  3. WAF in jeopardy today
18 Posts 5 Posters 3.6k Views 4 Watching
  • dbemowskD
    dbemowskD
    One other reason I'd like to switch to a MySensors based solution is that I bought a new batch of 5 Sonoff Basics, only to find that they changed the design of the board. The one on the right in the two images is the old version, and the left is the new updated version.
    The old version was based off of the ESP8266 controller like the NodeMCU devices. The new ones are ESP8285 based. The firmware that I use on my Sonoff devices is the ESPEasy firmware. My Vera plugin, which is a modified version of the "HTTP Switch (WiFi Switch)" plugin. My ESP8266 based sonoff devices were easily programmed using the Arduino IDE selecting ESP8266 with 64M No SPIFFS. Even after selecting ESP8285 and trying multiple SPIFFS settings, I cannot get them to flash. The ESPEasy website claims that the 8285 is supported, but they don't seem to show a way of flashing them that works. I have read a number of forum posts from various places that say they are difficult to program, with no one having a clear cut set of instructions to program them. Another reason to go the MySensors route.
    K 1 Reply Last reply
    • dbemowskD dbemowsk
      K
      K
      kimot
      wrote on last edited by kimot
      @dbemowsk
      I have 12 of these new and working without any problems.
      There is a missing gpio14 pin, where I connected the DS18B20, but I used the RX pin instead.
      PCB design is more solid to me - you can even see the power fuse.
      ESPeasy flashing without problem using esptool.
      My way to program new Sonoffs:
      To check comunication:
      esptool.py --port /dev/ttyUSB0 flash_id
      Erase flash:
      esptool.py --port /dev/ttyUSB0 erase_flash
      Program ESPeasy bin:
      esptool.py --port /dev/ttyUSB0 --baud 115200 write_flash 0x00000 ESP_Easy_v2.0-20180322_normal_ESP8285_1024.bin
      Look here:
      https://www.letscontrolit.com/forum/viewtopic.php?f=4&t=6415&p=35265#p35265
      • dbemowskD
        dbemowskD
        @kimot Do you have a copy of your ESP_Easy bin file? It would be nice to program these and use them, it's just been a big struggle trying to find out how to do it. The earlier ones I got were ESP8266 based and flashed really easy with the arduino IDE. I am assuming you are hooking it up with the standard gnd-gnd, tx-rx, rx-tx and 3.3v-3.3v, correct?
          K
          K
          kimot
          @dbemowsk
          It is from here:
          https://github.com/letscontrolit/ESPEasy/releases/tag/v2.0-20180322
          I connect it like you wrote.
          dbemowskD 2 Replies Last reply
          • K kimot
            @dbemowsk
            It is from here:
            dbemowskD
            dbemowskD
            @kimot Thanks, I will try flashing them tonight.
            • K kimot
              @dbemowsk
              It is from here:
              dbemowskD
              dbemowskD
              @kimot So I don't do a lot with python, and when I try to use a command similar to what you posted I get errors. So here is some background on the file structure that I have. I downloaded the ESPEasy_v2.0-20180322.zip file and unpacked it to a folder. That contained a source folder, the .bin files and a set of windows esp flash tools. I noticed that it didn't include the esptool.py python scripts, so I downloaded the source code zip file and unpacked the test folder into the same folder as the .bin files, since that looked like it had the necessary python scripts. So now I have a source and test folder, the .bin files and the windows executables. I navigated a terminal window into the test folder and ran this:
              ./esptool.py --port /dev/ttyUSB0 --baud 115200 write_flash 0x00000 ../ESP_Easy_v2.0-20180322_normal_ESP8285_1024.bin
              This is the errors that I got when I ran it.
              [dbemowsk@phpwebscripting test]$ ./esptool.py --port /dev/ttyUSB0 --baud 115200 write_flash 0x00000 ../ESP_Easy_v2.0-20180322_normal_ESP8285_1024.bin
              esptool.py v1.3
                File "./esptool.py", line 1328, in <module>
                  main()
                File "./esptool.py", line 1236, in main
                  esp = ESPROM(args.port, initial_baud)
                File "./esptool.py", line 75, in __init__
                  self._port = serial.serial_for_url(port)
                File "/usr/lib/python2.7/site-packages/serial/__init__.py", line 88, in serial_for_url
                  instance.open()
                File "/usr/lib/python2.7/site-packages/serial/serialposix.py", line 265, in open
                  self._update_dtr_state()
                File "/usr/lib/python2.7/site-packages/serial/serialposix.py", line 595, in _update_dtr_state
                  fcntl.ioctl(self.fd, TIOCMBIS, TIOCM_DTR_str)
              IOError: [Errno 5] Input/output error
              I must be missing something, but I cannot figure out what it is.
