  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 465.1k Views 30 Watching
  • AnticimexA Anticimex
    @alexsh1 yes there have been a lot of changes but hopefully they are perceived as improvements. Feedback on signing usability is always welcome :)
    alexsh1A
    alexsh1A
    alexsh1
    @Anticimex BTW, is signing compatible between 1.5.4 and 2.0b?
    AnticimexA 1 Reply Last reply
    • alexsh1A alexsh1
      AnticimexA
      AnticimexA
      Anticimex
      @alexsh1 no, it is not
      alexsh1A 1 Reply Last reply
        alexsh1A
        alexsh1A
        alexsh1
        #263
        @Anticimex Right, this is why I am not able to sign 1.5.4 nodes with 2.0b GW.
        In fact when I inserted #define MY_SIGNING_REQUEST_SIGNATURES into the GW code, some nodes stopped working and I think it has to be with signing as GW is throwing a lot of messages that signing failed.
        Bottom line is that I need to upgrade pretty much all sensors :-(
        • alexsh1A alexsh1
          AnticimexA
          AnticimexA
          Anticimex
          @alexsh1 yes, Unfortunately. But it is a huge release upcoming. And a major version step, hence the incompatibilities. Hopefully, the changes made will make it easier to do future maintenance.
          • C
            C
            cingolanifede
            Hi. Is there any difference in using RFM69? Signing is supported using that radio? Thanks
            • C cingolanifede
              AnticimexA
              AnticimexA
              Anticimex
              @cingolanifede signing has nothing to to with which radio you choose so yes. It supports any transport, but to my knowledge it has only been actually tested with nrf24 and rfm69.
              • alexsh1A
                alexsh1A
                alexsh1
                @Anticimex I must admit that signing is working really-really nicely on my custom made nodes (Soft sign and ATSHA204A)
                Apart from a small issue with the sensebender, which I believe is not a signing issue, it is working like a charm. All credit to you! Thank you
                Starting sensor (RNNNAS, 2.0.0-beta)
                Radio init successful.
                HTU21D Sensor1.1 - Online!
                isMetric: 1
                TempDiff :1098.00
                HumDiff  :136.75
                T: 998.00
                H: 36.75
                send: 5-5-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:998.0
                send: 5-5-0-0 s=1,c=1,t=1,pt=7,l=5,sg=0,st=ok:36.7
                send: 5-5-0-0 s=2,c=1,t=38,pt=7,l=5,sg=0,st=ok:3.29
                send: 5-5-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:106
                Signing required
                send: 5-5-0-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
                Waiting for GW to send signing preferences...
                Skipping security for command 3 type 15
                read: 0-0-5 s=255,c=3,t=15,pt=0,l=2,sg=0:
                Mark node 0 as one that do not require signed messages
                Mark node 0 as one that do not require whitelisting
                send: 5-5-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:2.0.0-beta
                send: 5-5-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                Skipping security for command 3 type 16
                read: 0-0-5 s=255,c=3,t=16,pt=0,l=0,sg=0:
                Signing backend: ATSHA204Soft
                SHA256: 2C4A871ACCAE26760F41E547DD39B7B816FE22EEBCD8DFA2FE00000000000000
                Transmittng nonce
                send: 5-5-0-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:2C4A871ACCAE26760F41E547DD39B7B816FE22EEBCD8DFA2FE
                Signature in message: 01C31110DAE29D5DCD3771F68B6F29B5CCCF43A3D5397CC8
                Message to process: 00050E0306FF4D
                Current nonce: 2C4A871ACCAE26760F41E547DD39B7B816FE22EEBCD8DFA2FEAAAAAAAAAAAAAA
                HMAC: 0CC31110DAE29D5DCD3771F68B6F29B5CCCF43A3D5397CC89A82A89D87E931B8
                Signature OK
                read: 0-0-5 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                send: 5-5-0-0 s=255,c=3,t=11,pt=0,l=24,sg=0,st=ok:Temp/Hum Sensor - HTU21D
                send: 5-5-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
                send: 5-5-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                send: 5-5-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                send: 5-5-0-0 s=2,c=0,t=13,pt=0,l=0,sg=0,st=ok:
                Init complete, id=5, parent=0, distance=1
                TempDiff :971.94
                HumDiff  :0.02
                T: 26.06
                H: 36.72
                send: 5-5-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:26.1
                • alexsh1A alexsh1
                  isMetric: 1
                  TempDiff :1098.00
                  HumDiff  :136.75
                  T: 998.00
                  H: 36.75
                  Signing required
                  Transmittng nonce
                  Signature OK
