Multiple Relays + Motion sketch, fully customizable, optional timer, manual override
@AndreD said in Multiple Relays + Motion sketch, fully customizable, optional timer, manual override:
How to send the relay to the gateway every 30 seconds?
Why would you need that?
Suppose.
We have a server + gateway + relay module 1 + relay module 2 ..... all relays are on.
There is a power failure at the relay module ..... the relays turned off.
The server status is old, not correct.
The recording of the status of the relay in memory is not acceptable. -
person
Next problem....
Anybody know how edit sketch for relays to add itrms to send repeate update status to gateway? I want eliminate problem when node start and change status , but gateway is disabled. And after gateway will be enable show in my Domoticz old status/last memory before disable gateway. But after this node has changed status and this status is not show in Domoticz after run. I want to work it as Z-Wave. Z-wave has always actual status. Is any chance to also MySensors Gateway and not has always actual status ? -
Suppose.
то gohan
Example.- The server turned on the relay at 11 hours 00 minutes.
2.In 11-02 minutes. Alarm with relay module power.
3.In 11-05 minutes the server sends a command to turn off the relay. - in 11-30 minutes. The power to the relay module resumes. (Relay Enabled)
- Server status is off (Relay is on)
- The result - the neighbors below are happy to repair: (
Question. How to request real relay status from the server.
то gohan
I'm having trouble getting Domoticz to see any more than 1 relay. I've tried the MySensors example basic relay sketch and no luck. Then I tried this one (which is amazing btw as I want to have a PIR independent of the relays) and the same problem.
I've tried to present the sensors individually without the FOR statement, and added a delay between presentation in case that was an issue, also I've tried different output pins on the Arduino, and I've tried multiple boards... Nothing has worked
I am very much an enthusiastic amateur, so any advice on what to try next much appreciated
Thanks in advance
Thanks in advance
@Ben-Andrewes My domoticz instance behaves weirdly with relay sketches too. Maybe you can find some help here: https://forum.mysensors.org/topic/7101/domoticz-relay-node-doesn-t-show-up-in-devices/21
@thierryd Thanks for the reply. In case it helps anyone I ended up individually defining and presenting the relays and their parameters within the sketch rather than using the FOR statement and it worked fine.
@gohan - yep added wait(100) between each sensor. To be honest I made a number of small changes without re-uploading and testing between so I'm not sure what solved it... Oh well, at least it works now :)
Hello! Sorry for my english. This sketch works fine. But I still need to add a temperature sensor ds18b20. If I add a temperature sensor, the sketch stops working. Please help. I'm new to both Arduino and Mysensors. Many thanks!!!
@ostoja Please add your code. Most likely you just transfered the DS18x20-Code into the relay sketch including the sleep() at the end of the loop().
If you did it that way: This had been discussed here several times, you have to change the code into a so-called non-bocking loop(). -
If you did it that way: This had been discussed here several times, you have to change the code into a so-called non-bocking loop().@rejoe2, MANY thanks for answer! Relay don't work in Domoticz :white_frowning_face:
// Enable and uncomment attached radio type #define MY_RADIO_NRF24 //#define MY_TRANSPORT_WAIT_READY_MS 1 // uncomment this to enter the loop() and setup()-function even when the node cannot be registered to gw //----------------------- Relay and Motion Sensor Configuration ----------------------- #define MOTION // un-comment to enable motion sensing #define NUMBER_OF_RELAYS 1 // Total number of attached relays. Must be equal to total number of elements in array below! const int RELAYS[] = {4}; // digital pins of attached relays const int MOTION_ACTIVATED_RELAYS[] = {1, 0}; // 1 to trigger the relay through motion, 0 to not trigger. Array length must correspond to RELAYS[] array. const long ON_TIMES[] = {300, 0}; // Specify for each element in MOTION_ACTIVATED_RELAYS, how long the specified relay should be active in seconds. #define RELAY_ON 1 // GPIO value to write to turn on attached relay #define RELAY_OFF 0 // GPIO value to write to turn off attached relay #define MOTION_PIN 3 // The digital input pin of the motion sensor #define MOTION_CHILD_ID 10 // Set the child id of the motion sensor bool ack = 1; // set this to 1 if you want destination node to send ack back to this node //----------------------- DO NOT CHANGE ----------------------------- #include <MySensors.h> MyMessage motion_msg(MOTION_CHILD_ID, V_TRIPPED); // Initialize motion message unsigned long trigger_millis[NUMBER_OF_RELAYS]; // Used for the timer bool lastTripped = 0; // Used to store last motion sensor value bool manual_override = 1; // if this gets set to 1 (e.g. by a switch or a command from the gateway), motion triggering of relays is deactivated MyMessage relay_msg; // Initialize relay message #include <DallasTemperature.h> #include <OneWire.h> #define COMPARE_TEMP 1 // Send temperature only if changed? 1 = Yes 0 = No #define ONE_WIRE_BUS 2 // Pin where dallase sensor is connected #define MAX_ATTACHED_DS18B20 16 unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds) OneWire oneWire(ONE_WIRE_BUS); // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs) DallasTemperature sensors(&oneWire); // Pass the oneWire reference to Dallas Temperature. float lastTemperature[MAX_ATTACHED_DS18B20]; int numSensors=0; bool receivedConfig = false; bool metric = true; // Initialize temperature message MyMessage msg(0,V_TEMP); void before() { // Startup up the OneWire library sensors.begin(); int i; for (int sensor = 1, i = 0; sensor <= NUMBER_OF_RELAYS; sensor++, i++) { // set relay pins to output mode pinMode(RELAYS[i], OUTPUT); // Restore relay to last known state (using eeprom storage) digitalWrite(RELAYS[i], loadState(sensor) ? RELAY_ON : RELAY_OFF); } // set motion pin to output mode, if MOTION is defined #ifdef MOTION pinMode(MOTION_PIN, INPUT); #endif } void setup() { // requestTemperatures() will not block current thread sensors.setWaitForConversion(false); #ifdef MOTION // give the motion sensor some time to settle Serial.println("Starting up. Please wait 8 seconds..."); delay(8000); #endif } void presentation() { // Send the sketch version information to the gateway and Controller sendSketchInfo("Relay/Motion", "1.0"); // Fetch the number of attached temperature sensors numSensors = sensors.getDeviceCount(); // Present all sensors to controller for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) { present(i, S_TEMP); } // Register all sensors to gw (they will be created as child devices) for (int sensor = 1; sensor <= NUMBER_OF_RELAYS; sensor++) { present(sensor, S_BINARY, "Relay", ack); } #ifdef MOTION present(MOTION_CHILD_ID, S_MOTION, "Motion Sensor", ack); #endif } void loop() { // Fetch temperatures from Dallas sensors sensors.requestTemperatures(); // query conversion time and sleep until conversion completed int16_t conversionTime = sensors.millisToWaitForConversion(sensors.getResolution()); // sleep() call can be replaced by wait() call if node need to process incoming messages (or if node is repeater) sleep(conversionTime); // Read temperatures and send them to controller for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) { // Fetch and round temperature to one decimal float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.; // Only send data if temperature has changed and no error #if COMPARE_TEMP == 1 if (lastTemperature[i] != temperature && temperature != -127.00 && temperature != 85.00) { #else if (temperature != -127.00 && temperature != 85.00) { #endif // Send in the new temperature send(msg.setSensor(i).set(temperature,1)); // Save new temperatures for next compare lastTemperature[i]=temperature; } } sleep(SLEEP_TIME); #ifdef MOTION if (!manual_override) { // Read digital motion value bool tripped = digitalRead(MOTION_PIN) == HIGH; if (lastTripped != tripped) { Serial.print("New Motion State: "); Serial.println(tripped); // Send tripped value to gw send(motion_msg.set(tripped ? "1" : "0")); lastTripped = tripped; // Change relay states, send new state to gw and store state in eeprom if (tripped == 1) { for (int i = 0; i < NUMBER_OF_RELAYS; i++) { if (MOTION_ACTIVATED_RELAYS[i] == 1) { digitalWrite(RELAYS[i], RELAY_ON); relay_msg_constructor(i + 1, V_STATUS); send(relay_msg.set(RELAY_ON)); trigger_millis[i] = millis(); Serial.print("Relay "); Serial.print(RELAYS[i]); Serial.println(" turned on"); saveState(i, 1); } } } } for (int i = 0; i < NUMBER_OF_RELAYS; i++) { if (tripped == 1 and MOTION_ACTIVATED_RELAYS[i] == 1 and trigger_millis[i] != 0) { trigger_millis[i] = millis(); } if ((trigger_millis[i] + ON_TIMES[i] * 1000 < millis()) and MOTION_ACTIVATED_RELAYS[i] == 1 and trigger_millis[i] != 0) { digitalWrite(RELAYS[i], RELAY_OFF); relay_msg_constructor(i + 1, V_STATUS); send(relay_msg.set(RELAY_OFF)); Serial.print("Relay "); Serial.print(RELAYS[i]); Serial.println(" turned off"); saveState(i, 0); trigger_millis[i] = 0; } } } else { bool tripped = digitalRead(MOTION_PIN) == HIGH; if (lastTripped != tripped) { Serial.print("New Motion State: "); Serial.println(tripped); // Send tripped value to gw send(motion_msg.set(tripped ? "1" : "0")); lastTripped = tripped; } for (int i = 0; i < NUMBER_OF_RELAYS; i++) { if (MOTION_ACTIVATED_RELAYS[i] == 1 and trigger_millis[i] != 0) { trigger_millis[i] = 0; // reset running timers } } } #endif } void receive(const MyMessage &message) { // Handle incoming relay commands if (message.type == V_STATUS) { // Change relay state if (RELAYS[message.sensor - 1]) { digitalWrite(RELAYS[message.sensor - 1], message.getBool() ? RELAY_ON : RELAY_OFF); // Store state in eeprom saveState(message.sensor - 1, message.getBool()); // Write some debug info Serial.print("Incoming change for sensor:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println(message.getBool()); } } // Handle incoming manual override/bypass of motion sensor if (message.type == V_ARMED and message.sensor == 0) { manual_override = message.getBool(); Serial.print("Manual Override: "); Serial.println(manual_override); } } void relay_msg_constructor(int sensor, uint8_t type) { relay_msg.setSensor(sensor); relay_msg.setType(type); } -
// Enable and uncomment attached radio type #define MY_RADIO_NRF24 //#define MY_TRANSPORT_WAIT_READY_MS 1 // uncomment this to enter the loop() and setup()-function even when the node cannot be registered to gw //----------------------- Relay and Motion Sensor Configuration ----------------------- #define MOTION // un-comment to enable motion sensing #define NUMBER_OF_RELAYS 1 // Total number of attached relays. Must be equal to total number of elements in array below! const int RELAYS[] = {4}; // digital pins of attached relays const int MOTION_ACTIVATED_RELAYS[] = {1, 0}; // 1 to trigger the relay through motion, 0 to not trigger. Array length must correspond to RELAYS[] array. const long ON_TIMES[] = {300, 0}; // Specify for each element in MOTION_ACTIVATED_RELAYS, how long the specified relay should be active in seconds. #define RELAY_ON 1 // GPIO value to write to turn on attached relay #define RELAY_OFF 0 // GPIO value to write to turn off attached relay #define MOTION_PIN 3 // The digital input pin of the motion sensor #define MOTION_CHILD_ID 10 // Set the child id of the motion sensor bool ack = 