  3. 230V power supply to Arduino
67 Posts 25 Posters 78.6k Views 22 Watching
  • T Tibus
    Hello, I'm also searching a way to get 5V from AC to make a beatiful mysensor wallPlug... I'm searching the smallest and cheapest way to do it. My problem is I want to drive a regular relay (a SSR is not very good for plug and other things no?), an atmega328 tqfp, a NRF24 and some other things like a current sensor,... so, I think I need 150ma +-? (100ma for the relay, max 25-30ma for the NRF and arduino and some ma for the status leds,...)
    I found here the SR086 but I don't know if I could take 150ma on it.
    What is the best way for my projet?
    I also found these one but don't know if it ok too :
    http://www.newark.com/vigortronix/vtx-214-001-105/ac-dc-conv-fixed-1-o-p-1w-5v/dp/45X5484?ost=VTX-214-001-105
    I'm searchin the smallest way because i also would like to make a in wall module for interuptor,... so the VTX above is ok for a wallplug but a bit big for a in wall module... How the cubino for exemple make a DC module so small?
    axillentA
    axillentA
    axillent
    @Tibus your selection is fine. Any one above is also fine
    what is you worry?
    sense and drive
    • T
      Tibus
      @axillent My worry is taking 150ma out of a SR086? Is the SR086 ok to give 150ma?
      The VTX is ok but big for an inwall module so is there a good way to get 150ma in 5V from 220VAC in the smallest form factor possible? (or in less than 1cm height?)
      I also found these one but a SR086 would be fine for a inwall relay... (but 150ma?)
      http://fr.rs-online.com/web/p/alimentations-a-decoupage-integrables/7719379/
      axillentA 1 Reply Last reply
      • T Tibus
        axillentA
        axillentA
        axillent
        #26
        @Tibus SR086 able to provide 100mA from 9-50V. For example you can set it to provide 20V and add DC-DC step-down for example based on MP2359. This will give you current-UP benefit at 5V etc. 20V@100mA will give you 5V@360mA maximum with 90% efficiency
        My preference in your case LNK306, you can get directly up to 350mA. Using ceramic capacitors and SMD inductors you will fit in 7-10mm height (see one of my picture above)
        And at last. Why not SSR? What type of the load do you have?
        sense and drive
        • T
          Tibus
          @axillent Thank's verry much. I didn't know the current up benefit of a step-down. I think it's the key of my problem!
          I'll test the lnk306. Hope It will work for my project.
          For my "in wall module", it's just lights so no problem for an SSR. But for the wall plug, The user chose the load they want... so if it's a TV or a washing machine or a power supply, I read an SSR is not verry good for these things...
          • T Tibus
            axillentA
            axillentA
            axillent
            @Tibus YAW
            For LNK take a look for AN37, especially optimization at table 9
            an37-linkswitch.pdf
            SSR is fine for most of the loads. But you need to follow recommendation of their use and to control limitations (like maximum ratings and heat dissipation)
            sense and drive
            • axillentA
              axillentA
              axillent
              I'm expecting to receive my SR086 and SR10 this week
              I have a plan to run some tests
              sense and drive
              • klimK
                klimK
                klim
                Regarding the SR10 i've already here a few, but just no time to build up something ;-(
                The more i'm curious for your results.
                • klimK klim
                  axillentA
                  axillentA
                  axillent
                  #31
                  @klim I made a test PCB
                  I succeed to get about 34mA with 1uF capacitor and probably it will provide 40mA stated in the datasheet
                  it is not possible to use it directly without an additional LDO or step-down because of a very high ripple.
                  According to my measurement ripple is 2.8V with 12.6V average output (figures in table should be multiplied by 10):
                  consumed power from AC is 0.8 W with 36mA output
                  this means 57% efficiency, not bad for such thing
                  sense and drive
                  • T
                    Tibus
                    hox much current could you get with a LDO ort step-Down to 5V or 3.3V? 80ma?
                    • T Tibus
                      axillentA
                      axillentA
                      axillent
                      @Tibus the output current from SR10 is depends on the capacitor and rectifier. See the table inside the datasheet
                      with step-down I can get from my prototype about 100mA at 3.3V
                      with LDO you will get out as many as you get in minus quiescent current of LDO itself
                      sense and drive
                      • axillentA
                        axillentA
                        axillent
                        I made a success by replacing polymer capacitor by ceramic one in the usage of SR10
                        it leads to a dramatical decrease in needed space. I believe that it will be the smallest AC-DC fotprint
                        But still I have som problems with DHT sensor to work from SR10 (http://forum.mysensors.org/topic/971/small-wall-outlet-sensor-node)
                        sense and drive
                        jeylitesJ 1 Reply Last reply
                        • axillentA axillent
                          jeylitesJ
                          jeylitesJ
                          jeylites
                          @axillent
                          I like the case you are using. Where did you get it from?upload-a5807239-d1ad-499a-97c0-c24a736c0ce8.JPG
                          • jeylitesJ jeylites
                            @axillent
                            marceltrapmanM
                            marceltrapmanM
                            marceltrapman
                            @jeylites said:
                            @axillent
                            It looks like it was printed.
                            If so, are you willing to share the files?
                            Fulltime Servoy Developer
                            • axillentA
                              axillentA
                              axillent
                              yes, all cases are printed
                              sure, I can share if you need
                              the case developed for a particular custom made PCB
                              sense and drive
                                marceltrapmanM
                                marceltrapmanM
                                marceltrapman
                                I understand but the design is still a good starting point :)
                                  axillentA
                                  axillentA
                                  axillent
                                  @marceltrapman sure, just give me some time to publish it on thingerverse
                                  sense and drive
                                  • marceltrapmanM
                                    marceltrapmanM
                                    marceltrapman
                                    Nice, thanks...
                                    • MagiskeM
                                      MagiskeM
                                      Magiske
                                      wrote on last edited by Magiske
                                      #41
                                      Was looking into the same and ordered 2 different 230/110v to 5v of ebay to get a cheap 5v powersource. Just got them today.
                                      The White around $1.5 and the Black was $1.0
                                      Before wirering everything up, I just added the smaller white's pcb to the black case incl. radio and pro mini. And there is room for a bit more.
                                      So unless it goes up in flames I will try to create a default sensor node.
                                      • Vladut GrecuV
                                        Vladut GrecuV
                                        Vladut Grecu
                                        If you don`t go over 50-60% of the amps that that charger can output, there will be no problems. I suggest you replace the capacitor on the 5V area with a bigger one and change the 220/110v capacitor with a higher quality one. What I figure from your pictures is that the black charger doesn't have a bridge rectifier.. It's safer for you to use one. (Don't forget about the fuse)
                                        • ferpandoF
                                          ferpandoF
                                          ferpando
                                          Anyone tested one of these cheap power supplies with an osciloscope?
                                          I got a couple yesterday but not sure if they are good enough
