1.1k Posts 105 Posters 790.4k Views 98 Watching
  • acbA acb
    Built a 1284(p) into a 328p Pro Mini footprint. Not sure what to call it, a Pro Mini XL maybe?
    I now have x4 the program memory (128K vs. 32K), x4 the EEPROM (4K vs. 1K) and x8 the SRAM (16K vs. 2K) all in a 328p Pro Mini pin-compatible (I think!) footprint of about same size.
    I can also run at 20MHz vs. the usual 8MHz provided I’m prepared to run it at 4.5v and above.
    Had to sacrifice a few pins and components, but might be able to put various selections back in future revisions. Nothing major (in my opinion) just components associated with the regulator really. I also went for a crystal (not installed yet, on order, LEDs too..) over a resonator - just a personal preference for when timing is critical.
    And yes, those are 0402 SMDs. I actually did them by hand (!) with a microscope and a judicious amount of coffee; a fine-point iron, solder wick and flux became my best friends.
    So far, I’ve had it working with nRF24s and RFM69s radios, ATSHA for personalization and external flash for FOTA. The DualOptiboot bootloader code and makefile needed a bit of tweaking, but nothing major.
    I broke out the JTAG I/F but haven’t played with that yet and also added power pins next to the I2C to make some of the sensor modules (like SI7021) pluggable - see below.
    I also want to play with the QTouch library support for built-in capacitive touch buttons, sliders, etc.
    Why not just go with an ARM (STM32, SAMD, nRF52)?
    I’m working on it! ;o)
    Am not wanting to start a(nother) 8-bit vs. 32-bit discussion. I’ve got an AliExpress package of 32-bit MCUs coming (very) slowly to me. When it arrives, I’ll start experimenting and exploring - probably with the nRF52s, since those seem to be the flavor-of-the-month and very capable-looking chips...
    But until then, I need more program memory!
    (Among other things…)
    acbA
    acbA
    acb
    Continuing along the theme of one of my last projects, I built a nRF52832 into a 328p Pro Mini footprint. Made two versions: One with some edge SMA or U.Fl pads and another with a PCB trace antenna:
    I wanted to start getting into using 32-bit microcontrollers (ARM Cortex varieties like nRF5x, SAMDs, STMs, etc.) for some more complex HA and other electronics projects and am trying to ease the learning curve from all my 8-bit ATMEGA experience.
    Keeping the 328p pin-compatible footprint and PCB size means I can still reuse most of my other Pro Mini project boards to get going. An added bonus is the nRF52's ability to remap (almost) any pins, which will no doubt come in handy.
    They’re both two layer boards and I get pretty decent range out of the PCB trace antenna - ever so slightly better RSSI than EByte’s E73-2G4M04S1B, which was surprising since I didn’t really do anything different (that I’m aware of) and their module is shielded too.
    Since there’s no need for a separate nRF24 board and other associated components, like external SRAM or ATSHA, it’ll possibly save me a few $ too! Power pins next to the (remappable) I2C pins make some of the sensor modules (like SI7021) pluggable.
    I also gain 16x the program memory (512K vs. 32K) and 8x the speed (64MHz vs. 8MHz) which is no small increment!
    Some of the project boards I have made use of the Pro Mini 328p’s FTDI pins, so I added a few components to enable the use of an FTDI programmer with custom DFU serial bootloader.
    Basically, a DTR pin toggle from the FTDI will reset the nRF52 into a state where it’ll briefly listen for a new program - similar to Adafruit’s Feather. You can also force that state for a longer period with a combination button press like Nordic and SparkFun’s development boards.
    I’m unfamiliar with SWD/JTAG programming/debugging and all things GDB/OCD, so I built myself a black magic probe out of a STM32 blue pill and am going to have a play with all of that, along with VS Code and PlatformIO and probably one or two others.
    MySensors nRF52 support worked out of the box (!) - so a huge thanks to all the hard work of the folks round here for getting that up and running. If there’s anything I can help with there, please let me know and if I’m able, I’ll try to take a stab at it (OTA maybe?). Like I said, I’ve got quite a steep learning curve here though.
    On the low power end, I added the DCDC components Nordic recommend too and managed to get the MySensors smartSleep() current down to around 0.7uA - as per the datasheet, I think. However, I found that with a couple more code tweaks and grounding the SWDCLK, I would get into the nA region. This seems a bit out of spec to me and perhaps it’s just a measuring error, but it was repeatable and the board still happily sending data/heartbeat again each time it woke up. (It’s fluctuating around 1.6nA below - no sensors connected though, but it’s a start…)
    0_1555494689754_1.6nA Fluctuating Sleep Current - SWDCLK to GND - Pro Mini nRF52.JPG
    One other project in the back of my mind is using this board as the basis for a quadcopter, but that’ll probably have to wait until the summer holidays…!
    nagelcN monteM berkseoB 3 Replies Last reply
    • acbA acb
      nagelcN
      nagelcN
      nagelc
      @acb Nice! I have serious board envy. I really like that clip on programmer too.
