  3. Piezzo siren/alarm
Piezzo siren/alarm
32 Posts 5 Posters 9.4k Views 5 Watching
  • FotoFieberF
    FotoFieberF
    FotoFieber
    For portable usage I have a https://pokitmeter.com/ which is really small and lightweight.
    ben999B 1 Reply Last reply
    • FotoFieberF FotoFieber
      ben999B
      ben999B
      ben999
      wrote on last edited by ben999
      @fotofieber woooooooooooooooow :heart_eyes_cat: :heart_eyes_cat: :heart_eyes_cat:
      I searched last night for something similar (iOS and BT) but couldn't find one
      So i bought a cheap portable one on aliExpress
      https://fr.aliexpress.com/item/JYE-Tech-DSO138-13805K-Mini-Digital-Oscilloscope-DIY-Kit-SMD-Parts-Pre-soldered-Electronic-Learning-Set/32919633946.html?spm=a2g0w.10010108.1000016.1.6349de7cOC8Hnf&isOrigTitle=true
      We're not talking about the same amount of money there...
      But i'm now deeeeeeeeeply in love and will consider PokitMeter for my next workshop toy :heart_eyes:
      Thank you for the link :facepunch: :+1:
        @ben999 can't you just measure the output signal from the original board?
        ben999B
        ben999B
        ben999
        @mfalkvidd Something puzzling me here, can i please borrow your brain for a sec ?
        @bjacobse mentionned that his small piezzo buzzer could take up to 30V...
        So i had a go with my own buzzer and the previous schematic with 1S LiPo up to 6S LiPo (close to 25V) and 440Hz up to 32kHz (max Tone() )
        No change there. Still the same noise i got with a smaller transistor and a 5V power supply.
        Tone() changes the width of the modulation (X scale), so i get different tones.
        Voltage of the power suppy changes the power going through the piezzo disc... but it doesn't get any louder.
        So what is the magic to get a loud buzzer? I shall get my oscilloscope within a month, so until then i keep scratching my head !!
        bjacobseB 1 Reply Last reply
        • ben999B ben999
          bjacobseB
          bjacobseB
          bjacobse
          @ben999
          I guess you don't hit resonance frequency.
          Why not scavenge a piezo from a smokealarm, then you you know that the circuit is made for resonance frequency.
          BTW I did not write MY piezo is working at 30V, I directed to a piezo that Adafruit is using, and that uses up to 30V - just to correct that I hvae not used the pieo myself
          • bjacobseB bjacobse
            @ben999
            ben999B
            ben999B
            ben999
            @bjacobse thanks for clarification :smile:
            No smoke came out of mine under 25V DC so i guess it's ok
            And yes, i shall cut open an old smoke alarm, you're right.
            Thanks a lot
            • ben999B ben999
              Thanks a lot
              bjacobseB
              bjacobseB
              bjacobse
              @ben999
              But also look careful at the smokealarm PCB, as you might be able to reuse this to ensure that you are using resonance frequency
              • FotoFieberF
                FotoFieberF
                FotoFieber
                wrote on last edited by FotoFieber
                AFAIK the piezo acts like a capacitor. If you don't use AC, you may have to discharge it with a parallel resistor or discharge it with a transistor.
                You could find some useful information on eevblog, e.g. http://www.eevblog.com/forum/projects/how-to-connect-a-piezo-speaker-to-a-microcontroller/
                toneAC:
                https://bitbucket.org/teckel12/arduino-toneac/wiki/Home
                  toneAC:
                  ben999B
                  ben999B
                  ben999
                  @fotofieber hi thank you for your message
                  I was coming back here to share my findings.... been playing with... ToneAC :joy:
                  Yes you're right, differential drive makes a hell of a difference! each pin of the piezo speaker are connected to its own arduino output (serial resistor on one pin though) that send the same signal in opposition as to get a differential movment.
                  But i don't quite get it :
                  • driving the piezo speaker with up to 25V doesn't improve noise level at all
                  • switching to differential drive @5V (so it's a 10V potential peak-to-peak) opens hell's doors wide open
                  That's the part i dont understand. I'll carry on investigating.
                  Still: noise level is a bit below as compared to same pizeo speaker connected to original alarm enclosure...
                  I might have a go with transistors and try a differential of 2S or 3S LiPo.
                  Also waiting for my oscilloscope to find out!
                  And lastly: ToneAC uses pins 9 and 10... so it's a NO-NO with nRF24 :cry:
                  Enters... ToneAC2. It's inferior (CPU cycle, accuracy, lower freq) in many points except that pins are configurable.
                  More soon... :nerd_face:
                  mfalkviddM FotoFieberF 2 Replies Last reply
                  • ben999B ben999
                    @ben999 nice work, thanks for sharing.
                    To change pins for the nrf24, use the following in your sketch
                    #define MY_RF24_CE_PIN 7
                    #define MY_RF24_CS_PIN 8
                    • ben999B ben999
                      FotoFieberF
                      FotoFieberF
                      FotoFieber
                      @ben999 said in Piezzo siren/alarm:
                      You may try to use a 1kOhm resistor parallel to the piezo (as suggested on eevblog).
                        ben999B
                        ben999B
                        ben999
                        @mfalkvidd oh yeah I forgot about that one!!! Thanks a lot! I have used this with a Mega for who-knows-what-reason in the past but completely forgot about it! ToneAC still in the race then, thanks again
                        @fotofieber thanks a lot, but that thread is for high-level hobbyists!!! :scream: Schematics, yummy!!!
