  3. Custom made ethernet gateway based on atmega128
39 Posts 6 Posters 25.8k Views 2 Watching
  • axillentA
    axillentA
    axillent
    I need to have 4-5 ethernet gateways for my two installations (one for the apartment and one for the house)
    for this I'm developing a custom hardware
    it is a PCB with AC power supply, atmega128A, step-down for 5V (for atmega128), step-down for 3.3V (for radio and ENC28J60) ,
    4 leds (powe, error, TX, RX), ISP connector, 3.5mm jack to connect Serial, connector for NRF24L01 and connector for ENC8J60
    to use atmega128A a have to adjust Arduino configuration using some presets from the Internet.
    currently I'm running a standard Ethernet Gateway 1.4.1
    The plan is to add menu style configuration from the Serial connection for ethernet network parameters and for MySensors parameters.
    The plan is to propose a patch to MySensors to support Gateway ID - this will add support to the project to have multiple gateways without need of a hack. Otherwise devices from different gateways will conflict on the air.
    sense and drive
    RJ_MakeR AnticimexA 2 Replies Last reply
    • axillentA axillent
      RJ_MakeR
      RJ_MakeR
      RJ_Make
      @axillent You are one talented dude.. Nice job...
      What is the advantage here?
      RJ_Make
      axillentA 1 Reply Last reply
      • RJ_MakeR RJ_Make
        axillentA
        axillentA
        axillent
        @ServiceXp thanks!
        regular arduina with atmega328 on board is too limited in the size of programming memory for the powerful and configurable ethernet gateway. Especially in case of using ENC28J60
        mega board is too big.
        the advantage is to have compact and powerful design. It is even more important if you need a future design like this one http://forum.mysensors.org/topic/887/future-network-topology-for-discussion. With my multi-gateway installation I'm going to test this concept. This one on the photo is a prototype. As soon as it will succeeds I will made 3-4 more.
        sense and drive
        • epierreE
          epierreE
          epierre
          Have you made mysensors compliant with ENC28J60 ?
          z-wave - Vera -> Domoticz
          • epierreE epierre
            axillentA
            axillentA
            axillent
            @epierre not me, @hek made
            I'm using a standard sketch from 1.4.1 version of the Mysensors library
            what i'm going to do is to add flexibility for multi-gateway setup
            sense and drive
            AnticimexA 1 Reply Last reply
              AnticimexA
              AnticimexA
              Anticimex
              @axillent
              Nice. On the topic of flash usage of ethernet gateways, I also struggle with fitting signing support to an ethernet GW. I will eventually succeed, but it will leave virtually no room for other additions (at least with DEBUG enabled). So my question to you is: will you make your additions to the GW software (if any) switchable (if they add to the codesize)?
              Or will you simply state that a Ethernet GW with "multi gw support" is not supported on a vanilla Arduino Nano?
              • AnticimexA Anticimex
                @axillent
                axillentA
                axillentA
                axillent
                @Anticimex as such multi-gateway do not requires code size increase but will need a hardcoding : IP, MAC, radio channel or BASE_ADDRSS. You have to use different parameters for different gateway nodes, Otherwise it will be a conflict on Air or on Ethernet
                My list of additional futures will require more flash and atmega128 is very sufficient for this:
                I plan a serial terminal with a configuration menu. It will work like BIOS on any PC. The "BIOS" will be activated by a button pressed during power on circle. By connecting a computer to the serial connector (I'm using audio 3.5mm stereo jack) you will be able to interact with the "BIOS" menu.. Menu will allow to:
                • switch between DHCP/no DHCP
                • to see assigned IP
                • to assign a MAC
                • to assign an IP
                • to set radio channel
                • to set BASE_ADDRESS
                • to display current configuration
                • to test ethernet and radio
                • to see statistics
                • to switch ON/OFF serial debug
                sense and drive
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @axillent
                  Ah, I see. It makes sense that the routing logic updates are to the controller(s) in that case. I like it. Especially since nothing prevents existing gateways to be added to this topology without modification :)
                  • axillentA
                    axillentA
                    axillent
                    it got been print-cased)
                    this is in progress the development of gateway #2
                    sense and drive
                    • axillentA
                      axillentA
                      axillent
                      instant made PCB is ready to be soldered
                      sense and drive
                        marceloaqno
                        Code Contributor
                        Great Job! What are you using for the power supply?
                        • M marceloaqno
                          axillentA
                          axillentA
                          axillent
                          @celonunes thanks!
                          on the photo you can see a black square part, it is a transformer
                          after transformer i have a bridge rectifier, one step-down based on MP2359 to get +5V
                          and other step-down base on NCP1529 to get 3.3V from the +5V
                          sense and drive
                          • axillentA
                            axillentA
                            axillent
                            the schematics
                            sense and drive
                            RJ_MakeR 1 Reply Last reply
                              the schematics
                              RJ_MakeR
                              RJ_MakeR
                              RJ_Make
                              @axillent I just noticed 2 push buttons in the schematics? Is one a reset?
                              RJ_Make
                              • RJ_MakeR RJ_Make
                                axillentA
                                axillentA
                                axillent
                                @ServiceXp atmega128 provides 53 I/O pins, I had to use at least some of them)))
                                I have no exact application for both buttons but probably will use them somehow in extended version of the Ethernet Gateway
                                sense and drive
                                • epierreE
                                  epierreE
                                  epierre
                                  why not use a photon ? it is $19 and already has the wifi ?
                                  • epierreE epierre
                                    axillentA
                                    axillentA
                                    axillent
                                    @epierre cortex is a nice thing but currently not supported by Mysensors. Do you want to add the support?
                                    we are looking for the gateway based on ESP8266, it is just $4 board including WIFI and powerful MCU
                                    sense and drive
                                    • epierreE
                                      epierreE
                                      epierre
                                      @axillent I'm currently supporting my scripts on both arduino and spark.io to avoid everybody reinventing the wheel. Hopefully spark.io is more a hardware provider, meaning they design and implement hardware of their own they afterward sell, or sponsor through indiegogo. They also already have a could cum IFTTT already working.
                                      Currently mysensors is too much linked to the vera although it is opening up. With a gateway that would be automatically wifi or wired, as you plan to do, that would change this.
                                      I understand the approch for a cheap board, but I guess that you would need more components in you BOM that just the ESP8266 plus some soldering on a board ? (I don't speak of this nice russian transformer ;-) but that would kill many people in between just soldering, no ?
                                      • epierreE epierre
                                        axillentA
                                        axillentA
                                        axillent
                                        @epierre nice value arduino provide is that you can do nice things with low entry barrier and without soldering
                                        Mysensors is intend to use this value as much as possible.
                                        "Solder or not solder" is a personal decision and mostly subject of the fan.
                                        At least for me it is fan
                                        as for device from this topic it is not share of the schematics, it is just share of a fan)
                                        russian transformer is part of it (i have a german one but it is too weak for this particular application)
                                        as for ESP8266 - 4$ is the cost of a ready to use module. The only missing thing is radio, you will need to connect 5 wires to radio,
                                        your BOM is simple - ESP module, nordic module and power supply
                                        should be simple even without a special Mysensors board.
                                        I see a good potential here
                                        also I see a good potential on a future network topology discussed in a separate thread, I'm going to test myself an installation with multi hardware layer multi gateway MySensors network
                                        sense and drive
                                        • epierreE
                                          epierreE
                                          epierre
                                          @axillent which is something I actually do with all deversing into domoticz (vera, mysensors, spark core, webcam), and have an uniformized access through imperihome.
                                          I'm very interrested about the wifi capacity if we cannot achieve some level of security within rf24.
