  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 465.1k Views 30 Watching
  • AnticimexA Anticimex
    @executivul The bit is readonly. You cannot change it. It is used to determine the variant of chip, not to select mode of operation.
    From the documentation:
    0_1478094689558_upload-93242040-4814-4ad6-8951-4ad4d1e99a23
    But you are welcome to submit a pull request for adding support for I2C variants of ATSHA204a. I have none myself so I have not bothered looking into that and currently I am out of time to spend on it I am afraid.
    E
    E
    executivul
    Please excuse my noobish ignorance: How and where do I submit one?
    AnticimexA 1 Reply Last reply
    • E executivul
      AnticimexA
      AnticimexA
      Anticimex
      @executivul By forking the MySensors core repository and create a local git branch, do your code, push it back to your fork on GitHub and then create a pull request from that. There are good guides on GitHub for how do do it.
        meddie
        ok, thank you, but do you know why the sketch didnt generate the keys, and instead of random i get only keys ffffffffffff ?
        thank you
        • M meddie
          thank you
          AnticimexA
          AnticimexA
          Anticimex
          @meddie Without actually seeing your sketch it is pretty hard for me to help with anything ;)
          My guess is, you did not enable the proper defines to instruct it to generate and store any keys.
            meddie
            @Anticimex
            Hi i have posted my sketch few posts ago, but no problem here is it:
            #include "sha204_library.h"
            #include "sha204_lib_return_codes.h"
            #define MY_CORE_ONLY
            #if DOXYGEN
            #define LOCK_CONFIGURATION
            #define LOCK_DATA
            #define SKIP_KEY_STORAGE
            #define USER_KEY
            #define SKIP_UART_CONFIRMATION
            #define USE_SOFT_SIGNING
            #define STORE_SOFT_KEY
            #define USER_SOFT_KEY
            #define STORE_SOFT_SERIAL
            #define USER_SOFT_SERIAL
            #define STORE_AES_KEY
            #define USER_AES_KEY
            //#define LOCK_CONFIGURATION
            //#define LOCK_DATA
            //#define USER_KEY
            //#define SKIP_UART_CONFIRMATION
            //#define USE_SOFT_SIGNING
            //#define STORE_SOFT_KEY
            //#define USER_SOFT_KEY
            //#define STORE_SOFT_SERIAL
            //#define USER_SOFT_SERIAL
            //#define STORE_AES_KEY
            //#define USER_AES_KEY
            #if defined(SKIP_UART_CONFIRMATION) && !defined(USER_KEY)
            #error You have to define USER_KEY for boards that does not have UART
            #ifdef USER_KEY
            /** @brief The user-defined HMAC key to use for personalization */
            #define MY_HMAC_KEY 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
            /** @brief The data to store in key slot 0 */
            const uint8_t user_key_data[32] = {MY_HMAC_KEY};
            #ifdef USER_SOFT_KEY
            /** @brief The user-defined soft HMAC key to use for EEPROM personalization */
            #define MY_SOFT_HMAC_KEY 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
            /** @brief The data to store as soft HMAC key in EEPROM */
            const uint8_t user_soft_key_data[32] = {MY_SOFT_HMAC_KEY};
            #ifdef USER_SOFT_SERIAL
            /** @brief The user-defined soft serial to use for EEPROM personalization */
            #define MY_SOFT_SERIAL 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
            /** @brief The data to store as soft serial in EEPROM */
            const uint8_t user_soft_serial[9] = {MY_SOFT_SERIAL};
            #ifdef USER_AES_KEY
            /** @brief The user-defined AES key to use for EEPROM personalization */
            #define MY_AES_KEY 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
            /** @brief The data to store as AES key in EEPROM */
            const uint8_t user_aes_key[16] = {MY_AES_KEY};
            #ifndef USE_SOFT_SIGNING
            const int sha204Pin = MY_SIGNING_ATSHA204_PIN; //!< The IO pin to use for ATSHA204A
            atsha204Class sha204(sha204Pin);
            /** @brief Print a error notice and halt the execution */
            void halt()
            	Serial.println(F("Halting!"));
            	while(1);
            uint16_t write_config_and_get_crc()
            	uint16_t crc = 0;
            	uint8_t config_word[4];
            	uint8_t tx_buffer[SHA204_CMD_SIZE_MAX];
            	uint8_t rx_buffer[SHA204_RSP_SIZE_MAX];
            	uint8_t ret_code;
            	bool do_write;
            	for (int i=0; i < 88; i += 4) {
            		do_write = true;
            		if (i == 20) {
            			config_word[0] = 0x8F;
            			config_word[1] = 0x80;
            			config_word[2] = 0x80;
            			config_word[3] = 0xA1;
            		} else if (i == 24) {
            			config_word[0] = 0x82;
            			config_word[1] = 0xE0;
            			config_word[2] = 0xA3;
            			config_word[3] = 0x60;
            		} else if (i == 28) {
            			config_word[0] = 0x94;
            			config_word[1] = 0x40;
            			config_word[2] = 0xA0;
            			config_word[3] = 0x85;
            		} else if (i == 32) {
            			config_word[0] = 0x86;
            			config_word[2] = 0x87;
            			config_word[3] = 0x07;
            		} else if (i == 36) {
            			config_word[0] = 0x0F;
            			config_word[1] = 0x00;
            			config_word[2] = 0x89;
            			config_word[3] = 0xF2;
            		} else if (i == 40) {
            			config_word[0] = 0x8A;
            			config_word[1] = 0x7A;
            			config_word[2] = 0x0B;
            			config_word[3] = 0x8B;
            		} else if (i == 44) {
            			config_word[0] = 0x0C;
            			config_word[1] = 0x4C;
            			config_word[2] = 0xDD;
            			config_word[3] = 0x4D;
