  3. Possible problem with sketch?
7 Posts 3 Posters 1.2k Views 3 Watching
  • HomerH Offline
    HomerH Offline
    Homer
    Hi everyone
    I haven't been around all that often recently, had stuff happening in my life for the last couple years, but things are getting better and I am keen to get back into this and start enjoying myself again, even though I am very much a noob.
    So I recently dusted off my Mysensors gear and and getting it all up and running again. A couple days ago I managed to redo my Ethernet Gateway and connect it successfully to my Vera controller. I even managed to connect a couple old sensors. As I was just testing at the time, today I deleted those old sensors with the plan to rebuild what I have and set them up again. Unfortunately I seem to be having issues with connecting my first 'new' Mysensor to the gateway and showing in Vera. The node is a repeater with 2 relays. I did have it working a couple days ago, but today I changed the code as I needed the relays to just open momentarily, and the Arduino IDE saved the new sketch over the old working one. Anyways, this is the sketch:
     * Version 1.0 - Henrik Ekblad
     * Example sketch showing how to control physical relays.
     * This example will remember relay state after power failure.
     * http://www.mysensors.org/build/relay
    #define MY_REPEATER_FEATURE
    #define NUMBER_OF_RELAYS 2 // Total number of attached relays
    void before()
            pinMode(pin, OUTPUT);
            if (loadState(sensor) == RELAY_ON) {
    digitalWrite(pin, RELAY_ON);
    wait(1000);
    digitalWrite(pin, RELAY_OFF);
        sendSketchInfo("Relay", "1.0");
            present(sensor, S_BINARY);
        if (message.type==V_STATUS) {
            // Change relay state
            if (message.getBool() == RELAY_ON) {
    digitalWrite(message.sensor-1+RELAY_1, RELAY_ON);
    wait(1000);
    digitalWrite(message.sensor-1+RELAY_1, RELAY_OFF);
            // Store state in eeprom
    I have restarted the Gateway, but the issue is still present. I thought I would see if you all could review the sketch in case I did something wrong to it, because I can't see a problem.
    • HomerH Homer
      Hi everyone
      void before()
      wait(1000);
      wait(1000);
      @homer could you describe the nature of this potential problem? Does the sketch not compile? If so, what error message are you getting? Does the sketch not behave as you planned? If so, how does it behave and how do you expect it to behave? A debug log from the sensor could be useful as well.
      Use the auto formatting feature in the Arduino IDE. It will make it easier to read the code, for yourself and for everyone trying to help you.
      • HomerH Offline
        HomerH Offline
        Homer
        Thank you for your reply.
        Good news; it's working, but I don't know why exactly. The last thing I did was to send the sketch to the arduino twice in a row. Anyways, the gateway now registers the node, so that is great!
        I will have to look into the auto formatting, because I thought that I had uploaded the sketch in an easy to view way. Anyways I will look into it if it will help with assistance!
        Now though I have another issue.... I have it so the relay will open, wait a second, and then close. The controller though is not updating and showing that the relay has closed. Time to look for a fix! :-)
        • HomerH Offline
          HomerH Offline
          Homer
          I managed to do a workaround. I have created a scene in Vera where it will automatically turn the device off after two seconds whenever it's operated.
          If there was something I could have added to the sketch to make this happen without the scene, I'm keen to know!
          • B Offline
            B Offline
            bgunnarb
            Hi @Homer
            The reason that the controller does not reflect the status of the relay is that you are not telling it that the status has changed.
            This is a snippet of how I have coded the same thing:
                  state = message.getBool();          // Change relay state
                  saveState(CHILD_ID_RELAY, state);        // Store state in eeprom
                  printStateChangedDebug(CHANGE_STATE_SOURCE_RADIO, CHILD_ID_RELAY, state);
            // Set status of relay pin
              send(msgSW.set(state), false);           // acknowledge new state to controller, no ack requested
            When the message is received, I first change the relay, then I confirm the status with the send-message.
            I have never been so busy since I retired!
            • B bgunnarb
              Hi @Homer
              @bgunnarb just a note: calling send from within receive will overwrite the received message. In your case it is ok, since you're not using the message variable after calling setRelayState (which calls send). But for example if printStateChangedDebug would use the message variable, the data would contain the sent message, not the received message.
              • HomerH Offline
                HomerH Offline
                Homer
                Thank you for everyone's replies!
                12.1k
