  3. WAF in jeopardy today
18 Posts 5 Posters 3.6k Views 4 Watching
  • dbemowskD dbemowsk
    @kimot Do you have a copy of your ESP_Easy bin file? It would be nice to program these and use them, it's just been a big struggle trying to find out how to do it. The earlier ones I got were ESP8266 based and flashed really easy with the arduino IDE. I am assuming you are hooking it up with the standard gnd-gnd, tx-rx, rx-tx and 3.3v-3.3v, correct?
    K
    K
    kimot
    wrote on last edited by kimot
    @dbemowsk
    It is from here:
    https://github.com/letscontrolit/ESPEasy/releases/tag/v2.0-20180322
    I connect it like you wrote.
    dbemowskD 2 Replies Last reply
    • K kimot
      @dbemowsk
      It is from here:
      dbemowskD
      dbemowskD
      @kimot Thanks, I will try flashing them tonight.
      • K kimot
        @dbemowsk
        It is from here:
        dbemowskD
        dbemowskD
        @kimot So I don't do a lot with python, and when I try to use a command similar to what you posted I get errors. So here is some background on the file structure that I have. I downloaded the ESPEasy_v2.0-20180322.zip file and unpacked it to a folder. That contained a source folder, the .bin files and a set of windows esp flash tools. I noticed that it didn't include the esptool.py python scripts, so I downloaded the source code zip file and unpacked the test folder into the same folder as the .bin files, since that looked like it had the necessary python scripts. So now I have a source and test folder, the .bin files and the windows executables. I navigated a terminal window into the test folder and ran this:
        ./esptool.py --port /dev/ttyUSB0 --baud 115200 write_flash 0x00000 ../ESP_Easy_v2.0-20180322_normal_ESP8285_1024.bin
        This is the errors that I got when I ran it.
        [dbemowsk@phpwebscripting test]$ ./esptool.py --port /dev/ttyUSB0 --baud 115200 write_flash 0x00000 ../ESP_Easy_v2.0-20180322_normal_ESP8285_1024.bin
        esptool.py v1.3
          File "./esptool.py", line 1328, in <module>
            main()
          File "./esptool.py", line 1236, in main
            esp = ESPROM(args.port, initial_baud)
          File "./esptool.py", line 75, in __init__
            self._port = serial.serial_for_url(port)
          File "/usr/lib/python2.7/site-packages/serial/__init__.py", line 88, in serial_for_url
            instance.open()
          File "/usr/lib/python2.7/site-packages/serial/serialposix.py", line 265, in open
            self._update_dtr_state()
          File "/usr/lib/python2.7/site-packages/serial/serialposix.py", line 595, in _update_dtr_state
            fcntl.ioctl(self.fd, TIOCMBIS, TIOCM_DTR_str)
        IOError: [Errno 5] Input/output error
        I must be missing something, but I cannot figure out what it is.
        EDIT: if it matters, I am running Fedora 28 linux.
        K 1 Reply Last reply
          esptool.py v1.3
              main()
              instance.open()
          K
          K
          kimot
          @dbemowsk
          You must install esptool:
          https://diyprojects.io/esp-easy-flash-firmware-esptool-py-esp8266/
          or
          https://github.com/arendst/Sonoff-Tasmota/wiki/Esptool#esptool-executable-windows--linux
          Attention, there are some dependencies...
          Then normally go to folder where .bin file is placed and run command:
          esptool.py --port /dev/ttyUSB0 --baud 115200 write_flash 0x00000 ESP_Easy_v2.0-20180322_normal_ESP8285_1024.bin
          or
          python esptool.py .........................
          not ./esptool.py
          But I suggest first try :
          esptool.py --port /dev/ttyUSB0 flash_id
          To check if every is OK ( port, etc )
          • K kimot
            @dbemowsk
            or
            or
            not ./esptool.py
            dbemowskD
            dbemowskD
            @kimot I had already tried that through dnf prior to running that, but I did it again.
            [root@phpwebscripting test]# sudo dnf install esptool
            Last metadata expiration check: 2:13:12 ago on Wed 27 Feb 2019 04:35:51 AM CST.
            Package esptool-2.3.1-1.fc27.noarch is already installed, skipping.
            Dependencies resolved.
            Nothing to do.
            Complete!
            • wallyllamaW
              wallyllamaW
              wallyllama
              I know WAF is not a joking matter, but I immediately heard Greg Kihn sing, " my WAf's in jeopardy, baby".
              dbemowskD 1 Reply Last reply
              • wallyllamaW wallyllama
                dbemowskD
                dbemowskD
                @wallyllama YES.....Drop the mic.
                • K kimot
                  @dbemowsk
                  or
                  or
                  not ./esptool.py
                  dbemowskD
                  dbemowskD
                  @kimot So I'm a bit confused. I ran this:
                  pip install esptool
                  and then got this:
                  [root@phpwebscripting test]# esptool.py --port /dev/ttyUSB0 --baud 115200 write_flash 0x00000 ../ESP_Easy_v2.0-20180322_normal_ESP8285_1024.bin
                  esptool.py v2.6
                  Serial port /dev/ttyUSB0
                  Connecting....
                  Detecting chip type... ESP8266
                  Chip is ESP8285
                  Features: WiFi, Embedded Flash
                  MAC: dc:4f:22:92:eb:55
                  Uploading stub...
                  Running stub...
                  Stub running...
                  Configuring flash size...
                  Auto-detected Flash size: 1MB
                  Compressed 609280 bytes to 403063...
                  Wrote 609280 bytes (403063 compressed) at 0x00000000 in 36.0 seconds (effective 135.4 kbit/s)...
                  Hash of data verified.
                  Leaving...
                  Hard resetting via RTS pin...
                  So it worked. BUT, I connected a second one and tried running it again and got this:
                  esptool.py v2.6
                    File "/usr/bin/esptool.py", line 2959, in <module>
                      _main()
                    File "/usr/bin/esptool.py", line 2952, in _main
                      main()
                    File "/usr/bin/esptool.py", line 2646, in main
                      esp = ESPLoader.detect_chip(each_port, initial_baud, args.before, args.trace)
                    File "/usr/bin/esptool.py", line 258, in detect_chip
                      detect_port = ESPLoader(port, baud, trace_enabled=trace_enabled)
                    File "/usr/bin/esptool.py", line 222, in __init__
                      instance.open()
                  I ended up getting them all programmed, but I had to unplug and plug in the serial adapter a few times to reset it. It had even reset the device to /dev/ttyUSB1 for a couple of them. STRANGE...
                  Thanks for the help.
                    pip install esptool
                    and then got this:
                    esptool.py v2.6
                    Connecting....
                    Chip is ESP8285
                    Uploading stub...
                    Running stub...
                    Stub running...
                    Leaving...
                    esptool.py v2.6
                        _main()
                        main()
                        instance.open()
                    K
                    K
                    kimot
                    @dbemowsk
                    Yes, sometimes it got USB1 instead of USB0.
                    You can create fix symlink for your USBtoSerial adapter and then write for example ttySonoff and allways will be right.
                    • K kimot
                      @dbemowsk
                      dbemowskD
                      dbemowskD
                      @kimot The main thing is that I got them flashed. I still have yet to figure out the new firmware and test them, but I am confident I can get them to work.
                      Thanks again.