            		} else if (i == 48) {
            			config_word[0] = 0xC2;
            			config_word[1] = 0x42;
            			config_word[2] = 0xAF;
            			config_word[3] = 0x8F;
            		} else if (i == 52 || i == 56 || i == 60 || i == 64) {
            			config_word[0] = 0xFF;
            			config_word[2] = 0xFF;
            			config_word[3] = 0x00;
            		} else if (i == 68 || i == 72 || i == 76 || i == 80) {
            			config_word[1] = 0xFF;
            			config_word[3] = 0xFF;
            		} else {
            			// All other configs are untouched
            			ret_code = sha204.sha204m_read(tx_buffer, rx_buffer, SHA204_ZONE_CONFIG, i);
            			if (ret_code != SHA204_SUCCESS) {
            				Serial.print(F("Failed to read config. Response: "));
            				Serial.println(ret_code, HEX);
            				halt();
            			// Set config_word to the read data
            			config_word[0] = rx_buffer[SHA204_BUFFER_POS_DATA+0];
            			config_word[1] = rx_buffer[SHA204_BUFFER_POS_DATA+1];
            			config_word[2] = rx_buffer[SHA204_BUFFER_POS_DATA+2];
            			config_word[3] = rx_buffer[SHA204_BUFFER_POS_DATA+3];
            			do_write = false;
            		// Update crc with CRC for the current word
            		crc = sha204.calculateAndUpdateCrc(4, config_word, crc);
            		// Write config word
            		if (do_write) {
            			ret_code = sha204.sha204m_execute(SHA204_WRITE, SHA204_ZONE_CONFIG,
            			                                  i >> 2, 4, config_word, 0, NULL, 0, NULL,
            			                                  WRITE_COUNT_SHORT, tx_buffer, WRITE_RSP_SIZE, rx_buffer);
            				Serial.print(F("Failed to write config word at address "));
            				Serial.print(i);
            				Serial.print(F(". Response: "));
            				halt();
            	return crc;
             * @brief Write provided key to slot 0
             * @param key The key data to write
            void write_key(uint8_t* key)
            	uint8_t ret_code;
            	// Write key to slot 0
            	ret_code = sha204.sha204m_execute(SHA204_WRITE, SHA204_ZONE_DATA | SHA204_ZONE_COUNT_FLAG,
            	                                  0, SHA204_ZONE_ACCESS_32, key, 0, NULL, 0, NULL,
            	                                  WRITE_COUNT_LONG, tx_buffer, WRITE_RSP_SIZE, rx_buffer);
            		Serial.print(F("Failed to write key to slot 0. Response: "));
            		halt();
            #endif // not USE_SOFT_SIGNING
            /** @brief Dump current configuration to UART */
            void dump_configuration()
            	uint8_t buffer[32];
            	Serial.println(F("EEPROM DATA:"));
            	hwReadConfigBlock((void*)buffer, (void*)EEPROM_SIGNING_SOFT_HMAC_KEY_ADDRESS, 32);
            	Serial.print(F("SOFT_HMAC_KEY | "));
            	for (int j=0; j<32; j++) {
            		if (buffer[j] < 0x10) {
            			Serial.print('0'); // Because Serial.print does not 0-pad HEX
            		Serial.print(buffer[j], HEX);
            	Serial.println();
            	hwReadConfigBlock((void*)buffer, (void*)EEPROM_SIGNING_SOFT_SERIAL_ADDRESS, 9);
            	Serial.print(F("SOFT_SERIAL   | "));
            	for (int j=0; j<9; j++) {
            	Serial.println();
            	hwReadConfigBlock((void*)buffer, (void*)EEPROM_RF_ENCRYPTION_AES_KEY_ADDRESS, 16);
            	Serial.print(F("AES_KEY       | "));
            	for (int j=0; j<16; j++) {
            	Serial.println();
            	uint8_t ret_code;
            	Serial.println(F("ATSHA204A DATA:"));
            			halt();
            		if (i == 0x00) {
            			Serial.print(F("           SN[0:1]           |         SN[2:3]           | "));
            			for (int j=0; j<4; j++) {
            				if (rx_buffer[SHA204_BUFFER_POS_DATA+j] < 0x10) {
            				Serial.print(rx_buffer[SHA204_BUFFER_POS_DATA+j], HEX);
            				if (j == 1) {
            					Serial.print(F(" | "));
            				} else {
            					Serial.print(F("   "));
            			Serial.println();
            		} else if (i == 0x04) {
            			Serial.print(F("                          Revnum                         | "));
            			Serial.println();
            		} else if (i == 0x08) {
            			Serial.print(F("                          SN[4:7]                        | "));
            			Serial.println();
            		} else if (i == 0x0C) {
            			Serial.print(F("    SN[8]    |  Reserved13   | I2CEnable | Reserved15    | "));
            				if (j < 3) {
            				} else {
            			Serial.println();
            		} else if (i == 0x10) {
            			Serial.print(F("  I2CAddress |  TempOffset   |  OTPmode  | SelectorMode  | "));
            				if (j < 3) {
            				} else {
            			Serial.println();
            		} else if (i == 0x14) {
            			Serial.print(F("         SlotConfig00        |       SlotConfig01        | "));
            				if (j == 1) {
            				} else {
            			Serial.println();
            		} else if (i == 0x18) {
            			Serial.print(F("         SlotConfig02        |       SlotConfig03        | "));
            				if (j == 1) {
            				} else {
            			Serial.println();
            		} else if (i == 0x1C) {
            			Serial.print(F("         SlotConfig04        |       SlotConfig05        | "));
            				if (j == 1) {
            				} else {
            			Serial.println();
            		} else if (i == 0x20) {
            			Serial.print(F("         SlotConfig06        |       SlotConfig07        | "));
            				if (j == 1) {
            				} else {
            			Serial.println();
            		} else if (i == 0x24) {
            			Serial.print(F("         SlotConfig08        |       SlotConfig09        | "));
            				if (j == 1) {
            				} else {
            			Serial.println();
            		} else if (i == 0x28) {
