  3. 💬 EFEKTA Temp&Hum sensor(ver. nRF52 )+E-Ink display
nrf52832e-ink displaye-papernrf52nrf52810nrf52811nrf52840temperature & humidity sensor
105 Posts 11 Posters 35.1k Views 12 Watching
  • berkseoB berkseo
    @magpern
    https://static.chipdip.ru/lib/465/DOC002465453.pdf
    H
    H
    heinzv
    @berkseo I have continued to work on the new PCB's und have oredered some 603 resistors und condensors. I have checked all of the parts and the soldering but did not get the one PCB to displays something. The program runs und I see the LED flashing and also the log looks normal.
    A build a second PCB and this one shows the intro graphics but with a grey background and then it stops showing something. No idea what goes wrong.
    berkseoB 1 Reply Last reply
    • H heinzv
      berkseoB
      berkseoB
      berkseo
      @heinzv
      I apologize that long did not answer. Did you solve the problem? I noticed that the inductance is small (it seemed to me). You should also check for solder connectors ribbon cable. Perhaps not all contacts are soldered and some contact lies on the PCB is not soldered. I had once, it was not well soldered contact pin on display connector .
      • berkseoB
        berkseoB
        berkseo
        Can you take me pictures in good resolution?
        H 1 Reply Last reply
        • berkseoB berkseo
          H
          H
          heinzv
          @berkseo no I have not solved the problem yet. I 'll take another picture with higher resolution tomorrow and post it here.
          The inductance has the value which is specifiied (I think 68uH). I have all ordered by the links provided.
          I have checked the soldering and resolved a few times. I think all pins shall be soldered, but I can verify it again. That was also my first thought and checked the ribbon cable over and over again.
          • H heinzv
            H
            H
            heinzv
            wrote on last edited by heinzv
            #80
            @berkseo took a bit longer and I have now taken a picture with my Nikon Cam, not sure if it helps, I might add another one if required.
            But you see the inductor has 68uH.
            • D
              dakipro
              hey @berkseo these look amazing, any estimate when they might be available again as assembled unit?
              Any estimate on how long the battery lasts, with lats say update every 15min?
              Could these be updated OTA somehow (or directly perhaps)?
              I would like to have option to change layout, or perhaps add some other values to it maybe.
              They look amazing, I would like several of these in each room for various things displayed
              • magpernM
                magpernM
                magpern
                wrote on last edited by magpern
                #82
                @berkseo @heinzv I finally got around to solder one of these together. It was not easy, placing the components was kind of a guessing game, but I think I got it right. When I put two batteries in and turn it on there is a buzzing noise, maybe normal? Anyway... I never realized programming this thing would be a problem.
                What equipment is needed to program it? I don't recognize the labeling on the pcb (gnd/vcc sdo/sclk rx/tx)
                magpernM 1 Reply Last reply
                • magpernM magpern
                  magpernM
                  magpernM
                  magpern
                  @berkseo is the device programmed when output says this?
                  Licensed under GNU GPL v2
                  For bug reports, read
                  debug_level: 0
                  0x4000
                  adapter speed: 10000 kHz
                  xPSR: 0x01000000 pc: 0xfffffffe msp: 0xfffffffc
                  ** Programming Started **
                  auto erase enabled
                  target halted due to breakpoint, current mode: Thread
                  xPSR: 0x61000000 pc: 0x2000001e msp: 0xfffffffc
                  wrote 102400 bytes from file C:\Users\eu1391\AppData\Local\Temp\arduino_build_38086/epd1in54-demo.ino.hex in 2.178483s (45.904 KiB/s)
                  ** Programming Finished **
                  ** Verify Started **
                  xPSR: 0x61000000 pc: 0x2000002e msp: 0xfffffffc
                  verified 100668 bytes in 0.296666s (331.378 KiB/s)
                  ** Verified OK **
                  ** Resetting Target **
                  shutdown command invoked
                  The only thing happening when I turn it on, is that the LED flashed once. Then occasionally the LED flashed sporadically.
                  The e-paper is just white.
                  Questions?
                  Can you power the board from another source then the battery pcb?
                  The board needs to be powered when programming it, right? I'm using a ST-LINK V2 with the SWD pins connected.
                  How do you debug the board? I use Arduino IDE
                  magpernM berkseoB 2 Replies Last reply
                  • magpernM magpern
                    debug_level: 0
                    0x4000
                    auto erase enabled
                    ** Verified OK **
                    Questions?
                    magpernM
                    magpernM
                    magpern
                    It sure is lonely in here... but finally SUCCESS!!!!
                    After days of googling and checking and rechecking the board for shorts, I found the problem. The 68uH was dead. Maybe damaged when soldering it. It did not conduct anything. After changing it to a new one, the display started working.
                    Any idea how battery can be at 60% on more or less fresh batteries... anyway, that is another problem.
                    I still have one question, if anyone can chip in that would be great.
