  3. void receive(const MyMessage &message)
40 Posts 6 Posters 7.1k Views 5 Watching
    @skywatch I think you're looking for the wait() function. https://www.mysensors.org/download/sensor_api_20#waiting
    Or _process() but that's an internal function so it might not be as well documented and might undergo changes that aren't mentioned in release notes in future releases.
    skywatchS
    skywatchS
    skywatch
    @mfalkvidd I was just about to say something on that! - you just beat me too it! ;)
    I understand the wait(), but what I have no clue of is how long should a wait() be to get incomming messages? -- Would wait(25); be enough?
    mfalkviddM YveauxY 2 Replies Last reply
    • skywatchS skywatch
      @skywatch it depends a bit on which platform you are using, the clock speed you are using, how often wait is called, how busy your network is, which transport you are using and how much packet loss you are willing to accept. But 25 should work.
      I found transportProcess() which is called without any parameters. You can use that instead.
      skywatchS 1 Reply Last reply
        skywatchS
        skywatchS
        skywatch
        @mfalkvidd pro mini @ 16MHz - I didn't mention that as I was looking at it as purely a programming issue....doh!
        So are you saying that if I simply put transportProcess() in the while statement it will pause the while loop, check for any messages from the nrf24 and then resume the while loop? Of so, that should work if it is quick.
          @skywatch said in void receive(const MyMessage &message):
          Just wait as short as possible, 1ms or even 0 (not sure if that is supported).
          It allows the stack to process any queued messages and returns as quickly as possible.
          There is no need to wait for a longer time, as radios will queue incoming messages in hardware. The actual number of messages that can be queued depends on the radio used; for nrf24 it is 3.
          • skywatchS
            skywatchS
            skywatch
            @mfalkvidd I tried with transportProcess() and it seemed to work well initially, but then something happened (probably HW related) so it is looking promising.
            @Yveaux Thank you for the tip :)
            I will try this next and see how much of a difference it makes -would wait(1); be better in any way to calling transportProcess()?
            But at least it looks like the system might operate as I had intended, hurrah! ;)
              Definately! transportProcess() is a library internal call, which might change without notice or has side effects one cannot oversee. Wait() is an external api call, which won't change without notice, and is documented.
              • YveauxY Yveaux
                skywatchS
                skywatchS
                skywatch
                @yveaux Thank you for the fast response and explaination. I'll go with what you said! ;)
                • YveauxY Yveaux
                  There is a slight risk that wait() will return immediately without processing messages, if the parameter is lower than the increment of millis(). The increment of millis() depends on platform and clock speed. I am not sure if this risk is big enough that it needs to be considered.
                  • skywatchS
                    skywatchS
                    skywatch
                    Thank you both for the help - much appreciated.
                    So I went with wait(1); and then only called it every 250 steps as otherwise it was slowing things down too much. It seems pretty reliable at the moment, but I do have dodgy duponts so have to sort them out next!
                    One thing I do see is this......
                    352968 !MCO:WAI:RC=3
                    352971 !MCO:WAI:RC=3
                    352974 !MCO:WAI:RC=3
                    352977 !MCO:WAI:RC=3
                    352980 !MCO:WAI:RC=3
                    352984 !MCO:WAI:RC=3
                    352987 !MCO:WAI:RC=3
                    352990 !MCO:WAI:RC=3
                    Not always, but sometimes.....what is this trying to tell me and where do I look to fix it - I can post full code if you like, but it's not for the faint of heart;)
                      @skywatch those messages mean that wait is being called from within wait. That is usually bad, so MySensors prints a warning message. Could you post your code?
                        skywatchS
                        skywatchS
                        skywatch
                        #22
                        @mfalkvidd Here is the code - remember it is in development and some things are currently commented out to concentrate on the places where I have issues.
                           Solar Powered Roller Blind - Landing
                           Pin Assignments..... 5V pro mini
                           D2 Down Button.
                           D3 Up Button.
                           D4,D5,D6,D7 for stepper motor. 12V
                           D8 Power fail detect? -and write stepcount to eeprom
                           D9,D10,D11,D12,D13 for NRF24L01+. 3.3V
                           A0 UP LIMIT magnet sensor.