1; // set this to 1 if you want destination node to send ack back to this node //----------------------- DO NOT CHANGE ----------------------------- #include <MySensors.h> MyMessage motion_msg(MOTION_CHILD_ID, V_TRIPPED); // Initialize motion message unsigned long trigger_millis[NUMBER_OF_RELAYS]; // Used for the timer bool lastTripped = 0; // Used to store last motion sensor value bool manual_override = 1; // if this gets set to 1 (e.g. by a switch or a command from the gateway), motion triggering of relays is deactivated MyMessage relay_msg; // Initialize relay message #include <DallasTemperature.h> #include <OneWire.h> #define COMPARE_TEMP 1 // Send temperature only if changed? 1 = Yes 0 = No #define ONE_WIRE_BUS 2 // Pin where dallase sensor is connected #define MAX_ATTACHED_DS18B20 16 unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds) OneWire oneWire(ONE_WIRE_BUS); // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs) DallasTemperature sensors(&oneWire); // Pass the oneWire reference to Dallas Temperature. float lastTemperature[MAX_ATTACHED_DS18B20]; int numSensors=0; bool receivedConfig = false; bool metric = true; // Initialize temperature message MyMessage msg(0,V_TEMP); void before() { // Startup up the OneWire library sensors.begin(); int i; for (int sensor = 1, i = 0; sensor <= NUMBER_OF_RELAYS; sensor++, i++) { // set relay pins to output mode pinMode(RELAYS[i], OUTPUT); // Restore relay to last known state (using eeprom storage) digitalWrite(RELAYS[i], loadState(sensor) ? RELAY_ON : RELAY_OFF); } // set motion pin to output mode, if MOTION is defined #ifdef MOTION pinMode(MOTION_PIN, INPUT); #endif } void setup() { // requestTemperatures() will not block current thread sensors.setWaitForConversion(false); #ifdef MOTION // give the motion sensor some time to settle Serial.println("Starting up. Please wait 8 seconds..."); delay(8000); #endif } void presentation() { // Send the sketch version information to the gateway and Controller sendSketchInfo("Relay/Motion", "1.0"); // Fetch the number of attached temperature sensors numSensors = sensors.getDeviceCount(); // Present all sensors to controller for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) { present(i, S_TEMP); } // Register all sensors to gw (they will be created as child devices) for (int sensor = 1; sensor <= NUMBER_OF_RELAYS; sensor++) { present(sensor, S_BINARY, "Relay", ack); } #ifdef MOTION present(MOTION_CHILD_ID, S_MOTION, "Motion Sensor", ack); #endif } void loop() { // Fetch temperatures from Dallas sensors sensors.requestTemperatures(); // query conversion time and sleep until conversion completed int16_t conversionTime = sensors.millisToWaitForConversion(sensors.getResolution()); // sleep() call can be replaced by wait() call if node need to process incoming messages (or if node is repeater) sleep(conversionTime); // Read temperatures and send them to controller for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) { // Fetch and round temperature to one decimal float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.; // Only send data if temperature has changed and no error #if COMPARE_TEMP == 1 if (lastTemperature[i] != temperature && temperature != -127.00 && temperature != 85.00) { #else if (temperature != -127.00 && temperature != 85.00) { #endif // Send in the new temperature send(msg.setSensor(i).set(temperature,1)); // Save new temperatures for next compare lastTemperature[i]=temperature; } } sleep(SLEEP_TIME); #ifdef MOTION if (!manual_override) { // Read digital motion value bool tripped = digitalRead(MOTION_PIN) == HIGH; if (lastTripped != tripped) { Serial.print("New Motion State: "); Serial.println(tripped); // Send tripped value to gw send(motion_msg.set(tripped ? "1" : "0")); lastTripped = tripped; // Change relay states, send new state to gw and store state in eeprom if (tripped == 1) { for (int i = 0; i < NUMBER_OF_RELAYS; i++) { if (MOTION_ACTIVATED_RELAYS[i] == 1) { digitalWrite(RELAYS[i], RELAY_ON); relay_msg_constructor(i + 1, V_STATUS); send(relay_msg.set(RELAY_ON)); trigger_millis[i] = millis(); Serial.print("Relay "); Serial.print(RELAYS[i]); Serial.println(" turned on"); saveState(i, 1); } } } } for (int i = 0; i < NUMBER_OF_RELAYS; i++) { if (tripped == 1 and MOTION_ACTIVATED_RELAYS[i] == 1 and trigger_millis[i] != 0) { trigger_millis[i] = millis(); } if ((trigger_millis[i] + ON_TIMES[i] * 1000 < millis()) and MOTION_ACTIVATED_RELAYS[i] == 1 and trigger_millis[i] != 0) { digitalWrite(RELAYS[i], RELAY_OFF); relay_msg_constructor(i + 1, V_STATUS); send(relay_msg.set(RELAY_OFF)); Serial.print("Relay "); Serial.print(RELAYS[i]); Serial.println(" turned off"); saveState(i, 0); trigger_millis[i] = 0; } } } else { bool tripped = digitalRead(MOTION_PIN) == HIGH; if (lastTripped != tripped) { Serial.print("New Motion State: "); Serial.println(tripped); // Send tripped value to gw send(motion_msg.set(tripped ? "1" : "0")); lastTripped = tripped; } for (int i = 0; i < NUMBER_OF_RELAYS; i++) { if (MOTION_ACTIVATED_RELAYS[i] == 1 and trigger_millis[i] != 0) { trigger_millis[i] = 0; // reset running timers } } } #endif } void receive(const MyMessage &message) { // Handle incoming relay commands if (message.type == V_STATUS) { // Change relay state if (RELAYS[message.sensor - 1]) { digitalWrite(RELAYS[message.sensor - 1], message.getBool() ? RELAY_ON : RELAY_OFF); // Store state in eeprom saveState(message.sensor - 1, message.getBool()); // Write some debug info Serial.print("Incoming change for sensor:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println(message.getBool()); } } // Handle incoming manual override/bypass of motion sensor if (message.type == V_ARMED and message.sensor == 0) { manual_override = message.getBool(); Serial.print("Manual Override: "); Serial.println(manual_override); } } void relay_msg_constructor(int sensor, uint8_t type) { relay_msg.setSensor(sensor); relay_msg.setType(type); }@ostoja said in Multiple Relays + Motion sketch, fully customizable, optional timer, manual override:
// Present all sensors to controller for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) { present(i, S_TEMP); } // Register all sensors to gw (they will be created as child devices) for (int sensor = 1; sensor <= NUMBER_OF_RELAYS; sensor++) { present(sensor, S_BINARY, "Relay", ack); }With this two "for" loops you set present(n) multiple times. in the first for() you start with 0 until MAX_ATTACHED_DS18B20-1, in the second for() you start with 1 until NUMBER_OF_RELAYS-1, so this will assign the sensors with identical IDs as the relays.
I have not checked the internal code of this method, but I would think that you should better user a different range in the second for() loop starting at least with MAX_ATTACHED_DS18B20+1. -
@dirkc said in Multiple Relays + Motion sketch, fully customizable, optional timer, manual override:
I have not checked the internal code of this method, but I would think that you should better user a different range in the second for() loop starting at least with MAX_ATTACHED_DS18B20+1.Additional remarks:
For the relays better start with 1.
Shift the Temp values to higer range (use e.g. a variable like FRIST_DS_SENSOR_ID).
Check, if the receive()-part and the ID you get really fits together with the relay you want to switch.
Don't try to read the temperature values every few parts of a second. Use a millis()-routine.Please search the forum, there have to be at least 2 threads with exactly the same problems in which I posted how to solve this. You are "trying to reinvent the wheel". :grin:
I commented out the "sleep", but when I press the relay switch in Domoticz, it does not work:white_frowning_face:
@HenryWhite thank you for the excellent sketch. It works like a charm in my HA configuration!
