  3. void receive(const MyMessage &message)
40 Posts 6 Posters 7.1k Views 5 Watching
  • skywatchS
    skywatchS
    skywatch
    @mfalkvidd Thanks as ever for the help. So here is my problem and I can't see a way to do it right now.
    A roller blind can be commanded to 'go down' either ....
    by pressing a 'down' button or ...
    by a 'down' command from the controller.
    This needs to move the stepper motor until a pre-defined number of steps have occured UNLESS.....
    it gets a stop message from the controller or......
    the up button is pressed. (this saves having a third button for stop!)..
    I have omitted limit switches and timers to make it simple, but I just can't find a way to make it happen - I know it's not impossible, just beyond my imagination right now! ;)
    Adding too many wait() cycles in the main loop will slow the motor down and it is slow enough already....Hmmmm.....would it be better to just have an if loop instead of while and let that run?
    Or what about putting that pesky 'while' loop within the receive section?
    • skywatchS skywatch
      @skywatch something like this:
      #define STOP 0
      #define UP 1
      #define DOWN 1
      byte state = STOP;
      void loop(){
        // If button is pressed, set state accordingly
        upButton.update();
        // Get the update value
        if (upButton.read()) {
          if(state == STOP){
            state = UP;
          state = STOP // Stop if it was running
        switch (state) {
          case STOP:
          // Stop motor
          digitalWrite(motor_pin_up, 0);
          digitalWrite(motor_pin_down, 0);
          case UP:
          // Start motor up
          digitalWrite(motor_pin_up, 1);
          case DOWN:
          // Start motor down
          digitalWrite(motor_pin_down, 1);
      void receive(){
       // set state to the right value depending on the message from the controller
       if (msg...) state = xxx
      I don't know how you know for how long you need to run the motor, could you explain that part?
      skywatchS 1 Reply Last reply
        #define STOP 0
        #define UP 1
        #define DOWN 1
        byte state = STOP;
        void loop(){
          upButton.update();
            if(state == STOP){
              state = UP;
          switch (state) {
            case STOP:
            // Stop motor
            case UP:
            // Start motor up
            case DOWN:
            // Start motor down
        void receive(){
        skywatchS
        skywatchS
        skywatch
        @mfalkvidd Thanks for the suggestion.
        In order to minimise trouble I have a multi approach to detecting if the blind is 'down'.
        I can count the number of steps the stepper takes to get from fully 'up' to fully 'down'. This figure I can use in the sketch to see if the number of steps moved == measured steps. That way it should be 'down'.
        I can also use a watch to time the motion to get an approximate idea of time of travel. Again, this can be used to act as an indicator that it should have reached it's position and turn off motor just in case.
        I will soon add a magnet to the bottom rail of the blind and this too can be detected with reed relay or hall effect chip as up and down 'limit switches' (not really true limit switches I know, but performing the same function as limit switches).
        This way I now know that if any one thing fails, the other should still stop the motor turning indefinitly.
        Trouble is that steppers require constant commands to go to the next step (hence the while loop) - but then it blocks the receive() from working.
        I'l try and understand your soution and see if it will work with what I have.
        TsM.
        • T
          tommies
          I had problems with incoming messages ans loop.
          If you use nrf24 @Yveaux suggested me to use irq to handle incoming messages.
          I my case it solved my problem
          https://forum.mysensors.org/topic/7190/irq-pin-for-nrf24l01
          • skywatchS
            skywatchS
            skywatch
            @tommies
            Thanks for the help but today I think I am nearly there with this. I am on the third version and it looks promising. I hope to test it fully this week and I'll let you (all) know if it works.
            • P
              P
              pjr
              How about non blocking interrupt driven stepper library? For example: https://github.com/bjpirt/HotStepper
              • skywatchS
                skywatchS
                skywatch
                @pjr Thanks for the hint.
                I believe I have what I need now, will be testing tomorrow I hope.
                Essentially I have reduced void loop() and void receive() down to minimum so the program loops very fast. This way it only calls other void () routines as needed.
                  skywatchS
                  skywatchS
                  skywatch
                  @skywatch Hmmmm....It didn't work as I expected.
