  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 465.0k Views 30 Watching
  • scalzS scalz
    Hi @Anticimex,
    I read your first post and followed it, it was very interesting and comprehensible. So I am trying autentication to see how it looks. I entered the key in a Gateway (nano) and a mini pro node. The mini is running DHT Humidity sketch (I know it is not very interesting node for autentication but it's easy on breadboard). I am using latest dev branch. Communication seems to work but i am a little confused with serial output on GW as I see some no sign. It seems that humidity is ok, but not the temperature child.. but I am not sure.
    What do you think I am doing wrong?
    Edit: I am getting others nosign... Does presentation and version messages uses autentication too? because they seem to be ok but not the child sensors value..
    Here is GW logs:
    0;0;3;0;9;read: 10-10-0 s=255,c=3,t=15,pt=2,l=2,sg=0:1
    0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:1
    0;0;3;0;9;read: 10-10-0 s=255,c=3,t=16,pt=0,l=0,sg=0:
    0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:01F989B
    0;0;3;0;9;read: 10-10-0 s=255,c=0,t=17,pt=0,l=6,sg=1:1.5 b1
    10;255;0;0;17;1.5 b1
    0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:017DA4B
    0;0;3;0;9;read: 10-10-0 s=255,c=3,t=6,pt=1,l=1,sg=1:0
    10;255;3;0;6;0
    0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:01C7E11
    0;0;3;0;9;read: 10-10-0 s=255,c=3,t=11,pt=0,l=8,sg=1:Humidity
    10;255;3;0;11;Humidity
    0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:017B669
    0;0;3;0;9;read: 10-10-0 s=255,c=3,t=12,pt=0,l=3,sg=1:1.0
    10;255;3;0;12;1.0
    0;0;3;0;9;read: 10-10-0 s=0,c=0,t=7,pt=0,l=0,sg=0:
    10;0;0;0;7;
    0;0;3;0;9;read: 10-10-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
    10;1;0;0;6;
    0;0;3;0;9;no sign
    0;0;3;0;9;no sign
    AnticimexA
    AnticimexA
    Anticimex
    @scalz Thanks.
    Could you please also post the construction code of your MySensor object.
    And also your MyConfig.h changes (where you enable the signing functionality). Don't post your private key though :)
    The initial setup is all signed and well but then your node seem to not even attempt to sign the data it sends (because it should have sent a c=3,t=16 and waited for a c=3,t=17 prior to any sensor data).
    I see from the first two messages that the gateway has been informed that your sensor require signatures (of messages from the gateway). And the gateway do respond that it also require signautres but for some reason your sensor do not sign the sensor values (the presentation handshaking is transmitted in signed form as expected).
    I don't have a quick answer to why your node does not sign it's sensor data. Could you also share your code that transmits (in your sketch that is). Perhaps the easiest is to post the entire sketch :) (WITHOUT your private key).
    I am afraid I have to prioritize my newborn son, so I hope for understanding if my replies will be delayed. @hek might know if something has happened on dev branch that could affect signing. I did thoroughly test it when it was submitted but I have not been keeping track on activities on dev for a while now.
    • scalzS
      scalzS
      wrote on last edited by scalz
      #102
      @Anticimex: Congratulation for your son! it is not hurry, no problem. and thank you for taking time.
      So maybe I am missing something, because I have no key in the sketch??? I am using ATSHA hardware chip.. The key is stored by using SHAPersonalizer, isn't it??