            			Serial.print(F("         SlotConfig0A        |       SlotConfig0B        | "));
            				if (j == 1) {
            				} else {
            			Serial.println();
            		} else if (i == 0x2C) {
            			Serial.print(F("         SlotConfig0C        |       SlotConfig0D        | "));
            				if (j == 1) {
            				} else {
            			Serial.println();
            		} else if (i == 0x30) {
            			Serial.print(F("         SlotConfig0E        |       SlotConfig0F        | "));
            				if (j == 1) {
            				} else {
            			Serial.println();
            		} else if (i == 0x34) {
            			Serial.print(F("  UseFlag00  | UpdateCount00 | UseFlag01 | UpdateCount01 | "));
            				if (j < 3) {
            				} else {
            			Serial.println();
            		} else if (i == 0x38) {
            			Serial.print(F("  UseFlag02  | UpdateCount02 | UseFlag03 | UpdateCount03 | "));
            				if (j < 3) {
            				} else {
            			Serial.println();
            		} else if (i == 0x3C) {
            			Serial.print(F("  UseFlag04  | UpdateCount04 | UseFlag05 | UpdateCount05 | "));
            				if (j < 3) {
            				} else {
            			Serial.println();
            		} else if (i == 0x40) {
            			Serial.print(F("  UseFlag06  | UpdateCount06 | UseFlag07 | UpdateCount07 | "));
            				if (j < 3) {
            				} else {
            			Serial.println();
            		} else if (i == 0x44) {
            			Serial.print(F("                      LastKeyUse[0:3]                    | "));
            			Serial.println();
            		} else if (i == 0x48) {
            			Serial.print(F("                      LastKeyUse[4:7]                    | "));
            			Serial.println();
            		} else if (i == 0x4C) {
            			Serial.print(F("                      LastKeyUse[8:B]                    | "));
            			Serial.println();
            		} else if (i == 0x50) {
            			Serial.print(F("                      LastKeyUse[C:F]                    | "));
            			Serial.println();
            		} else if (i == 0x54) {
            			Serial.print(F("  UserExtra  |    Selector   | LockValue |  LockConfig   | "));
            				if (j < 3) {
            				} else {
            			Serial.println();
            /** @brief Sketch setup code */
            	// Delay startup a bit for serial consoles to catch up
            	unsigned long enter = hwMillis();
            	while (hwMillis() - enter < (unsigned long)500);
            	uint8_t ret_code;
            	uint8_t lockConfig = 0;
            	uint8_t lockValue = 0;
            	uint16_t crc;
            	(void)crc;
            #else
            	// initialize pseudo-RNG
            	randomSeed(analogRead(MY_SIGNING_SOFT_RANDOMSEED_PIN));
            	uint8_t key[32];
            	(void)key;
            	Serial.begin(115200);
            	hwInit();
            	Serial.println(F("Personalization sketch for MySensors usage."));
            	Serial.println(F("-------------------------------------------"));
            	// Wake device before starting operations
            	ret_code = sha204.sha204c_wakeup(rx_buffer);
            		Serial.print(F("Failed to wake device. Response: "));
            		halt();
            	// Read out lock config bits to determine if locking is possible
            	ret_code = sha204.sha204m_read(tx_buffer, rx_buffer, SHA204_ZONE_CONFIG, 0x15<<2);
            		Serial.print(F("Failed to determine device lock status. Response: "));
            		halt();
            	} else {
            		lockConfig = rx_buffer[SHA204_BUFFER_POS_DATA+3];
            		lockValue = rx_buffer[SHA204_BUFFER_POS_DATA+2];
            #ifdef STORE_SOFT_KEY
            	memcpy(key, user_soft_key_data, 32);
            	Serial.println(F("Using this user supplied soft HMAC key:"));
            #else
            	// Retrieve random value to use as soft HMAC key
            #ifdef USE_SOFT_SIGNING
            	for (int i = 0; i < 32; i++) {
            		key[i] = random(256) ^ micros();
            		while (hwMillis() - enter < (unsigned long)2);
            	Serial.println(F("This value will be stored in EEPROM as soft HMAC key:"));
            #else
            	ret_code = sha204.sha204m_random(tx_buffer, rx_buffer, RANDOM_SEED_UPDATE);
            		Serial.print(F("Random key generation failed. Response: "));
            		halt();
            	} else {
            		memcpy(key, rx_buffer+SHA204_BUFFER_POS_DATA, 32);
            	if (lockConfig == 0x00) {
            	} else {
            		Serial.println(F("Key is not randomized (configuration not locked):"));
            #endif // not USER_SOFT_KEY
            	Serial.print("#define MY_SOFT_HMAC_KEY ");
            	for (int i=0; i<32; i++) {
            		Serial.print("0x");
            		if (key[i] < 0x10) {
            		Serial.print(key[i], HEX);
            		if (i < 31) {
            			Serial.print(',');
            	Serial.println();
            	hwWriteConfigBlock((void*)key, (void*)EEPROM_SIGNING_SOFT_HMAC_KEY_ADDRESS, 32);
            #endif // STORE_SOFT_KEY
            #ifdef STORE_SOFT_SERIAL
            	memcpy(key, user_soft_serial, 9);
            	Serial.println(F("Using this user supplied soft serial:"));
            #else
            	// Retrieve random value to use as serial
            	for (int i = 0; i < 9; i++) {
            	Serial.println(F("This value will be stored in EEPROM as soft serial:"));
            #else
            		Serial.print(F("Random serial generation failed. Response: "));
            		halt();
            	} else {
            		memcpy(key, rx_buffer+SHA204_BUFFER_POS_DATA, 9);
            	} else {
            		Serial.println(F("Serial is not randomized (configuration not locked):"));
            #endif // not USER_SOFT_SERIAL
            	Serial.print("#define MY_SOFT_SERIAL ");
            	for (int i=0; i<9; i++) {
