  3. OpenHAB
  4. openHAB 2.2 binding
openHAB 2.2 binding
3 Posts 2 Posters 2.1k Views 2 Watching
  • zookazimZ
    zookazimZ
    zookazim
    MySensors values not showing in openHAB
    Hi all, newbie here - please could I ask you all to have a look at my configuration and let me know where I am going wrong on my first MySensors DHT node. I'm not able to view temperature or humidity from the node the standard DHT sketch here; https://www.mysensors.org/build/humidity.
    I am using an ethernet gateway running on my Raspberry Pi running Openhabian - all installed well and gateway seems to be working from the logs below and I can see it's receiving the temperature and humidity values as expected. Problem is there are no values showing on the Paper UI control page or my sitemap (screen shots below). I have added a binding to openHAB for my solar panel inverter and that is receiving and displaying values ok.
    Can anyone spot my mistake? Any suggestion very welcome ...
    Here is my configuration;
    $ lsb_release -a
    No LSB modules are available.
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 9.6 (stretch)
    Release:        9.6
    Codename:       stretch
    $ cat /home/openhabian/MySensors/README.md
    MySensors Library v2.3.1
    $ tail -f /var/log/openhab2/openhab.log
    2019-03-30 11:40:11.637 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;0;1;0;1;35.4
    2019-03-30 11:41:12.179 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;0;25.4
    2019-03-30 11:41:12.303 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;0;1;0;1;35.0
    2019-03-30 11:42:12.731 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;0;1;0;1;34.7
    2019-03-30 11:43:13.295 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;0;1;0;1;34.6
    2019-03-30 11:44:13.845 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;0;25.5
    2019-03-30 11:44:13.859 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;0;1;0;1;34.4
    2019-03-30 11:45:14.419 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;0;25.6
    2019-03-30 11:45:14.433 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;0;1;0;1;34.6
    2019-03-30 11:46:14.999 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;0;25.7
    2019-03-30 11:47:15.567 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;0;25.8
    2019-03-30 11:47:15.601 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;0;1;0;1;34.2
    $ cat /etc/openhab2/things/mysensors.things
    // MySensors Ethernet Bridge
    Bridge mysensors:bridge-eth:gateway [ ipAddress="127.0.0.1", tcpPort=5003, sendDelay=200 , startupCheckEnabled=false ] {
            humidity    hum01    [ nodeId=101, childId=0 ]
            temperature temp01   [ nodeId=101, childId=1 ]
    // Solar Edge:
    Thing  solaredge:generic:se2200 [ tokenOrApiKey="********", solarId="******"]
    $ cat /etc/openhab2/items/mysensors.items
    // MySensors
    Number          hum01                    "Humidity"    { channel="mysensors:humidity:gateway:hum01:hum" }
    Number          temp01                   "Temperature" { channel="mysensors:temperature:gateway:temp01:temp" }
    // Solar Edge
    Number:Power    SE2200_Live_Production   "PV Production [%.2f %unit%]"    {channel="solaredge:generic:se2200:live#production"}
    Number:Energy   SE2200_Day_Production    "Day Production [%.2f kWh]"      {channel="solaredge:generic:se2200:aggregate_day#production"}
    Number:Energy   SE2200_Month_Production  "Month production [%.2f kWh]"    {channel="solaredge:generic:se2200:aggregate_month#production"}
    //Demo
    Switch          DEMOSW                   "Demo Switch"
    $ cat /etc/openhab2/sitemaps/home.sitemap
    sitemap home label="Main Menu"
            Frame label="Demo"
                Switch item=DEMOSW
            Frame label="Sensors"
                Text item=hum01
                Text item=temp01
            Frame label="SolarEdge"
                Text item=SE2200_Live_Production
                Text item=SE2200_Day_Production
                Text item=SE2200_Month_Production
    D 1 Reply Last reply
    • zookazimZ zookazim
      $ lsb_release -a
      Release:        9.6
      Codename:       stretch
      // Solar Edge:
      // MySensors
      // Solar Edge
      //Demo
              Frame label="Demo"
                  Switch item=DEMOSW
                  Text item=hum01
                  Text item=temp01
      D
      D
      djal
      wrote on last edited by djal
      @zookazim From your openhab.log it seems that the sensor is sending messages with nodeId=1, but in your mysensors.things you mapped humidity and temperature channels to nodeId=101
      zookazimZ 1 Reply Last reply
      • D djal
        zookazimZ
        zookazimZ
        zookazim
        @djal Beautiful! Amazing! It works!
        I've been struggling with this issue for over two weeks ... I guess I'll have to learn about the assignment of node numbers in more detail.
        Thanks @djal much appreciated.