      I have not made any changes in Myconfig.h as it is default enabled. So it is like this:
      // Disable to completly disable signing functionality in library
      #define MY_SIGNING_FEATURE
      And the node sketch:
      #include <MyTransportNRF24.h>
      #include <MyHwATMega328.h>
      #include <DHT.h>
      #include <MySigningAtsha204.h>
      #define CHILD_ID_HUM 0
      #define CHILD_ID_TEMP 1
      #define HUMIDITY_SENSOR_DIGITAL_PIN 5
      MyTransportNRF24 radio;  // NRFRF24L01 radio driver
      MyHwATMega328 hw; // Select AtMega328 hardware profile
      MySigningAtsha204 signer; // Select HW ATSHA signing backend
      MySensor gw(radio, hw, signer);
      DHT dht;
      float lastTemp;
      float lastHum;
      boolean metric = true;
        gw.begin(NULL, 10);
        gw.sendSketchInfo("Humidity", "1.0");
        if (isnan(temperature)) {
          lastTemp = temperature;
          if (!metric) {
          Serial.print("T: ");
          Serial.println(temperature);
        if (isnan(humidity)) {
            lastHum = humidity;
            Serial.print("H: ");
            Serial.println(humidity);
        gw.sleep(SLEEP_TIME); //sleep a bit
      and in Serial Gateway, I have only changed this:
      // Message signing driver (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h)
      //MySigningNone signer;
      //MySigningAtsha204Soft signer;
      // Hardware profile
      MyHwATMega328 hw;
      // Construct MySensors library (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h)
      // To use LEDs blinking, uncomment WITH_LEDS_BLINKING in MyConfig.h
      #ifdef WITH_LEDS_BLINKING
      MySensor gw(transport, hw , signer, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
      #else
      MySensor gw(transport, hw , signer);
      AnticimexA 1 Reply Last reply
      • scalzS scalz
        #include <DHT.h>
        DHT dht;
        float lastTemp;
        float lastHum;
          gw.begin(NULL, 10);
            if (!metric) {
              lastHum = humidity;
        // Hardware profile
        MyHwATMega328 hw;
        #else
        AnticimexA
        AnticimexA
        Anticimex
        @scalz Thanks :)
        Correct. With HW ATSHA204A no key in the sketch is necessary.
        And your setup seem ok since there are signed messages being passed successfully so the HW seem ok.
        Perhaps you could add a debug print that dumps your messages in the gateway before they are checked for signatures in MySensor::process?
        Just put debug(PSTR("read: %d-%d-%d s=%d,c=%d,t=%d,pt=%d,l=%d,sg=%d\n"), msg.sender, msg.last, msg.destination, msg.sensor, mGetCommand(msg), msg.type, mGetPayloadType(msg), mGetLength(msg), mGetSigned(msg)); before #ifdef MY_SIGNING_FEATURE.
        You could also do the corresponding thing in your nodes MySensor::sendRoute function so we can see what data you send in order to determine why your node has decided it should not be signed.
        It could be you stumbled over a library bug because I see in the code that in sendRoute the if case looks funky.
        It says:
        if (DO_SIGN(message.destination) && message.sender == nc.nodeId && !mGetAck(message) && mGetLength(msg) &&
        but I think it should say
        if (DO_SIGN(message.destination) && message.sender == nc.nodeId && !mGetAck(message) && mGetLength(message) &&
        Try to change this and see what happens. I have a strong suspicion that your node's msg buffer is empty, and sendRoute therefore don't sign the message because it gets the length from the wrong buffer.
        @hek if @scalz tests this successfully, could you patch it? I think it is a bug that it checks mGetLength(msg) and not mGetLength(message) in MySensor::sendRoute.
          @Anticimex
          I could probably fix it tonight if it turns out wrong.
          • scalzS
            scalzS
            #105
            @Anticimex @Hek
            Thank you very much for debugging!
            First, I tried to add the debug watch. And like you said it seems there was no value.
            Then, I looked at sendRoute like you advised, and oh!, it makes sense. A tiny small bug is living there !
            So I changed mGetLength(msg) with mGetLength(message)
            And now... it seems to work well! yeah! I am so happy :smiley:
            If you want below is my GW logs (with the debug watch too), but I think it's ok now. there is no unwanted "nosign" anymore.
