  3. 💬 EFEKTA Temp&Hum sensor(ver. nRF52 )+E-Ink display
nrf52832e-ink displaye-papernrf52nrf52810nrf52811nrf52840temperature & humidity sensor
105 Posts 11 Posters 35.1k Views 12 Watching
  • magpernM
    magpernM
    magpern
    wrote on last edited by magpern
    #74
    @berkseo said in 💬 EFEKTA Temp&Hum sensor(ver. nRF52832 )+E-Ink display:
    @magpern said in 💬 EFEKTA Temp&Hum sensor(ver. nRF52832 )+E-Ink display:
    Seriously!!!!!!!!!!!!! It cannot be true!!! I have just ordered PCBs and all needed stuff to assemble it, and now the code is gone!!! Please post the code again, or make it available on alternative sites.. please. It is hundreds of dollars to waste otherwise!
    The project will remain open, like others. I was in a bad mood that day:)... The rules of the site administration are reasonable, and the decision to open the project was mine.
    Code for Arduino IDE - https://drive.google.com/file/d/13wmxCt9XehJr1E2eyG1RnYsQTMb9A2LR/view?usp=sharing
    Thank you! You scared me big time!
    Bad ting without links is that eg. clock button 2 pcs... there are millions of clock buttons and to pick the right one with out a link.. well, almost impossible.
    Thanks again!
    berkseoB 1 Reply Last reply
    • magpernM magpern
      Thanks again!
      berkseoB
      berkseoB
      berkseo
      @magpern
      https://static.chipdip.ru/lib/465/DOC002465453.pdf
      H 1 Reply Last reply
      • berkseoB berkseo
        @magpern
        H
        H
        heinzv
        @berkseo I have continued to work on the new PCB's und have oredered some 603 resistors und condensors. I have checked all of the parts and the soldering but did not get the one PCB to displays something. The program runs und I see the LED flashing and also the log looks normal.
        A build a second PCB and this one shows the intro graphics but with a grey background and then it stops showing something. No idea what goes wrong.
        • H heinzv
          berkseoB
          berkseoB
          berkseo
          @heinzv
          I apologize that long did not answer. Did you solve the problem? I noticed that the inductance is small (it seemed to me). You should also check for solder connectors ribbon cable. Perhaps not all contacts are soldered and some contact lies on the PCB is not soldered. I had once, it was not well soldered contact pin on display connector .
          • berkseoB
            berkseoB
            berkseo
            Can you take me pictures in good resolution?
            • berkseoB berkseo
              H
              H
              heinzv
              @berkseo no I have not solved the problem yet. I 'll take another picture with higher resolution tomorrow and post it here.
              The inductance has the value which is specifiied (I think 68uH). I have all ordered by the links provided.
              I have checked the soldering and resolved a few times. I think all pins shall be soldered, but I can verify it again. That was also my first thought and checked the ribbon cable over and over again.
              • H heinzv
                H
                H
                heinzv
                wrote on last edited by heinzv
                #80
                @berkseo took a bit longer and I have now taken a picture with my Nikon Cam, not sure if it helps, I might add another one if required.
                But you see the inductor has 68uH.
                • D
                  dakipro
                  hey @berkseo these look amazing, any estimate when they might be available again as assembled unit?
                  Any estimate on how long the battery lasts, with lats say update every 15min?
                  Could these be updated OTA somehow (or directly perhaps)?
                  I would like to have option to change layout, or perhaps add some other values to it maybe.
                  They look amazing, I would like several of these in each room for various things displayed
                  • magpernM
                    magpernM
                    magpern
                    #82
                    @berkseo @heinzv I finally got around to solder one of these together. It was not easy, placing the components was kind of a guessing game, but I think I got it right. When I put two batteries in and turn it on there is a buzzing noise, maybe normal? Anyway... I never realized programming this thing would be a problem.
                    What equipment is needed to program it? I don't recognize the labeling on the pcb (gnd/vcc sdo/sclk rx/tx)
                    magpernM 1 Reply Last reply
                    • magpernM magpern
                      magpernM
                      magpernM
                      magpern
                      @berkseo is the device programmed when output says this?
