  3. 230V power supply to Arduino
67 Posts 25 Posters 78.6k Views 22 Watching
  • T
    Tibus
    hox much current could you get with a LDO ort step-Down to 5V or 3.3V? 80ma?
    axillentA 1 Reply Last reply
    • T Tibus
      axillentA
      axillentA
      axillent
      @Tibus the output current from SR10 is depends on the capacitor and rectifier. See the table inside the datasheet
      with step-down I can get from my prototype about 100mA at 3.3V
      with LDO you will get out as many as you get in minus quiescent current of LDO itself
      sense and drive
      • axillentA
        axillentA
        axillent
        I made a success by replacing polymer capacitor by ceramic one in the usage of SR10
        it leads to a dramatical decrease in needed space. I believe that it will be the smallest AC-DC fotprint
        But still I have som problems with DHT sensor to work from SR10 (http://forum.mysensors.org/topic/971/small-wall-outlet-sensor-node)
        sense and drive
        jeylitesJ 1 Reply Last reply
        • axillentA axillent
          jeylitesJ
          jeylitesJ
          jeylites
          @axillent
          I like the case you are using. Where did you get it from?upload-a5807239-d1ad-499a-97c0-c24a736c0ce8.JPG
          • jeylitesJ jeylites
            @axillent
            marceltrapmanM
            marceltrapmanM
            marceltrapman
            @jeylites said:
            @axillent
            It looks like it was printed.
            If so, are you willing to share the files?
            Fulltime Servoy Developer
            • axillentA
              axillentA
              axillent
              yes, all cases are printed
              sure, I can share if you need
              the case developed for a particular custom made PCB
              sense and drive
                marceltrapmanM
                marceltrapmanM
                marceltrapman
                I understand but the design is still a good starting point :)
                  axillentA
                  axillentA
                  axillent
                  @marceltrapman sure, just give me some time to publish it on thingerverse
                  sense and drive
                  • marceltrapmanM
                    marceltrapmanM
                    marceltrapman
                    Nice, thanks...
                    • MagiskeM
                      MagiskeM
                      Magiske
                      wrote on last edited by Magiske
                      #41
                      Was looking into the same and ordered 2 different 230/110v to 5v of ebay to get a cheap 5v powersource. Just got them today.
                      The White around $1.5 and the Black was $1.0
                      Before wirering everything up, I just added the smaller white's pcb to the black case incl. radio and pro mini. And there is room for a bit more.
                      So unless it goes up in flames I will try to create a default sensor node.
                      • Vladut GrecuV
                        Vladut GrecuV
                        Vladut Grecu
                        If you don`t go over 50-60% of the amps that that charger can output, there will be no problems. I suggest you replace the capacitor on the 5V area with a bigger one and change the 220/110v capacitor with a higher quality one. What I figure from your pictures is that the black charger doesn't have a bridge rectifier.. It's safer for you to use one. (Don't forget about the fuse)
                        • ferpandoF
                          ferpandoF
                          ferpando
                          Anyone tested one of these cheap power supplies with an osciloscope?
                          I got a couple yesterday but not sure if they are good enough
                          • gaduG
                            gaduG
                            gadu
                            I've seen these and also got interested. Any input on these is appreciated.
                            • MagiskeM Magiske
                              J
                              J
                              Jan Gatzke
                              @Magiske I am using a power supply similar to the black one. My one has a fake optocoupler. The output voltage is unregulated. Have a close look before using this pcb. ;)
                              • Roberto BrunialtiR
                                Roberto BrunialtiR
                                Roberto Brunialti
                                wrote on last edited by Roberto Brunialti
                                #46
                                May be too big or too expansive... but it is for sure a good (and safe...) product with a 33x22 mm footprint..
                                http://www.mouser.com/ProductDetail/RECOM-Power/RAC01-33SC/?qs=waQl70lBfV2Z5QQrs%2FIAaw%3D%3D
                                • J
                                  J
                                  Jan Gatzke
                                  Does it fit on 2.54 mm prototype boards?
                                  • DidiD
                                    DidiD
                                    Didi
                                    Yes it does.
                                    Look data sheet http://www.mouser.com/ds/2/468/RAC01_02-SC-16262.pdf
                                      Roberto BrunialtiR
                                      Roberto Brunialti
                                      I've got a couple of them (3.3 and 5 V models), the wired models. Just received. Still to test...
                                        #50
                                        you can disassemble some components like transformer and cap. So you can make your own mysensors design and you get very small and cheap transformer. I can't find cheaper I think. or maybe on alibaba!
                                        I have these http://fr.aliexpress.com/item/AC-220V-DC-3V-10V-5V-9V-1w-1x1w-2w-2x1w-3w-3x1w-Constant-Current-Constant/1900256299.html?recommendVersion=1
                                        M axillentA 2 Replies Last reply
                                        • scalzS scalz
                                          msebbe
                                          Can this convert 230v to 5v and supply enough power for say an pro mini with motion sensor?