            		Serial.print("0x");
            		if (i < 8) {
            			Serial.print(',');
            	Serial.println();
            	hwWriteConfigBlock((void*)key, (void*)EEPROM_SIGNING_SOFT_SERIAL_ADDRESS, 9);
            #endif // STORE_SOFT_SERIAL
            #ifdef STORE_AES_KEY
            #ifdef USER_AES_KEY
            	memcpy(key, user_aes_key, 16);
            	Serial.println(F("Using this user supplied AES key:"));
            #else
            	// Retrieve random value to use as key
            	for (int i = 0; i < 16; i++) {
            	Serial.println(F("This key will be stored in EEPROM as AES key:"));
            #else
            		halt();
            	} else {
            	} else {
            #endif // not USER_AES_KEY
            	Serial.print("#define MY_AES_KEY ");
            	for (int i=0; i<16; i++) {
            		Serial.print("0x");
            		if (i < 15) {
            			Serial.print(',');
            	Serial.println();
            	hwWriteConfigBlock((void*)key, (void*)EEPROM_RF_ENCRYPTION_AES_KEY_ADDRESS, 16);
            #endif // STORE_AES_KEY
            	Serial.println(F("EEPROM configuration:"));
            	dump_configuration();
            #else
            	// Output device revision on console
            	ret_code = sha204.sha204m_dev_rev(tx_buffer, rx_buffer);
            		Serial.print(F("Failed to determine device revision. Response: "));
            		halt();
            	} else {
            		Serial.print(F("Device revision: "));
            		for (int i=0; i<4; i++) {
            			if (rx_buffer[SHA204_BUFFER_POS_DATA+i] < 0x10) {
            			Serial.print(rx_buffer[SHA204_BUFFER_POS_DATA+i], HEX);
            		Serial.println();
            	// Output serial number on console
            	ret_code = sha204.getSerialNumber(rx_buffer);
            		Serial.print(F("Failed to obtain device serial number. Response: "));
            		halt();
            	} else {
            		Serial.print(F("Device serial:   "));
            		Serial.print('{');
            			Serial.print(F("0x"));
            			if (rx_buffer[i] < 0x10) {
            			Serial.print(rx_buffer[i], HEX);
            			if (i < 8) {
            				Serial.print(',');
            		Serial.print('}');
            		Serial.println();
            		Serial.println();
            	if (lockConfig != 0x00) {
            		// Write config and get CRC for the updated config
            		crc = write_config_and_get_crc();
            		// List current configuration before attempting to lock
            		Serial.println(F("Chip configuration:"));
            #ifdef LOCK_CONFIGURATION
            		// Purge serial input buffer
            #ifndef SKIP_UART_CONFIRMATION
            		while (Serial.available()) {
            			Serial.read();
            		Serial.println(F("Send SPACE character now to lock the configuration..."));
            		while (Serial.available() == 0);
            		if (Serial.read() == ' ')
            #endif //not SKIP_UART_CONFIRMATION
            			Serial.println(F("Locking configuration..."));
            			// Correct sequence, resync chip
            			ret_code = sha204.sha204c_resync(SHA204_RSP_SIZE_MAX, rx_buffer);
            			if (ret_code != SHA204_SUCCESS && ret_code != SHA204_RESYNC_WITH_WAKEUP) {
            				Serial.print(F("Resync failed. Response: "));
            				halt();
            			// Lock configuration zone
            			ret_code = sha204.sha204m_execute(SHA204_LOCK, SHA204_ZONE_CONFIG,
            			                                  crc, 0, NULL, 0, NULL, 0, NULL,
            			                                  LOCK_COUNT, tx_buffer, LOCK_RSP_SIZE, rx_buffer);
            				Serial.print(F("Configuration lock failed. Response: "));
            				halt();
            			} else {
            				Serial.println(F("Configuration locked."));
            				// Update lock flags after locking
            					halt();
            				} else {
            		else {
            			Serial.println(F("Unexpected answer. Skipping lock."));
            #else //LOCK_CONFIGURATION
            		Serial.println(F("Configuration not locked. Define LOCK_CONFIGURATION to lock for real."));
            	} else {
            		Serial.println(F("Skipping configuration write and lock (configuration already locked)."));
            #ifdef SKIP_KEY_STORAGE
            	Serial.println(F("Disable SKIP_KEY_STORAGE to store key."));
            #else
            #ifdef USER_KEY
            	memcpy(key, user_key_data, 32);
            	Serial.println(F("Using this user supplied HMAC key:"));
            #else
            		halt();
            	} else {
            		Serial.println(F("Take note of this key, it will never be the shown again:"));
            	} else {
            	Serial.print("#define MY_HMAC_KEY ");
            		Serial.print("0x");
            		if (i < 31) {
            			Serial.print(',');
            		if (i+1 == 16) {
            			Serial.print("\\\n                    ");
            	Serial.println();
            	// It will not be possible to write the key if the configuration zone is unlocked
            		// Write the key to the appropriate slot in the data zone
            		Serial.println(F("Writing key to slot 0..."));
            		write_key(key);
            	} else {
            		Serial.println(F("Skipping key storage (configuration not locked)."));
            		Serial.println(F("The configuration must be locked to be able to write a key."));
            	if (lockValue != 0x00) {
            #ifdef LOCK_DATA
            			Serial.read();
            		Serial.println(F("Send SPACE character to lock data..."));
            				halt();
            			// If configuration is unlocked, key is not updated. Locking data in this case will cause
            			// slot 0 to contain an unknown (or factory default) key, and this is in practically any
            			// usecase not the desired behaviour, so ask for additional confirmation in this case.
