  3. OpenHAB
  4. openHAB 4 MySensors Binding
19 Posts 9 Posters 3.9k Views 8 Watching
  • ben999B
    ben999B
    ben999
    Hello there
    I thought it would be a good idea to upgrade my system to openHAB4, as i wanted to play with my security cameras linked to a Synology NAS system...
    Well it didn't go according to plan.
    First openhabian had to be upgraded from Buster to Bullseye in order to get Java from 11 to 17. Then Java got upgraded, By that time MySensors stopped working. So i started over with a fresh install of MySensors. All went well until
    make
    hal/architecture/Linux/drivers/core/GPIO.cpp: In constructor ‘GPIOClass::GPIOClass()’:
    hal/architecture/Linux/drivers/core/GPIO.cpp:53:50: warning: ‘%s’ directive output may be truncated writing up to 255 bytes into a region of size 48 [-Wformat-truncation=]
       53 |    snprintf(file, sizeof(file), "/sys/class/gpio/%s/base", de->d_name);
    hal/architecture/Linux/drivers/core/GPIO.cpp:53:12: note: ‘snprintf’ output between 22 and 277 bytes into a destination of size 64
    hal/architecture/Linux/drivers/core/GPIO.cpp:62:50: warning: ‘%s’ directive output may be truncated writing up to 255 bytes into a region of size 48 [-Wformat-truncation=]
       62 |    snprintf(file, sizeof(file), "/sys/class/gpio/%s/ngpio", de->d_name);
    hal/architecture/Linux/drivers/core/GPIO.cpp:62:12: note: ‘snprintf’ output between 23 and 278 bytes into a destination of size 64
    g++ -MT build/hal/architecture/Linux/drivers/core/interrupt.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_RF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_MQTT_CLIENT_ID=\"impassedesroses\" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX=\"mysensors-in\" -DMY_MQTT_PUBLISH_TOPIC_PREFIX=\"mysensors-out\" -DMY_RF24_PA_LEVEL=RF24_PA_LOW -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1  -Ofast -g -Wall -Wextra -std=c++11 -I. -I./core -I./hal/architecture/Linux/drivers/core -I./hal/architecture/Linux/drivers/BCM -c hal/architecture/Linux/drivers/core/interrupt.cpp -o build/hal/architecture/Linux/drivers/core/interrupt.o
    hal/architecture/Linux/drivers/core/interrupt.cpp:33:10: fatal error: stropts.h: No such file or directory
       33 | #include <stropts.h>
    compilation terminated.
    make: *** [Makefile:99: build/hal/architecture/Linux/drivers/core/interrupt.o] Error 1
    Please advise if i should start over from the very begenning (fresh SD) or just stick with openHAB 3 (but soon or later it will be superseeded)
    Thanks a lot for your time people.
    mfalkviddM ben999B 2 Replies Last reply
    • ben999B ben999
      Hello there
      make
      @ben999 just remove the stropts include (in hal/architecture/Linux/drivers/core/interrupt.cpp), or use the development branch where the include has already been removed.
      https://github.com/mysensors/MySensors/pull/1446
      ben999B 1 Reply Last reply
      • ben999B ben999
        Hello there
        make
        ben999B
        ben999B
        ben999
        This post is deleted!
          ben999B
          ben999B
          ben999
          @mfalkvidd Genius !!! :open_mouth:
          • Z
            Z
            zkarolyi
            After changed to develop branch, the make was successfull, but how to get MySensors binding?
            I have found this: https://github.com/tobof/openhab-addons/wiki/Installation but it is for OpenHab 3.
            When I installed the jar, I get this error:
            [WARN ] [org.apache.felix.fileinstall        ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.mysensors-3.1.0.jar
            org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.mysensors [265]
              Unresolved requirement: Import-Package: org.apache.commons.lang; version="[2.6.0,3.0.0)"
            How to get a new binding?
            How to solve this?
            ben999B ChachaC C 3 Replies Last reply
            • Z zkarolyi
              How to solve this?
              ben999B
              ben999B
              ben999
              Hi @zkarolyi
              I can not provide any help on that matter as i went the MQTT way.
              The binding for serial gateway requires loads of work from the MySensors dev team; so it might tatke a while before it becomes available (if it does all together). I really appreciate all the effort put into this but i also understand that it might come to an end someday. No matter how much i prefer the serial gateway over MQTT... i ended up in the mqtt team
              Back to your issu : the jar file might not be compatible with OH4
              • N
                N
                niccodemi
                wrote on last edited by niccodemi
                Hi @ben999
                I used to have OH3 with MySensors Ethernet gateway but now I have upgraded to OH4 and it seems the only option is to connect MySensors network to OH via MQTT.
                I flashed MySensors mqtt_gateway and installed Mosquitto on same machine where OH4 is installed (ip=192.168.1.yyy). I also installed MQTT binding in OH4.
                Can you please advise how did you configure things and items file? In OH3 I had them configured in textual format.
