _MQTT_client.publish(topic, message.getString(_convBuffer), retain);
      void incomingMQTT(char* topic, uint8_t* payload, unsigned int length)
      	GATEWAY_DEBUG(PSTR("GWT:IMQ:TOPIC=%s, MSG RECEIVED\n"), topic);
      	_MQTT_available = protocolMQTTParse(_MQTT_msg, topic, payload, length);
      bool reconnectMQTT(void)
      	GATEWAY_DEBUG(PSTR("GWT:RMQ:MQTT RECONNECT\n"));
      	// Attempt to connect
      	if (_MQTT_client.connect(MY_MQTT_CLIENT_ID
      #if defined(MY_MQTT_USER) && defined(MY_MQTT_PASSWORD)
      	                         , MY_MQTT_USER, MY_MQTT_PASSWORD
      		GATEWAY_DEBUG(PSTR("GWT:RMQ:MQTT CONNECTED\n"));
      		// Send presentation of locally attached sensors (and node if applicable)
      		presentNode();
      		// Once connected, publish an announcement...
      		//_MQTT_client.publish("outTopic","hello world");
      		// ... and resubscribe
      		_MQTT_client.subscribe(MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "/+/+/+/+/+");
      		return true;
      	return false;
      bool gatewayTransportConnect(void)
      	while (WiFi.status() != WL_CONNECTED) {
      		wait(500);
      		GATEWAY_DEBUG(PSTR("GWT:TPC:CONNECTING...\n"));
      	GATEWAY_DEBUG(PSTR("GWT:TPC:IP=%s\n"),WiFi.localIP().toString().c_str());
      #elif defined(MY_GATEWAY_LINUX) /* Elif part of MY_GATEWAY_ESP8266 */
      	_MQTT_ethClient.bind(_MQTT_clientIp);
      #elif defined(MY_GATEWAY_TINYGSM)
          GATEWAY_DEBUG(PSTR("GWT:TPC:IP=%s\n"), modem.getLocalIP().c_str());
      #else /* Else part of MY_GATEWAY_ESP8266 */
      	Ethernet.begin(_MQTT_clientMAC, _MQTT_clientIp);
      #else /* Else part of MY_IP_ADDRESS */
      	// Get IP address from DHCP
      	if (!Ethernet.begin(_MQTT_clientMAC)) {
      		GATEWAY_DEBUG(PSTR("!GWT:TPC:DHCP FAIL\n"));
      		_MQTT_connecting = false;
      		return false;
      	GATEWAY_DEBUG(PSTR("GWT:TPC:IP=%" PRIu8 ".%" PRIu8 ".%" PRIu8 ".%" PRIu8 "\n"),
      	              Ethernet.localIP()[0],
      	              Ethernet.localIP()[1], Ethernet.localIP()[2], Ethernet.localIP()[3]);
      	// give the Ethernet interface a second to initialize
      	delay(1000);
      	return true;
      bool gatewayTransportInit(void)
      #if defined(MY_GATEWAY_TINYGSM)
      #if defined(MY_GSM_RX) && defined(MY_GSM_TX)
      	SoftwareSerial SerialAT(MY_GSM_RX, MY_GSM_TX);
      	// TODO: Needs sanity checks
      #if !defined(MY_GSM_BAUDRATE)
      	rate = TinyGsmAutoBaud(SerialAT);
      	SerialAT.begin(rate);
      	delay(3000);
      	modem.restart();
      #if defined(MY_GSM_PIN) && !defined(TINY_GSM_MODEM_ESP8266)
      	modem.simUnlock(MY_GSM_PIN);
      #ifndef TINY_GSM_MODEM_ESP8266
      	if (!modem.waitForNetwork()) {
      		GATEWAY_DEBUG(PSTR("!GWT:TIN:GPRS FAIL\n"));
      		while (true);
      	GATEWAY_DEBUG(PSTR("GWT:TIN:GPRS OK\n"));
      	if (!modem.gprsConnect(MY_GSM_APN, MY_GSM_USR, MY_GSM_PSW)) {
      		GATEWAY_DEBUG(PSTR("!GWT:TIN:APN FAIL\n"));
      		while (true);
      	GATEWAY_DEBUG(PSTR("GWT:TIN:APN OK\n"));
      	delay(1000);
          if (!modem.networkConnect(MY_GSM_SSID, MY_GSM_PSW)) {
              GATEWAY_DEBUG(PSTR("!GWT:TIN:WIFI AP FAIL\n"));
              while (true);
            GATEWAY_DEBUG(PSTR("GWT:TIN:WIFI AP OK\n"));
            delay(1000);
      #if defined(MY_CONTROLLER_IP_ADDRESS)
      	_MQTT_client.setServer(_brokerIp, MY_PORT);
      	_MQTT_client.setServer(MY_CONTROLLER_URL_ADDRESS, MY_PORT);
      #endif /* End of MY_CONTROLLER_IP_ADDRESS */
      	_MQTT_client.setCallback(incomingMQTT);
      	// Turn off access point