            					Serial.read();
            				Serial.println(F("*** ATTENTION ***"));
            				Serial.println(F("Configuration is not locked. Are you ABSULOUTELY SURE you want to lock data?"));
            				Serial.println(F("Locking data at this stage will cause slot 0 to contain a factory default key"));
            				Serial.println(
            				    F("which cannot be change after locking is done. This is in practically any usecase"));
            				Serial.println(F("NOT the desired behavour. Send SPACE character now to lock data anyway..."));
            				if (Serial.read() != ' ') {
            					halt();
            			// Lock data zone
            			ret_code = sha204.sha204m_execute(SHA204_LOCK, SHA204_ZONE_DATA | LOCK_ZONE_NO_CRC,
            			                                  0x0000, 0, NULL, 0, NULL, 0, NULL,
            				Serial.print(F("Data lock failed. Response: "));
            				halt();
            			} else {
            				Serial.println(F("Data locked."));
            					halt();
            				} else {
            		else {
            #else //LOCK_DATA
            		Serial.println(F("Data not locked. Define LOCK_DATA to lock for real."));
            	} else {
            		Serial.println(F("Skipping OTP/data zone lock (zone already locked)."));
            	Serial.println(F("--------------------------------"));
            	Serial.println(F("Personalization is now complete."));
            	Serial.print(F("Configuration is "));
            		Serial.println("LOCKED");
            	} else {
            		Serial.println("UNLOCKED");
            	Serial.print(F("Data is "));
            	if (lockValue == 0x00) {
            	} else {
            /** @brief Sketch execution code */
            • M meddie
              @Anticimex
              #if DOXYGEN
              #define LOCK_DATA
              #define USER_KEY
              //#define LOCK_DATA
              //#define USER_KEY
              #ifdef USER_KEY
              #ifdef USER_AES_KEY
              void halt()
              	while(1);
              	uint16_t crc = 0;
              	uint8_t ret_code;
              	bool do_write;
              		do_write = true;
              		if (i == 20) {
              		} else {
              				halt();
              			do_write = false;
              		if (do_write) {
              				Serial.print(i);
              				halt();
              	return crc;
              	uint8_t ret_code;
              		halt();
              	uint8_t buffer[32];
              	Serial.println();
              	Serial.println();
              	Serial.println();
              	uint8_t ret_code;
              			halt();
              		if (i == 0x00) {
              				if (j == 1) {
              				} else {
              			Serial.println();
              			Serial.println();
              			Serial.println();
              				if (j < 3) {
              				} else {
              			Serial.println();
              				if (j < 3) {
              				} else {
              			Serial.println();
              				if (j == 1) {
              				} else {
              			Serial.println();
              				if (j == 1) {
              				} else {
              			Serial.println();
              				if (j == 1) {
              				} else {
              			Serial.println();
              				if (j == 1) {
              				} else {
              			Serial.println();
              				if (j == 1) {
              				} else {
              			Serial.println();
              				if (j == 1) {
              				} else {
              			Serial.println();
              				if (j == 1) {
              				} else {
              			Serial.println();
              				if (j == 1) {
              				} else {
              			Serial.println();
              				if (j < 3) {
              				} else {
              			Serial.println();
              				if (j < 3) {
              				} else {
              			Serial.println();
              				if (j < 3) {
              				} else {
              			Serial.println();
              				if (j < 3) {
              				} else {
              			Serial.println();
              			Serial.println();
              			Serial.println();
              			Serial.println();
              			Serial.println();
              				if (j < 3) {
              				} else {
              			Serial.println();
              	uint8_t ret_code;
              	uint16_t crc;
              	(void)crc;
              #else
              	uint8_t key[32];
              	(void)key;
              	hwInit();
              		halt();
              		halt();
              	} else {
              #else
              #else
              		halt();
              	} else {
              	} else {
              		Serial.print("0x");
              		if (i < 31) {
              			Serial.print(',');
              	Serial.println();
              #else
              #else
              		halt();
              	} else {
              	} else {
              		Serial.print("0x");
              		if (i < 8) {
              			Serial.print(',');
              	Serial.println();
              #ifdef USER_AES_KEY
              #else
              #else
              		halt();
              	} else {
              	} else {
              		Serial.print("0x");
              		if (i < 15) {
              			Serial.print(',');
              	Serial.println();
              #else
              		halt();
              	} else {
              		Serial.println();
              		halt();
              	} else {
              		Serial.print('{');
              			if (i < 8) {
              				Serial.print(',');
              		Serial.print('}');
              		Serial.println();
              		Serial.println();
              			Serial.read();
              				halt();
              				halt();
              			} else {
              					halt();
              				} else {
              		else {
              	} else {
              #else
              #ifdef USER_KEY
              #else
              		halt();
              	} else {
              	} else {
              		Serial.print("0x");
              		if (i < 31) {
              			Serial.print(',');
              		if (i+1 == 16) {
              	Serial.println();
              		write_key(key);
              	} else {
              #ifdef LOCK_DATA
              			Serial.read();
              				halt();
              					Serial.read();
              				Serial.println(
              					halt();
              			// Lock data zone
              				halt();
              			} else {
              					halt();
              				} else {
              		else {
              #else //LOCK_DATA
              	} else {
              	} else {
              	} else {
              AnticimexA
              AnticimexA
              Anticimex
              @meddie Sorry, missed that post.
              You have SKIP_KEY_STORAGE defined so no keys will be stored. This is the default and intentional, to avoid people just executing the sketch and accidentally overwrite existing keys.
              Furthermore, you have selected to personalize a ATSHA device, and have it generate the keys. That means that you have to define LOCK_CONFIGURATION or the ATSHA random number generator will not work.
              M 1 Reply Last reply
              • AnticimexA
                AnticimexA
                Anticimex
                You can read about personalization here.
                  meddie
                  Ah, thank you very much, yes now i get generated a key. But one more question the AES key will not be generated? I got only the HMAC Key, do i have to put the AES Key at myself?
                  Thank you very much!
                  • M meddie
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @meddie Please read the documentation and the sketch carefully. It quite clearly states in both documentation and code that you need to define STORE_AES_KEY to generate and store an AES key.
                      meddie
                      @Anticimex
                      sorry sorry for so many questions, i have read the how to use already some times, but maybe its my bad english or the fear to do something wrong or to destroy the chip. I get a little bit unsure.
                      Now i get both keys. If i understood correctly, the keys are now stored, i have now to put the shown keys to the sketch as HMAC and AES Key, and run this sketch on the sensor nodes.
                      On the gateway on which i generated the keys i dont need to do anything more as to upload the gateway sketch ?
                      Thank you very much for your support!
                      • M meddie
                        @Anticimex
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @meddie assuming you locked the configuration of the atsha, no you should not need to do more.
