1.1k Posts 105 Posters 790.3k Views 98 Watching
  • sundberg84S sundberg84
    O
    O
    Omemanti
    @sundberg84 that board looks nice and crisp 👍
    • berkseoB
      berkseoB
      berkseo
      Birth of water leakage sensor:) on mysensors..
      https://youtu.be/xsoeffaGAG0
      • O
        O
        Omemanti
        wrote on last edited by Omemanti
        #738
        After months of slow painstaking work (day job is somewhat busy, o and the kids ;) ) I finally completed my Domoticz server(case) with Dashticz as frontend.
        The Endgame; when my new house is finished every room is monitored for motion, RH and Temperature using my MySensors PCB's. (Jung AS500 Node)
        Everything is monitored using a raspberry with a MySensors serial gateway (NRF52) and an RFLink controller for my KAKU switches.
        To make everything nice and shiny I use Dasticz to interface the data in a proper way using a tablet that somehow will be mounted on a wall or something.
        So far the introduction;
        To put everything away nice and tidy I used a box to install everything using 2 pieces of din-rail.
        It has a 230V inlet that is converted to 5V using an off the shelf (safety sake) MeanWell RS-15-5 converter. This powers everything using a couple of din-Rail terminals.
        • Terminal => USB-micro => Raspberry
        • Terminal => just a couple of wires => old nrf52 prototype => FTDI => Raspberry
        • Raspberry => RF-link (ard. Mega +433mhz)
        Since the Raspberry has Wifi no other cable then power is needed to operate
        Second part: the 2 screenshots of dasthicsz.
        The best part, it took some work, but the WAF incread big time, because everything looks clean :)
        dbemowskD 1 Reply Last reply
        • O Omemanti
          dbemowskD
          dbemowskD
          @omemanti Nice DIN rail enclosure.
          O 1 Reply Last reply
          • dbemowskD dbemowsk
            O
            O
            Omemanti
            @dbemowsk
            If someone would be interested:
            Enclosure
            Ard. Mega enclosure
            Raspberry enclosure
            Had to do some modifications for the mega, but the cost of this enclosure was more than worth it.
            Hmz.. normaly don't buy stuff at conrad but apparently they have good prices on cases... 😏
            monteM 1 Reply Last reply
            • O Omemanti
              @dbemowsk
              Enclosure
              Ard. Mega enclosure
              Raspberry enclosure
              monteM
              monteM
              monte
              @omemanti well...enclosure at a price of 3 raspberry pi zero. Good price indeed :)
              • sundberg84S
                sundberg84S
                • HonkH
                  HonkH
                  Honk
                  Nothing fancy. Got my new ts100 today and I pre-soldered some V10 easyPCBs with 3.3v Arduino pro minis.
                  The iron is pretty good. It is Louis Rossmann approved. Now I need a good 24V power source to drive this thing.
                  • FotoFieberF
                    FotoFieberF
                    FotoFieber
                    Testing a CCS811 CO2 sensor. It seems to use less power then the MH-Z14A I am using now. The CCS811 may even run on battery. I will compare measurements of these two sensors with a Netatmo sensor. The sensors have to burn in for two days bevore I start the comparison.
                    The CCS811 breakout board I use hast temp, hum and barometer sensors (and the CO2).
                    Nca78N 1 Reply Last reply
                    • FotoFieberF FotoFieber
                      wrote on last edited by Nca78
                      #745
                      @fotofieber said in What did you build today (Pictures) ?:
                      Unfortunately this is not a CO2 sensor. It's only a VOC sensor giving an estimated eCO2 value. It's useful to tell you if your room needs ventilation, but not much more. And as even the VOC part is not calibrated it's only good for relative measurement.
                      AFAIK the only similar sensors which are calibrated and give absolute values are SGP30 and BME680.
                      If you want to measure CO2 you need a CO2 sensor and it's going to consume a lot of power, at least too much for a battery powered sensor.
                      [edit] there's also the MiCS-VZ-89TE TVOC sensor, they claim to have a curve of eCO2 not too far from NDIR sensor in their datasheet. But that datasheet is strangely poor in details, they didn't even put any electrical characteristics...
                      https://sgx.cdistore.com/datasheets/sgx/MiCS-VZ-89TE_V1.0.pdf
                      • berkseoB
                        berkseoB
                        berkseo
                        My battery operated mini touch switch
                        1_1554642160825_photo_2019-04-07_13-58-03.jpg 0_1554642160824_photo_2019-04-07_13-58-02.jpg
                        • berkseoB
                          berkseoB
                          berkseo
                          1_1554642422327_photo_2019-04-05_21-32-08.jpg 0_1554642422326_photo_2019-04-05_21-32-08 (2).jpg
                          • sundberg84S
                            sundberg84S
                            I don't think I ever managed to get it right the first revision.
                              sundberg84S
                              sundberg84S
                              But it's something...
                                @sundberg84 you should print the board on paper, stick it on a piece cardboard and cut. Then check if size is good, you can even put the "big" components on it by sticking the pins through the cardboard to make sure you'll have enough space.
                                • Nca78N Nca78
                                  sundberg84S
                                  sundberg84S
                                  @nca78 great tip! But it's more common it's a schematic or footprint error. The outline "should" be the easy part even if I messed up.
                                  • Nca78N Nca78
                                    FotoFieberF
                                    FotoFieberF
                                    FotoFieber
                                    wrote on last edited by FotoFieber
                                    #752
                                    @nca78 said in What did you build today (Pictures) ?:
                                    My tests will show, how far away I am with this sensor in my indoor usage scenario.
                                    My Netatmo sensors claim to measure CO2 and are battery powered. They seem to calibrate themselves to the lowest level they measure in 24 hours. This behaviour seems to be similar with the CCS811. The Netatmo sensors seem quite close to my MH-Z14A.
                                    In the datasheet for the CCS811 I have read, that you can't use them in your green house, because of its self calibration. Netatmo may have the same restriction too.
                                    I have ordered a SGP30 some days ago and will test it too. The BME680 needs binary code linked which is a no go for me. (As a gift I would take it into my test setup. :) )
                                    The problem with high power sensors is, that they produce heat, which can make your temperature measurements unusable. :(
                                    As my CO2 sensors have a color led to show air quality, they are mains powered anyway.
                                    Thank you for the link. I have ordered one for my test setup. They are really expensive, about twice the price of the MH-Z14A, the SGP30 or the CCS811.
                                    Other CO2 sensors I should use in my test setup?
                                    I like the MH-Z14A and depending on my tests may stay with them.
                                    EDIT: ordered a MHZ-19 for the tests
                                      Make sure you order a MHZ-19B, it uses less power and has fixed an autocalibration problem.
                                      SenseAir S8 has a better calibration process using several days, so if you don't ventilate your room during 24h it will not use a wrong reference level and report wrong values.
                                      And about BME680 there are boards on AliExpress with included STM32 Cortex M0+, basically it's the same than the MiCS-VZ-89. Search for GY-MCU680V1.
                                      • Nca78N Nca78
                                        FotoFieberF
                                        FotoFieberF
                                        FotoFieber
                                        #754
                                        Thx, ordered one on aliexpress. Hope I have time to test when they arrive... :)
                                        EDIT: first results, hope CCS811 will calibrate better in the next two days
                                        • berkseoB
                                          berkseoB
                                          berkseo
                                          #755
                                          All elements are assembled :)
                                          https://youtu.be/U437QXp3pqI
                                          petewillP 1 Reply Last reply