                           A1 DOWN LIMIT magnet sensor.
                           A2 Window Sensor.
                           A3 FREE
                           A4 ATSHA204a.
                           A5 Battery Voltage Sensor.
                           A6 FREE - input only
                           A7 FREE - input only
                        #define MY_RADIO_RF24
                        #define MY_RF24_PA_LEVEL   RF24_PA_HIGH
                        #define MY_NODE_ID 181
                        #define MY_RF24_CHANNEL (97)
                        #define MY_PARENT_NODE_ID 0
                        //#define MY_REPEATER_FEATURE
                        //#define MY_SIGNING_ATSHA204
                        //#define MY_SIGNING_SOFT
                        //#define MY_SIGNING_SIMPLE_PASSWD
                        #include <Stepper.h>
                        // define number of steps per revolution
                        #define STEPS 32
                        // define stepper motor control pins
                        #define IN1   7
                        #define IN2   6
                        #define IN3   5
                        #define IN4   4
                        #define EEPROM_STEPCOUNT_ADDRESS 0
                        #define BLIND_UP 39500  //********
                        #define BLIND_DOWN 100  //********
                        //#define LIMIT_UP A0
                        //#define LIMIT_DOWN A1
                        #define DOWN_BUTTON 2
                        #define UP_BUTTON 3
                        #define WINDOW_SENSOR A2
                        //#define VOLTMETER A5
                        #define CHILD_ID_LANDING_BLIND 0
                        //#define CHILD_ID_BATTERY 1
                        #define CHILD_ID_LANDING_WINDOW 2
                        #define CHILD_ID_LANDING_ALARM 3
                        //float battery = 0.0;
                        //unsigned long BattSendDelay = 10800000;
                        unsigned long previousMillis = 0;
                        unsigned long previousButtonMillis = 0;
                        unsigned long ButtonMillis = 5000;
                        unsigned long stepcount = BLIND_UP;  //******Blind UP for CAL....
                        unsigned long laststepcount = BLIND_UP;
                        unsigned long upspeed = 900;
                        int upstep = 5;
                        int downstep = -1;
                        int oldValue=-1;
                        bool MOVING_UP = false;
                        bool MOVING_DOWN = false;
                        bool ALARM_ARMED = false;
                        bool ALARM_TRIPPED = false;
                        Bounce debouncerUP = Bounce();
                        Bounce debouncerDOWN = Bounce();
                        Bounce debouncerWINDOW = Bounce();
                        // initialize stepper library
                        Stepper stepper(STEPS, IN4, IN2, IN3, IN1);
                        MyMessage msgB_UP(CHILD_ID_LANDING_BLIND, V_UP);
                        MyMessage msgB_DOWN(CHILD_ID_LANDING_BLIND, V_DOWN);
                        MyMessage msgB_STOP(CHILD_ID_LANDING_BLIND, V_STOP);
                        //MyMessage msgBBattery(CHILD_ID_LANDING_BLIND, V_VOLTAGE);
                        //MyMessage msgB_PERCENTAGE(CHILD_ID_LANDING_BLIND, V_PERCENTAGE);
                        MyMessage msgB_ALARM(CHILD_ID_LANDING_WINDOW, V_TRIPPED);
                        MyMessage msgB_WINDOW(CHILD_ID_LANDING_WINDOW, V_TRIPPED);
                          pinMode(DOWN_BUTTON, INPUT_PULLUP);
                          pinMode(UP_BUTTON, INPUT_PULLUP);
                          //pinMode(LIMIT_UP, INPUT_PULLUP);
                          //pinMode(LIMIT_DOWN, INPUT_PULLUP);
                          pinMode(WINDOW_SENSOR, INPUT_PULLUP);
                          //pinMode(VOLTMETER, INPUT);
                          debouncerUP.attach(UP_BUTTON);
                          debouncerUP.interval(25);
                          debouncerDOWN.attach(DOWN_BUTTON);
                          debouncerDOWN.interval(25);
                          debouncerWINDOW.attach(WINDOW_SENSOR);
                          debouncerWINDOW.interval(25);
                          //**** Comment next line after first upload - inital calibration only....
