  3. Multiple Relays + Motion sketch, fully customizable, optional timer, manual override
24 Posts 11 Posters 10.2k Views 13 Watching
    Did you try to add a small delay in the presentation?
    • B
      B
      Ben Andrewes
      @gohan - yep added wait(100) between each sensor. To be honest I made a number of small changes without re-uploading and testing between so I'm not sure what solved it... Oh well, at least it works now :)
      • O
        O
        Ostoja
        Hello! Sorry for my english. This sketch works fine. But I still need to add a temperature sensor ds18b20. If I add a temperature sensor, the sketch stops working. Please help. I'm new to both Arduino and Mysensors. Many thanks!!!
        rejoe2R 1 Reply Last reply
        • O Ostoja
          rejoe2R
          rejoe2R
          rejoe2
          @ostoja Please add your code. Most likely you just transfered the DS18x20-Code into the relay sketch including the sleep() at the end of the loop().
          If you did it that way: This had been discussed here several times, you have to change the code into a so-called non-bocking loop().
          O 1 Reply Last reply
          • rejoe2R rejoe2
            O
            O
            Ostoja
            wrote on last edited by Ostoja
            @rejoe2, MANY thanks for answer! Relay don't work in Domoticz :white_frowning_face:
            // Enable and uncomment attached radio type
            //#define MY_TRANSPORT_WAIT_READY_MS 1      // uncomment this to enter the loop() and setup()-function even when the node cannot be registered to gw
            //----------------------- Relay and Motion Sensor Configuration -----------------------
            #define MOTION                                                    // un-comment to enable motion sensing
            #define NUMBER_OF_RELAYS  1                                       // Total number of attached relays. Must be equal to total number of elements in array below!
            const int RELAYS[]                  =     {4};                    // digital pins of attached relays
            const int MOTION_ACTIVATED_RELAYS[] =     {1,  0};                // 1 to trigger the relay through motion, 0 to not trigger. Array length must correspond to RELAYS[] array.
            const long ON_TIMES[]               =     {300, 0};               // Specify for each element in MOTION_ACTIVATED_RELAYS, how long the specified relay should be active in seconds.
            #define RELAY_ON          1                                       // GPIO value to write to turn on attached relay
            #define RELAY_OFF         0                                       // GPIO value to write to turn off attached relay
            #define MOTION_PIN        3                                       // The digital input pin of the motion sensor
            #define MOTION_CHILD_ID   10                                      // Set the child id of the motion sensor
            bool ack = 1;                                                     // set this to 1 if you want destination node to send ack back to this node
            //----------------------- DO NOT CHANGE -----------------------------
            MyMessage motion_msg(MOTION_CHILD_ID, V_TRIPPED);                 // Initialize motion message
            unsigned long trigger_millis[NUMBER_OF_RELAYS];                   // Used for the timer
            bool lastTripped = 0;                                             // Used to store last motion sensor value
            bool manual_override = 1;                                         // if this gets set to 1 (e.g. by a switch or a command from the gateway), motion triggering of relays is deactivated
            MyMessage relay_msg;                                              // Initialize relay message
            #include <OneWire.h>
            #define ONE_WIRE_BUS 2 // Pin where dallase sensor is connected
            int numSensors=0;
            bool receivedConfig = false;
            bool metric = true;
            MyMessage msg(0,V_TEMP);
            void before()
              sensors.begin();
              int i;
              for (int sensor = 1, i = 0; sensor <= NUMBER_OF_RELAYS; sensor++, i++) {
                // set relay pins to output mode
                pinMode(RELAYS[i], OUTPUT);
                // Restore relay to last known state (using eeprom storage)
                digitalWrite(RELAYS[i], loadState(sensor) ? RELAY_ON : RELAY_OFF);
              // set motion pin to output mode, if MOTION is defined
            #ifdef MOTION
              pinMode(MOTION_PIN, INPUT);
            #ifdef MOTION
              // give the motion sensor some time to settle
              Serial.println("Starting up. Please wait 8 seconds...");
              delay(8000);
              sendSketchInfo("Relay/Motion", "1.0");
                 present(i, S_TEMP);
              for (int sensor = 1; sensor <= NUMBER_OF_RELAYS; sensor++) {
                present(sensor, S_BINARY, "Relay", ack);
            #ifdef MOTION
              present(MOTION_CHILD_ID, S_MOTION, "Motion Sensor", ack);
              sleep(conversionTime);
                #if COMPARE_TEMP == 1
              sleep(SLEEP_TIME);
            #ifdef MOTION
              if (!manual_override) {
                // Read digital motion value
                bool tripped = digitalRead(MOTION_PIN) == HIGH;
