  3. 💬 EFEKTA Temp&Hum sensor(ver. nRF52 )+E-Ink display
nrf52832e-ink displaye-papernrf52nrf52810nrf52811nrf52840temperature & humidity sensor
105 Posts 11 Posters 35.2k Views 12 Watching
  • berkseoB
    berkseoB
    berkseo
    #70
    The project became closed. Reason: I previously placed links to all the necessary components for this device(see screenshot). This allowed me to earn quite a bit on the affiliate program. This allowed me a bit to recoup the costs, they are not small. The site administration considers this type of earnings unacceptable.
    magpernM 1 Reply Last reply
    • berkseoB berkseo
      magpernM
      magpernM
      magpern
      @berkseo Seriously!!!!!!!!!!!!! It cannot be true!!! I have just ordered PCBs and all needed stuff to assemble it, and now the code is gone!!! Please post the code again, or make it available on alternative sites.. please. It is hundreds of dollars to waste otherwise!
      berkseoB 1 Reply Last reply
      • magpernM magpern
        berkseoB
        berkseoB
        berkseo
        @magpern said in 💬 EFEKTA Temp&Hum sensor(ver. nRF52832 )+E-Ink display:
        The project will remain open, like others. I was in a bad mood that day:)... The rules of the site administration are reasonable, and the decision to open the project was mine.
        Code for Arduino IDE - https://drive.google.com/file/d/13wmxCt9XehJr1E2eyG1RnYsQTMb9A2LR/view?usp=sharing
        • berkseoB
          berkseoB
          berkseo
          development continues...
          https://youtu.be/U1xtnGWoTKE
          • magpernM
            magpernM
            magpern
            wrote on last edited by magpern
            #74
            @berkseo said in 💬 EFEKTA Temp&Hum sensor(ver. nRF52832 )+E-Ink display:
            Thank you! You scared me big time!
            Bad ting without links is that eg. clock button 2 pcs... there are millions of clock buttons and to pick the right one with out a link.. well, almost impossible.
            Thanks again!
            • magpernM magpern
              Thanks again!
              berkseoB
              berkseoB
              berkseo
              @magpern
              https://static.chipdip.ru/lib/465/DOC002465453.pdf
              H 1 Reply Last reply
              • berkseoB berkseo
                @magpern
                H
                H
                heinzv
                @berkseo I have continued to work on the new PCB's und have oredered some 603 resistors und condensors. I have checked all of the parts and the soldering but did not get the one PCB to displays something. The program runs und I see the LED flashing and also the log looks normal.
                A build a second PCB and this one shows the intro graphics but with a grey background and then it stops showing something. No idea what goes wrong.
                • H heinzv
                  berkseoB
                  berkseoB
                  berkseo
                  @heinzv
                  I apologize that long did not answer. Did you solve the problem? I noticed that the inductance is small (it seemed to me). You should also check for solder connectors ribbon cable. Perhaps not all contacts are soldered and some contact lies on the PCB is not soldered. I had once, it was not well soldered contact pin on display connector .
                  • berkseoB
                    berkseoB
                    berkseo
                    Can you take me pictures in good resolution?
                    • berkseoB berkseo
                      H
                      H
                      heinzv
                      @berkseo no I have not solved the problem yet. I 'll take another picture with higher resolution tomorrow and post it here.
                      The inductance has the value which is specifiied (I think 68uH). I have all ordered by the links provided.
                      I have checked the soldering and resolved a few times. I think all pins shall be soldered, but I can verify it again. That was also my first thought and checked the ribbon cable over and over again.
                      • H heinzv
                        H
                        H
                        heinzv
                        wrote on last edited by heinzv
                        #80
                        @berkseo took a bit longer and I have now taken a picture with my Nikon Cam, not sure if it helps, I might add another one if required.
                        But you see the inductor has 68uH.
                        • D
                          dakipro
                          hey @berkseo these look amazing, any estimate when they might be available again as assembled unit?
                          Any estimate on how long the battery lasts, with lats say update every 15min?
                          Could these be updated OTA somehow (or directly perhaps)?
                          I would like to have option to change layout, or perhaps add some other values to it maybe.