      • acbA acb
        monteM
        monteM
        monte
        @acb have you written a bootloader yourself, or found already available? Can you tell more about it and a board you using to connect nrf52 to FTDI?
        Nice work!
        acbA 1 Reply Last reply
        • FanfanF
          FanfanF
          Fanfan
          wrote on last edited by Fanfan
          #766
          Well,in my case, I mounted and tried to fix bugs in my very first design. This is supposed to be a castelizable Sensebender compatible node, embedding NRF24L01+, LED, Temp/Humi/Press sensor, Memory, crypto, with most of the IO exposed. The updated design is online, but still work in progress. 0_1555517692648_IMG_20190417_180651748.jpg
          project on OpenHardware
          • acbA acb
            berkseoB
            berkseoB
            berkseo
            @acb Wow. Awesome
            • berkseoB
              berkseoB
              berkseo
              #768
              My light sensor on the window. Will work as a slave device for the curtain controller.
              https://youtu.be/DQcyOksFXE8
              • sundberg84S
                sundberg84S
                New gateway going live and migrating slowly from Domoticz to Homeassistant. At least to try it.
                • acbA
                  acbA
                  acb
                  @nagelc Thanks! The clip on programmer is one-part Adafruit’s FTDI “Fiddy” from here, and one-part SparkFun’s old (retired?) 3.3 or 5v selectable FTDI programmer with a custom 3D printed enclosure.
                  I plan to modify the “Fiddy” design a bit as there were some elements of it that I’ve found a bit frustrating. However, YMMV. Gotta love pogo pins for programming though…
                  Re: Board envy. Really? Well, if you like, I could do what I did on my last project - which was selling the leftovers. At the moment, I always make more than I need, for testing and some much needed practice with the smaller 0402s. Just send me a chat message if you (or anyone else?) are interested.
                  • monteM monte
                    Nice work!
                    acbA
                    acbA
                    acb
                    @monte Re: FTDI Boards & Bootloaders.
                    I didn’t write the bootloader myself from scratch, but modified and combined various elements from Nordic’s SDK v11 example, SparkFun’s development version and Adafruit’s Feather version.
                    It was quite a nice learning experience of hacking in bootloader land and dealing with event-driven architectures without any low level debugging skills (yet!) - that’s why I’m now trying to get into SWD/JTAG debugging to make things like this easier.
                    I certainly don’t understand everything that’s going on, but “loosely” from what I can figure out, it uses Nordic’s proprietary SoftDevice (S132) combined with some custom bootloader code to boot into a predefined state, where it’ll wait for new “image” either over a serial or bluetooth connection.
                    The new “image” can be either your regular sketch-type code (referred to as the “application”), a new SoftDevice (S212, S332, etc.) and/or even a new bootloader.
                    Once the new “image” is received and validated by the (existing) bootloader, it is copied to replace the existing “image” parts where necessary and the chip is reset.
                    Nordic’s pc-nrfutil command line utility handles interfacing with any standard FTDI board over a COM port (mine is an old SparkFun, but any should work) to perform the upload.
                    In SDK11, there isn’t much in the way of safeguards, but in SDK15 there are things like cryptographic signing, custom initialization packets and protocol buffers, etc.
                    I did have to make one tweak to the nrfutil Python code, to make it wait a little longer after opening the COM port before sending the DFU initialization packet. This might be unnecessary with optimized bootloader code, I don’t know, since the nRF52832 boots pretty quickly.
                    I could go on, but I’m still learning myself, and so if you or anyone else has any other questions, comments, suggestions, etc., perhaps we better move them to a new discussion thread? (Just tag me in so I see it…)
                    Thanks for your interest though!
                    monteM 1 Reply Last reply
                    • FanfanF Fanfan
                      acbA
                      acbA
                      acb
                      Very nice @Fanfan!
                      Love the power protections - those would have saved me a few nRF24s in the past!
                      How have you found the ceramic antennas?
                      I’ve been wondering whether to add pads to mine for experimenting...
                      • berkseoB berkseo
                        @acb Wow. Awesome
                        acbA
                        acbA
                        acb
                        Thanks @berkseo!
                        Have been enjoying your work with nRF52 designs.
                        Also on my list is trying the built-in capacitive touch capabilities of the chip.
                        I can @ you if I get anywhere with it - might come in handy for your capacitive touch glass mini switch to save you a few components?
