  3. Dectect wake up source
12 Posts 5 Posters 2.3k Views 3 Watching
  • GeforceGamerG GeforceGamer
    is it possible to dectect how my node wakes up? If the wake up cames form the button or by timer?
    this is my sleep code:
    sleep(digitalPinToInterrupt(reedswitch), CHANGE, SLEEP_TIME);
    I want to check something like this:
    If (wakeUpByTime == 1)
        Serial.println("Node wakes up by timer");
       Serial.println("Node wakes up by Button");
    sundberg84S
    sundberg84S
    @geforcegamer
    if (interruptReturn == true) {    // Woke up by changing pin
       if woken by interrupt code
    if (interruptReturn == false) { // Woke up by timer  (or it's the first run)
    'if not by interrupt
     interruptReturn = sleep(digitalPinToInterrupt(PIR_PIN), RISING, SLEEP_TIME);
    From my doorbell sensor: https://github.com/sundberg84/HomeAutomation/blob/master/Sketches MySensors Nrf24l01 radio/DoorBellDec1mhz/DoorBellDec1mhz.ino
    Waiting for en external interrupt, or a timer.
    Im sure there are better/prettier code since thats not my stronge side. But its an example...
    • GeforceGamerG
      GeforceGamerG
      GeforceGamer
      @nagelc Thank you.
      @sundberg84 Thanks for the great example. It really helped me a lot. I will try it out the days.
      • GeforceGamerG
        GeforceGamerG
        GeforceGamer
        unfortunately it does not work with me so. I don't know whats wrong. At the first start of the node it works. But the wakeup by time shows wake up by interrupt and the wake by interrupt shows "wake up by interrupt" too.
        if (interruptReturn == true)     // Woke up by changing pin
            wakeup= 1;
            Serial.println("wake up interrupt");
          if (interruptReturn == false)     // Woke up by Timer
            wakeup= 0;
            Serial.println("wake up timer");
        interruptReturn = sleep(digitalPinToInterrupt(reedswitch), CHANGE, SLEEP_TIME);
              wakeup= 1;
              wakeup= 0;
          @geforcegamer what do you use as interrupt source?
          If you use e.g. a hardware button then bouncing of the switch contacts can cause the node to wake up unexpectedly.
          Also, you wake on CHANGE, meaning both a low high and high low transition will wake up your node (e.g. Button press and button release).
          Can you describe your hardware setup?
          • GeforceGamerG
            GeforceGamerG
            GeforceGamer
            @Yveaux
            I use an reedswitch as interrupt source. It is use in a bin to measure the level. I use the CHANGE command to always wake up the node. No matter if the lid is opened or closed.
              @Yveaux
              @geforcegamer how is the interruptreturn variable declared? Is it scoped to survive (we can only see part of your code - maybe the value is lost at the end of loop()?
              • GeforceGamerG
                GeforceGamerG
                GeforceGamer
                wrote on last edited by GeforceGamer
                bool interruptReturn;
                    offen = 1;
                    Serial.println("aufwachen durch Deckel");
                    offen = 0;
                    Serial.println("aufwachen durch Timer");
                      offen = 1;
                      offen = 0;
                  @geforcegamer I think I found the problem. Sleep returns an int, not a bool. Change
                  to
                  int interruptReturn;
                  and change
                    offen = 1;
                    offen = 0;
                  to
                  if (interruptReturn == MY_WAKE_UP_BY_TIMER)
                    offen = 0;
                  } else  {     // Woke up by interrupt (or MY_SLEEP_NOT_POSSIBLE)
                    offen = 1;
                  Documentation: https://www.mysensors.org/download/sensor_api_20#sleeping
                  • GeforceGamerG
                    GeforceGamerG
                    GeforceGamer
                    @mfalkvidd
                    Thanks alot. Now the wake-up detection works perfectly
                      @mfalkvidd
                      @geforcegamer great, thanks for reporting the result.
                      @sundberg84 next time you update your doorbell, maybe you should add the same changes.
                      12.5k
