  3. Vera
  4. What makes a device controllable with the mobile app?
15 Posts 4 Posters 5.8k Views 4 Watching
    I mentioned mqtt because it's more widespread and so it's more probable you may find a more tested mqtt plug in rather than a mysensors one. I don't know anything about Vera, I'm just trying to approach the problem from a different perspective 😀
    dbemowskD 1 Reply Last reply
      dbemowskD
      dbemowskD
      @gohan Thanks, I appreciate the help. I do understand that MQTT is more widespread, but as mentioned, I am mainly doing this to learn more about plugin development. That and once it is done, I can give back an option for people that may have a lot of devices set up with ESP Easy and want to switch to Vera, but don't want to re-flash all of their devices.
        I don't know which app you are talking about but I guess the app must recognise the device type. The MySensors plugin mostly uses "standard" device types which probably shows up fine... but we also have a few custom once... like the distance sensor.
        If the app doesn't recognise the type, you probably won't see it.
        gohanG 1 Reply Last reply
          @hek
          It seems that locally everything is working, but on the cloud service he can't interact with the mysensors devices. Could it be that plugins only work locally on the Vera? (I wouldn't be surprised as cloud services are usually not very flexible)
            @hek
            dbemowskD
            dbemowskD
            @hek The app I am talking about is the Vera app for Android. Where can I find/define the device type?
            @gohan That is exactly it. Locally everything is working, but I see what @hek is saying that if the app doesn't recognize the device type, then it won't work from the app.
              Not sure, I haven't tried their cloud service. If you start modifying and create new devices their "cloud" must know how to create the layout... so they would need the locally stored device files (xml/json) which contain the presentation logic.
                dbemowskD
                dbemowskD
                @hek OK, I'll rephrase the question. Where would I find the device type for a standard switch in the MySensors plugin? If I know where to find it there I may be able to find out what I need to change in the new plugin.
                  https://github.com/mysensors/Vera/blob/development/L_Arduino.lua#L53
                    dbemowskD
                    dbemowskD
                    @hek ok, I am assuming that the device type has something to do with the urn:schemas. I am trying to understand the urn:schemas, because I had thought that that might have been part of the issue. In the D_HttpSwitch1.json file from the original creator uses "urn:mios-nullx8-com:serviceId:HttpSwitch1", where the D_BinaryLight1.json file uses "urn:upnp-org:serviceId:SwitchPower1"
                    camadortC 1 Reply Last reply
                    • dbemowskD dbemowsk
                      camadortC
                      camadortC
                      camadort
                      @dbemowsk I know this is a very old topic, but if you still need to control the device with the app, you can change:
                      device_json from D_HttpSwitch1.json to D_BinaryLight1.json
                      • camadortC camadort
                        dbemowskD
                        dbemowskD
                        @camadort Thanks, I didn't know that. I'll give it a try.
