MKR1000 gateway problem
Hello all,
I have a problem with a serial gateway based on a MKR1000 compatible board ( Dustino ).
It inits properly and receives message from a test node equipped with a BMP180 sensor. The problem is that the sensor value ( both humidity and temperature ) are always zero. The node is sending correct values, as shown in the serial terminal, and if I connect another gateway based on an Arduino uno board I receive correct values.I have logs of the node, the Arduino Uno gateway and the MKR1000 gateway if needed.
Any ideas?Thank you,
Vittorio
Hello all,
Vittorio
thanks for your answer.
Here follow the three logs. As an additional information I have also connected a node with a relay and I can properly switch the state with the SAMD Gateway. It looks like a parsing problem to me.Node log from serial console:
0 NM:INIT:VER=1.8 0 NM:INIT:INO=NodeManager v1.0 0 NM:INIT:LIB VER=2.3.1 CP=RNNNA--- 0 NM:INIT:RBT p=255 20 NM:BFR:INIT 2184 NM:BFR:OK 2203 NM:PRES:BMP180(1) p=6 t=0 2238 NM:PRES:BMP180(2) p=8 t=4 2275 NM:PRES:BMP180(3) p=8 t=5 2335 NM:STP:ID=110 M=1 2360 NM:SENS:BMP180:I2C a=0x77 2471 NM:STP:HW V=4892 F=17 M=1076 2513 NM:LOOP:BMP180(1):SET t=0 v=17.60 2588 NM:LOOP:BMP180(2):SET t=4 v=985.-57 2665 NM:LOOP:BMP180(3):SET t=5 v=stable``` Working Arduino nano Gateway log:0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGA---,VER=2.2.0
0;255;3;0;9;8 TSM:INIT
0;255;3;0;9;12 TSF:WUR:MS=0
0;255;3;0;9;23 TSM:INIT:TSP OK
0;255;3;0;9;28 TSM:INIT:GW MODE
0;255;3;0;9;34 TSM:READY:ID=0,PAR=0,DIS=0
0;255;3;0;9;41 MCO:REG:NOT NEEDED
0;255;0;0;18;2.2.0
0;255;3;0;9;49 MCO:BGN:STP
0;255;3;0;9;62 MCO:BGN:INIT OK,TSP=1
0;255;3;0;9;8285 TSF:MSG:READ,110-110-0,s=1,c=1,t=0,pt=7,l=5,sg=0:17.80
110;1;1;0;0;17.80
0;255;3;0;9;8298 TSF:MSG:READ,110-110-0,s=2,c=1,t=4,pt=7,l=5,sg=0:985.11
110;2;1;0;4;985.11
0;255;3;0;9;8313 TSF:MSG:READ,110-110-0,s=3,c=1,t=5,pt=0,l=6,sg=0:stable
110;3;1;0;5;stable```SAMD faulty Gateway log:
0;255;3;0;9;120220 MCO:BGN:INIT GW,CP=RNNGS---,REL=255,VER=2.3.1 0;255;3;0;9;120230 TSF:LRT:OK 0;255;3;0;9;120240 TSM:INIT 0;255;3;0;9;120250 TSF:WUR:MS=0 0;255;3;0;9;120265 TSM:INIT:TSP OK 0;255;3;0;9;120275 TSM:INIT:GW MODE 0;255;3;0;9;120285 TSM:READY:ID=0,PAR=0,DIS=0 0;255;3;0;9;120295 MCO:REG:NOT NEEDED 0;255;3;0;14;Gateway startup complete. 0;255;0;0;18;2.3.1 0;255;3;0;9;120305 MCO:BGN:STP 0;255;3;0;9;120315 MCO:BGN:INIT OK,TSP=1 0;255;3;0;9;120325 TSM:READY:NWD REQ 0;255;3;0;9;120370 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK: 0;255;3;0;9;127494 TSF:MSG:READ,110-110-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 0;255;3;0;9;127504 TSF:MSG:BC 0;255;3;0;9;127514 TSF:MSG:FPAR REQ,ID=110 0;255;3;0;9;127524 TSF:PNG:SEND,TO=0 0;255;3;0;9;127534 TSF:CKU:OK 0;255;3;0;9;127544 TSF:MSG:GWL OK 0;255;3;0;9;128123 TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0 0;255;3;0;9;129530 TSF:MSG:READ,110-110-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1 