            0;0;3;0;9;read: 0-0-0 s=0,c=0,t=0,pt=0,l=0,sg=0
            0;0;3;0;9;read: 0-0-10 s=255,c=3,t=15,pt=2,l=2,sg=0
            0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:01F428B
            0;0;3;0;9;read: 0-0-10 s=255,c=3,t=17,pt=6,l=25,sg=0
            0;0;3;0;9;read: 10-10-0 s=255,c=0,t=17,pt=0,l=6,sg=0
            0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:013E014
            10;255;3;0;6;0
            0;0;3;0;9;read: 10-10-0 s=255,c=3,t=6,pt=1,l=1,sg=0
            0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:0174D82
            0;0;3;0;9;read: 10-10-0 s=255,c=3,t=11,pt=0,l=8,sg=0
            0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:01827E7
            10;255;3;0;12;1.0
            0;0;3;0;9;read: 10-10-0 s=255,c=3,t=12,pt=0,l=3,sg=0
            10;0;0;0;7;
            10;1;0;0;6;
            0;0;3;0;9;read: 10-10-0 s=1,c=3,t=16,pt=0,l=0,sg=0:
            0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:01E4D70
            0;0;3;0;9;read: 10-10-0 s=1,c=1,t=0,pt=7,l=5,sg=1:23.0
            10;1;1;0;0;23.0
            0;0;3;0;9;read: 10-10-0 s=1,c=1,t=0,pt=7,l=5,sg=0
            0;0;3;0;9;read: 10-10-0 s=0,c=3,t=16,pt=0,l=0,sg=0:
            0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:0148CE9
            0;0;3;0;9;read: 10-10-0 s=0,c=1,t=1,pt=7,l=5,sg=1:36.0
            10;0;1;0;1;36.0
            I have just a last question regarding signature :
            • in the future, when Mysensors new version will be released, does the controller will have to check the signature and to store the PSK? I think so, as the logs shows it is crypted. For doing this we should inspire ourselves
              with your atsha_soft, isn't it? It is just curiosity of mine, as I am looking at your libs, and I am thinking about what changes will be involved on controller side when the moment will come for plugin update...
            Now, I have to check the atsha soft version too, then ota with the recently great improvement of tekka..., and understand all new changes in the message format...lots of things.
            I like this lib! 1.4 is smart, but dev branch looks very well done and much more optimized.
            See you soon!
            • scalzS scalz
              @Anticimex @Hek
              10;255;3;0;6;0
              10;255;3;0;12;1.0
              10;0;0;0;7;
              10;1;0;0;6;
              10;1;1;0;0;23.0
              10;0;1;0;1;36.0
              See you soon!
              AnticimexA
              AnticimexA
              Anticimex
              @scalz Great! Thanks for finding and testing this.
              I am not sure I understand your question. You mean to store the PSK of atsha_soft in encrypted form in the sketch? That is difficult since the encryption secret then needs to be stored somewhere as well.
              I would recommend (if you do use atsha_soft) to burn the fuses to prevent memory readout to protect the PSK.
              Normally, this implementation is stored in the gateway which should be physically protected in any case, so the need to protekt PSK in the gateway is less critical than in a node which may be located "outside".
              Secure OTA is currently unsupported. It might be supported in the future.
              • scalzS
                scalzS
                #107
                Oh, sorry for my bad english!
                Is signing just between a Node and a Gateway. or is the controller involved too? Maybe it's a dumb question, I have not checked yet the changes in message.
                For OTA, I understand it is not suppported by signature as you explained in your tuto. But, in the other hand, I think that for initiating an ota, it should need a signed message, so I think it is good.
                • scalzS scalz
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @scalz You decide if your component will require signatures when you create your signer. That is, if you want your gateway to be able to sign messages sent to an actuator (like a lock) but you don't want your gateway to require signed messages from your nodes, you pass a argument to the constructor like this:
                  MySigningAtsha204 signer(false);
                  That will
                  • Configure that node/gw to support signed message processing using HW ATSHA
                  • Have that node/gw inform others that it does not require signed messages
                  • Still permit that node/gw to sign messages sent to other nodes/gw who do requre signing
                  If you stick to default constructor arguments or pass true, the difference is that the node/gw will also inform others that it requires signed messages, and will ignore/discard any message that is not signed which it receive (and is targeted to that particular node/gw). It will not affect messages which are to be relayed, so the node will still work as a relay for unsigned messages.
