  3. Back to Basics - Arduino MEGA + NRF24+LNA + W5100 Shield
8 Posts 2 Posters 2.0k Views 3 Watching
  • Z
    Z
    ZachFlem
    Hi Folks,
    After my last little brain implosion, I've decided to go back to basics.
    I've completely rebuilt my gatewayNode from the ground up, and included the current sketch below.
    When I run the serial monitor on the bench, i get a slow "eth failed" message, which I expect (sadly I don't have Ethernet connection at my outdoor workspace) and when I plug it into the router (both USB to power the unit and eth) I get an "eth failed" message approx 4 times a second, but I can PING the address.
    I can't add the gateway to MyController, it just times out.
    I am powering the radio directly from the 3v pin on the mega, (no cap as I don't have any here) and there is nothing other than the LED indicators plugged into it.
    I'm just trying to work out where I should START looking, before i go back to pulling my hair out!
    Any advice greatly appreciated!
     * NRF24/Ethernet Gateway Node - v0.1
    // Pin Confuguration for Arduino Mega
    #define MY_RF24_CE_PIN 49
    #define MY_RF24_CS_PIN 53
    // Radio type
    // Ethernet module type
    #define MY_GATEWAY_W5100
    // MAC Address
    #define MY_IP_ADDRESS 10,0,0,201
    #define MY_IP_GATEWAY_ADDRESS 10,0,0,1
    // Listening Port
    #define MY_PORT 5003
    // MyController IP Address
    #define MY_CONTROLLER_IP_ADDRESS 10,0,0,200
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #define MY_DEFAULT_ERR_LED_PIN 22  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  26  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  24  // Transmit led pin
    #include <Ethernet.h>
    • Z ZachFlem
      Hi Folks,
      // Radio type
      // MAC Address
      // Listening Port
      @zachflem do you have more than one W5100 running at home? All W5100 need to have a unique mac address.
      Could ypu post the full debug log?
      Z 1 Reply Last reply
        Z
        Z
        ZachFlem
        Evening @mfalkvidd
        This is the only one currently. I'm aware of the need for unique MAC addresses and have a schema in place to cover this.
        Sure! This is the first 3 bursts that appear, anything after this just increases the TSM:FAIL:CNT=X count
        I'm not even getting the ETH:FAIL errors now =(
        0 MCO:BGN:INIT GW,CP=RNNGA---,VER=2.2.0
        3 TSM:INIT
        4 TSF:WUR:MS=0
        11 !TSM:INIT:TSP FAIL
        13 TSM:FAIL:CNT=1
        14 TSM:FAIL:DIS
        16 TSF:TDI:TSL
        10018 TSM:FAIL:RE-INIT
        10020 TSM:INIT
        10028 !TSM:INIT:TSP FAIL
        10030 TSM:FAIL:CNT=2
        10032 TSM:FAIL:DIS
        10034 TSF:TDI:TSL
        20036 TSM:FAIL:RE-INIT
        20038 TSM:INIT
        20045 !TSM:INIT:TSP FAIL
        20047 TSM:FAIL:CNT=3
        20049 TSM:FAIL:DIS
        20051 TSF:TDI:TSL
        • Z ZachFlem
          Evening @mfalkvidd
          3 TSM:INIT
          4 TSF:WUR:MS=0
          13 TSM:FAIL:CNT=1
          14 TSM:FAIL:DIS
          16 TSF:TDI:TSL
          10020 TSM:INIT
          10032 TSM:FAIL:DIS
          10034 TSF:TDI:TSL
          20038 TSM:INIT
          20049 TSM:FAIL:DIS
          20051 TSF:TDI:TSL
          TSM:INIT:TSP FAIL
          means the nrf24 could not be initialized. The most common cause is miswiring or "wrong" pins defined.
          The defines in your sketch look good to me.
          Could you post a photo of your wiring? Sometimes it helps to get a new pair of eyes on it. Try to take a photo (or multiple) so each wire can be traced from start to finish.
            TSM:INIT:TSP FAIL
            Z
            Z
            ZachFlem
            @mfalkvidd
            I've got the following:
            3v-----------RED------------V+
            GND-------BROWN------GND
            49----------WHITE--------CE
            50----------PURPLE------MISO
            51----------BLUE-----------MOSI
            52----------GREEN--------SCK
            53----------BLACK--------CSN
            • Z ZachFlem
              @mfalkvidd
              @zachflem I can't tell from the picture where the blue, white and purple wires are connected to the mega, but except that it looks good. Nice case.
                Z
                Z
                ZachFlem
                @mfalkvidd the blue, white and purple are 100% as per my wiring description. Might it have something to do with not having the cap on the power?
                I'm at a loss as to what is going wrong here...
                The case is a AUD$10 waterproof unit (before i drilled holes in the side of it) from Bunnings: https://goo.gl/kzDaZi
                I've also got a bigger (AUD$16) version housing a bigger project: https://goo.gl/zgvd7h
                • Z ZachFlem
                  @zachflem using the nrf without cap often (almost always) leads to failed transmission, but it should not affect initialization of the radio.