                  So if I have a loop with a 'while' routine running, what do I need to do in the 'while' code to check if any messages have arrived?
                  something ike.....
                  while (MOVING_UP == true && stepcount < BLIND_UP) {
                  Do code to turn stepper motor.
                  Check for radio message.
                  Act on radio message (if there is one)
                  Check for button press.
                  Act on button press (if there is one)
                  update step count
                  The buttons and motor I have working, its just that radio messages are currently 'blocked' during the while loop and this isn't good if an emergency stop call is required.
                    something ike.....
                    update step count
                    @skywatch I think you're looking for the wait() function. https://www.mysensors.org/download/sensor_api_20#waiting
                    Or _process() but that's an internal function so it might not be as well documented and might undergo changes that aren't mentioned in release notes in future releases.
                      skywatchS
                      skywatchS
                      skywatch
                      @mfalkvidd I was just about to say something on that! - you just beat me too it! ;)
                      I understand the wait(), but what I have no clue of is how long should a wait() be to get incomming messages? -- Would wait(25); be enough?
                      mfalkviddM YveauxY 2 Replies Last reply
                        @skywatch it depends a bit on which platform you are using, the clock speed you are using, how often wait is called, how busy your network is, which transport you are using and how much packet loss you are willing to accept. But 25 should work.
                        I found transportProcess() which is called without any parameters. You can use that instead.
                          skywatchS
                          skywatchS
                          skywatch
                          @mfalkvidd pro mini @ 16MHz - I didn't mention that as I was looking at it as purely a programming issue....doh!
                          So are you saying that if I simply put transportProcess() in the while statement it will pause the while loop, check for any messages from the nrf24 and then resume the while loop? Of so, that should work if it is quick.
                            @skywatch said in void receive(const MyMessage &message):
                            Just wait as short as possible, 1ms or even 0 (not sure if that is supported).
                            It allows the stack to process any queued messages and returns as quickly as possible.
                            There is no need to wait for a longer time, as radios will queue incoming messages in hardware. The actual number of messages that can be queued depends on the radio used; for nrf24 it is 3.
                            • skywatchS
                              skywatchS
                              skywatch
                              @mfalkvidd I tried with transportProcess() and it seemed to work well initially, but then something happened (probably HW related) so it is looking promising.
                              @Yveaux Thank you for the tip :)
                              I will try this next and see how much of a difference it makes -would wait(1); be better in any way to calling transportProcess()?
                              But at least it looks like the system might operate as I had intended, hurrah! ;)
                                Definately! transportProcess() is a library internal call, which might change without notice or has side effects one cannot oversee. Wait() is an external api call, which won't change without notice, and is documented.
                                • YveauxY Yveaux
                                  skywatchS
                                  skywatchS
                                  skywatch
                                  @yveaux Thank you for the fast response and explaination. I'll go with what you said! ;)
                                  • YveauxY Yveaux
                                    There is a slight risk that wait() will return immediately without processing messages, if the parameter is lower than the increment of millis(). The increment of millis() depends on platform and clock speed. I am not sure if this risk is big enough that it needs to be considered.
                                    • skywatchS
                                      skywatchS
                                      skywatch
                                      Thank you both for the help - much appreciated.
                                      So I went with wait(1); and then only called it every 250 steps as otherwise it was slowing things down too much. It seems pretty reliable at the moment, but I do have dodgy duponts so have to sort them out next!
                                      One thing I do see is this......
                                      352968 !MCO:WAI:RC=3
                                      352971 !MCO:WAI:RC=3
                                      352974 !MCO:WAI:RC=3
                                      352977 !MCO:WAI:RC=3
                                      352980 !MCO:WAI:RC=3
                                      352984 !MCO:WAI:RC=3
                                      352987 !MCO:WAI:RC=3
                                      352990 !MCO:WAI:RC=3
                                      Not always, but sometimes.....what is this trying to tell me and where do I look to fix it - I can post full code if you like, but it's not for the faint of heart;)
                                        @skywatch those messages mean that wait is being called from within wait. That is usually bad, so MySensors prints a warning message. Could you post your code?