0;255;3;0;9;129540 TSF:MSG:PINGED,ID=110,HP=1 0;255;3;0;9;129556 TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1 0;255;3;0;9;129566 TSF:MSG:READ,110-110-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100 0;255;3;0;9;129578 TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100 0;255;3;0;9;129588 TSF:MSG:READ,110-110-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.1 110;255;0;0;17;2.3.1 0;255;3;0;9;129598 TSF:MSG:READ,110-110-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0 110;255;3;0;6;0 0;255;3;0;9;131600 TSF:MSG:READ,110-110-0,s=255,c=3,t=11,pt=0,l=11,sg=0:NodeManager 110;255;3;0;11;NodeManager 0;255;3;0;9;131611 TSF:MSG:READ,110-110-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0 110;255;3;0;12;1.0 0;255;3;0;9;131637 TSF:MSG:READ,110-110-0,s=1,c=0,t=6,pt=0,l=6,sg=0:BMP180 110;1;0;0;6;BMP180 0;255;3;0;9;131673 TSF:MSG:READ,110-110-0,s=2,c=0,t=8,pt=0,l=6,sg=0:BMP180 110;2;0;0;8;BMP180 0;255;3;0;9;131708 TSF:MSG:READ,110-110-0,s=3,c=0,t=8,pt=0,l=6,sg=0:BMP180 110;3;0;0;8;BMP180 0;255;3;0;9;131718 TSF:MSG:READ,110-110-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2 0;255;3;0;9;131734 TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1 0;255;3;0;9;132646 TSF:MSG:READ,110-110-0,s=1,c=1,t=0,pt=7,l=5,sg=0:0.00 110;1;1;0;0;0.00 0;255;3;0;9;132657 TSF:MSG:READ,110-110-0,s=2,c=1,t=4,pt=7,l=5,sg=0:0.00 110;2;1;0;4;0.00 0;255;3;0;9;132668 TSF:MSG:READ,110-110-0,s=3,c=1,t=5,pt=0,l=6,sg=0:stable 110;3;1;0;5;stable``` Thanks, Vittorio -
Sorry for the mistake, I repost the Arduino nano gatewaylog:
0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGA---,VER=2.2.0 0;255;3;0;9;8 TSM:INIT 0;255;3;0;9;12 TSF:WUR:MS=0 0;255;3;0;9;23 TSM:INIT:TSP OK 0;255;3;0;9;28 TSM:INIT:GW MODE 0;255;3;0;9;34 TSM:READY:ID=0,PAR=0,DIS=0 0;255;3;0;9;41 MCO:REG:NOT NEEDED 0;255;3;0;14;Gateway startup complete. 0;255;0;0;18;2.2.0 0;255;3;0;9;49 MCO:BGN:STP 0;255;3;0;9;62 MCO:BGN:INIT OK,TSP=1 0;255;3;0;9;8285 TSF:MSG:READ,110-110-0,s=1,c=1,t=0,pt=7,l=5,sg=0:17.80 110;1;1;0;0;17.80 0;255;3;0;9;8298 TSF:MSG:READ,110-110-0,s=2,c=1,t=4,pt=7,l=5,sg=0:985.11 110;2;1;0;4;985.11 0;255;3;0;9;8313 TSF:MSG:READ,110-110-0,s=3,c=1,t=5,pt=0,l=6,sg=0:stable 110;3;1;0;5;stable -
The sketches are the serialGateway example with no modification, and the node manager template with the BMP180 lines uncommented.
it seems I found the problem:
The dtostrf function included in MyHwSAMD.h is the AVR one ( avr/dtostrf.h) does not work with SAMD core.
I found a working replacement here: https://forum.arduino.cc/index.php?topic=368720.0
and the SAMD board Gateway is now working properly.Thanks for your help,
Ciao,
Vittorio
Ciao,
Vittorio
@ziovic said in MKR1000 gateway problem:
Well, this implementation is part of the official arduino Samd core: https://github.com/arduino/ArduinoCore-samd/blob/master/cores/arduino/avr/dtostrf.c
You could file a bug report there if you like.
