  3. Vera
  4. What makes a device controllable with the mobile app?
15 Posts 4 Posters 5.7k Views 4 Watching
  • dbemowskD
    dbemowskD
    Have I ever thought of using MQTT? I had thought about it, just haven't dove into that yet. Most of my MySensors devices are running on nRF24L01 radios and that part is running good.
    One of my main reasons for doing this is to learn Vera plugin development a bit. The position I am in with this I think is a good way to learn some of the little things about plugin development without having to write an entire plugin from scratch right off the bat. Everything works fine when I connect directly to the Vera. I can turn the devices on and off, use them in scenes and just about anything that I would normally do on the Vera side. The only thing that doesn't seem to be working is anything that connects to my Vera from the getvera site when connecting to my account.
      I mentioned mqtt because it's more widespread and so it's more probable you may find a more tested mqtt plug in rather than a mysensors one. I don't know anything about Vera, I'm just trying to approach the problem from a different perspective 😀
      dbemowskD 1 Reply Last reply
        dbemowskD
        dbemowskD
        @gohan Thanks, I appreciate the help. I do understand that MQTT is more widespread, but as mentioned, I am mainly doing this to learn more about plugin development. That and once it is done, I can give back an option for people that may have a lot of devices set up with ESP Easy and want to switch to Vera, but don't want to re-flash all of their devices.
          I don't know which app you are talking about but I guess the app must recognise the device type. The MySensors plugin mostly uses "standard" device types which probably shows up fine... but we also have a few custom once... like the distance sensor.
          If the app doesn't recognise the type, you probably won't see it.
          gohanG 1 Reply Last reply
            @hek
            It seems that locally everything is working, but on the cloud service he can't interact with the mysensors devices. Could it be that plugins only work locally on the Vera? (I wouldn't be surprised as cloud services are usually not very flexible)
              @hek
              dbemowskD
              dbemowskD
              @hek The app I am talking about is the Vera app for Android. Where can I find/define the device type?
              @gohan That is exactly it. Locally everything is working, but I see what @hek is saying that if the app doesn't recognize the device type, then it won't work from the app.
                Not sure, I haven't tried their cloud service. If you start modifying and create new devices their "cloud" must know how to create the layout... so they would need the locally stored device files (xml/json) which contain the presentation logic.
                  dbemowskD
                  dbemowskD
                  @hek OK, I'll rephrase the question. Where would I find the device type for a standard switch in the MySensors plugin? If I know where to find it there I may be able to find out what I need to change in the new plugin.
                    https://github.com/mysensors/Vera/blob/development/L_Arduino.lua#L53
                      dbemowskD
                      dbemowskD
                      @hek ok, I am assuming that the device type has something to do with the urn:schemas. I am trying to understand the urn:schemas, because I had thought that that might have been part of the issue. In the D_HttpSwitch1.json file from the original creator uses "urn:mios-nullx8-com:serviceId:HttpSwitch1", where the D_BinaryLight1.json file uses "urn:upnp-org:serviceId:SwitchPower1"
                      camadortC 1 Reply Last reply
                      • dbemowskD dbemowsk
                        camadortC
                        camadortC
                        camadort
                        @dbemowsk I know this is a very old topic, but if you still need to control the device with the app, you can change:
                        device_json from D_HttpSwitch1.json to D_BinaryLight1.json
                        • camadortC camadort
                          dbemowskD
                          dbemowskD
                          @camadort Thanks, I didn't know that. I'll give it a try.