                          They look amazing, I would like several of these in each room for various things displayed
                          • magpernM
                            magpernM
                            magpern
                            #82
                            @berkseo @heinzv I finally got around to solder one of these together. It was not easy, placing the components was kind of a guessing game, but I think I got it right. When I put two batteries in and turn it on there is a buzzing noise, maybe normal? Anyway... I never realized programming this thing would be a problem.
                            What equipment is needed to program it? I don't recognize the labeling on the pcb (gnd/vcc sdo/sclk rx/tx)
                            • magpernM magpern
                              magpernM
                              magpernM
                              magpern
                              @berkseo is the device programmed when output says this?
                              Licensed under GNU GPL v2
                              For bug reports, read
                              debug_level: 0
                              0x4000
                              adapter speed: 10000 kHz
                              xPSR: 0x01000000 pc: 0xfffffffe msp: 0xfffffffc
                              ** Programming Started **
                              auto erase enabled
                              target halted due to breakpoint, current mode: Thread
                              xPSR: 0x61000000 pc: 0x2000001e msp: 0xfffffffc
                              wrote 102400 bytes from file C:\Users\eu1391\AppData\Local\Temp\arduino_build_38086/epd1in54-demo.ino.hex in 2.178483s (45.904 KiB/s)
                              ** Programming Finished **
                              ** Verify Started **
                              xPSR: 0x61000000 pc: 0x2000002e msp: 0xfffffffc
                              verified 100668 bytes in 0.296666s (331.378 KiB/s)
                              ** Verified OK **
                              ** Resetting Target **
                              shutdown command invoked
                              The only thing happening when I turn it on, is that the LED flashed once. Then occasionally the LED flashed sporadically.
                              The e-paper is just white.
                              Questions?
                              Can you power the board from another source then the battery pcb?
                              The board needs to be powered when programming it, right? I'm using a ST-LINK V2 with the SWD pins connected.
                              How do you debug the board? I use Arduino IDE
                              magpernM berkseoB 2 Replies Last reply
                              • magpernM magpern
                                debug_level: 0
                                0x4000
                                auto erase enabled
                                ** Verified OK **
                                Questions?
                                magpernM
                                magpernM
                                magpern
                                It sure is lonely in here... but finally SUCCESS!!!!
                                After days of googling and checking and rechecking the board for shorts, I found the problem. The 68uH was dead. Maybe damaged when soldering it. It did not conduct anything. After changing it to a new one, the display started working.
                                Any idea how battery can be at 60% on more or less fresh batteries... anyway, that is another problem.
                                I still have one question, if anyone can chip in that would be great.
                                On the SWD connector it says, TX and RX, how do I use them?
                                Or really what I mean, how do you debug the device? I use a ST-Link V2, but I am not getting any COM-port so I cannot start the serial debugger. Is the TX/RX used for the serial debugging? Can I use ST-Link V2 for this or do I need a separate device?
                                I have tried to change the driver with ZADIG, but still no COM-port. As for now I have only connected 4 of the 6 pins in the SWD.
                                Please @berkseo help me!
                                berkseoB 4 Replies Last reply
                                • magpernM magpern
                                  debug_level: 0
                                  0x4000
                                  auto erase enabled
                                  ** Verified OK **
                                  Questions?
                                  berkseoB
                                  berkseoB
                                  berkseo
                                  yes
                                  • magpernM magpern
                                    berkseoB
                                    berkseoB
                                    berkseo
                                    Calculate the resistor divider. It is on the power Board. Perhaps you have mixed up resistors.
                                    • magpernM magpern
                                      berkseoB
                                      berkseoB
                                      berkseo
                                      Via TTL Converter. The program must be enabled in the debug.
                                      • berkseoB berkseo
                                        magpernM
                                        magpernM
                                        magpern
                                        TTL Converter.
                                        Thanks! I found in another thread one could use a FTDI, I will try that!
                                        • magpernM magpern
                                          berkseoB
                                          berkseoB
                                          berkseo
                                          You can connect the programmer and TTL Converter at the same time. You can also do so - https://translate.google.ru/translate?hl=&sl=ru&tl=en&u=https%3A%2F%2Fmysensors-rus.github.io%2Ftroubleshooting_on_Cortex_MCU_in_Arduino%2F