                          hwWriteConfigBlock((void*)&stepcount, (void*)(EEPROM_LOCAL_CONFIG_ADDRESS + EEPROM_STEPCOUNT_ADDRESS), 4); //saveStepcount - Use once to set 'memory'. Then reflash with this commented out.
                          hwReadConfigBlock((void*)&stepcount, (void*)(EEPROM_LOCAL_CONFIG_ADDRESS + EEPROM_STEPCOUNT_ADDRESS), 4); // Get from EEPROM last position.
                          digitalWrite(IN1, LOW);
                          digitalWrite(IN2, LOW);
                          digitalWrite(IN3, LOW);
                          digitalWrite(IN4, LOW);
                        void presentation()  {
                          sendSketchInfo("MYS-Landing Blind", "0.4");
                          wait(150);
                          present(CHILD_ID_LANDING_BLIND, S_COVER, "Landing-Blind", true);
                          // present(CHILD_ID_BATTERY, S_MULTIMETER, "Battery", true);
                           wait(200);
                           present(CHILD_ID_LANDING_ALARM, S_BINARY, "Landing-Alarm", true);
                           wait(200);
                           present(CHILD_ID_LANDING_WINDOW, S_BINARY, "Landing-Window", true);
                            //long batterytemp = (readVcc());
                          //float batteryf = (float) batterytemp;
                          //battery = batteryf/1000.0;
                          //send(msgBBattery.set(battery,2),true);
                          // move the blind UP
                          debouncerUP.update();
                          if (debouncerUP.fell() || MOVING_UP == true) {
                            MOVING_UP = true;
                            UP();
                          // move the blind DOWN
                          debouncerDOWN.update();
                          if (debouncerDOWN.fell() || MOVING_DOWN == true) {
                            MOVING_DOWN = true;
                            DOWN();
                          //Manual calibration call
                          if (debouncerUP.fell() && debouncerDOWN.fell()){
                            previousButtonMillis = millis();
                            while (millis() - previousButtonMillis < ButtonMillis){
                              if (debouncerUP.rose() || debouncerDOWN.rose()){
                            else calibrate();
                          debouncerWINDOW.update();
                          if (debouncerWINDOW.rose() && ALARM_ARMED == true){
                            send(msgB_ALARM.set(ALARM_TRIPPED = 0), true);
                            if (debouncerWINDOW.fell() && ALARM_ARMED == true){
                            send(msgB_ALARM.set(ALARM_TRIPPED = 1), true);
                        //    debouncer.update();
                          // Send window update...
                          int value = debouncerWINDOW.read();
                          if (value != oldValue) {
                             // Send in the new value
                             send(msgB_WINDOW.set(value==HIGH ? 1 : 0));
                             oldValue = value;
                          //Read and send battery every 3 hours
                          /* if (millis() - previousMillis >= BattSendDelay) {
                             previousMillis = millis();
                             //float batteryraw = digitalRead(VOLTMETER);
                             //add calibration here.....
                          //!!!!!  NO SLEEPING !!!!!  ;)
                          // STOP - if message == V_STOP, stop blinds immediately.
                          if (message.type == V_STOP) {
                            stop();
                          // UP - if message == V_UP call void UP()
                          if (message.type == V_UP) {
                            MOVING_UP = true;
                            UP();
                          // DOWN - if message == V_DOWN call void DOWN()
                          if (message.type == V_DOWN) {
                            MOVING_DOWN = true;
                            DOWN();
                          //Add if (message.type==V_PERCENTAGE); and add calculation....maybe?
                          // for reference 1% == 395 steps....
                        void stop()
                          send(msgB_STOP.set(stepcount), true);
                          MOVING_UP = false;
                          wait(100);
                        void UP()
                          //If already in motion then stop and reverse direction.
                          if (MOVING_DOWN == true) {
                            stop();
                            MOVING_UP = true;
                           // test if already up here!!!! - if not recall stepcount and calulate number of steps required.
                          while (MOVING_UP == true && stepcount < BLIND_UP) { //&& LIMIT_UP == HIGH)
                            // set motor speed
                            if (stepcount >= 20000) {
                               upspeed = 1000;
                            if (stepcount >= (BLIND_UP - 50)) {
                               upstep = 1;
                            stepper.setSpeed(upspeed); //higher speed = lower torque...
