  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 471.0k Views 30 Watching
  • J
    J
    jkandasa
    @Anticimex Thanks a lot! Its a great work.
    Does signature feature supports for node to node communication (I mean without gateway)?
    AnticimexA 1 Reply Last reply
    • J jkandasa
      AnticimexA
      AnticimexA
      Anticimex
      @jkandasa thanks. Yes it does. But then you (as sketch developer) is responsible for sending the internal I_REQUEST_SIGNING message to inform the other node of your nodes signing requirements. The library manages this automatically for the node2gateway (and gateway2node) but not for node2node messages since the library "does not know" anything about that.
      • C
        C
        C.r.a.z.y.
        @hek do you have any plan to use this logic in new version api?
        @Anticimex awesome work!
        hekH 1 Reply Last reply
        • C C.r.a.z.y.
          @C.r.a.z.y.
          Yes, this will be part of 1.5 release.
          • AnticimexA
            AnticimexA
            Anticimex
            Thanks guys! Glad to see that it's appreciated :)
            I am now working on strengthening the nonces and implementing whitelisting. I hope to be able to finish it in time for the 1.5 release.
            Voluntary testers are desired!
            I will update the first post also with more instructions on how to handle whitelisting and also update it so it reflects the more recent changes on the development branch with respect to configuration as soon has I have finished the hacking.
            • AnticimexA
              AnticimexA
              Anticimex
              UPDATE: Thread topic post updated with a lot of stuff. Whitelisting is now "in" and explained. Various updates to the text to make a few things more clear and some code examples added to show how this ties into the updates on development branch when it comes to construction of the library class and how signing comes into play.
              • P
                P
                phil83
                @Anticimex This really is great work!
                I have one question regarding ATSHA204A: do you know where to buy ATSHA204A-STUCZ-T? I couldn't find any supplier in Europe and even on Aliexpress, I could onlyfind the ATSHA204 in SOT23-3.
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @phil83
                  mouser.com got it in stock, they will deliver to europe as well :)
                  • P
                    P
                    phil83
                    @tbowmo Thanks for the info. I found mouser this morning as well but they charge me 20€ for shipping :-(.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @phil83
                      You just need to make an order big enough, then they drop the handling charge :-)
                      • P
                        P
                        phil83
                        Any other Europeans interested in getting some chips from mouser? I could redistribute from Germany via letter. ;-)
                        • T
                          Tibus
                          hello, i'm making some mysensors board that I'll present you a bit later and I've add a place for the Atsha204 sot23-3.
                          I can't find it in Europe still and I would like to know if is it possible ton connect it on pin A6 instead of pin A3. I would like to keep the A0 to A5 for the user and use A6 for Atsha204 and A7 for Atcha204 floating point. Can anyone test it for me please?
                          Thank's verry much!
                          • T Tibus
                            Thank's verry much!
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @Tibus No, you cant. A6 and A7 are analog-only pins. Also, make sure you order ATSHA204A. Not ATSHA204. ATSHA uses no "floating point". Just single wire digital interface.
                            • T
                              Tibus
                              Ok, So I've to connect it on A3 (default value in mysensor?) and let the A7 floating? The A6 is not used so? (other question : I can't use digitalWrite on A6 pin?)
                              Thank's verry much for the details on ATSHA204A instead of ATSHA204. The ATSHA204A is in SOT23-3 too? so the A7 is only use inside the Atmega library?
                              • T Tibus
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @Tibus A6 and A7 are analog input pins. You can use them as such but not as digital I/O.
                                ATSHA204A is identical but more feature-rich compared to ATSHA204. One added feature is a SHA256 which is required for MySensors use. ATSHA204 is discontinued by Atmel. You can connect the ATSHA to any digital I/O pin you like but you will have to patch the config if you pick anything not called "A3".
                                • T
                                  Tibus
                                  Ok, thank's! I've already change every A6 pin connection to A3. Can the user use A3 for analogic even if ATSHA204 is connected on it? or do I have to remove the A3 pin available for the user?
                                  • T Tibus
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @Tibus You have to check the datasheet of ATSHA204A to see how it handles the datapin when not in use. I would recommend you have any analog cirquitry on dedicated pins though and keep one reserved for the ATSHA.
                                    • AnticimexA Anticimex
                                      @Anticimex
                                      The "analog" pins can actually be used as digital IO pins.
                                        @Anticimex
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @hek Not A6 and A7. They are pure analog.
                                          Ok! That's new to me :)