      	WiFi.mode(WIFI_STA);
      #if defined(MY_ESP8266_HOSTNAME)
      	WiFi.hostname(MY_ESP8266_HOSTNAME);
      #endif /* End of MY_ESP8266_HOSTNAME */
      	WiFi.config(_MQTT_clientIp, _gatewayIp, _subnetIp);
      #ifndef MY_ESP8266_BSSID
      #define MY_ESP8266_BSSID NULL
      	(void)WiFi.begin(MY_ESP8266_SSID, MY_ESP8266_PASSWORD, 0, MY_ESP8266_BSSID);
      	gatewayTransportConnect();
      	return true;
      bool gatewayTransportAvailable(void)
      	if (_MQTT_connecting) {
      		return false;
      	//keep lease on dhcp address
      	//Ethernet.maintain();
      		//reinitialise client
      		if (gatewayTransportConnect()) {
      			reconnectMQTT();
      		return false;
      	_MQTT_client.loop();
      	return _MQTT_available;
      MyMessage & gatewayTransportReceive(void)
      	// Return the last parsed message
      	return _MQTT_msg;
      • Define these in your gateway sketch:
      // Define the GSM modem. See TinyGSM documentation for full list
      //#define TINY_GSM_MODEM_ESP8266
      #define MY_GSM_APN "internet" // your mobile providers APN
      #define MY_GSM_USR "" // Leave empty if not used
      #define MY_GSM_PIN "" // Leave empty if not used
      #define MY_GSM_PSW "" // This is either your mobile providers password or WiFi password, depending if you are using the ESP8266 or a GSM modem
      #define MY_GSM_SSID ""
      #define SerialAT Serial1
      #define MQTT_VERSION MQTT_VERSION_3_1 // I apparently need this to be able to run mosquitto
      MySensors: 2.2.0
      gohanG 1 Reply Last reply
      • ThucarT Thucar
        It is alive!!!
        uint32_t rate = 0;
        		return false;
        		presentNode();
        		return true;
        	return false;
        		wait(500);
        		return false;
        	delay(1000);
        	return true;
        	delay(3000);
        	modem.restart();
        		while (true);
        		while (true);
        	delay(1000);
                while (true);
              delay(1000);
        	return true;
        		return false;
        			reconnectMQTT();
        		return false;
        	return _MQTT_msg;
        @thucar said in MY_GATEWAY_TINYGSM:
        Did you mean esp8266 as gateway or...? BTW great job :+1:
        ThucarT 1 Reply Last reply
          ThucarT
          ThucarT
          Thucar
          wrote on last edited by Thucar
          @gohan said in MY_GATEWAY_TINYGSM:
          Nope, ESP8266 is a modem in this scenario. So in my case I'm using an Arduino Mega 2560 with loads of IOs as the gateway and the ESP8266 as a Wifi modem for connectivity. No sketch is uploaded on the ESP and the only connections used (in addition to power and ground of course) are TX/RX from ESP to the Arduino.
          MySensors: 2.2.0
          J 1 Reply Last reply
          • A
            astron
            Hello.
            Is it possible to add support for the gateway with TinyGSM without MQTT?
            Controller IoBroker can work in server mode for a gateway with TinyGSM.
            • ThucarT Thucar
              J
              J
              jkandasa
              @thucar Great work! Thank you!
              I am using MY_GATEWAY_TINYGSM from a month ago. I face Gateway hangs after a week and it needs a hard reboot(Power OFF and ON). Are you facing any issue similar to this?
              My Hardware details:
              • ESP8266 (ESP-12E)
              • RFM69HW
              • SIM800L
              To power up GSM modem I am using 1500mA 18650 battery with charger board.
              Can you share your hardware details?
