  3. [SOLVED] Gateway with signing = low memory
10 Posts 4 Posters 1.9k Views 4 Watching
  • SnyfirS
    SnyfirS
    Snyfir
    I use MySensors V2.3.1 in an arduino nano has gateway.
    my code is
    #define MY_RADIO_RF24
    #define MY_GATEWAY_SERIAL
    #define MY_SIGNING_ATSHA204
    	delay(10);
    but when i upload with arduino IDE i have a warning message: "Low memory available, stability problems may occur"
    how can i solve this issue ?
    thank you for your help
    • SnyfirS Snyfir
      my code is
      	delay(10);
      @snyfir use hardware signing or use an Arduino with more memory.
      Edit: sorry, I see you are already using hardware signing.
      SnyfirS 1 Reply Last reply
        SnyfirS
        SnyfirS
        Snyfir
        wrote on last edited by Snyfir
        @mfalkvidd said in Gateway with signing = low memory:
        MY_SIGNING_ATSHA204 is not hardware signing ? i have connected an ATSHA204 to the arduino pin.
        • SnyfirS Snyfir
          @snyfir sorry, I see you are already using hardware signing.
            SnyfirS
            SnyfirS
            Snyfir
            @mfalkvidd
            So my only solution is to use an arduino with more memory ? do you have an exemple of arduino board i can use ?
            • SnyfirS Snyfir
              @mfalkvidd
              @snyfir what is the full output of the verify step? This is what I get when using your sketch:
              Using library MySensors at version 2.3.2-beta in folder: R:\Documents\Arduino\libraries\MySensors
              Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
              "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\Micke\\AppData\\Local\\Temp\\ArduinoBuild/sketch_apr08a.ino.elf"
              Sketch uses 15574 bytes (50%) of program storage space. Maximum is 30720 bytes.
              Global variables use 1026 bytes (50%) of dynamic memory, leaving 1022 bytes for local variables. Maximum is 2048 bytes.
              On 2.3.1 I get this:
              Using library MySensors at version 2.3.1 in folder: R:\Documents\Arduino\libraries\MySensors
              Sketch uses 15650 bytes (50%) of program storage space. Maximum is 30720 bytes.
              Global variables use 1022 bytes (49%) of dynamic memory, leaving 1026 bytes for local variables. Maximum is 2048 bytes.
              So plenty of ram left.
              You might need to check this in preferences to get useful output
              • SnyfirS
                SnyfirS
                Snyfir
                I had the same result but when i add the two lines:
                #define MY_RX_MESSAGE_BUFFER_FEATURE
                #define MY_RF24_IRQ_PIN (2)
                i have
                Sketch uses 16296 bytes (50%) of program storage space. Maximum is 32256 bytes.
                Global variables use 1693 bytes (82%) of dynamic memory, leaving 355 bytes for local variables. Maximum is 2048 bytes.
                Low memory available, stability problems may occur.
                A gateway without MY_RX_MESSAGE_BUFFER_FEATURE defined, can be problematic non ?
                YveauxY 1 Reply Last reply
                • SnyfirS Snyfir
                  i have
                  YveauxY
                  YveauxY
                  @snyfir said in Gateway with signing = low memory:
                  It's hard to have it all with an Arduino Nano, but you could try with a smaller receive buffer, by defining
                  #define MY_RX_MESSAGE_BUFFER_SIZE (10)
                  Here it is changed to 10, default is 20, which is rather large.
                  Each buffer entry reserves 33 bytes, so you'll save 330 going back to 10 entries.
                  • YveauxY Yveaux
                    SnyfirS
                    SnyfirS
                    Snyfir
                    @yveaux said in Gateway with signing = low memory:
                    thank you @Yveaux et @mfalkvidd
                    • alowhumA
                      alowhumA
                      alowhum
                      I've created a lot of devices on Arduino Nano's with soft signing. You have to learn how to manage memory, and then it works great.
                      A gateway on a nano with nothing in the code except it being a gateway, that should work fine. I've never seen that error message when I used the SIMPLE SECURITY option.
                      Low memory warning might also not really be a problem in practise. If your sketch is empty, then there may not be much to worry about: there are no functions in your code that suddenly need a lot of memory. The only question then is how much MySensors needs which isn't globally defined. I don't know the answer to that, but someone else might.
                      In the end I'd say: test it. If all seems to work ok, then there's really not a problem.