              EDIT: if it matters, I am running Fedora 28 linux.
                esptool.py v1.3
                    main()
                    instance.open()
                K
                K
                kimot
                @dbemowsk
                You must install esptool:
                https://diyprojects.io/esp-easy-flash-firmware-esptool-py-esp8266/
                or
                https://github.com/arendst/Sonoff-Tasmota/wiki/Esptool#esptool-executable-windows--linux
                Attention, there are some dependencies...
                Then normally go to folder where .bin file is placed and run command:
                or
                python esptool.py .........................
                not ./esptool.py
                But I suggest first try :
                To check if every is OK ( port, etc )
                • K kimot
                  @dbemowsk
                  or
                  or
                  not ./esptool.py
                  dbemowskD
                  dbemowskD
                  @kimot I had already tried that through dnf prior to running that, but I did it again.
                  [root@phpwebscripting test]# sudo dnf install esptool
                  Last metadata expiration check: 2:13:12 ago on Wed 27 Feb 2019 04:35:51 AM CST.
                  Package esptool-2.3.1-1.fc27.noarch is already installed, skipping.
                  Dependencies resolved.
                  Nothing to do.
                  Complete!
                  • wallyllamaW
                    wallyllamaW
                    wallyllama
                    I know WAF is not a joking matter, but I immediately heard Greg Kihn sing, " my WAf's in jeopardy, baby".
                    dbemowskD 1 Reply Last reply
                    • wallyllamaW wallyllama
                      dbemowskD
                      dbemowskD
                      @wallyllama YES.....Drop the mic.
                      • K kimot
                        @dbemowsk
                        or
                        or
                        not ./esptool.py
                        dbemowskD
                        dbemowskD
                        @kimot So I'm a bit confused. I ran this:
                        pip install esptool
                        and then got this:
                        [root@phpwebscripting test]# esptool.py --port /dev/ttyUSB0 --baud 115200 write_flash 0x00000 ../ESP_Easy_v2.0-20180322_normal_ESP8285_1024.bin
                        esptool.py v2.6
                        Serial port /dev/ttyUSB0
                        Connecting....
                        Detecting chip type... ESP8266
                        Chip is ESP8285
                        Features: WiFi, Embedded Flash
                        MAC: dc:4f:22:92:eb:55
                        Uploading stub...
                        Running stub...
                        Stub running...
                        Configuring flash size...
                        Auto-detected Flash size: 1MB
                        Compressed 609280 bytes to 403063...
                        Wrote 609280 bytes (403063 compressed) at 0x00000000 in 36.0 seconds (effective 135.4 kbit/s)...
                        Hash of data verified.
                        Leaving...
                        Hard resetting via RTS pin...
                        So it worked. BUT, I connected a second one and tried running it again and got this:
                        esptool.py v2.6
                          File "/usr/bin/esptool.py", line 2959, in <module>
                            _main()
                          File "/usr/bin/esptool.py", line 2952, in _main
                            main()
                          File "/usr/bin/esptool.py", line 2646, in main
                            esp = ESPLoader.detect_chip(each_port, initial_baud, args.before, args.trace)
                          File "/usr/bin/esptool.py", line 258, in detect_chip
                            detect_port = ESPLoader(port, baud, trace_enabled=trace_enabled)
                          File "/usr/bin/esptool.py", line 222, in __init__
                            instance.open()
                        I ended up getting them all programmed, but I had to unplug and plug in the serial adapter a few times to reset it. It had even reset the device to /dev/ttyUSB1 for a couple of them. STRANGE...
                        Thanks for the help.
                          pip install esptool
                          and then got this:
                          esptool.py v2.6
                          Connecting....
                          Chip is ESP8285
                          Uploading stub...
                          Running stub...
                          Stub running...
                          Leaving...
                          esptool.py v2.6
                              _main()
                              main()
                              instance.open()
                          K
                          K
                          kimot
                          @dbemowsk
                          Yes, sometimes it got USB1 instead of USB0.
                          You can create fix symlink for your USBtoSerial adapter and then write for example ttySonoff and allways will be right.
                          • K kimot
                            @dbemowsk
                            dbemowskD
                            dbemowskD
                            @kimot The main thing is that I got them flashed. I still have yet to figure out the new firmware and test them, but I am confident I can get them to work.
                            Thanks again.