                          meddie
                          @Anticimex said in 💬 Sensebender Gateway:
                          @Anticimex
                          sorry i have one more question, because i didnt fully understand this. In the gettings started how to you wrote:
                          Pick a “master” device with serial debug port.
                          Set the following sketch configuration of the personalizer:
                          Enable SKIP_KEY_STORAGE
                          Execute the sketch on the “master” device to obtain a randomized key. Save this key to a secure location and keep it confidential so that you can retrieve it if you need to personalize more devices later on.
                          Now reconfigure the sketch with these settings:
                          Put the saved key in the user_key_data variable.
                          Now execute the sketch on all devices you want to personalize with this secret key.
                          on the first run i have to enable SKIP_KEY_STORAGE so i removed the comments.
                          But here in forum you write i have to disable this. After i has disabled it wroked fine for me.
                          But now i have to run the sketch on my node, and i think i have to disable the SKIP function too, because i need that the keys will be stored in the node.
                          So if i am right, the on both runs the SKIP function has to be commented out? Or i am wrong?
                          Thank you.
                          • M meddie
                            @Anticimex
                            Thank you.
                            AnticimexA
                            AnticimexA
                            Anticimex
                            #293
                            @meddie If your read the text carefully it says:
                            So in other words; you first use the settings described in the first setting, execute that once. Follow the instructions carefully. Write down the key you got. Then you reconfigure the sketch and execute it on all devices you want to personalize. That is, you execute it twice on the first device.
                            I wrote that you need to undefine SKIP_KEY_STORAGE if you want to store a key. But the first set of instructions in the documentation is not saying that you are supposed to store a key. It says "Execute the sketch on the “master” device to obtain a randomized key."
                            So the documentation is correct, and describe a flow where you personalize nodes and gateways with the minimum amount of changes needed. First you generate a key, and this step can actually be skipped altogether if you just make your own random key or password to use for HMAC/AES.
                            Then you reconfigure the personalizer to use your generated (or selected) key and write it to all your devices.
                              meddie
                              @Anticimex
                              but as i runned the sketch with SKIP_KEY_STORAGE defined, so no keys were generated.
                              i did not like to say that the documentation is incorrect, i like your documentation and your work very well! i just didnt understand it!
                              Greets Eddie
                              • M meddie
                                @Anticimex
                                Greets Eddie
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @meddie are you sure you ran with the exact settings described for generating the keys? The SKIP_KEY_STORAGE flag does not prevent the keys from being generated. They are still printed in the serial log. It prevents the keys from being stored to the atsha204a device.
                                  meddie
                                  i fear to write again, but my fail story goes on :-(
                                  i have uploaded on the gateway this sketch:
                                  * Version 1.0 - Henrik EKblad
                                  * Contribution by Tomas Hozza <thozza@gmail.com>
                                  * This GW code is designed for Sensebender GateWay / (Arduino Zero variant)
                                  * Wire connections (OPTIONAL):
                                  * - Inclusion button should be connected to SW2
                                  * LEDs on board (default assignments):
                                  * - Orange: USB RX/TX - Blink when receiving / transmitting on USB CDC device
                                  * - Yellow: RX  - Blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
                                  * - Green : TX  - Blink fast on radio message transmitted. In inclusion mode will blink slowly
                                  * - Red   : ERR - Fast blink on error during transmission error or recieve crc error
                                  * - Blue  : free - (use with LED_BLUE macro)
                                  #include <stdint.h>
                                  #include <pins_arduino.h>
                                  #define SKETCH_VERSION "0.2"
                                  #define MY_DEBUG_VERBOSE_SIGNING
                                  //#define MY_RF24_PA_LEVEL RF24_PA_HIGH
                                  #define MY_SIGNING_ATSHA204
                                  //#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01}}}
                                  //#define MY_SIGNING_REQUEST_SIGNATURES
                                  #ifndef MY_SIGNING_SOFT_RANDOMSEED_PIN
                                  #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
                                  #ifndef MY_SIGNING_ATSHA204_PIN
                                  #define MY_SIGNING_ATSHA204_PIN 17
                                  #define MY_RF24_ENABLE_ENCRYPTION
                                  #define MY_GATEWAY_W5100
                                  //#define MY_W5100_SPI_EN 4
                                  // radio on the same spi bus.
                                  #define MY_SOFTSPI
                                  #ifndef MY_RF24_CE_PIN
                                  #define MY_RF24_CE_PIN 5
                                  #ifndef MY_RF24_CS_PIN
                                  #define MY_RF24_CS_PIN 6
                                  // Enable to UDP
                                  //#define MY_USE_UDP
                                  #define MY_IP_ADDRESS 10,0,0,253   // If this is disabled, DHCP is used to retrieve address
                                  #define MY_PORT 5003
                                  //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
                                  // Enable inclusion mode
                                  // Set blinking period
                                  // Flash leds on rx/tx/err
                                  #if defined(MY_USE_UDP)
                                  #include <EthernetUdp.h>
                                  #include <Ethernet.h>
                                  #include <SD.h>
                                  //#include <drivers/ATSHA204/ATSHA204.cpp>
                                  Sd2Card card;
                                  #define EEPROM_VERIFICATION_ADDRESS 0x01
                                  static uint8_t num_of_leds = 5;
                                  static uint8_t leds[] = {LED_BLUE, LED_RED, LED_GREEN, LED_YELLOW, LED_ORANGE};
                                  void preHwInit()
                                    pinMode(MY_SWC1, INPUT_PULLUP);
                                    pinMode(MY_SWC2, INPUT_PULLUP);
                                    if (digitalRead(MY_SWC1) && digitalRead(MY_SWC2)) {
                                      return;
                                    uint8_t tests = 0;
                                    for (int i=0; i< num_of_leds; i++) {
                                      pinMode(leds[i], OUTPUT);
                                    uint8_t led_state = 0;
                                    if (digitalRead(MY_SWC1)) {
                                      while (!Serial) {
                                        digitalWrite(LED_BLUE, led_state);
                                        led_state ^= 0x01;
                                        delay(500);
                                      } // Wait for USB to be connected, before spewing out data.