                      Licensed under GNU GPL v2
                      For bug reports, read
                      debug_level: 0
                      0x4000
                      adapter speed: 10000 kHz
                      xPSR: 0x01000000 pc: 0xfffffffe msp: 0xfffffffc
                      ** Programming Started **
                      auto erase enabled
                      target halted due to breakpoint, current mode: Thread
                      xPSR: 0x61000000 pc: 0x2000001e msp: 0xfffffffc
                      wrote 102400 bytes from file C:\Users\eu1391\AppData\Local\Temp\arduino_build_38086/epd1in54-demo.ino.hex in 2.178483s (45.904 KiB/s)
                      ** Programming Finished **
                      ** Verify Started **
                      xPSR: 0x61000000 pc: 0x2000002e msp: 0xfffffffc
                      verified 100668 bytes in 0.296666s (331.378 KiB/s)
                      ** Verified OK **
                      ** Resetting Target **
                      shutdown command invoked
                      The only thing happening when I turn it on, is that the LED flashed once. Then occasionally the LED flashed sporadically.
                      The e-paper is just white.
                      Questions?
                      Can you power the board from another source then the battery pcb?
                      The board needs to be powered when programming it, right? I'm using a ST-LINK V2 with the SWD pins connected.
                      How do you debug the board? I use Arduino IDE
                      magpernM berkseoB 2 Replies Last reply
                      • magpernM magpern
                        debug_level: 0
                        0x4000
                        auto erase enabled
                        ** Verified OK **
                        Questions?
                        magpernM
                        magpernM
                        magpern
                        It sure is lonely in here... but finally SUCCESS!!!!
                        After days of googling and checking and rechecking the board for shorts, I found the problem. The 68uH was dead. Maybe damaged when soldering it. It did not conduct anything. After changing it to a new one, the display started working.
                        Any idea how battery can be at 60% on more or less fresh batteries... anyway, that is another problem.
                        I still have one question, if anyone can chip in that would be great.
                        On the SWD connector it says, TX and RX, how do I use them?
                        Or really what I mean, how do you debug the device? I use a ST-Link V2, but I am not getting any COM-port so I cannot start the serial debugger. Is the TX/RX used for the serial debugging? Can I use ST-Link V2 for this or do I need a separate device?
                        I have tried to change the driver with ZADIG, but still no COM-port. As for now I have only connected 4 of the 6 pins in the SWD.
                        Please @berkseo help me!
                        berkseoB 4 Replies Last reply
                        • magpernM magpern
                          debug_level: 0
                          0x4000
                          auto erase enabled
                          ** Verified OK **
                          Questions?
                          berkseoB
                          berkseoB
                          berkseo
                          yes
                          • magpernM magpern
                            berkseoB
                            berkseoB
                            berkseo
                            Calculate the resistor divider. It is on the power Board. Perhaps you have mixed up resistors.
                            • magpernM magpern
                              berkseoB
                              berkseoB
                              berkseo
                              Via TTL Converter. The program must be enabled in the debug.
                              • berkseoB berkseo
                                magpernM
                                magpernM
                                magpern
                                TTL Converter.
                                Thanks! I found in another thread one could use a FTDI, I will try that!
                                • magpernM magpern
                                  berkseoB
                                  berkseoB
                                  berkseo
                                  You can connect the programmer and TTL Converter at the same time. You can also do so - https://translate.google.ru/translate?hl=&sl=ru&tl=en&u=https%3A%2F%2Fmysensors-rus.github.io%2Ftroubleshooting_on_Cortex_MCU_in_Arduino%2F
                                  • magpernM magpern
                                    TTL Converter.
                                    berkseoB
                                    berkseoB
                                    berkseo
                                    @magpern any USB2COM of your choice :)
                                    • magpernM magpern
                                      berkseoB
                                      berkseoB
                                      berkseo
                                      @magpern Very neatly done!
                                      magpernM bjacobseB 3 Replies Last reply
                                      • berkseoB berkseo
                                        magpernM
                                        magpernM
                                        magpern
                                        @berkseo Thanks! Hopefully I can finish my project of automating my radiators. Project has been ongoing for many years.
                                        Btw, any chance you could upload the gerber for the newest version of the board, the one with the inductor placed more centered on the board and with a hole in the power board? I see now the boards sandwich better if the hole is there.
                                        (and ofcourse of you have a newer version of the code, that too)
                                        • berkseoB berkseo
                                          bjacobseB
                                          bjacobseB
                                          bjacobse
                                          @berkseo
                                          Good looking device that you have created originally :-)