                            // move the motor (x steps)
                            stepper.step(upstep);
                            stepcount = stepcount + upstep;
                           // Serial.println("UP-StepCount = " + (String)stepcount);
                            //Test if manual stop.
                            if (debouncerDOWN.fell()) {
                              stop();
                            //Add time limit for safety?
                            //up timeout message?
                            //Test if at end of travel.
                            if (stepcount == BLIND_UP) {   // || digitalRead(LIMIT_UP) == LOW)
                              stop();
                              downstep = -1;
                            //Check for incomming radio message at frequent intervals.
                            if(stepcount > laststepcount + 500){
                              laststepcount = stepcount;
                              wait(1); //allows RX function.
                        void DOWN()
                          if (MOVING_UP == true) {
                            stop();
                            MOVING_DOWN = true;
                           //Check if window open
                          //Do not close if window is open or already closed.
                          while (MOVING_DOWN == true && stepcount > BLIND_DOWN && debouncerWINDOW.read() == LOW)// && digitalRead(WINDOW_SENSOR) == LOW && LIMIT_DOWN == HIGH)
                            stepper.setSpeed(1200); //higher speed = lower torque...
                            if (stepcount <= (BLIND_UP-500) && stepcount > 150) {
                               downstep = -5;
                            if (stepcount <= 150) {
                               downstep = -1;
                            stepper.step(downstep);
                            stepcount = stepcount + downstep;
                            //Serial.println("DOWN-StepCount = " + (String)stepcount);
                            if (debouncerUP.fell()) {
                            stop();
                            if (stepcount == BLIND_DOWN) { // || digitalRead(LIMIT_DOWN) == LOW) -- maybe add timer as well?
                              stop();
                              upstep = 5;
                              upspeed = 900;
                             if(stepcount < laststepcount - 500){
                        void calibrate()
                          //Move fully up or down and set stepcounter. - From controller, buttons or if position is unknown.....
                          long readVcc() {
                          wait(5); // Wait for Vref to settle
                        It works like this......
                        Pressing up or down button will move the blind up or down depending on window sensor status (I don't want blinds to close with the window open)......
                        Whilst blind is in motion pressing button corresponding to the opposite direction will stop the blind and save position to eeprom.
                        Pressing both buttons at the same time for more than 5 seconds will call a self calibration routine.
                        At any point the controller should be able to send a message to the blinds to move or stop. This now happens even whilst the blind is in motion, which is what I thought to be the best option.
                        Every time the stop is called the position is saved to eeprom so that in the event of power interruption it will know where it last was.
                        Maybe I need to re-think the whole approach to this, but it is annoyingly close to what I would like now ;)
                        mfalkviddM 2 Replies Last reply
                             D2 Down Button.
                             D3 Up Button.
                             A2 Window Sensor.
                             A3 FREE
                             A4 ATSHA204a.
                          #define STEPS 32
                          #define IN1   7
                          #define IN2   6
                          #define IN3   5
                          #define IN4   4
                          #define UP_BUTTON 3
                          int upstep = 5;
                          int downstep = -1;
                          int oldValue=-1;
                            wait(150);
                             wait(200);
                             wait(200);
                              MOVING_UP = true;
                              UP();
                              MOVING_DOWN = true;
                              DOWN();
                              else calibrate();
                               oldValue = value;
                              stop();
                              MOVING_UP = true;
                              UP();
                              MOVING_DOWN = true;
                              DOWN();
                          void stop()
                            MOVING_UP = false;
                            wait(100);
                          void UP()
                              stop();
                              MOVING_UP = true;
                              // set motor speed
                                 upspeed = 1000;
                                 upstep = 1;
                                stop();
                                stop();
                                downstep = -1;
                          void DOWN()
                              stop();
                              MOVING_DOWN = true;
                                 downstep = -5;
                                 downstep = -1;
                              stop();
                                stop();
                                upstep = 5;
                                upspeed = 900;
                          void calibrate()
                            long readVcc() {
                          @skywatch the reason you're getting the wait warning messages (and probably the reason why your code behaves in strage ways sometimes) is that you're calling send and wait from within receive. Doing so can have very strange side effects.
