  3. 230V power supply to Arduino
67 Posts 25 Posters 78.6k Views 22 Watching
  • klimK klim
    Regarding the SR10 i've already here a few, but just no time to build up something ;-(
    The more i'm curious for your results.
    axillentA
    axillentA
    axillent
    #31
    @klim I made a test PCB
    I succeed to get about 34mA with 1uF capacitor and probably it will provide 40mA stated in the datasheet
    it is not possible to use it directly without an additional LDO or step-down because of a very high ripple.
    According to my measurement ripple is 2.8V with 12.6V average output (figures in table should be multiplied by 10):
    consumed power from AC is 0.8 W with 36mA output
    this means 57% efficiency, not bad for such thing
    sense and drive
    • T
      Tibus
      hox much current could you get with a LDO ort step-Down to 5V or 3.3V? 80ma?
      axillentA 1 Reply Last reply
      • T Tibus
        axillentA
        axillentA
        axillent
        @Tibus the output current from SR10 is depends on the capacitor and rectifier. See the table inside the datasheet
        with step-down I can get from my prototype about 100mA at 3.3V
        with LDO you will get out as many as you get in minus quiescent current of LDO itself
        sense and drive
        • axillentA
          axillentA
          axillent
          I made a success by replacing polymer capacitor by ceramic one in the usage of SR10
          it leads to a dramatical decrease in needed space. I believe that it will be the smallest AC-DC fotprint
          But still I have som problems with DHT sensor to work from SR10 (http://forum.mysensors.org/topic/971/small-wall-outlet-sensor-node)
          sense and drive
          jeylitesJ 1 Reply Last reply
          • axillentA axillent
            jeylitesJ
            jeylitesJ
            jeylites
            @axillent
            I like the case you are using. Where did you get it from?upload-a5807239-d1ad-499a-97c0-c24a736c0ce8.JPG
            • jeylitesJ jeylites
              @axillent
              marceltrapmanM
              marceltrapmanM
              marceltrapman
              @jeylites said:
              @axillent
              It looks like it was printed.
              If so, are you willing to share the files?
              Fulltime Servoy Developer
              • axillentA
                axillentA
                axillent
                yes, all cases are printed
                sure, I can share if you need
                the case developed for a particular custom made PCB
                sense and drive
                  marceltrapmanM
                  marceltrapmanM
                  marceltrapman
                  I understand but the design is still a good starting point :)
                    axillentA
                    axillentA
                    axillent
                    @marceltrapman sure, just give me some time to publish it on thingerverse
                    sense and drive
                    • marceltrapmanM
                      marceltrapmanM
                      marceltrapman
                      Nice, thanks...
                      • MagiskeM
                        MagiskeM
                        Magiske
                        wrote on last edited by Magiske
                        #41
                        Was looking into the same and ordered 2 different 230/110v to 5v of ebay to get a cheap 5v powersource. Just got them today.
                        The White around $1.5 and the Black was $1.0
                        Before wirering everything up, I just added the smaller white's pcb to the black case incl. radio and pro mini. And there is room for a bit more.
                        So unless it goes up in flames I will try to create a default sensor node.
                        • Vladut GrecuV
                          Vladut GrecuV
                          Vladut Grecu
                          If you don`t go over 50-60% of the amps that that charger can output, there will be no problems. I suggest you replace the capacitor on the 5V area with a bigger one and change the 220/110v capacitor with a higher quality one. What I figure from your pictures is that the black charger doesn't have a bridge rectifier.. It's safer for you to use one. (Don't forget about the fuse)
                          • ferpandoF
                            ferpandoF
                            ferpando
                            Anyone tested one of these cheap power supplies with an osciloscope?
                            I got a couple yesterday but not sure if they are good enough
                            • gaduG
                              gaduG
                              gadu
                              I've seen these and also got interested. Any input on these is appreciated.
                              • MagiskeM Magiske
                                J
                                J
                                Jan Gatzke
                                @Magiske I am using a power supply similar to the black one. My one has a fake optocoupler. The output voltage is unregulated. Have a close look before using this pcb. ;)
                                • Roberto BrunialtiR
                                  Roberto BrunialtiR
                                  Roberto Brunialti
                                  wrote on last edited by Roberto Brunialti
                                  #46
                                  May be too big or too expansive... but it is for sure a good (and safe...) product with a 33x22 mm footprint..
                                  http://www.mouser.com/ProductDetail/RECOM-Power/RAC01-33SC/?qs=waQl70lBfV2Z5QQrs%2FIAaw%3D%3D
                                  • J
                                    J
                                    Jan Gatzke
                                    Does it fit on 2.54 mm prototype boards?
                                    • DidiD
                                      DidiD
                                      Didi
                                      Yes it does.
                                      Look data sheet http://www.mouser.com/ds/2/468/RAC01_02-SC-16262.pdf
                                        Roberto BrunialtiR
                                        Roberto Brunialti
                                        I've got a couple of them (3.3 and 5 V models), the wired models. Just received. Still to test...
                                          #50
                                          you can disassemble some components like transformer and cap. So you can make your own mysensors design and you get very small and cheap transformer. I can't find cheaper I think. or maybe on alibaba!
                                          I have these http://fr.aliexpress.com/item/AC-220V-DC-3V-10V-5V-9V-1w-1x1w-2w-2x1w-3w-3x1w-Constant-Current-Constant/1900256299.html?recommendVersion=1
                                          M axillentA 2 Replies Last reply
