  3. IR Sensor
IR Sensor
6 Posts 5 Posters 3.0k Views 3 Watching
  • T
    Terence Faul
    Hi
    Is it possible to add buttons to this sensor, the example only does Volume up/down, but would you be able to add all the buttons of your settop box for instance.
    If so how would you go about altering the sketch, or is this something for the controller?
    gigiG 1 Reply Last reply
    • T Terence Faul
      Hi
      gigiG
      gigiG
      gigi
      @Terence-Faul which controller do you have?
      Vera lite - mysensors Ethernet gateway - AirWik sensor - Relay Module
      • T
        Terence Faul
        Jeedom on Raspberry Pi
        Using Serial gateway
          One option (if jeedom supports it) is to present it as a scene controller device.
          That way you can send in 256 "commands" to the controller..
          • jeylitesJ
            jeylitesJ
            jeylites
            wrote on last edited by jeylites
            Can this work on Vera Ui7 too?
            korttomaK 1 Reply Last reply
            • jeylitesJ jeylites
              korttomaK
              korttomaK
              korttoma
              @jeylites Vera does support scene controller also and it is working great in UI5. I have no experience with UI7 but I bet it works.
              • Tomas