                        berkseoB 1 Reply Last reply
                        • acbA acb
                          Thanks @berkseo!
                          berkseoB
                          berkseoB
                          berkseo
                          @acb Of course!!!, ttp 223 gives a reliable result, but if there is an opportunity to make a stable implementation based on the chip itself, then definitely it needs to be done. I would appreciate any help and advice.
                          • acbA acb
                            monteM
                            monteM
                            monte
                            @acb we can continue discussion in this thread, If you want: https://forum.mysensors.org/topic/6961/nrf5-action/
                            So as I understand for now you are using native SDK and not using Arduino and mysensors? As far as I know arduino's core for nrf5 has no support for bootloaders, and mysensors conflicts even with softdevice being present on a chip. And it seems that sandeepmistry (author of the core) isn't going to invest his time into writing bootloader and can't use nordic's one because of license. I would like to have a bootloader solely for bluetooth OTA programming for projects beside mysensors. Maybe you could share your work, and/or write some kind of brief tutorial on where to start working on this subject maybe to avoid problems you have already solved? Anyway, great work from you, hope someday we will have mysensors on nrf52 with working OTA.
                            • fernando alvarez buyllaF
                              well this is my project , right now im using 2 arduino nano with ethernet shield to read 3 lines Voltage on a delta instalation , 3 current sensors of 300amps for a motor , and 1 water pressure ,
                              all conected to a raspberry pi with domoticz
                              but yesterday i decide to change all , instead of 2 uno i will use a pro mini with a nrf24
                              so i desing two pcb
                              some code
                              #define MY_NODE_ID 100
                              #define CHILD_ID_VOLT_1 1
                              #define CHILD_ID_VOLT_2 2
                              #define CHILD_ID_VOLT_3 3
                              #define CHILD_ID_CURRENT_1 4
                              #define CHILD_ID_CURRENT_2 5
                              #define CHILD_ID_CURRENT_3 6
                              #define CHILD_ID_PRESION 7
                              #define VOLT_SENSOR_ANALOG_PIN_1 0
                              #define VOLT_SENSOR_ANALOG_PIN_2 1
                              #define VOLT_SENSOR_ANALOG_PIN_3 2
                              #define CURRENT_SENSOR_ANALOG_PIN_1 3
                              #define CURRENT_SENSOR_ANALOG_PIN_2 4
                              #define CURRENT_SENSOR_ANALOG_PIN_3 5
                              #define PressPin      A6
                              unsigned long SLEEP_TIME = 20000; // Sleep time between reads (in milliseconds)
                              MyMessage msg(CHILD_ID_VOLT_1, V_VOLTAGE);
                              MyMessage msg2(CHILD_ID_VOLT_2, V_VOLTAGE);
                              MyMessage msg3(CHILD_ID_VOLT_3, V_VOLTAGE);
                              MyMessage msg4(CHILD_ID_CURRENT_1, V_CURRENT);
                              MyMessage msg5(CHILD_ID_CURRENT_2, V_CURRENT);
                              MyMessage msg6(CHILD_ID_CURRENT_3, V_CURRENT);
                              MyMessage pressureMsg(CHILD_ID_PRESION, V_PRESSURE);
                              float lastVolt1;
                              float lastVolt2;
                              float lastVolt3;
                              float lastCurrent1;
                              float lastCurrent2;
                              float lastCurrent3;
                              float lastPresion;
                              int pressure = 0;
                              float PSI = 0;
                              float PSI_CAL = 2.0;            // Calibration of sensor
                              int PSImsb = 0;
                              int PSIr = 0;
                              void before() {
                               sendSketchInfo("Multisensor", "1.7");  // Send the sketch version information to the gateway and Controller
                               present(CHILD_ID_VOLT_1, S_MULTIMETER);   // Register this device as power sensor
                               present(CHILD_ID_VOLT_2, S_MULTIMETER);   // Register this device as power sensor
                               present(CHILD_ID_VOLT_3, S_MULTIMETER);   // Register this device as power sensor
                               present(CHILD_ID_CURRENT_1, S_MULTIMETER);   // Register this device as power sensor
                               present(CHILD_ID_CURRENT_2, S_MULTIMETER);   // Register this device as power sensor
                               present(CHILD_ID_CURRENT_3, S_MULTIMETER);   // Register this device as power sensor
                               present(CHILD_ID_PRESION, S_WATER);   // Register this device as power sensor
                               int Voltaje1 = analogRead(A0);
                               int Voltaje2 = analogRead(A1);
                               int Voltaje3 = analogRead(A2);
                               int Corriente1 = analogRead(A3);
                               int Corriente2 = analogRead(A4);
                               int Corriente3 = analogRead(A5);
                               float VoltLevel1 = map(Voltaje1,0,1023,0,500);
                               float VoltLevel2 = map(Voltaje2,0,1023,0,500);
                               float VoltLevel3 = map(Voltaje3,0,1023,0,500);
                               float CorrienteLevel1 = map(Corriente1,0,1023,0,200);