              • J jkandasa
                • ESP8266 (ESP-12E)
                • RFM69HW
                • SIM800L
                J
                J
                jkandasa
                After some days, internet connection disconnected(identified via SIM800L LED blink status), but still, ESP says all ok. I lost communication from controller too.
                193617834 RFM69:SAC:SEND ACK,TO=11,RSSI=-57
                193617847 RFM69:CSMA:RSSI=-107
                193617866 TSF:MSG:READ,12-11-0,s=255,c=3,t=0,pt=1,l=1,sg=0:48
                193617882 GWT:TPS:TOPIC=out_rfm69/12/255/3/0/0,MSG SENT
                193629390 RFM69:SAC:SEND ACK,TO=1,RSSI=-82
                193629403 RFM69:CSMA:RSSI=-107
                193629421 TSF:MSG:READ,1-1-0,s=1,c=1,t=25,pt=1,l=1,sg=0:64
                193629437 GWT:TPS:TOPIC=out_rfm69/1/1/1/0/25,MSG SENT
                193629735 RFM69:SAC:SEND ACK,TO=1,RSSI=-49
                193629747 RFM69:CSMA:RSSI=-106
                193629766 TSF:MSG:READ,1-1-0,s=1,c=1,t=35,pt=7,l=5,sg=0:70.60
                193629782 GWT:TPS:TOPIC=out_rfm69/1/1/1/0/35,MSG SENT
                193650334 RFM69:SAC:SEND ACK,TO=11,RSSI=-98
                193650347 RFM69:CSMA:RSSI=-103
                193650366 TSF:MSG:READ,11-11-0,s=1,c=1,t=0,pt=7,l=5,sg=0:30.75
                193650382 GWT:TPS:TOPIC=out_rfm69/11/1/1/0/0,MSG SENT
                193659264 RFM69:SAC:SEND ACK,TO=1,RSSI=-102
                193659277 RFM69:CSMA:RSSI=-106
                193659296 TSF:MSG:READ,1-1-0,s=1,c=1,t=25,pt=1,l=1,sg=0:64
                193659311 GWT:TPS:TOPIC=out_rfm69/1/1/1/0/25,MSG SENT
                193659609 RFM69:SAC:SEND ACK,TO=1,RSSI=-92
                193659621 RFM69:CSMA:RSSI=-108
                193659640 TSF:MSG:READ,1-1-0,s=1,c=1,t=35,pt=7,l=5,sg=0:70.60
                193659656 GWT:TPS:TOPIC=out_rfm69/1/1/1/0/35,MSG SENT
                193673497 RFM69:SAC:SEND ACK,TO=11,RSSI=-93
                193673510 RFM69:CSMA:RSSI=-103
                193673529 TSF:MSG:READ,12-11-0,s=1,c=1,t=38,pt=7,l=5,sg=0:12.89
                193673546 GWT:TPS:TOPIC=out_rfm69/12/1/1/0/38,MSG SENT
                193674042 RFM69:SAC:SEND ACK,TO=11,RSSI=-99
                193674054 RFM69:CSMA:RSSI=-103
                193674073 TSF:MSG:READ,12-11-0,s=1,c=1,t=0,pt=7,l=5,sg=0:27.00
                193674090 GWT:TPS:TOPIC=out_rfm69/12/1/1/0/0,MSG SENT
                193674585 RFM69:SAC:SEND ACK,TO=11,RSSI=-99
                193674598 RFM69:CSMA:RSSI=-105
                193674617 TSF:MSG:READ,12-11-0,s=1,c=1,t=25,pt=1,l=1,sg=0:247
                193674633 GWT:TPS:TOPIC=out_rfm69/12/1/1/0/25,MSG SENT
                193675129 RFM69:SAC:SEND ACK,TO=11,RSSI=-105
                193675142 RFM69:CSMA:RSSI=-108
                193675160 TSF:MSG:READ,12-11-0,s=3,c=1,t=38,pt=7,l=5,sg=0:13.65
                193675177 GWT:TPS:TOPIC=out_rfm69/12/3/1/0/38,MSG SENT
                193675675 RFM69:SAC:SEND ACK,TO=11,RSSI=-99
                193675688 RFM69:CSMA:RSSI=-102
                193675707 TSF:MSG:READ,12-11-0,s=3,c=1,t=39,pt=7,l=5,sg=0:0.97
                193675723 GWT:TPS:TOPIC=out_rfm69/12/3/1/0/39,MSG SENT
                193676219 RFM69:SAC:SEND ACK,TO=11,RSSI=-103
                193676232 RFM69:CSMA:RSSI=-106
                193676251 TSF:MSG:READ,12-11-0,s=0,c=1,t=38,pt=7,l=5,sg=0:4.979
                193676268 GWT:TPS:TOPIC=out_rfm69/12/0/1/0/38,MSG SENT
                193676755 RFM69:SAC:SEND ACK,TO=11,RSSI=-97
                I did a hard reboot of ESP8266, all back to normal.