                  • scalzS
                    scalzS
                    @Anticimex:
                    ok, it is good to know. You have thought about everything!
                    If signer(true) for gateway, Will the controller (Jeedom, Domoticz..) see a crypted payload in serial transmission or will it work like before (I understand there are some changes in message structure, but what about crypted payload, does the controller need to decrypt?)
                    • scalzS scalz
                      @Anticimex:
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @scalz We only sign messages. There is no encryption involved. And the signature is stored without affecting the message contents so it is perfectly compatible with all controllers. The only thing that could affect a controller is the new sign bit in the message header but I don't think that will make any difference as it is not relevant to the controller. It is the gateway that manages this for it.
                      • scalzS
                        scalzS
                        ok, it is new for me, so I am mixing vocabulary, but I understand the concept. Thank you, and now I have my answer. no big changes for controller side, great! It makes sense, but I was not sure.
                          Fix pushed to development.
                          • AnticimexA
                            AnticimexA
                            Anticimex
                            Thanks for that!
                            • J
                              J
                              jsondag
                              wrote on last edited by jsondag
                              #114
                              I put together a garage door opening using code from korttoma. I used soft signing, and it works great. I was wanting to use a real atsha though.
                              I bought some atsha204a chips from amazon, and the chips are marked with only "3eas", and a "Y" in one corners. They are soic-8. Is that how this should be marked? I wired one up according to the data sheet. Gnd to Gnd, VCC to 5V, and SDA to A3. I ran the personalizer to generate a key and it said "Failed to wake device." in the serial console. Am I doing something wrong? or did I just get the wrong chip from the seller?
                              • J jsondag
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @jsondag I don't have a good explanation on the software signing not working. Maybe inadequate decoupling leads to a too noisy power rail?
                                About the HW issue, it is important that you use the single wire version of atsha204. NOT the i2c version. The i2c version also has an scl line while the single wire only has sda (and power and ground). That means your soic8 should have 5 unused pads. Atmel ordering code for that variant is ATSHA204A-SSHCZ-T but unfortunately it is not printed on the case. So unless you find that information from Amazon, I am afraid it is very difficult to determine the type of the chips you've got.
                                • J
                                  J
                                  jsondag
                                  #116
                                  @Anticimex. Software signing is working fine.
                                  Thanks for the information though. I didn't realize the soic 8 couldn't do one wire. It's a ATSHA204-SH-DA-B according to the listing.
                                  EDIT:
                                  Looking at the datasheet, it says that the SCL pin can be ignored for single wire interface. perhaps I'll wire another one up and give it a go.
                                  Just connect, SDA to A3, correct?
                                  • J jsondag
                                    EDIT:
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    #117
                                    @jsondag ok. From what I could read there are two different order codes for i2c and one-wire so I don't think you can take an i2c variant board and treat it as a one-wire board by just ignoring the scl pin. But if the board really is single-wire, the pinout will be the same as the i2c version, you can just ignore the scl pin as it is NC for the one-wire variant. And from the data sheet, SHDAB is i2c not "single-wire" so I am afraid you cannot use my libs for those. I only have drivers for single-wire chips i am afraid.
                                    • TD22057T
                                      TD22057T
                                      TD22057
                                      I just received my chips today from digikey (part num ATSHA204A-STUCZ-TCT-ND) which are the small 3 pin versions. Holy cow these are things are tiny. These are going to be a lot more difficult than I expected to hand solder.
                                      • TD22057T TD22057
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @TD22057 If you don't have a "inverse" tweezer to fixate the chip to the board, just glue it in place. With proper iron temp (at least 300 deg C, I use 330) it's very doable. Much easier than smd resistors/caps if you ask me :) (just don't forget to solder after you glue if you do that)
                                        TD22057T 1 Reply Last reply
                                        • AnticimexA Anticimex
                                          TD22057T
                                          TD22057T
                                          TD22057
                                          Thanks - I'll try that as soon as everything arrives. Watching parts trickle in from aliexpress shippers is killing me (I think I've become spoiled on Amazon prime shipping).
