  3. 230V power supply to Arduino
67 Posts 25 Posters 78.6k Views 22 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @axillent
    What if you place a 3v3 ldo at the 5V output, what is the ripple then, at the different loads?
    axillentA 1 Reply Last reply
    • tbowmoT tbowmo
      @axillent
      axillentA
      axillentA
      axillent
      with good ldo supported by sufficient capacitors it can be fine for arduino
      but still I will not recommend to go above 500mA with this supply
      sense and drive
      • tbowmoT
        tbowmoT
        tbowmo
        @axillent
        500mA should also be sufficient for a sensor node, even with a couple of relays, mysensors in GW mode, etc. it's not even near the 500mA limit
        • axillentA
          axillentA
          axillent
          sure. sensornode without relays requires 15-20mA
          with SSR relay will need +10-15mA for each relay
          +50-100mA for each regular relay
          sense and drive
          • T
            Tibus
            Hello, I'm also searching a way to get 5V from AC to make a beatiful mysensor wallPlug... I'm searching the smallest and cheapest way to do it. My problem is I want to drive a regular relay (a SSR is not very good for plug and other things no?), an atmega328 tqfp, a NRF24 and some other things like a current sensor,... so, I think I need 150ma +-? (100ma for the relay, max 25-30ma for the NRF and arduino and some ma for the status leds,...)
            I found here the SR086 but I don't know if I could take 150ma on it.
            What is the best way for my projet?
            I also found these one but don't know if it ok too :
            http://www.newark.com/vigortronix/vtx-214-001-105/ac-dc-conv-fixed-1-o-p-1w-5v/dp/45X5484?ost=VTX-214-001-105
            I'm searchin the smallest way because i also would like to make a in wall module for interuptor,... so the VTX above is ok for a wallplug but a bit big for a in wall module... How the cubino for exemple make a DC module so small?
            • T Tibus
              axillentA
              axillentA
              axillent
              @Tibus your selection is fine. Any one above is also fine
              what is you worry?
              sense and drive
              • T
                Tibus
                @axillent My worry is taking 150ma out of a SR086? Is the SR086 ok to give 150ma?
                The VTX is ok but big for an inwall module so is there a good way to get 150ma in 5V from 220VAC in the smallest form factor possible? (or in less than 1cm height?)
                I also found these one but a SR086 would be fine for a inwall relay... (but 150ma?)
                http://fr.rs-online.com/web/p/alimentations-a-decoupage-integrables/7719379/
                • T Tibus
                  axillentA
                  axillentA
                  axillent
                  #26
                  @Tibus SR086 able to provide 100mA from 9-50V. For example you can set it to provide 20V and add DC-DC step-down for example based on MP2359. This will give you current-UP benefit at 5V etc. 20V@100mA will give you 5V@360mA maximum with 90% efficiency
                  My preference in your case LNK306, you can get directly up to 350mA. Using ceramic capacitors and SMD inductors you will fit in 7-10mm height (see one of my picture above)
                  And at last. Why not SSR? What type of the load do you have?
                  sense and drive
                  • T
                    Tibus
                    @axillent Thank's verry much. I didn't know the current up benefit of a step-down. I think it's the key of my problem!
                    I'll test the lnk306. Hope It will work for my project.
                    For my "in wall module", it's just lights so no problem for an SSR. But for the wall plug, The user chose the load they want... so if it's a TV or a washing machine or a power supply, I read an SSR is not verry good for these things...
                    • T Tibus
                      axillentA
                      axillentA
                      axillent
                      @Tibus YAW
                      For LNK take a look for AN37, especially optimization at table 9
                      an37-linkswitch.pdf
                      SSR is fine for most of the loads. But you need to follow recommendation of their use and to control limitations (like maximum ratings and heat dissipation)
                      sense and drive
                      • axillentA
                        axillentA
                        axillent
                        I'm expecting to receive my SR086 and SR10 this week
                        I have a plan to run some tests
                        sense and drive
                        • klimK
                          klimK
                          klim
                          Regarding the SR10 i've already here a few, but just no time to build up something ;-(
                          The more i'm curious for your results.
                          • klimK klim
                            axillentA
                            axillentA
                            axillent
                            #31
                            @klim I made a test PCB
                            I succeed to get about 34mA with 1uF capacitor and probably it will provide 40mA stated in the datasheet
                            it is not possible to use it directly without an additional LDO or step-down because of a very high ripple.
                            According to my measurement ripple is 2.8V with 12.6V average output (figures in table should be multiplied by 10):
                            consumed power from AC is 0.8 W with 36mA output
                            this means 57% efficiency, not bad for such thing
                            sense and drive
                            • T
                              Tibus
                              hox much current could you get with a LDO ort step-Down to 5V or 3.3V? 80ma?
                              • T Tibus
                                axillentA
                                axillentA
                                axillent
                                @Tibus the output current from SR10 is depends on the capacitor and rectifier. See the table inside the datasheet
                                with step-down I can get from my prototype about 100mA at 3.3V
                                with LDO you will get out as many as you get in minus quiescent current of LDO itself
                                sense and drive
                                • axillentA
                                  axillentA
                                  axillent
                                  I made a success by replacing polymer capacitor by ceramic one in the usage of SR10
                                  it leads to a dramatical decrease in needed space. I believe that it will be the smallest AC-DC fotprint
                                  But still I have som problems with DHT sensor to work from SR10 (http://forum.mysensors.org/topic/971/small-wall-outlet-sensor-node)
                                  sense and drive
                                  jeylitesJ 1 Reply Last reply
                                  • axillentA axillent
                                    jeylitesJ
                                    jeylitesJ
                                    jeylites
                                    @axillent
                                    I like the case you are using. Where did you get it from?upload-a5807239-d1ad-499a-97c0-c24a736c0ce8.JPG
                                    • jeylitesJ jeylites
                                      @axillent
                                      marceltrapmanM
                                      marceltrapmanM
                                      marceltrapman
                                      @jeylites said:
                                      @axillent
                                      It looks like it was printed.
                                      If so, are you willing to share the files?
                                      Fulltime Servoy Developer
                                      • axillentA
                                        axillentA
                                        axillent
                                        yes, all cases are printed
                                        sure, I can share if you need
                                        the case developed for a particular custom made PCB
                                        sense and drive
                                          marceltrapmanM
                                          marceltrapmanM
                                          marceltrapman
                                          I understand but the design is still a good starting point :)