                  TempDiff :971.94
                  HumDiff  :0.02
                  T: 26.06
                  H: 36.72
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @alexsh1 I'm really glad to hear that. Thank you! Glad that signing is being used and is perceived as something not to complicated to bother with. It sets us apart from many other projects dealing with the same thing :)
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @Anticimex I did not say it was not complicated :)
                    Just kidding - speaking just for myself, it did require some time investment to understand the concept and then upgrading my gateway and my nodes (I am still in the process of rolling signing across the rest of my nodes) to MySensors 2.0b. I probably spent more time upgrading MySensors lib and breaking some hardware in the meantime (the SMA connector on the nrf24l01+ PA+LNA) than the actual signing.
                    • alexsh1A alexsh1
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @alexsh1 yeah, well if there is room for improvement in the documentation then feel free to help put with suggestions if there is anything unclear about that :) I use doxygen to document signing features, and a link is available on the GitHub "front-page" (the readme.md)
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @Anticimex I think a noob's section would be good. Having said that, the point is that signing is not something beginners should touch. What do you think?
                        How about a section on the web-site? Somewhere here - https://www.mysensors.org/build/
                        • alexsh1A alexsh1
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @alexsh1 hm, yeah, perhaps something for @hek to consider. At least a link to the signing section of the doxygen docs could be placed there. I have tried to make the documentation as step-by-step friendly as I can. That said, as I also did the actual implementation, I may well be blind for certain aspects I take for granted that a "novice" does not.
                            The next release of the main site will be much more flexible and integrated with openhardware-added projects. The idea is to allow community members to maintain their projects and/or "articles" themselves. The how-to for signing is a good example of an article.
                            • F
                              F
                              Fabien
                              This tutorial is up to date for 2.0 release ?
                              • F Fabien
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @Fabien Yes, top post is now updated for 2.0.0. Documentation is in doxygen.
                                • F
                                  F
                                  Fabien
                                  Thank you @Anticimex I will update my network soon and had RFM69 Encryption too.
                                  • NiklasON
                                    NiklasON
                                    NiklasO
                                    wrote on last edited by NiklasO
                                    #277
                                    Trying this:
                                    https://www.mysensors.org/build/raspberry
                                    How do I enable signing and give the gateway the serial, hmac and aes-key when running on Linux? (rPi).
                                    Edit: Pin 7 as random number generator maybe need some change?
                                    • NiklasON NiklasO
                                      Trying this:
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @NiklasO @marceloaqno is working on this.
                                      • E
                                        E
                                        executivul
                                        I have about 100 ATSHA204 I2C variant to be used in a MySensors project.
                                        Do you think that by modifying the personalizer sketch to disable the I2C bit in the configuration (0x03 word address) the chips can be set to be used as single-wire, or are they hardcoded to use only one protocol, but then why having the config bit?
                                        • E executivul
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          #280
                                          @executivul The bit is readonly. You cannot change it. It is used to determine the variant of chip, not to select mode of operation.
                                          From the documentation:
                                          0_1478094689558_upload-93242040-4814-4ad6-8951-4ad4d1e99a23
                                          But you are welcome to submit a pull request for adding support for I2C variants of ATSHA204a. I have none myself so I have not bothered looking into that and currently I am out of time to spend on it I am afraid.
                                          E 1 Reply Last reply