                A 1 Reply Last reply
                • J jkandasa
                  astron
                  @jkandasa
                  I'm just designing a smart home system.
                  Do you use a MQTT connection to the controller?
                  ESP8266 memory is enough. You can add a communication check to the controller (for example, a request for the current time). And then you can restart SIM800L through an external pin on the module, and you can also restart ESSP8266.
                  alexsh1A 1 Reply Last reply
                  • A astron
                    @jkandasa
                    alexsh1A
                    alexsh1A
                    alexsh1
                    Is there a chance to reboot GSM modem / gateway on a regular basis?
                    What I have discovered is that some operators cells stop communicating with the modem if the location is not changed for days. Therefore, modem has to be rebooted manually or on the timer, i.e. rebooting every day at 04:00 morning time.
                    • alexsh1A alexsh1
                      @alexsh1 calling gatewayTransportInit() might work.
                      S 1 Reply Last reply
                        shajek
                        @mfalkvidd can you descirbe how ? where to place to periodically check if connected, and if not do some action ?
                        • S shajek
                          @shajek sorry I don't know
                          • alowhumA
                            alowhumA
                            alowhum
                            @alexsh1
                            Here's a bit of code I use to send an SMS once in a while. Providers will disable your simcard if you don't do anything that makes them money once in a while. Perhaps you can use it to reset.
                            #ifdef SEND_SMS_EVERY_49_DAYS
                              // This is an optional feature.
                              // Every 49,7 days (using the millis() rollover) the system sends out an SMS. This helps keep the simcard active and registered on the GSM network.
                              // Use at your own risk: if the system experiences a power loss, the timer starts at 0 again. If your experience frequent powerlosses, then the simcard might be-deregistered anyway, since the keep-alive SMS's won't get sent.
                              // A slight delay is built in: the first sms is sent a week after the smart lock becomes active. This avoid sending a lot of SMS's if you are still playing with setting up the device, and powerlosses may be frequent.
                              // This smart lock also offers another option. You can let the controller trigger the sending of the sms using the 'send test sms' button. Of course, your controller could also be down when you scheduled to trigger the button.
                              static bool keepAliveSMSsent = false;             // used to make sure an SMS is only sent as the milliseconds starts, and not during every loop in the millisecond.
                              if(millis() < 5){
                                keepAliveSMSsent  = false;                      // when the clock rolls over, set the variable back so that a new SMS can be sent.
                              if (millis() > 604800000 && millis() < 604800010 && keepAliveSMSsent == false){ // 604800000 = 1 week in milliseconds. Sending the first keep-alive SMS after a week avoids sending a lot of SMS-es while testing the system (which may involve a lot of reboots).
                                keepAliveSMSsent  = true;
                                sendStatusSMS();
                            Alternatively, you could check out the smart alarm clock code. It will show you how to request the time from the controller, turn that into a human readable time, and then you can do your thing.
                            uint32_t unixTime = 0;
                              Serial.print(F("Received time: ")); Serial.println(controllerTime);
                              unixTime = controllerTime;
                              breakUpTime(unixTime);
                            void breakUpTime(uint32_t timeInput)
                            // Break the given time_t into time components.
                            // This is a more compact version of the C library localtime function
                            // Note that year is offset from 1970!
                              uint32_t time;
                              time = (uint32_t)timeInput;
                              uint32_t Second = time % 60;
                              time /= 60; // now it is minutes
                              minutes = time % 60;
                              time /= 60; // now it is hours
                              hours = time % 24;
                              time /= 24; // now it is days
                              //int Wday = ((time + 4) % 7) + 1;                  // Which day of the week is it. Sunday is day 1
                              Serial.print(F("Calculated time: "));
                              Serial.print(hours);
                              Serial.print(F(":"));
                              Serial.println(minutes);
