  3. Confirming node connected to gateway.
5 Posts 3 Posters 984 Views 3 Watching
  • skywatchS Offline
    skywatchS Offline
    skywatch
    I was thinking of adding something to nodes so that when I reboot them I can see at the node if it has connected to the GW or not. Maybe a message on a small oled to confirm successful registration.
    What would be the most reliable way to do this?
    Can I get some value back from presentation stage?
    Is there anything better to do (like get confirmation from the controller)?
    Maybe I missed the obvious here, but it's late and I have a cold.
    • skywatchS skywatch
      FotoFieberF Offline
      FotoFieberF Offline
      FotoFieber
      @skywatch
      I look for messages (e.g. presentation) at the gateway to diagnose connections at bootup. And I have a flow in node-red, which shows me, when a node didn't send for some time.
      You could use a led and blink codes on the node, if you really need a local indicator. A OLED would be a no go with battery powered sensors.
      • skywatchS Offline
        skywatchS Offline
        skywatch
        Thanks for the reply.
        I really just need 'something' at the node so that when I power it on I know that it has successfully established communication with the gateway.
        On mains powered units it could be a message on a display, on battery units it could be number of flashes of an led.
        I do not know 'how' I can do this. Is there some response at the node that I can monitor/interrogate to find out if successful connection has been made with a remote gateway?
        • alowhumA Offline
          alowhumA Offline
          alowhum
          Here's an example from some of my code, specifically the SETUP function.
            Serial.begin(115200); // for serial debugging over USB.
            if(isTransportReady()){
              Serial.println(F("Connected to gateway!"));
            }else{
              Serial.println(F("! NOT CONNECTED TO GATEWAY"));
          #ifdef HAS_DISPLAY
            mySerial.begin(115200);
            wait(1500);
            mySerial.print(F("CLR(0);"));
            mySerial.print(F("SBC(0);"));
              mySerial.print(F("DCV16(115,1,w,0);"));
            // Labels
            mySerial.print(F("DCV16(10,155,Barometer,5);"));  // Barometer label
            // Wait icon
            mySerial.print(F("CIRF(120,239,35,3);"));       // Circle as a background
            //mySerial.print(F("SBC(3);"));
            //mySerial.print(F("DCV16(105,230,wait,15);"));     // Show while the forecast is not available yet.
            //mySerial.println(F("SBC(0);"));
            wait(400);
            if(!bme280.init()){
              Serial.println(F("! Sensor error"));
          #ifdef HAS_DISPLAY
              mySerial.println(F("DCV16(10,250,Sensor error,1);"));
            wdt_enable(WDTO_2S);                              // Starts the watchdog timer. If it is not reset once every 2 seconds, then the entire device will automatically restart.
          Personally I then display a "w" icon in the top-right of the screen if a connection has been made.
          In the loop code it requests an ACK whenever it updates the sensor values to the gateway (once a minute). There is also a simple incrementing counter byte that increases by 1 every time there is no reply. As soon as this reaches 5 (meaning no response from the server for 5 minutes in a row) it prints an " " to the corner of the screen, to indicate the loss of connection.
          If data once again arrives in the receive function, then a "w" is once again printed to the top right corner, and the incrementing byte is set back to 0.
          skywatchS 1 Reply Last reply
          • alowhumA alowhum
              }else{
            #ifdef HAS_DISPLAY
              wait(1500);
              // Labels
              // Wait icon
              wait(400);
              if(!bme280.init()){
            #ifdef HAS_DISPLAY
            skywatchS Offline
            skywatchS Offline
            skywatch
            @alowhum Thank you for sharing this! - This looks like exactly the kind of thing I was trying to achieve.
            Hopefully I get some time at the weekend to test it out.
            Cheers! :)
            11.9k
            113.3k