                        "replace the resistor with an inductor then you double the swing" but no figures... i'll google that and see where it gets me...
                        I dont even know the specs of my piezo :zipper_mouth_face:
                        • ben999B ben999
                          FotoFieberF
                          FotoFieberF
                          FotoFieber
                          @fotofieber thanks a lot, but that thread is for high-level hobbyists!!! Schematics, yummy!!!
                          I try to simplify: Take a 1 kOhm resistor and attach each side of it to another pin of the piezo. Don't change anything else.
                            ben999B
                            ben999B
                            ben999
                            #21
                            @fotofieber :grin: oh yes i got that one correct :stuck_out_tongue_winking_eye:
                            It was more about how to size the inductor and stuff. Guys on these forums know their sh*t, they dont go into much details: "just stick a thing there and you'll be good" :joy:
                            • ben999B
                              ben999B
                              ben999
                              #22
                              Guys,
                              Thanks all a lot for your input.
                              Seems sorted :
                              • differential drive (ToneAC)
                              • transistor (TIP120 in my case, not sure it's my best move)
                              • 3S louder than 2S, itself louder than 1S
                              Schematic TIP120 and 1k resistors
                              I did also put a 1k resistor in between the piezo speaker pins... but it lowered the tone by quite a lot... :thinking_face:
                              To be tested
                              I'll have a go with an inductance to see what " then you double the swing" means... double the loudness or double the speed ?
                              Thanks again, people involved :wink:
                              • ben999B ben999
                                Guys,
                                Seems sorted :
                                To be tested
                                FotoFieberF
                                FotoFieberF
                                FotoFieber
                                Cool, you sorted it out! The resistor may only help in an DC setup (one output from the arduino). In your AC setup it is useless.
                                  ben999B
                                  ben999B
                                  ben999
                                  #24
                                  @fotofieber gosh that a good analysis :+1: that makes a lot of sense
                                  Then i can picture things better:
                                  • one output with 0 et +5V is considered as DC
                                  • two output pulling differentially -5V to +5V... looks like a sin curbe... so it's AC !
                                  Breadboard is out and still cabled, i'll have a go asap and confirm
                                  Thanks again for your knowledge
                                  • ben999B ben999
                                    FotoFieberF
                                    FotoFieberF
                                    FotoFieber
                                    @ben999
                                    You could try DC (one output) with 12V to the piezo. If you want to use only 5V, the AC solution should be louder, as it gets 10V difference to the piezo.
                                    I usually stop optimizing, when it is good enough. If AC is enough, go with it. :)
                                      @ben999
                                      ben999B
                                      ben999B
                                      ben999
                                      #26
                                      @fotofieber DC+ one output is really poor and voltage has no impact on noise. I have tested with up to 6S LiPo and there's absolutely no gain as compared to 5V DC
                                      AC+ two outputs is a game changer! Much louder right from +/-5V and really a killer @ +/-12V.
                                      So that's it: the first iteration of this project will go for a step-up converter from 5V up to 12V for the piezo speaker.
                                      Thanks folks!
                                      EDIT: could someone suggest a MOSFET (or transistor) that could be used in lieu of the huge (and probably over-sized) TIP120 (that where there, waiting in the drawer :) ). Through-hole is my league. SMD is a bit of a struggle (welding, machining pcb, ...)
                                      Thanks again :smiley:
                                      • ben999B
                                        ben999B
                                        ben999
                                        #27
                                        back at it !
                                        I got my LCD microscope out and tried to reverse-engineer the original board. I should have done that to start with.
                                        I drew that circuit on www.falstad.com (this link takes you to my actual circuit) and got several kV out of the simulation lol.
                                        I used the original transformer: i could only measure resistance, so 5,5ohms on primary side, and 195ohms on secondary.
                                        First transistor hooked to wave generator is J3Y. I replaced it with a BC547 (the "copy-paste" engineer hidden inside my head told me it's fairly close lol).
                                        Second transistor is labeled J41CG and seems pretty strong to me so i replaced it with TIP120 .
                                        Next I put all these components onto the breadboard, and load my favourite Nano with this sketch :
                                        const int buzzerPin = 9;
                                        int i = 0;
                                        unsigned long duration = 1000;
                                          pinMode(buzzerPin, OUTPUT);
                                        void   loop() {
                                          for (i = 1000; i < 5000; i++) {
                                            tone(buzzerPin, i, duration);
                                          for (i = 5000; i > 1000; i--) {
                                        That is ever so LOUD !!
                                        So this is plenty good enough for my little project !
                                        next step
                                        • TheoLT
                                          TheoLT
                                          TheoL
                                          There are also a lot of circuits using 555 timers and some old CMOS or TTL chips that easily create the oscilation you need. It draws a bit more power when the piezo is active. But for me that's worth it, because it gets rid of the complication in the code.
                                          And is you have a bad MySensors radio connection, MySensors will keep executing code that might interrupt code. Which is annoying for applications like this, because it will interfere with your piezo sound. That's why I prefer a hardware solution or an active piezo buzzer. The ones that have a range from 3.3V to 24V are usually very load at 24V. They can be driven with a simple fet.
                                          At least that's how I look at electronics now, don't jump to a software solution when some old skool electronics make your life easier.
                                          But I love the project!
                                          12.5k