                Things file in OH3
                Bridge mysensors:bridge-eth:gateway [ ipAddress="192.168.1.xxx", tcpPort=5003, sendDelay=300, startupCheckEnabled=false, networkSanCheckEnabled=true ] {
                	 light			relunderstair0101 [ nodeId=1, childId=1, requestAck=false ]
                Items file in OH3
                Switch relunderstair0101  "LED-stairs" { channel="mysensors:light:gateway:relunderstair0101:status" }
                • N niccodemi
                  Hi @ben999
                  Things file in OH3
                  Items file in OH3
                  ben999B
                  ben999B
                  ben999
                  wrote on last edited by ben999
                  @niccodemi I am no expert and am having a tough time with these files as well !!!
                  My .things file looks like so :
                  Bridge mqtt:broker:mosquitto "MySensorsGateway"@"Home" [host="openhabian", port="1883", secure=false]
                  	Thing topic garageDoor01 "Garage"@"Basement" {
                  		Channels:
                  			Type contact :	garageDoor01switch	[stateTopic="mysensors-out/19/1/1/0/16", transformationPattern="MAP:contact.map"]
                  			Type datetime : garageDoor01switch_LastUpdate
                  As far as i understand, you're missing that "linktopic" descrption...
                  N 1 Reply Last reply
                  • ben999B ben999
                    		Channels:
                    N
                    N
                    niccodemi
                    @ben999 Thank you. I managed to get sensors data coming into OH.
                    Would you happen to have also any thing / item example for switch / relay sketch?
                    • F
                      F
                      forexsieno
                      Hello anybody runing openhab4 with latest bindings (3.3.0) and serial gateway?
                      I'm not able to get the bindings active. They are installed but not active.
                      diag gives following message:
                      Any ideas?
                      • F forexsieno
                        Any ideas?
                        N
                        N
                        niccodemi
                        @forexsieno I am running OH4 but have migrated MySensors to MQTTGateway. Below example of how to control relays.
                        thing file
                        Bridge mqtt:broker:Mosquitto "Mysensors MQTT Broker" [host="192.xxx.xxx.xxx", secure=false, port=1883, clientID="Openhab"]
                            Thing topic relunderstair "Relay" (mqtt:broker:Mosquitto) {
                                Channels:
                                    Type switch : relunderstair0101 "LED-stairs" [ stateTopic="mygateway1-out/1/1/0/0/2", commandTopic ="mygateway1-in/1/1/0/0/2", on="1", off="0" ]
                        item file
                        Switch relunderstair0101  "LED-stairs" { channel="mqtt:topic:Mosquitto:relunderstair:relunderstair0101" }
                        • Z zkarolyi
                          How to solve this?
                          ChachaC
                          ChachaC
                          Chacha
                          Hi @zkarolyi
                          You can download the 3.2.0-Snapshot version from here:
                          https://forum.mysensors.org/post/110626
                          It is working in OH3 and OH4!
                          There is also a 3.3.0-Snapshot version, but it doesn't work in OH4.
                          See my post here: https://forum.mysensors.org/post/113864
                          • Z zkarolyi
                            How to solve this?
                            C
                            C
                            CyborgAndy
                            wrote on last edited by CyborgAndy
                            Hi @zkarolyi
                            Download org.openhab.binding.mysensors-4.0.4-SNAPSHOT.jar from my Google Disk and try it.
                            I only tested as a MySensors MQTT Gateway
                            kerberosK Z 2 Replies Last reply
                            • C CyborgAndy
                              Hi @zkarolyi
                              kerberosK
                              kerberosK
                              kerberos
                              Hi @CyborgAndy
                              many thanks for providing the binding update for MySensors 4.0.4! I upgrade my OpenHAB 3.4.4 a few minutes ago to 4.0.4 successfully with your binding update. I use a USB connected serial-gateway. The OpenHAB manual installation upgrade works perfect. I need to do afterwards the following steps in the Karaf console, to get the gateway online again, after the update:
                              feature:install openhab-transport-serial
                              feature:install openhab-core-io-transport-mqtt
                              feature:install openhab-core-io-transport-serial-javacomm
                              Many thanks again!
                              kerberos
                              • kerberosK
                                kerberosK
                                kerberos
                                As x-mas gift :santa: works with OpenHAB 4.1 as well...
                                • C CyborgAndy
                                  Hi @zkarolyi
                                  Z
                                  Z
                                  zkarolyi
                                  Hi @CyborgAndy
                                  Really thank you for this jar so much, I finally managed to bring my sensors to life!
                                  A thousand thanks and gratitude!
                                  zkarolyi
                                  • A
                                    A
                                    adds666
                                    As an OH3 user looking to upgrade, I'm wondering, do all of the binding points from OH to mysensor nodes, children etc work after upgrade and loading this new .jar?
                                    Or do I have to re-build everything in OH?
                                    kerberosK 2 Replies Last reply
                                    • A adds666
                                      kerberosK
                                      kerberosK
                                      kerberos
                                      • A adds666
                                        kerberosK
                                        kerberosK
                                        kerberos
                                        Hi @adds666
                                        I did in between the switch from 2.5.12 to 3.4.4 a change from pure textual configuration in 2.5.12 to a UI configuration in 3.4.4. This requires some homework. Can't remember beside the exchanged mysensors binding files anything else to upgrade to 4.0.4 from 3.4.4 and finally to current 4.1.1. Keep in mind, I use a OpenHAB manual installation on a non-Debian Linux system, not openHABian. This may have an influence, but I don't expect any hiccups.
                                        kerberos