                               float CorrienteLevel2 = map(Corriente2,0,1023,0,200);
                               float CorrienteLevel3 = map(Corriente3,0,1023,0,200);
                               Serial.print("Voltaje L1: ");
                               Serial.println(VoltLevel1);
                               Serial.print("Voltaje L2: ");
                               Serial.println(VoltLevel2);
                               Serial.print("Voltaje L3: ");
                               Serial.println(VoltLevel3);
                               Serial.print("Corriente L1: ");
                               Serial.println(CorrienteLevel1);
                               Serial.print("Corriente L2: ");
                               Serial.println(CorrienteLevel2);
                               Serial.print("Corriente L3: ");
                               Serial.println(CorrienteLevel3);
                               //sensor de voltaje
                               if (VoltLevel1 != lastVolt1) {
                                   send(msg.set(VoltLevel1, 1));
                                   lastVolt1 = VoltLevel1;
                                 if (VoltLevel2 != lastVolt2) {
                                   send(msg2.set(VoltLevel2, 1));
                                   lastVolt2 = VoltLevel2;
                                 if (VoltLevel3 != lastVolt3) {
                                   send(msg3.set(VoltLevel3, 1));
                                   lastVolt3 = VoltLevel3;
                              //sensor de corriente
                                 if (CorrienteLevel1 != lastCurrent1) {
                                   send(msg4.set(CorrienteLevel1, 1));
                                   lastCurrent1 = CorrienteLevel1;
                                   if (CorrienteLevel2 != lastCurrent2) {
                                   send(msg5.set(CorrienteLevel2, 1));
                                   lastCurrent2 = CorrienteLevel2;
                                   if (CorrienteLevel3 != lastCurrent3) {
                                   send(msg6.set(CorrienteLevel3, 1));
                                   lastCurrent3 = CorrienteLevel3;
                                 pressure  = analogRead    (PressPin) ;        // junk read
                                 wait(25);
                              /* • Output: 0.5V – 4.5V linear voltage output. 0 psi outputs 0.5V, 50 psi outputs 2.5V, 100 psi outputs 4.5V
                                 0   psi = .33v after scalling 5.0v to 3.3v
                                 50  psi = 1.65v
                                 100 psi = 2.97v
                                 3.3v/1024 = .0032266 volt per bit
                                 if (pressure < 106) pressure = 106;         // this is minimum of .5v
                                 PSI = (pressure - 106 ) * .1246;            // where did we get this?? was .119904
                                 PSI = PSI + PSI_CAL;                        // adjustment
                                 PSImsb = PSI * 100;
                                 PSIr = PSImsb % 100;
                                 send(pressureMsg.set(PSI, 2));            // Send water pressure to gateway
                                 Serial.print("Presion: ");
                                 Serial.println(PSI);
                                 wait(200);
                                  // end of if (SLEEP_MODE || (cu
                               sleep(SLEEP_TIME);
                              havent tested with sensors yet
                              but looks good so far
                              • berkseoB
                                berkseoB
                                berkseo
                                #777
                                Today, the first sensors of the devices were soldered, the prototypes of which passed long-time tests. Eliminated children's sores. In matt black they are good :)
                                1_1556060042292_IMG_20190424_014140.jpg 0_1556060042291_IMG_20190424_014129.jpg
                                • alowhumA
                                  alowhumA
                                  alowhum
                                  #778
                                  @berkseo whoa, time for a Kickstarter! They look great! Where did you have them made, and what do they cost?
                                  @fernando-alvarez-buylla Always nice to see the Aurora theme being used :-)
                                    And a few days later my pcb's arrived
                                    Now to test the next version
                                    • berkseoB
                                      berkseoB
                                      berkseo
                                      #780
                                      Hacking Redmond smart bulb socket RSP-202S
                                      https://youtu.be/ApcpM_Oh7uE
                                      on nRF51822...
                                      • alowhumA
                                        alowhumA
                                        alowhum
                                        How did you 'hack' it? All I see in the video is you changing a power wire?
                                        • alowhumA alowhum
                                          berkseoB
                                          berkseoB
                                          berkseo
                                          #782
                                          @alowhum I replaced the manufacturer's software with my own.
                                          The device now works on the mysensors network
                                          1_1556490583713_photo_2019-04-27_15-12-06.jpg 0_1556490583712_photo_2019-04-07_15-31-44.jpg