                               D2 Down Button.
                               D3 Up Button.
                               A2 Window Sensor.
                               A3 FREE
                               A4 ATSHA204a.
                            #define STEPS 32
                            #define IN1   7
                            #define IN2   6
                            #define IN3   5
                            #define IN4   4
                            #define UP_BUTTON 3
                            int upstep = 5;
                            int downstep = -1;
                            int oldValue=-1;
                              wait(150);
                               wait(200);
                               wait(200);
                                MOVING_UP = true;
                                UP();
                                MOVING_DOWN = true;
                                DOWN();
                                else calibrate();
                                 oldValue = value;
                                stop();
                                MOVING_UP = true;
                                UP();
                                MOVING_DOWN = true;
                                DOWN();
                            void stop()
                              MOVING_UP = false;
                              wait(100);
                            void UP()
                                stop();
                                MOVING_UP = true;
                                // set motor speed
                                   upspeed = 1000;
                                   upstep = 1;
                                  stop();
                                  stop();
                                  downstep = -1;
                            void DOWN()
                                stop();
                                MOVING_DOWN = true;
                                   downstep = -5;
                                   downstep = -1;
                                stop();
                                  stop();
                                  upstep = 5;
                                  upspeed = 900;
                            void calibrate()
                              long readVcc() {
                            @skywatch also, requesting that the gateway echos sent messages back to your node will have very bad effects. Could you elaborate on what you are trying to achive by requesting echo?
                              skywatchS
                              skywatchS
                              skywatch
                              #25
                              @mfalkvidd Ah, I didn't know that it also applied to a wait within other void loop - I'll change the code so that it just sets a variable and then modify the main loop accordingly. Thank you for your time - I know it was not easy to go through that lot! ;) - Once it is working and tested I will tidy it up and optimise it all somewhat.
                                skywatchS
                                skywatchS
                                skywatch
                                @mfalkvidd said in void receive(const MyMessage &message):
                                I simply wanted to know that the message got through. Otherwise the controller might send 'down' command without having received the window open status. - I will look into that too..... :)
                                  @skywatch if you want to know that, you need to add code in receive() to handle the echoed message. And you need to make sure those echoed messages don't interfere with "normal" messages.
                                  • skywatchS
                                    skywatchS
                                    skywatch
                                    #28
                                    @mfalkvidd Thank you soooo much for the tips with this, I still am learning new stuff and getting a project done = a double win for me :)
                                    SO here is what I changed.....
                                    In void loop I added
                                    //Stop if received message = STOP
                                      if(RX_STOP == true){
                                        stop();
                                    And void receive() now looks like this ( I never needed to call up() or down() from here anyway. I realise that now - doh!).
                                       RX_STOP = true;
                                        MOVING_UP = true;
                                        MOVING_DOWN = true;
                                    I'll test it later as I need some food now! ;)
                                          stop();
                                         RX_STOP = true;
                                          MOVING_UP = true;
                                          MOVING_DOWN = true;
                                      @skywatch great work. This is a much better design.
                                        skywatchS
                                        skywatchS
                                        skywatch
                                        #30
                                        @mfalkvidd Thank you!
                                        And of course RX_STOP = false; is now at the end of the stop(); loop to reset it for next time it is needed.....I forgot that bit!
                                        Update - it didn't work as expected, but I know why. I also had to change in the UP() and DOWN() loops from
                                            stop();
                                        To....
                                         if (debouncerUP.fell()|| RX_STOP == true) {
                                            stop();
                                        And then to completely mimic the button responses...
                                        if (debouncerDOWN.fell() || RX_STOP == true || MOVING_DOWN == true) {
                                              stop();
                                        Now I am hungry and really will go get some food!
                                          skywatchS
                                          skywatchS
                                          skywatch
                                          Is there a basic example of this anywhere? I can't see it...
                                          And you need to make sure those echoed messages don't interfere with >"normal" messages.
                                          It is mainly for the window sensor which as well as being useful for the blind, it will also form part of the security alarm system as well.
                                          12.5k