                                          skywatchS
                                          skywatchS
                                          skywatch
                                          #22
                                          @mfalkvidd Here is the code - remember it is in development and some things are currently commented out to concentrate on the places where I have issues.
                                             Solar Powered Roller Blind - Landing
                                             Pin Assignments..... 5V pro mini
                                             D2 Down Button.
                                             D3 Up Button.
                                             D4,D5,D6,D7 for stepper motor. 12V
                                             D8 Power fail detect? -and write stepcount to eeprom
                                             D9,D10,D11,D12,D13 for NRF24L01+. 3.3V
                                             A0 UP LIMIT magnet sensor.
                                             A1 DOWN LIMIT magnet sensor.
                                             A2 Window Sensor.
                                             A3 FREE
                                             A4 ATSHA204a.
                                             A5 Battery Voltage Sensor.
                                             A6 FREE - input only
                                             A7 FREE - input only
                                          #define MY_RADIO_RF24
                                          #define MY_RF24_PA_LEVEL   RF24_PA_HIGH
                                          #define MY_NODE_ID 181
                                          #define MY_RF24_CHANNEL (97)
                                          #define MY_PARENT_NODE_ID 0
                                          //#define MY_REPEATER_FEATURE
                                          //#define MY_SIGNING_ATSHA204
                                          //#define MY_SIGNING_SOFT
                                          //#define MY_SIGNING_SIMPLE_PASSWD
                                          #include <Stepper.h>
                                          // define number of steps per revolution
                                          #define STEPS 32
                                          // define stepper motor control pins
                                          #define IN1   7
                                          #define IN2   6
                                          #define IN3   5
                                          #define IN4   4
                                          #define EEPROM_STEPCOUNT_ADDRESS 0
                                          #define BLIND_UP 39500  //********
                                          #define BLIND_DOWN 100  //********
                                          //#define LIMIT_UP A0
                                          //#define LIMIT_DOWN A1
                                          #define DOWN_BUTTON 2
                                          #define UP_BUTTON 3
                                          #define WINDOW_SENSOR A2
                                          //#define VOLTMETER A5
                                          #define CHILD_ID_LANDING_BLIND 0
                                          //#define CHILD_ID_BATTERY 1
                                          #define CHILD_ID_LANDING_WINDOW 2
                                          #define CHILD_ID_LANDING_ALARM 3
                                          //float battery = 0.0;
                                          //unsigned long BattSendDelay = 10800000;
                                          unsigned long previousMillis = 0;
                                          unsigned long previousButtonMillis = 0;
                                          unsigned long ButtonMillis = 5000;
                                          unsigned long stepcount = BLIND_UP;  //******Blind UP for CAL....
                                          unsigned long laststepcount = BLIND_UP;
                                          unsigned long upspeed = 900;
                                          int upstep = 5;
                                          int downstep = -1;
                                          int oldValue=-1;
                                          bool MOVING_UP = false;
                                          bool MOVING_DOWN = false;
                                          bool ALARM_ARMED = false;
                                          bool ALARM_TRIPPED = false;
                                          Bounce debouncerUP = Bounce();
                                          Bounce debouncerDOWN = Bounce();
                                          Bounce debouncerWINDOW = Bounce();
                                          // initialize stepper library
                                          Stepper stepper(STEPS, IN4, IN2, IN3, IN1);
                                          MyMessage msgB_UP(CHILD_ID_LANDING_BLIND, V_UP);
                                          MyMessage msgB_DOWN(CHILD_ID_LANDING_BLIND, V_DOWN);
                                          MyMessage msgB_STOP(CHILD_ID_LANDING_BLIND, V_STOP);
                                          //MyMessage msgBBattery(CHILD_ID_LANDING_BLIND, V_VOLTAGE);
                                          //MyMessage msgB_PERCENTAGE(CHILD_ID_LANDING_BLIND, V_PERCENTAGE);
                                          MyMessage msgB_ALARM(CHILD_ID_LANDING_WINDOW, V_TRIPPED);
                                          MyMessage msgB_WINDOW(CHILD_ID_LANDING_WINDOW, V_TRIPPED);
                                            pinMode(DOWN_BUTTON, INPUT_PULLUP);
                                            pinMode(UP_BUTTON, INPUT_PULLUP);
                                            //pinMode(LIMIT_UP, INPUT_PULLUP);
                                            //pinMode(LIMIT_DOWN, INPUT_PULLUP);
                                            pinMode(WINDOW_SENSOR, INPUT_PULLUP);
                                            //pinMode(VOLTMETER, INPUT);
                                            debouncerUP.attach(UP_BUTTON);
                                            debouncerUP.interval(25);
                                            debouncerDOWN.attach(DOWN_BUTTON);
                                            debouncerDOWN.interval(25);
                                            debouncerWINDOW.attach(WINDOW_SENSOR);
                                            debouncerWINDOW.interval(25);
                                            //**** Comment next line after first upload - inital calibration only....
