  3. RS485 & SoftwareSerial
8 Posts 4 Posters 2.1k Views 3 Watching
  • P Offline
    P Offline
    PawelD
    Re: How to use SoftwareSerial Library?
    Hi.
    Anyone managed to run SoftwareSerial on RS485 gateway?
    I tried to do everything according to what is said in the link above, but with no success.
    This works (using hardware serial1 of my Mega):
    #define MY_RS485
    #define MY_RS485_DE_PIN 3
    #define MY_RS485_HWSERIAL Serial1
    #define MY_GATEWAY_SERIAL
    void setup(){}
    void presentation(){}
    void loop(){}
    and this one doesn't work (trying to use SoftwareSerial pins 4 and 2)
    #define MY_RS485
    #include <SoftwareSerial.h>
    SoftwareSerial mySerial(4,2); //rx, tx
    #define MY_RS485_SWSERIAL mySerial
    void setup(){}
    void loop(){}
    I also made a change in MyTransportRS485.cpp
    before:
    #if defined(__linux__)
    SerialPort _dev = SerialPort(MY_RS485_HWSERIAL);
    #elif defined(MY_RS485_HWSERIAL)
    HardwareSerial& _dev = MY_RS485_HWSERIAL;
    AltSoftSerial _dev;
    and after:
    #if defined(MY_RS485_SWSERIAL)
    SoftwareSerial& _dev = MY_RS485_SWSERIAL;
    #elif defined(__linux__)
    AltSoftSerial _dev;
    What am I doing wrong?
    I'm using MySensors 2.3.1 library.
    mfalkviddM msmacsM 2 Replies Last reply
    • P PawelD
      Hi.
      #define MY_RS485
      void setup(){}
      void loop(){}
      #define MY_RS485
      void setup(){}
      void loop(){}
      before:
      AltSoftSerial _dev;
      and after:
      AltSoftSerial _dev;
      @paweld MY_RS485_SWSERIAL does not exist in the MySensors code. You'll need to modify the library in the way mentioned in https://forum.mysensors.org/post/71505
      Edit: Sorry, I see that you already did.
      What happens if you don't define MY_RS485_HWSERIAL at all?
      With "doesn't work" do you mean that the sketch compiles and can be uploaded, but communicating on the software serial pins does not work? Or does the code not compile?
      P 1 Reply Last reply
      • K Offline
        K Offline
        kimot
        A long time before I try serial gateway from MySensors example and it works without any modification.
        My configuration:
        Domoticz
        Pro mini like serial gateway - hw serial to Domoticz, sw serial to another Pro mini with serial motion node example with serial sw from MySensors too.
        But no RS485 drivers, only sw serial tx and rx pins cross wired.
        And do not forgot assign node_id in your sketch.
          P Offline
          P Offline
          PawelD
          wrote on last edited by PawelD
          @mfalkvidd
          I tried removing "define MY_RS485_HWSERIAL" but it didn't help.
          My code compiles correctly, but there is no communication.
          Hardware setup is identical for both examples, except for the rx/tx pins used.
          This is very simple setup: a button connected to Nano+Max485 module, and Mega+Max485 gateway, connected via RS485.
          @kimot
          I have node_id assigned in my Nano node's code.
          @kduino @hek maybe you can help here?
          K 1 Reply Last reply
          • P PawelD
            @mfalkvidd
            @kimot
            K Offline
            K Offline
            kimot
            wrote on last edited by kimot
            @paweld
            And must you really use SoftwareSerial and not AltSoftSerial, which is default for MySensors RS485 link layer?
            You do not need include SoftwareSerial in your sketch then.
            • K kimot
              @paweld
              P Offline
              P Offline
              PawelD
              @kimot
              I rejected AltSoftSerial library because:
              1. My shields operate on pins 0 to 5. AltSoftSerial has fixed pins 8,9 for Uno and 46,48 for Mega.
              2. I want to keep pins 0 and 1 for debug/controller communication
              3. I want to use two RS485 shields on my Mega: one using pins 2,3, and second pins 4,5.
              Here you can see the setup I'm talking about:
              Zihatec RS485 Multiple busses
              • P PawelD
                Hi.
                #define MY_RS485
                void setup(){}
                void loop(){}
                #define MY_RS485
                void setup(){}
                void loop(){}
                before:
                AltSoftSerial _dev;
                and after:
                AltSoftSerial _dev;
                msmacsM Offline
                msmacsM Offline
                msmacs
                @paweld Hi, I was just reading the "Limitations" section on the official page: https://www.arduino.cc/en/Reference/softwareSerial
                You are using a "Mega" board so it seems that with the SoftwareSerial library you can only use a subset of the available pins (actually the limitation is for the RX pin).
                Just to confirm, could you try to use different pins as described in the "Limitations"?
                Max
                • msmacsM msmacs
                  Max
                  P Offline
                  P Offline
                  PawelD
                  @msmacs
                  Thanks a lot. This is it.
                  I tried pins 10, 11, 12 (RX / TX / DE-RE) and it worked.
                  Problem solved.