                                    digitalWrite(LED_BLUE, LOW);
                                    if (Serial) {
                                      Serial.println("Sensebender GateWay test routine");
                                      Serial.print("Mysensors core version : ");
                                      Serial.println(MYSENSORS_LIBRARY_VERSION);
                                      Serial.print("GateWay sketch version : ");
                                      Serial.println(SKETCH_VERSION);
                                      Serial.println("----------------------------------");
                                      Serial.println();
                                    if (testSha204()) {
                                      digitalWrite(LED_GREEN, HIGH);
                                      tests++;
                                    if (testSDCard()) {
                                      digitalWrite(LED_YELLOW, HIGH);
                                      tests++;
                                    if (testEEProm()) {
                                      digitalWrite(LED_ORANGE, HIGH);
                                      tests++;
                                    if (testAnalog()) {
                                      digitalWrite(LED_BLUE, HIGH);
                                      tests++;
                                    if (tests == 4) {
                                      while(1) {
                                        for (int i=0; i<num_of_leds; i++) {
                                          digitalWrite(leds[i], HIGH);
                                          delay(200);
                                          digitalWrite(leds[i], LOW);
                                    } else {
                                      while (1) {
                                        digitalWrite(LED_RED, HIGH);
                                        delay(200);
                                        digitalWrite(LED_RED, LOW);
                                        delay(200);
                                  bool testSha204()
                                    uint8_t ret_code;
                                    if (Serial) {
                                      Serial.print("- > SHA204 ");
                                    atsha204_init(MY_SIGNING_ATSHA204_PIN);
                                    ret_code = atsha204_wakeup(rx_buffer);
                                    if (ret_code == SHA204_SUCCESS) {
                                      ret_code = atsha204_getSerialNumber(rx_buffer);
                                        if (Serial) {
                                          Serial.println(F("Failed to obtain device serial number. Response: "));
                                      } else {
                                        if (Serial) {
                                          Serial.print(F("Ok (serial : "));
                                          Serial.println(")");
                                        return true;
                                    } else {
                                      if (Serial) {
                                        Serial.println(F("Failed to wakeup SHA204"));
                                    return false;
                                  bool testSDCard()
                                    if (Serial) {
                                      Serial.print("- > SD CARD ");
                                    if (!card.init(SPI_HALF_SPEED, MY_SDCARD_CS)) {
                                      if (Serial) {
                                        Serial.println("SD CARD did not initialize!");
                                    } else {
                                      if (Serial) {
                                        Serial.print("SD Card initialized correct! - ");
                                        Serial.print("type detected : ");
                                        switch(card.type()) {
                                        case SD_CARD_TYPE_SD1:
                                          Serial.println("SD1");
                                          break;
                                        case SD_CARD_TYPE_SD2:
                                          Serial.println("SD2");
                                          break;
                                        case SD_CARD_TYPE_SDHC:
                                          Serial.println("SDHC");
                                          break;
                                        default:
                                          Serial.println("Unknown");
                                      return true;
                                    return false;
                                  bool testEEProm()
                                    uint8_t eeprom_d1, eeprom_d2;
                                    SerialUSB.print(" -> EEPROM ");
                                    Wire.begin();
                                    eeprom_d1 = i2c_eeprom_read_byte(EEPROM_VERIFICATION_ADDRESS);
                                    delay(500);
                                    eeprom_d1 = ~eeprom_d1; // invert the bits
                                    i2c_eeprom_write_byte(EEPROM_VERIFICATION_ADDRESS, eeprom_d1);
                                    delay(500);
                                    eeprom_d2 = i2c_eeprom_read_byte(EEPROM_VERIFICATION_ADDRESS);
                                    if (eeprom_d1 == eeprom_d2) {
                                      SerialUSB.println("PASSED");
                                      i2c_eeprom_write_byte(EEPROM_VERIFICATION_ADDRESS, ~eeprom_d1);
                                      return true;
                                    SerialUSB.println("FAILED!");
                                    return false;
                                  bool testAnalog()
                                    int bat_detect = analogRead(MY_BAT_DETECT);
                                    Serial.print("-> analog : ");
                                    Serial.print(bat_detect);
                                    if (bat_detect < 400 || bat_detect > 650) {
                                      Serial.println(" Failed");
                                      return false;
                                    Serial.println(" Passed");
                                    return true;
                                    meddie
                                    and on the node this sketch:
                                    #include <stdint.h>
                                    //#define MY_SIGNING_SOFT
                                    But the node does not connect and i get this on the serial monitor:
                                    0 MCO:BGN:INIT NODE,CP=RNNNAA-,VER=2.1.1
                                    4 TSM:INIT
                                    4 TSF:WUR:MS=0
                                    12 TSM:INIT:TSP OK
                                    14 TSF:SID:OK,ID=100
                                    16 TSM:FPAR
                                    18 Will not sign message for destination 255 as it does not require it
                                    67 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    2076 !TSM:FPAR:NO REPLY
                                    2078 TSM:FPAR
                                    2080 Will not sign message for destination 255 as it does not require it
                                    2127 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    4139 !TSM:FPAR:NO REPLY
                                    4141 TSM:FPAR
                                    4143 Will not sign message for destination 255 as it does not require it
                                    4190 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    6199 !TSM:FPAR:NO REPLY
                                    6201 TSM:FPAR
                                    6203 Will not sign message for destination 255 as it does not require it
                                    6250 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    8259 !TSM:FPAR:FAIL
                                    8261 TSM:FAIL:CNT=1
                                    8263 TSM:FAIL:PDT
                                    18266 TSM:FAIL:RE-INIT
                                    18268 TSM:INIT
                                    18276 TSM:INIT:TSP OK
                                    18278 TSF:SID:OK,ID=100
                                    18280 TSM:FPAR
                                    18282 Will not sign message for destination 255 as it does not require it
                                    18331 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    20340 !TSM:FPAR:NO REPLY
                                    20342 TSM:FPAR
                                    20344 Will not sign message for destination 255 as it does not require it