                    On the SWD connector it says, TX and RX, how do I use them?
                    Or really what I mean, how do you debug the device? I use a ST-Link V2, but I am not getting any COM-port so I cannot start the serial debugger. Is the TX/RX used for the serial debugging? Can I use ST-Link V2 for this or do I need a separate device?
                    I have tried to change the driver with ZADIG, but still no COM-port. As for now I have only connected 4 of the 6 pins in the SWD.
                    Please @berkseo help me!
                    berkseoB 4 Replies Last reply
                    • magpernM magpern
                      debug_level: 0
                      0x4000
                      auto erase enabled
                      ** Verified OK **
                      Questions?
                      berkseoB
                      berkseoB
                      berkseo
                      @magpern said in 💬 EFEKTA Temp&Hum sensor(ver. nRF52832 )+E-Ink display:
                      yes
                      • magpernM magpern
                        berkseoB
                        berkseoB
                        berkseo
                        Calculate the resistor divider. It is on the power Board. Perhaps you have mixed up resistors.
                        • magpernM magpern
                          berkseoB
                          berkseoB
                          berkseo
                          Via TTL Converter. The program must be enabled in the debug.
                          • berkseoB berkseo
                            magpernM
                            magpernM
                            magpern
                            @berkseo said in 💬 EFEKTA Temp&Hum sensor(ver. nRF52832 )+E-Ink display:
                            TTL Converter.
                            Thanks! I found in another thread one could use a FTDI, I will try that!
                            • magpernM magpern
                              berkseoB
                              berkseoB
                              berkseo
                              You can connect the programmer and TTL Converter at the same time. You can also do so - https://translate.google.ru/translate?hl=&sl=ru&tl=en&u=https%3A%2F%2Fmysensors-rus.github.io%2Ftroubleshooting_on_Cortex_MCU_in_Arduino%2F
                              • magpernM magpern
                                TTL Converter.
                                berkseoB
                                berkseoB
                                berkseo
                                @magpern any USB2COM of your choice :)
                                • magpernM magpern
                                  berkseoB
                                  berkseoB
                                  berkseo
                                  @magpern Very neatly done!
                                  magpernM bjacobseB 3 Replies Last reply
                                  • berkseoB berkseo
                                    magpernM
                                    magpernM
                                    magpern
                                    @berkseo Thanks! Hopefully I can finish my project of automating my radiators. Project has been ongoing for many years.
                                    Btw, any chance you could upload the gerber for the newest version of the board, the one with the inductor placed more centered on the board and with a hole in the power board? I see now the boards sandwich better if the hole is there.
                                    (and ofcourse of you have a newer version of the code, that too)
                                    • berkseoB berkseo
                                      bjacobseB
                                      bjacobseB
                                      bjacobse
                                      @berkseo
                                      Good looking device that you have created originally :-)
                                      • berkseoB berkseo
                                        magpernM
                                        magpernM
                                        magpern
                                        #94
                                        Edit: After I posted this the device has worked for 2 days. But still, the capasitors are they correct?
                                        @berkseo I have a wierd problem with the SHT20 sensor. It stops working after a few reads. Then the device hangs and goes into battery draining mode with atleast 8mA constant current. I have localized it to the SHT20, because if I comment out the init and read temp/humidity of the SHT20 the device boots up.
                                        The wierdest is that the SHT20 stops responding for quite some time, even if I power cycle the device, it is still not responding.
                                        Last night I had it running for 1 hour, powered with 3.3V directly. Turned power of, had some sleep, turned power on SHT20 not responding. Turned power of, played with the kids, 3 hours later turned power on, the SHT20 is now responding. Now it's been going for 20 minutes and is still responding. But I bet if I let it run, it will stop.
                                        I am fairly sure the SHT20 is soldered to the board correctly. I used reflow (heatgun) and solder paste was liquid and I could poke the SHT20 and it popped back automatically by surface tension.
                                        I have also tried to replace the SHT20, but the result is the same. the device when hung)
                                        Anything you recognize?
                                        I have not yet successfully been able to debug the device, if i compile with the MY_DEBUG active, the device does not come on and the led shines constantly and I'm not sure how to connect the FTDI, should Vcc on the SWD provide power or not?
                                        I have checked the capasitors C12, C13 and C14 since they have been talked about before and differ from the BOM list and the real board.
                                        C12 is 10uF
                                        C13 is 100uF (100uF is very big, only had a 1206 size, but I got it in place, will get 47uF 0805 for next iteration, waiting for a solder paste dispenser from China)
                                        C14 is 100nF
                                        • L
                                          L
                                          lexusburn
                                          @berkseo i have 2 questions regarding your device:
                                          1. Is it possible to add some additional sensors or are no UARTs left?
                                            I would like to add an accelerometer and 2-4 capacitive touch sensors.
                                          2. Where can I order the PCBs or an assembled version, because the order links on open hardware.io aren't working anymore. Get only the eBay startpage.