                if (lastTripped != tripped) {
                  Serial.print("New Motion State: ");
                  Serial.println(tripped);
                  // Send tripped value to gw
                  send(motion_msg.set(tripped ? "1" : "0"));
                  lastTripped = tripped;
                  // Change relay states, send new state to gw and store state in eeprom
                  if (tripped == 1) {
                    for (int i = 0; i < NUMBER_OF_RELAYS; i++) {
                      if (MOTION_ACTIVATED_RELAYS[i] == 1) {
                        digitalWrite(RELAYS[i], RELAY_ON);
                        relay_msg_constructor(i + 1, V_STATUS);
                        send(relay_msg.set(RELAY_ON));
                        trigger_millis[i] = millis();
                        Serial.print("Relay ");
                        Serial.print(RELAYS[i]);
                        Serial.println(" turned on");
                        saveState(i, 1);
                  if (tripped == 1 and MOTION_ACTIVATED_RELAYS[i] == 1 and trigger_millis[i] != 0) {
                  if ((trigger_millis[i] + ON_TIMES[i] * 1000 < millis()) and MOTION_ACTIVATED_RELAYS[i] == 1 and trigger_millis[i] != 0) {
                    digitalWrite(RELAYS[i], RELAY_OFF);
                    send(relay_msg.set(RELAY_OFF));
                    Serial.println(" turned off");
                    saveState(i, 0);
                    trigger_millis[i] = 0;
              else {
                  if (MOTION_ACTIVATED_RELAYS[i] == 1 and trigger_millis[i] != 0) {
                    trigger_millis[i] = 0;                            // reset running timers
              // Handle incoming relay commands
                if (RELAYS[message.sensor - 1]) {
                  digitalWrite(RELAYS[message.sensor - 1], message.getBool() ? RELAY_ON : RELAY_OFF);
                  // Store state in eeprom
                  saveState(message.sensor - 1, message.getBool());
              // Handle incoming manual override/bypass of motion sensor
              if (message.type == V_ARMED and message.sensor == 0) {
                manual_override = message.getBool();
                Serial.print("Manual Override: ");
                Serial.println(manual_override);
            void relay_msg_constructor(int sensor, uint8_t type)
              relay_msg.setSensor(sensor);
              relay_msg.setType(type);
            dirkcD 1 Reply Last reply
            • O
              O
              Ostoja
              I commented out the "sleep", but when I press the relay switch in Domoticz, it does not work:white_frowning_face:
              • O Ostoja
                int numSensors=0;
                bool metric = true;
                void before()
                  sensors.begin();
                  int i;
                #ifdef MOTION
                #ifdef MOTION
                  delay(8000);
                     present(i, S_TEMP);
                #ifdef MOTION
                  sleep(SLEEP_TIME);
                #ifdef MOTION
                      if (tripped == 1) {
                            saveState(i, 1);
                        saveState(i, 0);
                  else {
                dirkcD
                dirkcD
                dirkc
                wrote on last edited by dirkc
                #21
                @ostoja said in Multiple Relays + Motion sketch, fully customizable, optional timer, manual override:
                     present(i, S_TEMP);
                With this two "for" loops you set present(n) multiple times. in the first for() you start with 0 until MAX_ATTACHED_DS18B20-1, in the second for() you start with 1 until NUMBER_OF_RELAYS-1, so this will assign the sensors with identical IDs as the relays.
                I have not checked the internal code of this method, but I would think that you should better user a different range in the second for() loop starting at least with MAX_ATTACHED_DS18B20+1.
                Controller: Home Assistant & FHEM - Gateway: ESP8266wifi - MySensors: 2.3.2 (nRF24)
                • rejoe2R
                  rejoe2R
                  rejoe2
                  wrote on last edited by rejoe2
                  #22
                  @dirkc said in Multiple Relays + Motion sketch, fully customizable, optional timer, manual override:
                       present(i, S_TEMP);
                  Additional remarks:
                  For the relays better start with 1.
                  Shift the Temp values to higer range (use e.g. a variable like FRIST_DS_SENSOR_ID).
                  Check, if the receive()-part and the ID you get really fits together with the relay you want to switch.
                  Don't try to read the temperature values every few parts of a second. Use a millis()-routine.
                  Please search the forum, there have to be at least 2 threads with exactly the same problems in which I posted how to solve this. You are "trying to reinvent the wheel". :grin:
                  • O Ostoja
                    dirkcD
                    dirkcD
                    dirkc
                    @ostoja look at this video with an explanation of this topic and how to handle the IDs
                    https://forum.mysensors.org/post/26597
                    • B
                      B
                      bereska
                      @HenryWhite thank you for the excellent sketch. It works like a charm in my HA configuration!