                                            hwWriteConfigBlock((void*)&stepcount, (void*)(EEPROM_LOCAL_CONFIG_ADDRESS + EEPROM_STEPCOUNT_ADDRESS), 4); //saveStepcount - Use once to set 'memory'. Then reflash with this commented out.
                                            hwReadConfigBlock((void*)&stepcount, (void*)(EEPROM_LOCAL_CONFIG_ADDRESS + EEPROM_STEPCOUNT_ADDRESS), 4); // Get from EEPROM last position.
                                            digitalWrite(IN1, LOW);
                                            digitalWrite(IN2, LOW);
                                            digitalWrite(IN3, LOW);
                                            digitalWrite(IN4, LOW);
                                          void presentation()  {
                                            sendSketchInfo("MYS-Landing Blind", "0.4");
                                            wait(150);
                                            present(CHILD_ID_LANDING_BLIND, S_COVER, "Landing-Blind", true);
                                            // present(CHILD_ID_BATTERY, S_MULTIMETER, "Battery", true);
                                             wait(200);
                                             present(CHILD_ID_LANDING_ALARM, S_BINARY, "Landing-Alarm", true);
                                             wait(200);
                                             present(CHILD_ID_LANDING_WINDOW, S_BINARY, "Landing-Window", true);
                                              //long batterytemp = (readVcc());
                                            //float batteryf = (float) batterytemp;
                                            //battery = batteryf/1000.0;
                                            //send(msgBBattery.set(battery,2),true);
                                            // move the blind UP
                                            debouncerUP.update();
                                            if (debouncerUP.fell() || MOVING_UP == true) {
                                              MOVING_UP = true;
                                              UP();
                                            // move the blind DOWN
                                            debouncerDOWN.update();
                                            if (debouncerDOWN.fell() || MOVING_DOWN == true) {
                                              MOVING_DOWN = true;
                                              DOWN();
                                            //Manual calibration call
                                            if (debouncerUP.fell() && debouncerDOWN.fell()){
                                              previousButtonMillis = millis();
                                              while (millis() - previousButtonMillis < ButtonMillis){
                                                if (debouncerUP.rose() || debouncerDOWN.rose()){
                                              else calibrate();
                                            debouncerWINDOW.update();
                                            if (debouncerWINDOW.rose() && ALARM_ARMED == true){
                                              send(msgB_ALARM.set(ALARM_TRIPPED = 0), true);
                                              if (debouncerWINDOW.fell() && ALARM_ARMED == true){
                                              send(msgB_ALARM.set(ALARM_TRIPPED = 1), true);
                                          //    debouncer.update();
                                            // Send window update...
                                            int value = debouncerWINDOW.read();
                                            if (value != oldValue) {
                                               // Send in the new value
                                               send(msgB_WINDOW.set(value==HIGH ? 1 : 0));
                                               oldValue = value;
                                            //Read and send battery every 3 hours
                                            /* if (millis() - previousMillis >= BattSendDelay) {
                                               previousMillis = millis();
                                               //float batteryraw = digitalRead(VOLTMETER);
                                               //add calibration here.....
                                            //!!!!!  NO SLEEPING !!!!!  ;)
                                            // STOP - if message == V_STOP, stop blinds immediately.