                                    20393 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    22403 !TSM:FPAR:NO REPLY
                                    22405 TSM:FPAR
                                    22407 Will not sign message for destination 255 as it does not require it
                                    22456 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    24465 !TSM:FPAR:NO REPLY
                                    24467 TSM:FPAR
                                    24469 Will not sign message for destination 255 as it does not require it
                                    24518 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    26527 !TSM:FPAR:FAIL
                                    26529 TSM:FAIL:CNT=2
                                    26531 TSM:FAIL:PDT
                                    36534 TSM:FAIL:RE-INIT
                                    36536 TSM:INIT
                                    36544 TSM:INIT:TSP OK
                                    36546 TSF:SID:OK,ID=100
                                    36548 TSM:FPAR
                                    36550 Will not sign message for destination 255 as it does not require it
                                    36599 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    38610 !TSM:FPAR:NO REPLY
                                    38612 TSM:FPAR
                                    38615 Will not sign message for destination 255 as it does not require it
                                    38664 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    40673 !TSM:FPAR:NO REPLY
                                    40675 TSM:FPAR
                                    40677 Will not sign message for destination 255 as it does not require it
                                    40726 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    42735 !TSM:FPAR:NO REPLY
                                    42737 TSM:FPAR
                                    42739 Will not sign message for destination 255 as it does not require it
                                    42788 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    44800 !TSM:FPAR:FAIL
                                    44802 TSM:FAIL:CNT=3
                                    44804 TSM:FAIL:PDT
                                    54808 TSM:FAIL:RE-INIT
                                    54810 TSM:INIT
                                    54818 TSM:INIT:TSP OK
                                    54820 TSF:SID:OK,ID=100
                                    54822 TSM:FPAR
                                    54824 Will not sign message for destination 255 as it does not require it
                                    54874 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    56883 !TSM:FPAR:NO REPLY
                                    56885 TSM:FPAR
                                    56887 Will not sign message for destination 255 as it does not require it
                                    56936 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    please help me once again
                                    Thank you
                                    AnticimexA 3 Replies Last reply
                                    • M meddie
                                      #include <stdint.h>
                                      4 TSM:INIT
                                      4 TSF:WUR:MS=0
                                      12 TSM:INIT:TSP OK
                                      16 TSM:FPAR
                                      2078 TSM:FPAR
                                      4141 TSM:FPAR
                                      6201 TSM:FPAR
                                      8259 !TSM:FPAR:FAIL
                                      8261 TSM:FAIL:CNT=1
                                      8263 TSM:FAIL:PDT
                                      18268 TSM:INIT
                                      18280 TSM:FPAR
                                      20342 TSM:FPAR
                                      22405 TSM:FPAR
                                      24467 TSM:FPAR
                                      26531 TSM:FAIL:PDT
                                      36536 TSM:INIT
                                      36548 TSM:FPAR
                                      38612 TSM:FPAR
                                      40675 TSM:FPAR
                                      42737 TSM:FPAR
                                      44804 TSM:FAIL:PDT
                                      54810 TSM:INIT
                                      54822 TSM:FPAR
                                      56885 TSM:FPAR
                                      Thank you
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      #298
                                      @meddie if you want your node to sign messages to the gateway you have to tell the gateway to require it. The log says that it does not require it and it is clear from your gateway sketch that you have disabled the requirement.
                                      Is that your problem?
                                      EDIT: I see that the messages are broadcasts, those will never be signed. So the "will not sign messages" are perfectly normal no matter how you configure your gateway in this case.
                                      The problem, at least based on the node log is that your node cannot find a parent to communicate with for some reason.
                                      • M meddie
                                        #include <stdint.h>
                                        4 TSM:INIT
                                        4 TSF:WUR:MS=0
                                        12 TSM:INIT:TSP OK
                                        16 TSM:FPAR
                                        2078 TSM:FPAR
                                        4141 TSM:FPAR
                                        6201 TSM:FPAR
                                        8259 !TSM:FPAR:FAIL
                                        8261 TSM:FAIL:CNT=1
                                        8263 TSM:FAIL:PDT
                                        18268 TSM:INIT
                                        18280 TSM:FPAR
                                        20342 TSM:FPAR
                                        22405 TSM:FPAR
                                        24467 TSM:FPAR
                                        26531 TSM:FAIL:PDT
                                        36536 TSM:INIT
                                        36548 TSM:FPAR
                                        38612 TSM:FPAR
                                        40675 TSM:FPAR
                                        42737 TSM:FPAR
                                        44804 TSM:FAIL:PDT
                                        54810 TSM:INIT
                                        54822 TSM:FPAR
                                        56885 TSM:FPAR
                                        Thank you
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @meddie for parsing the log file you can use this tool
                                        • M meddie
                                          #include <stdint.h>
                                          4 TSM:INIT
                                          4 TSF:WUR:MS=0
                                          12 TSM:INIT:TSP OK
                                          16 TSM:FPAR
                                          2078 TSM:FPAR
                                          4141 TSM:FPAR
                                          6201 TSM:FPAR
                                          8259 !TSM:FPAR:FAIL
                                          8261 TSM:FAIL:CNT=1
                                          8263 TSM:FAIL:PDT
                                          18268 TSM:INIT
                                          18280 TSM:FPAR
                                          20342 TSM:FPAR
                                          22405 TSM:FPAR
                                          24467 TSM:FPAR
                                          26531 TSM:FAIL:PDT
                                          36536 TSM:INIT
                                          36548 TSM:FPAR
                                          38612 TSM:FPAR
                                          40675 TSM:FPAR
                                          42737 TSM:FPAR
                                          44804 TSM:FAIL:PDT
                                          54810 TSM:INIT
                                          54822 TSM:FPAR
                                          56885 TSM:FPAR
                                          Thank you
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @meddie I also see that you fail to find parent. Have you verified that you had working node-gateway communication before you enabled signing?