                                            if (message.type == V_STOP) {
                                              stop();
                                            // UP - if message == V_UP call void UP()
                                            if (message.type == V_UP) {
                                              MOVING_UP = true;
                                              UP();
                                            // DOWN - if message == V_DOWN call void DOWN()
                                            if (message.type == V_DOWN) {
                                              MOVING_DOWN = true;
                                              DOWN();
                                            //Add if (message.type==V_PERCENTAGE); and add calculation....maybe?
                                            // for reference 1% == 395 steps....
                                          void stop()
                                            send(msgB_STOP.set(stepcount), true);
                                            MOVING_UP = false;
                                            wait(100);
                                          void UP()
                                            //If already in motion then stop and reverse direction.
                                            if (MOVING_DOWN == true) {
                                              stop();
                                              MOVING_UP = true;
                                             // test if already up here!!!! - if not recall stepcount and calulate number of steps required.
                                            while (MOVING_UP == true && stepcount < BLIND_UP) { //&& LIMIT_UP == HIGH)
                                              // set motor speed
                                              if (stepcount >= 20000) {
                                                 upspeed = 1000;
                                              if (stepcount >= (BLIND_UP - 50)) {
                                                 upstep = 1;
                                              stepper.setSpeed(upspeed); //higher speed = lower torque...
                                              // move the motor (x steps)
                                              stepper.step(upstep);
                                              stepcount = stepcount + upstep;
                                             // Serial.println("UP-StepCount = " + (String)stepcount);
                                              //Test if manual stop.
                                              if (debouncerDOWN.fell()) {
                                                stop();
                                              //Add time limit for safety?
                                              //up timeout message?
                                              //Test if at end of travel.
                                              if (stepcount == BLIND_UP) {   // || digitalRead(LIMIT_UP) == LOW)
                                                stop();
                                                downstep = -1;
                                              //Check for incomming radio message at frequent intervals.
                                              if(stepcount > laststepcount + 500){
                                                laststepcount = stepcount;
                                                wait(1); //allows RX function.
                                          void DOWN()
                                            if (MOVING_UP == true) {
                                              stop();
                                              MOVING_DOWN = true;
                                             //Check if window open
                                            //Do not close if window is open or already closed.
                                            while (MOVING_DOWN == true && stepcount > BLIND_DOWN && debouncerWINDOW.read() == LOW)// && digitalRead(WINDOW_SENSOR) == LOW && LIMIT_DOWN == HIGH)
                                              stepper.setSpeed(1200); //higher speed = lower torque...
                                              if (stepcount <= (BLIND_UP-500) && stepcount > 150) {
                                                 downstep = -5;
                                              if (stepcount <= 150) {
                                                 downstep = -1;
                                              stepper.step(downstep);
                                              stepcount = stepcount + downstep;
                                              //Serial.println("DOWN-StepCount = " + (String)stepcount);
                                              if (debouncerUP.fell()) {
                                              stop();
                                              if (stepcount == BLIND_DOWN) { // || digitalRead(LIMIT_DOWN) == LOW) -- maybe add timer as well?
                                                stop();
                                                upstep = 5;
                                                upspeed = 900;
                                               if(stepcount < laststepcount - 500){
                                          void calibrate()
                                            //Move fully up or down and set stepcounter. - From controller, buttons or if position is unknown.....
                                            long readVcc() {
                                            wait(5); // Wait for Vref to settle
                                          It works like this......
                                          Pressing up or down button will move the blind up or down depending on window sensor status (I don't want blinds to close with the window open)......
                                          Whilst blind is in motion pressing button corresponding to the opposite direction will stop the blind and save position to eeprom.
                                          Pressing both buttons at the same time for more than 5 seconds will call a self calibration routine.
                                          At any point the controller should be able to send a message to the blinds to move or stop. This now happens even whilst the blind is in motion, which is what I thought to be the best option.
                                          Every time the stop is called the position is saved to eeprom so that in the event of power interruption it will know where it last was.
                                          Maybe I need to re-think the whole approach to this, but it is annoyingly close to what I would like now ;)
                                          mfalkviddM 2 Replies Last reply
                                          12.5k
